JeffreyK Posted February 11 Share Posted February 11 Hi everyone, I'd like to introduce to you my latest release at Hypersonic Models. B-26K Coutner Invader wheels, in 1:48, for the ICM kit. The set is created in CAD to accurate dimensions and all components are delivered as 3D printed parts. Tyres and hubs are separate pieces, in order to facilitate the best printing result and make painting easier. Print supports are kept to a minimum, clean-up is roughly equal to a good resin cast item although each individual support is easier to clip away than a thick casting block. The detail includes very fine brake detail, valve stems, tyre sidewall detail (kept as small/faint as possible) and weighted/bulged tyres. The axle holes correspond to the ICM gear struts and also fix the off-centre issue of the kit hubs. Direct link: https://www.hypersonicmodels.com/product/b-26k-wheels I hope you'll like this set. Thanks for looking, Jeffrey Link to comment Share on other sites More sharing options...
Scimitar F1 Posted February 11 Share Posted February 11 This set looks fantastic. it seems only yesterday I was hunting around for out of production sets (Paragon, Cutting Edge) to convert the Monogram Invader - each wrong in its own way. Link to comment Share on other sites More sharing options...
