Homebee Posted February 6 Share Posted February 6 (edited) HobbyBoss is to release 1/48th TBD-1 Devastator kits - ref. 81783 - Douglas TBD-1 Devastator - ref. 81784 - Douglas TBD-1A Devastator Source: https://tieba.baidu.com/p/8249037080 V.P. Edited September 21 by Homebee 1 Link to comment Share on other sites More sharing options...
TheKinksFan Posted February 6 Share Posted February 6 I wonder if it's the same as the GWH (or whatever they call themselves at the moment). It was released in 2012. Or a new tool, are these companies somehow affiliated. Link to comment Share on other sites More sharing options...
Stephen Posted February 6 Share Posted February 6 (edited) Trumpeter/Hobbyboss are nothing to do with GWH, completely separate companies. This will be a new tooling. Edited February 6 by Stephen 1 1 Link to comment Share on other sites More sharing options...
Sturmovik Posted February 9 Share Posted February 9 Hobby Boss looks to be in a production fever. Hopefully their next kit will be a Ta 152H in 1:48. And also a 1:48 early Skyhawk. Sorry for hijacking your thread @Homebee 1 Link to comment Share on other sites More sharing options...
RHWinter Posted February 9 Share Posted February 9 On 2/6/2023 at 5:56 PM, TheKinksFan said: I wonder if it's the same as the GWH (or whatever they call themselves at the moment). It was released in 2012. Or a new tool, are these companies somehow affiliated. I think GWH‘s Devastator was in 1/32th scale. Link to comment Share on other sites More sharing options...
neilh Posted February 9 Share Posted February 9 29 minutes ago, RHWinter said: I think GWH‘s Devastator was in 1/32th scale. GWH was 1/48th. I part built one until I trashed it after a canopy disaster 😪 and have another in the stash to replace it. 1 Link to comment Share on other sites More sharing options...
TheKinksFan Posted February 9 Share Posted February 9 16 minutes ago, neilh said: GWH was 1/48th. I part built one until I trashed it after a canopy disaster 😪 and have another in the stash to replace it. What happened with the canopy? I read that the kit canopy is too thick to position it open, that's why I ordered a Rob Taurus vacuform canopy. Quite strange that after 10 years another 1/48 new tool. And it's a Devastator, not a Spitfire, Bf 109 or such. Link to comment Share on other sites More sharing options...
IT_Man Posted February 9 Share Posted February 9 On 06/02/2023 at 16:00, Homebee said: HobbyBoss is to release 1/48th TBD-1 Devastator kits - ref. 81783 - Douglas TBD-1 Devastator - ref. 81784 - Douglas TBD-1A Devastator Source: https://tieba.baidu.com/p/8249037080 V.P. Hopefully won't be in the catalogue as long as Trumpeter's 32 one! Link to comment Share on other sites More sharing options...
neilh Posted February 10 Share Posted February 10 23 hours ago, TheKinksFan said: What happened with the canopy? I read that the kit canopy is too thick to position it open, that's why I ordered a Rob Taurus vacuform canopy. Quite strange that after 10 years another 1/48 new tool. And it's a Devastator, not a Spitfire, Bf 109 or such. I fitted the closed canopy which if I recall was slightly too narrow for the fuselage. When I removed the masking, not only had paint somehow got inside the now closed fuselage, but the canopy had lots of tiny stress cracks where I had clamped it to the fuselage to spread it slightly while it dried. I think the paint got in past the odd PE panel in the lower nose which kept detaching itself, and the stress cracks were down to me. I considered removing the canopy and replacing it with a mix of the open parts and a vac form , since you are right, the sections won't stack properly. However getting the canopy off caused more damage that I was prepared to bother with as I had become disheartened with the kit. Up to that point I had been enjoying the build and have salvaged a lot of the completed detail parts for the one in the stash. Next one I will also probably use a Rob Taurus vac form. Link to comment Share on other sites More sharing options...
SleeperService Posted February 10 Share Posted February 10 30 minutes ago, neilh said: I fitted the closed canopy which if I recall was slightly too narrow for the fuselage. When I removed the masking, not only had paint somehow got inside the now closed fuselage, but the canopy had lots of tiny stress cracks where I had clamped it to the fuselage to spread it slightly while it dried. I think the paint got in past the odd PE panel in the lower nose which kept detaching itself, and the stress cracks were down to me. I considered removing the canopy and replacing it with a mix of the open parts and a vac form , since you are right, the sections won't stack properly. However getting the canopy off caused more damage that I was prepared to bother with as I had become disheartened with the kit. Up to that point I had been enjoying the build and have salvaged a lot of the completed detail parts for the one in the stash. Next one I will also probably use a Rob Taurus vac form. I feel your pain as I'm in a similar position right HERE, the GWH transparent plastic is very easy to crack or craze and I think the HB kit will be similar if they try to make an open option. I know that GWH are a different company but there is still the chance that this is the same kit, it wouldn't be the first time the brand has been changed completely for a kit. That is assuming it ever actually appears of course. Link to comment Share on other sites More sharing options...
TheKinksFan Posted February 10 Share Posted February 10 1 hour ago, neilh said: Up to that point I had been enjoying the build and have salvaged a lot of the completed detail parts for the one in the stash. Next one I will also probably use a Rob Taurus vac form. I find attaching the canopy the most nerve-wracking part of the build. So much can go wrong, as your experience well illustrates. I've used to Rob Taurus vacuforms, for 1/72 Dauntless and and P-47D. These were my first experience with vacuforms, and I was really nervous that they would crack when cutting and sanding. But they proved to be very flexible, not brittle. But they didn't stack perfectly, but well enough. I hope the Devastator one will be better in that regard. By the way, there's a new 3D cockpit decals set for this kit from Kelik. 1 hour ago, SleeperService said: I know that GWH are a different company but there is still the chance that this is the same kit, it wouldn't be the first time the brand has been changed completely for a kit. That is assuming it ever actually appears of course. To be honest, I almost hope that it's the same kit, as if it's a new tool it could (or should) be better than the 10 years old kit that we have. In any case, I think that the market for 1/48 Devastators cannot be that big. 1 Link to comment Share on other sites More sharing options...
Homebee Posted May 12 Author Share Posted May 12 Test model Source: https://tieba.baidu.com/p/8407857663 V.P. 1 Link to comment Share on other sites More sharing options...
Homebee Posted May 12 Author Share Posted May 12 Source: https://hobby.dengeki.com/event/1927256/ V.P. 1 Link to comment Share on other sites More sharing options...
Homebee Posted September 21 Author Share Posted September 21 (edited) Release expected in November 2023 - ref. 81783 - Douglas TBD-1 Devastator Source: http://www.hobbyboss.com/index.php?g=home&m=article&a=show&id=241&l=en V.P. Edited September 21 by Homebee 5 Link to comment Share on other sites More sharing options...
28ZComeback Posted September 21 Share Posted September 21 Looks good from here. Link to comment Share on other sites More sharing options...
