Andrew Patmore Posted February 25, 2023 Posted February 25, 2023 This is almost certainly not the right place to post this since I have not started the build, but not sure where else to put it. Planning making a 1/48 Armory Flycatcher. Which is way above my paygrade! What is the best wire to use for suggested 0.2mm pushrods? Brass? Was going to have a go at adding 0.2mm lead wire as ignition leads. Should I go 0.3mm to differenciate between the two? Kit instructions also suggests 0.65mm styrene for struts. Thinking Brass? Not an easy kit, I know. But have a friend who's Grandfather flew them, so will have a go. Advice gratefully accepted.
bigbadbadge Posted February 25, 2023 Posted February 25, 2023 I used .33mm brass rod on mine, and the leads were 0.2 mm lead wire. The exhausts I made out of 0.8mm lead wire. I built the older lindberg kit with an armoury engine. Good luck with your build. Chris 1
rob Lyttle Posted February 26, 2023 Posted February 26, 2023 Wow Andrew, I just been googling this, looking like a fantastic project! Don't know the answers to your questions but it would certainly be an interesting build to follow. I guess you might get better feedback if you placed your enquiry in Military aircraft/ inter war but I expect the "ones with the knowledge" will find you here. Looks like there's plenty of enthusiasm for the kit here on BM 1
Greg B Posted February 26, 2023 Posted February 26, 2023 6 hours ago, Andrew Patmore said: This is almost certainly not the right place to post this since I have not started the build, but not sure where else to put it. Planning making a 1/48 Armory Flycatcher. Which is way above my paygrade! What is the best wire to use for suggested 0.2mm pushrods? Brass? Was going to have a go at adding 0.2mm lead wire as ignition leads. Should I go 0.3mm to differenciate between the two? Kit instructions also suggests 0.65mm styrene for struts. Thinking Brass? Not an easy kit, I know. But have a friend who's Grandfather flew them, so will have a go. Advice gratefully accepted. So why post it here in works in progress knowing that its in the wrong place and the Mods have to move it? A quick look in the forum contents would have found modelling tips... Or you could have PM'ed a mod...
Andrew Patmore Posted February 26, 2023 Author Posted February 26, 2023 14 hours ago, bigbadbadge said: I used .33mm brass rod on mine, and the leads were 0.2 mm lead wire. The exhausts I made out of 0.8mm lead wire. Thanks for that, will take your advice. Making the exhasts from wire is probably a good shout as the resin ones supplied look as if they woul snap if I look at them sideways. 11 hours ago, rob Lyttle said: I just been googling this, looking like a fantastic project! Wait until I make the thing before calling it a fantastic project! 🤪 10 hours ago, Greg B said: So why post it here in works in progress knowing that its in the wrong place and the Mods have to move it? A quick look in the forum contents would have found modelling tips... Yes I had found that Greg, but I am not able to start a new topic in that forum. Perhaps because I am a newbie?
bigbadbadge Posted February 26, 2023 Posted February 26, 2023 3 hours ago, Andrew Patmore said: Thanks for that, will take your advice. Making the exhasts from wire is probably a good shout as the resin ones supplied look as if they woul snap if I look at them sideways. No worries Andrew, I made the exhausts as they weren't present in the engine kit I bought. Chris
