Paul Lucas Posted January 11 Posted January 11 Also answered in the Cold War section. Dark Green invented 1933. Included in Air Ministry Standards from 1938. Included in MAP Standards from 1940. Included in MoS Standards from 1946. Introduced into BS 381C in 1964 as No.641. This had the wrong prefix number as in BS 381C '6' denotes shades of grey. Subsequently corrected to '241' in the 1988 edition as '2' denotes shades of green. 1 1
Flanker37 Posted January 11 Posted January 11 (edited) so what is better for a 1940 mk1a spit Humbrol 26/116 or 29/163? in 72nd scale Edited January 11 by Flanker37 missing info
PhantomBigStu Posted January 11 Author Posted January 11 5 minutes ago, Flanker37 said: so what is better for a 1940 mk1a spit Humbrol 26/116 or 29/163? in 72nd scale Depends, I only know the acrylics versions and neither green are right, 116 is too green, 163 is too dark, 29 however is close, not as close as the AK in the first post but still a good choice 1
Paul Lucas Posted January 11 Posted January 11 26 minutes ago, Flanker37 said: so what is better for a 1940 mk1a spit Humbrol 26/116 or 29/163? in 72nd scale If you want full size design colour, 29/116. 1
Flanker37 Posted January 11 Posted January 11 another question, and i'll leave you alone 😆 whats the best match for spitfire mk vb medium sea grey, ocean grey and dark green
Paul Lucas Posted January 11 Posted January 11 @Flanker37, assuming you mean in Humbrol for full size design colour, I use No.127 US Ghost Grey for Medium Sea Grey, No.5 Dark Admiralty Grey for Ocean Grey (it looks nothing like the real Dark Admiralty Grey) and No.116 for Dark Green. 1 1
PhantomBigStu Posted January 12 Author Posted January 12 On 1/11/2025 at 5:56 PM, Flanker37 said: another question, and i'll leave you alone 😆 whats the best match for spitfire mk vb medium sea grey, ocean grey and dark green I’ve not actually got any where with accurate for them in acrylics, in fact I’ve been using two I know to be wrong (aqua 68 and 79) alongside bog standard humbrol 165 which hasn’t yet been under Casey’s spectrometer as I like the look of them at least 1
Casey Posted January 12 Posted January 12 (edited) 1 hour ago, PhantomBigStu said: I’ve not actually got any where with accurate for them in acrylics, in fact I’ve been using two I know to be wrong (aqua 68 and 79) alongside bog standard humbrol 165 which hasn’t yet been under Casey’s spectrometer as I like the look of them at least It was. The LAB is: 56.99, -2.18, -2 Here is full Humbrol data. It is CSV file, just copy and paste it to humbrol.csv and load directly into excel There are 2 lines per color, one is readout in SCI mode, one in SCE, you also have all reflectances for each wavelength. The color simulation is broken since it is not supported in CSV, but there is RGB conversion (careful: it is D65/10 rgb so it is not sRGB. Do not use them for anything sRGB related, convert from spectra if needed). Please use LAB values or (or better - spectra) for comparisons. LAB are comparable only to other D65/10 SCI or SCE data. You might want to use SCI for color comparison too, SCE excludes the specular data. Spoiler Name,R,G,B,Color simulation,L*,a*,b*,H(Munsell),V(Munsell),C(Munsell),LRV,Light source/angle,Test mode,dE*00,UV settings,Metamerism,400nm,410nm,420nm,430nm,440nm,450nm,460nm,470nm,480nm,490nm,500nm,510nm,520nm,530nm,540nm,550nm,560nm,570nm,580nm,590nm,600nm,610nm,620nm,630nm,640nm,650nm,660nm,670nm,680nm,690nm,700nm DB0001 | No 1 | Primer | GU 5.6,136,139,139,-7828597,57.81,-1.22,-0.30,10.10P,5.68,4.20,25.76,D65/10°,SCI,,UV400,,22.33,24.97,25.58,25.76,26.05,26.20,26.09,25.99,25.86,25.79,25.85,25.95,26.07,26.18,26.24,26.22,25.93,25.76,25.56,25.40,25.22,25.04,24.82,24.69,24.47,24.31,24.16,24.01,23.86,23.67,23.52 DB0001 | No 1 | Primer | GU 5.6,135,138,138,-7894390,57.39,-1.12,-0.32,10.10P,5.64,4.17,25.32,D65/10°,SCE,,UV400,,22.30,24.59,25.06,25.31,25.60,25.83,25.67,25.54,25.43,25.36,25.42,25.53,25.64,25.69,25.70,25.64,25.53,25.38,25.15,24.97,24.84,24.68,24.50,24.30,24.13,23.95,23.78,23.55,23.36,23.21,23.11 DB0002 | No 2 | Emerald Green - Gloss | GU 79.8,63,115,68,-12618940,43.91,-27.97,20.37,2.11G,4.34,6.76,13.77,D65/10°,SCI,,UV400,,6.52,6.47,6.41,6.32,6.36,6.37,6.50,6.82,7.78,10.20,15.31,20.15,21.48,20.82,19.08,16.92,14.68,13.25,11.30,9.12,7.49,6.66,6.25,6.11,5.98,5.94,6.03,6.21,6.52,6.91,7.14 DB0002 | No 2 | Emerald Green - Gloss | GU 79.8,34,102,42,-14522838,38.11,-35.09,27.23,10.11GY,3.77,7.11,10.15,D65/10°,SCE,,UV400,,3.34,3.13,2.97,2.89,2.87,2.86,2.97,3.25,4.18,6.53,11.57,16.40,17.76,17.11,15.33,13.25,11.06,9.64,7.74,5.61,4.04,3.19,2.78,2.62,2.48,2.38,2.44,2.60,2.93,3.26,3.53 DB0003 | No 3 | Brunswick Green - Gloss | GU 63.0,59,83,63,-12889281,32.88,-13.81,8.77,2.07G,3.26,4.05,7.48,D65/10°,SCI,,UV400,,4.91,4.96,4.97,5.02,5.13,5.22,5.32,5.53,5.79,6.05,6.60,7.67,9.50,11.19,11.12,9.62,7.65,6.58,5.86,5.39,5.06,4.97,4.94,4.97,5.03,5.10,5.22,5.29,5.39,5.45,5.47 DB0003 | No 3 | Brunswick Green - Gloss | GU 63.0,32,66,39,-14663129,24.94,-19.31,12.51,10.12GY,2.48,4.79,4.40,D65/10°,SCE,,UV400,,2.48,2.34,2.29,2.29,2.29,2.27,2.33,2.43,2.67,2.89,3.43,4.47,6.29,7.96,7.89,6.44,4.64,3.62,2.93,2.45,2.17,2.01,1.92,1.90,1.88,1.86,1.92,1.92,2.00,2.02,2.03 AA0059 | No 5 | Dark Admiralty Grey - Gloss | GU 90.8,106,114,115,-9801101,47.75,-3.06,-1.42,4.16BG,4.69,2.62,16.60,D65/10°,SCI,,UV400,,15.10,16.04,16.39,16.78,17.23,17.49,17.52,17.52,17.50,17.49,17.52,17.55,17.53,17.43,17.24,16.94,16.50,16.16,15.81,15.57,15.38,15.21,15.08,15.07,15.07,15.07,14.99,14.83,14.60,14.36,14.20 AA0059 | No 5 | Dark Admiralty Grey - Gloss | GU 90.8,89,99,99,-10919069,41.30,-3.68,-1.18,2.28BG,4.06,1.42,12.05,D65/10°,SCE,,UV400,,10.12,11.18,11.54,11.98,12.43,12.71,12.82,12.79,12.80,12.79,12.87,12.90,12.93,12.85,12.67,12.42,12.00,11.66,11.33,11.09,10.94,10.76,10.65,10.64,10.67,10.66,10.63,10.47,10.29,10.05,9.91 AA0076 | No 7 | Light Buff - Gloss| GU 95.2,223,165,102,-2120346,72.25,14.32,41.01,9.14YR,7.30,7.08,44.03,D65/10°,SCI,,UV400,,13.87,14.40,14.70,15.35,16.30,17.00,17.39,17.73,18.35,19.89,22.89,26.56,30.15,34.15,38.94,44.32,51.71,56.59,59.63,61.29,61.96,62.12,62.00,61.90,61.88,61.97,62.22,62.67,63.30,64.12,65.17 AA0076 | No 7 | Light Buff - Gloss| GU 95.2,218,157,85,-2450091,69.36,15.24,45.76,10.03YR,7.01,7.63,39.85,D65/10°,SCE,,UV400,,9.65,10.23,10.53,11.22,12.15,12.89,13.31,13.60,14.27,15.83,18.82,22.44,25.99,29.93,34.67,40.15,47.53,52.43,55.44,57.07,57.77,57.92,57.85,57.70,57.70,57.77,58.05,58.48,59.10,59.97,60.93 DB0009 | No 9 | Tan - Gloss | GU 76.9,152,99,77,-6790323,47.38,18.72,21.42,2.83YR,4.74,5.60,16.31,D65/10°,SCI,,UV400,,7.09,7.34,7.46,7.75,8.31,8.60,8.67,8.73,8.96,9.31,9.73,10.12,10.68,11.43,11.82,11.87,13.12,17.12,24.00,29.42,29.72,27.87,26.38,25.50,24.73,24.28,24.57,25.64,27.18,28.82,30.29 DB0009 | No 9 | Tan - Gloss | GU 76.9,145,87,61,-7252163,43.15,21.02,25.15,3.07YR,4.34,6.21,13.26,D65/10°,SCE,,UV400,,4.64,4.66,4.71,5.03,5.52,5.79,5.87,5.87,6.09,6.41,6.83,7.18,7.72,8.43,8.78,8.85,10.06,14.02,20.87,26.16,26.49,24.66,23.20,22.30,21.57,21.09,21.38,22.41,23.91,25.53,26.98 DB0010 | No 10 | Service Brown - Gloss | GU 78.0,81,70,65,-11450815,31.01,3.50,4.60,2.56R,3.08,0.33,6.65,D65/10°,SCI,,UV400,,5.34,5.41,5.45,5.50,5.61,5.61,5.58,5.59,5.64,5.64,5.72,5.78,5.91,6.05,6.19,6.33,6.67,7.23,7.72,7.91,7.87,7.77,7.62,7.55,7.41,7.34,7.28,7.20,7.17,7.15,7.05 DB0010 | No 10 | Service Brown - Gloss | GU 78.0,64,50,46,-12570066,22.48,5.19,4.84,7.12R,2.25,0.88,3.65,D65/10°,SCE,,UV400,,2.92,2.86,2.83,2.89,2.98,2.95,2.92,2.85,2.87,2.84,2.88,2.90,3.00,3.06,3.15,3.25,3.60,4.13,4.61,4.80,4.79,4.68,4.53,4.45,4.34,4.23,4.18,4.07,4.04,3.99,3.90 DB0011 | No 11 | Silver - Metallic | GU 6.7 | Metallic,199,200,202,-3684150,80.89,-0.10,-0.90,9.89P,8.05,3.07,58.27,D65/10°,SCI,,UV400,,58.52,58.92,59.68,59.45,59.58,59.49,58.99,58.81,58.76,58.66,58.64,58.57,58.46,58.34,58.29,58.20,58.20,58.14,58.07,58.14,58.13,58.02,57.79,57.71,57.65,57.45,56.90,56.27,55.69,55.29,54.91 DB0011 | No 11 | Silver - Metallic | GU 6.7 | Metallic,188,189,189,-4407875,76.62,-0.05,-0.36,2.05RP,7.61,1.37,50.90,D65/10°,SCE,,UV400,,50.08,50.59,51.33,51.17,51.48,51.49,51.15,51.05,51.03,51.00,51.02,50.98,50.93,50.84,50.84,50.96,50.90,50.89,50.84,50.90,50.95,50.88,50.71,50.65,50.62,50.43,50.00,49.43,48.89,48.55,48.30 DB0012 | No 12 | Copper - Metallic | GU 48.2 | Metallic,163,113,94,-6065826,52.39,17.44,18.20,2.06YR,5.21,4.48,20.49,D65/10°,SCI,,UV400,,15.05,13.65,12.84,12.06,11.89,11.92,11.97,12.29,13.04,13.88,14.62,15.04,15.43,15.91,16.01,15.87,16.94,20.35,25.70,30.39,32.83,33.85,34.19,34.38,34.45,34.41,34.16,33.75,33.41,33.08,32.86 DB0012 | No 12 | Copper - Metallic | GU 48.2 | Metallic,151,98,77,-6856115,46.82,19.11,20.44,2.06YR,4.68,5.41,15.88,D65/10°,SCE,,UV400,,10.82,9.59,8.86,8.24,8.06,8.05,8.11,8.39,9.04,9.76,10.45,10.81,11.17,11.57,11.65,11.55,12.56,15.78,20.81,25.14,27.39,28.27,28.57,28.70,28.78,28.71,28.53,28.16,27.84,27.61,27.38 DB0014 | No 14 | French Blue - Gloss | GU 80.5,46,99,151,-13737065,40.97,-0.02,-33.52,5.11PB,3.87,8.65,11.84,D65/10°,SCI,,UV400,,20.53,24.48,25.98,27.48,29.60,31.40,31.20,29.45,26.57,23.14,19.72,16.68,14.06,12.10,10.62,9.36,7.97,7.36,7.10,6.99,6.90,6.85,6.90,7.26,7.72,8.23,8.53,8.42,8.00,7.68,7.68 DB0014 | No 14 | French Blue - Gloss | GU 80.5,0,86,143,-16755057,35.35,-0.40,-37.70,5.12PB,3.28,9.51,8.67,D65/10°,SCE,,UV400,,17.39,21.14,22.53,24.08,26.11,27.93,27.71,26.01,23.21,19.84,16.48,13.42,10.87,8.94,7.48,6.25,4.98,4.35,4.03,3.87,3.75,3.63,3.64,3.93,4.36,4.82,5.12,4.97,4.59,4.22,4.18 DB0015 | No 15 | Midnight Blue - Gloss | GU 79.7,49,84,107,-13544341,34.27,-5.44,-17.18,2.91PB,3.29,4.38,8.14,D65/10°,SCI,,UV400,,11.97,13.00,13.26,13.54,14.05,14.51,14.59,14.41,14.02,13.41,12.62,11.61,10.41,9.18,8.03,7.08,6.09,5.66,5.45,5.42,5.39,5.46,5.59,5.79,5.96,6.09,6.14,6.03,5.90,5.83,5.93 DB0015 | No 15 | Midnight Blue - Gloss | GU 79.7,0,68,94,-16759714,26.67,-8.03,-21.11,2.10PB,2.51,5.09,4.98,D65/10°,SCE,,UV400,,8.77,9.69,9.89,10.17,10.66,11.09,11.19,10.98,10.60,10.00,9.29,8.30,7.16,5.97,4.89,4.01,3.17,2.74,2.49,2.35,2.29,2.26,2.27,2.38,2.49,2.56,2.60,2.48,2.37,2.25,2.29 DB0016 | No 16 | Gold - Metallic | GU 6.4 | Metallic,177,148,115,-5139341,63.25,6.13,21.32,7.95YR,6.30,3.97,31.88,D65/10°,SCI,,UV400,,21.62,20.38,19.40,18.42,18.14,18.15,18.52,19.74,20.87,21.27,22.36,24.76,27.74,30.17,30.97,30.73,31.53,35.65,40.57,42.51,41.07,39.14,37.84,37.10,36.49,35.99,35.96,36.62,37.69,38.74,39.60 DB0016 | No 16 | Gold - Metallic | GU 6.4 | Metallic,174,145,113,-5336719,62.25,6.21,21.10,7.65YR,6.20,4.00,30.70,D65/10°,SCE,,UV400,,21.04,19.58,18.64,17.72,17.47,17.49,17.80,18.96,20.06,20.44,21.48,23.78,26.67,28.97,29.69,29.50,30.38,34.32,39.23,41.14,39.75,37.77,36.49,35.74,35.15,34.61,34.64,35.20,36.23,37.29,38.16 DB0018 | No 18 | Orange - Gloss | GU 78.0,230,105,55,-1677001,59.23,45.55,50.01,2.07YR,5.97,12.00,27.28,D65/10°,SCI,,UV400,,6.88,6.58,6.31,6.07,6.03,5.99,6.12,6.42,6.71,6.82,7.35,8.80,11.46,14.74,17.15,17.72,17.47,19.13,29.68,48.06,63.87,73.55,78.93,81.95,83.91,85.32,86.30,87.18,87.75,88.20,88.72 DB0018 | No 18 | Orange - Gloss | GU 78.0,225,92,26,-2008038,55.88,48.92,59.02,10.06R,5.65,14.35,23.79,D65/10°,SCE,,UV400,,4.35,3.89,3.56,3.32,3.21,3.12,3.18,3.38,3.61,3.67,4.14,5.50,8.09,11.27,13.65,14.22,14.00,15.63,26.11,44.41,60.13,69.69,75.12,78.13,80.11,81.32,82.10,82.76,83.13,83.67,84.04 DB0019 | No 19 | Red - Gloss | GU 90.2,158,60,57,-6407111,39.45,40.71,23.50,7.04R,3.98,10.00,10.92,D65/10°,SCI,,UV400,,4.93,4.89,4.85,4.78,4.74,4.68,4.62,4.58,4.56,4.53,4.56,4.69,4.84,4.98,5.08,5.37,6.14,7.00,8.85,13.19,20.45,29.27,38.07,45.32,50.49,53.73,55.62,56.41,55.95,55.51,56.23 DB0019 | No 19 | Red - Gloss | GU 90.2,149,27,31,-7005409,32.48,49.14,30.59,7.07R,3.31,11.30,7.30,D65/10°,SCE,,UV400,,2.33,2.17,2.08,2.03,1.95,1.86,1.80,1.71,1.69,1.62,1.58,1.55,1.60,1.59,1.62,1.71,2.24,2.97,4.79,9.12,16.44,25.18,33.92,41.17,46.37,49.60,51.47,52.25,51.78,51.35,52.12 DB0020 | No 20 | Crimson - Gloss | GU 84.2,151,66,62,-6864322,39.41,35.17,19.81,7.04R,3.97,7.96,10.90,D65/10°,SCI,,UV400,,5.53,5.51,5.48,5.44,5.44,5.39,5.40,5.42,5.44,5.43,5.46,5.45,5.43,5.44,5.44,5.59,6.31,7.69,10.64,15.89,22.56,28.19,30.75,32.49,36.43,43.11,51.23,58.13,62.22,64.71,67.22 DB0020 | No 20 | Crimson - Gloss | GU 84.2,141,36,28,-7527396,32.02,43.32,31.40,7.05R,3.27,10.57,7.09,D65/10°,SCE,,UV400,,1.88,1.78,1.71,1.71,1.69,1.67,1.69,1.67,1.72,1.72,1.74,1.74,1.77,1.72,1.75,1.91,2.70,3.96,6.71,11.82,18.50,24.04,26.61,28.31,32.24,38.89,47.06,53.89,57.99,60.55,62.97 DB0021 | No 21 | Black - Gloss | GU 45.3,59,60,61,-12895171,25.37,-0.09,-0.77,10.18G,2.51,3.55,4.54,D65/10°,SCI,,UV400,,4.72,4.80,4.79,4.74,4.73,4.68,4.64,4.63,4.63,4.59,4.59,4.55,4.55,4.58,4.58,4.55,4.51,4.51,4.47,4.49,4.46,4.48,4.46,4.46,4.47,4.45,4.46,4.43,4.43,4.41,4.40 DB0021 | No 21 | Black - Gloss | GU 45.3,39,41,43,-14210773,16.68,-0.04,-1.77,2.22BG,1.65,0.83,2.24,D65/10°,SCE,,UV400,,2.67,2.60,2.53,2.54,2.52,2.46,2.43,2.36,2.38,2.33,2.31,2.27,2.29,2.26,2.24,2.20,2.23,2.24,2.20,2.16,2.17,2.16,2.12,2.14,2.13,2.09,2.09,2.04,2.07,2.02,1.98 DB0022 | No 22 | White - Gloss | GU 65.9,249,250,246,-394506,98.29,-0.91,1.75,5.05RP,9.83,3.21,95.64,D65/10°,SCI,,UV400,,49.58,74.77,87.77,93.17,94.02,94.27,94.57,94.89,95.06,95.24,95.47,95.59,95.69,95.83,96.02,96.12,95.81,95.81,95.67,95.70,95.64,95.62,95.64,95.60,95.69,95.80,95.76,95.89,95.79,95.75,95.88 DB0022 | No 22 | White - Gloss | GU 65.9,243,244,241,-789263,96.34,-0.92,1.43,3.15RP,9.63,2.06,90.84,D65/10°,SCE,,UV400,,46.64,71.60,83.64,88.71,89.84,90.11,90.14,90.50,90.62,90.79,91.13,91.04,91.04,90.92,91.03,91.26,90.89,90.82,90.74,90.81,90.72,90.78,90.90,90.65,90.77,90.73,90.40,90.30,90.01,90.31,90.37 DB0023 | No 23 | Duck Egg Blue - Matt | GU 4.3,183,191,175,-4735057,76.43,-5.73,7.01,10.05GY,7.61,2.64,50.59,D65/10°,SCI,,UV400,,31.53,37.20,39.07,40.89,43.32,45.07,45.73,46.04,46.47,47.25,48.67,50.45,52.34,54.02,54.89,54.63,52.70,50.85,49.50,48.56,47.61,46.92,46.82,47.46,48.30,49.02,49.40,49.39,48.84,48.29,48.32 DB0023 | No 23 | Duck Egg Blue - Matt | GU 4.3,182,190,174,-4800850,76.10,-5.59,6.95,10.05GY,7.57,2.66,50.06,D65/10°,SCE,,UV400,,31.28,36.83,38.55,40.44,42.92,44.67,45.27,45.60,46.01,46.80,48.20,49.92,51.75,53.34,54.13,53.94,52.10,50.38,49.06,48.13,47.22,46.51,46.43,47.03,47.93,48.59,48.93,48.81,48.17,47.62,47.63 DB0024 | No 24 | Trainer Yellow - Matt | GU 3.6,221,159,58,-2252998,70.04,13.62,59.16,2.06Y,7.11,10.04,40.81,D65/10°,SCI,,UV400,,7.28,7.52,7.55,7.67,7.97,8.21,8.38,8.74,9.84,12.28,16.32,20.76,25.25,30.72,37.38,44.11,51.84,56.35,58.64,59.29,58.90,58.17,57.31,56.65,56.18,55.98,56.06,56.52,57.22,58.16,59.37 DB0024 | No 24 | Trainer Yellow - Matt | GU 3.6,220,159,60,-2318532,69.76,13.71,57.95,10.06YR,7.08,9.13,40.41,D65/10°,SCE,,UV400,,7.99,7.87,7.81,7.95,8.24,8.46,8.62,8.91,9.97,12.29,16.29,20.67,25.05,30.37,36.79,43.55,51.28,55.75,58.03,58.72,58.37,57.62,56.80,56.07,55.68,55.44,55.51,55.85,56.47,57.41,58.60 DB0025 | No 25 | Blue - Matt | GU 5.1,53,81,117,-13282955,34.08,0.75,-23.53,7.11PB,3.26,6.60,8.05,D65/10°,SCI,,UV400,,13.89,15.79,16.18,16.57,17.27,17.76,17.50,16.65,15.26,13.56,11.83,10.28,9.06,8.19,7.49,6.91,6.07,5.84,5.72,5.68,5.58,5.59,5.63,5.85,6.14,6.45,6.65,6.55,6.31,6.15,6.20 DB0025 | No 25 | Blue - Matt | GU 5.1,53,80,116,-13283212,33.77,0.95,-23.67,7.10PB,3.23,6.54,7.90,D65/10°,SCE,,UV400,,14.03,15.69,16.08,16.47,17.11,17.59,17.29,16.40,15.03,13.29,11.67,10.16,8.95,8.02,7.26,6.63,6.02,5.77,5.63,5.55,5.51,5.47,5.52,5.76,6.05,6.33,6.49,6.32,6.06,5.85,5.86 DB0026 | No 26 | Khaki - Matt | GU 3.4,116,92,66,-9151422,41.15,5.74,19.03,2.14Y,4.13,1.08,11.96,D65/10°,SCI,,UV400,,6.09,6.26,6.13,6.02,6.07,6.08,6.20,6.41,6.65,6.79,7.20,8.00,9.03,10.10,11.33,12.74,14.18,14.95,15.20,15.22,15.16,15.06,14.90,14.79,14.61,14.48,14.39,14.31,14.26,14.20,14.13 DB0026 | No 26 | Khaki - Matt | GU 3.4,116,92,67,-9151421,41.13,5.86,17.96,2.12Y,4.12,1.25,11.94,D65/10°,SCE,,UV400,,6.82,6.61,6.40,6.30,6.35,6.35,6.44,6.61,6.82,6.93,7.35,8.12,9.10,10.08,11.22,12.53,14.12,14.88,15.13,15.17,15.15,15.00,14.86,14.73,14.60,14.45,14.32,14.15,14.11,14.03,13.95 DB0027 | No 27 | Sea Grey - Matt | GU 10.5,99,107,111,-10261649,44.75,-2.00,-3.63,8.29BG,4.39,2.01,14.36,D65/10°,SCI,,UV400,,15.21,16.27,16.27,16.18,16.14,16.02,15.84,15.67,15.47,15.30,15.18,15.08,14.97,14.87,14.77,14.65,14.29,14.09,13.82,13.55,13.31,13.08,12.85,12.71,12.52,12.38,12.27,12.20,12.15,12.11,12.00 DB0027 | No 27 | Sea Grey - Matt | GU 10.5,97,105,110,-10393234,43.95,-1.83,-4.08,10.11BG,4.31,3.03,13.80,D65/10°,SCE,,UV400,,15.08,15.91,15.95,15.84,15.76,15.66,15.42,15.17,14.98,14.78,14.67,14.53,14.43,14.28,14.13,13.94,13.75,13.55,13.28,13.01,12.79,12.53,12.32,12.16,11.99,11.81,11.69,11.56,11.51,11.43,11.37 AA1496 | No 28 | Camouflage Grey - Matt | GU 17.2,190,183,164,-4278364,74.58,-0.70,10.28,7.06YR,7.43,-0.49,47.61,D65/10°,SCI,,UV400,,26.99,31.80,33.69,35.62,37.64,39.20,40.24,41.10,41.89,42.68,43.72,44.87,46.04,47.20,48.24,49.12,49.20,49.68,49.97,50.11,50.11,50.07,49.84,49.70,49.48,49.28,49.04,48.89,48.72,48.52,48.39 AA1496 | No 28 | Camouflage Grey - Matt | GU 17.2,187,179,160,-4476000,73.42,-0.64,10.66,5.06GY,7.31,2.65,45.81,D65/10°,SCE,,UV400,,25.44,29.92,31.72,33.72,35.76,37.36,38.36,39.25,40.03,40.82,41.86,43.01,44.20,45.33,46.33,47.28,47.40,47.95,48.22,48.36,48.40,48.34,48.14,47.95,47.79,47.53,47.28,47.03,46.80,46.64,46.49 DB0029 | No 29 | Dark Earth - Matt | GU 3.6,119,97,78,-8953522,43.10,5.68,14.32,10.05YR,4.31,2.37,13.23,D65/10°,SCI,,UV400,,7.37,7.87,7.92,8.04,8.34,8.46,8.47,8.45,8.54,8.72,9.10,9.62,10.24,11.05,12.23,13.72,15.34,16.19,16.45,16.44,16.34,16.17,15.97,15.81,15.60,15.43,15.29,15.19,15.11,15.03,14.93 DB0029 | No 29 | Dark Earth - Matt | GU 3.6,119,97,79,-8953521,43.07,5.79,13.52,10.04YR,4.30,2.25,13.20,D65/10°,SCE,,UV400,,8.14,8.20,8.15,8.30,8.58,8.69,8.67,8.63,8.69,8.84,9.24,9.73,10.29,11.02,12.10,13.51,15.28,16.13,16.39,16.39,16.31,16.13,15.93,15.75,15.58,15.40,15.22,15.04,14.96,14.87,14.78 DB0030 | No 30 | Dark Green - Matt | GU 3.2,79,90,80,-11576752,37.26,-6.36,4.19,2.03G,3.68,1.66,9.68,D65/10°,SCI,,UV400,,7.15,7.69,7.77,7.93,8.22,8.39,8.52,8.63,8.89,9.19,9.59,9.97,10.31,10.63,10.82,10.86,10.46,10.16,9.68,9.07,8.44,7.97,7.65,7.50,7.34,7.25,7.30,7.45,7.64,7.84,7.91 DB0030 | No 30 | Dark Green - Matt | GU 3.2,80,90,82,-11511214,37.44,-5.93,3.53,2.95G,3.70,1.85,9.78,D65/10°,SCE,,UV400,,7.96,8.08,8.09,8.24,8.54,8.69,8.79,8.87,9.10,9.38,9.78,10.12,10.42,10.66,10.78,10.76,10.57,10.27,9.79,9.18,8.61,8.12,7.82,7.67,7.52,7.40,7.42,7.48,7.65,7.78,7.90 AA0343 | No 31 | Slate Grey - Matt | GU 7.5,100,107,98,-10196126,44.66,-4.65,4.43,2.07G,4.41,1.29,14.30,D65/10°,SCI,,UV400,,9.97,10.62,10.92,11.48,12.35,12.89,13.03,13.05,13.14,13.37,13.83,14.45,15.04,15.55,15.79,15.63,14.88,14.28,13.81,13.49,13.22,13.00,12.88,12.98,13.13,13.27,13.32,13.16,12.82,12.53,12.35 AA0343 | No 31 | Slate Grey - Matt | GU 7.5,98,105,96,-10327712,43.84,-4.48,4.29,2.07G,4.33,1.27,13.73,D65/10°,SCE,,UV400,,10.01,10.32,10.50,11.08,11.91,12.44,12.54,12.50,12.58,12.78,13.28,13.85,14.47,14.92,15.10,14.92,14.33,13.74,13.28,12.96,12.73,12.48,12.37,12.46,12.65,12.77,12.76,12.53,12.24,11.94,11.84 DB0032 | No 32 | Dark Grey - Matt | GU 11.2,74,77,79,-11907761,32.82,-0.88,-1.56,2.86BG,3.24,1.59,7.45,D65/10°,SCI,,UV400,,7.75,8.11,8.10,8.01,8.01,7.91,7.81,7.71,7.66,7.57,7.54,7.55,7.59,7.64,7.68,7.68,7.45,7.41,7.29,7.21,7.14,7.08,6.98,6.95,6.85,6.80,6.76,6.72,6.70,6.67,6.59 DB0032 | No 32 | Dark Grey - Matt | GU 11.2,71,75,78,-12104882,31.80,-0.70,-2.29,5.16BG,3.13,3.37,6.99,D65/10°,SCE,,UV400,,7.94,7.96,7.84,7.76,7.75,7.65,7.54,7.38,7.31,7.20,7.18,7.15,7.17,7.15,7.11,7.07,7.03,6.97,6.84,6.73,6.69,6.62,6.52,6.47,6.39,6.31,6.24,6.11,6.08,5.99,5.93 DB0033 | No 33 | Black - Matt | GU 3.9,56,56,56,-13092808,23.89,-0.19,0.06,7.18G,2.36,0.64,4.07,D65/10°,SCI,,UV400,,3.87,4.08,4.10,4.09,4.08,4.04,4.03,4.03,4.06,4.03,4.03,4.02,4.04,4.11,4.16,4.20,4.04,4.04,4.02,4.04,4.02,4.04,4.04,4.04,4.04,4.05,4.06,4.06,4.10,4.09,4.10 DB0033 | No 33 | Black - Matt | GU 3.9,56,56,57,-13092807,23.79,0.07,-0.70,10.18G,2.35,3.56,4.04,D65/10°,SCE,,UV400,,4.28,4.28,4.22,4.22,4.21,4.15,4.14,4.10,4.11,4.06,4.06,4.04,4.06,4.04,4.03,4.03,4.04,4.04,4.00,3.98,4.02,4.01,3.99,4.01,4.00,3.97,3.97,3.91,3.94,3.91,3.89 DB0034 | No 34 | White - Matt | GU 6.5,246,247,243,-591885,97.10,-0.95,1.65,2.92RP,9.71,1.91,92.70,D65/10°,SCI,,UV400,,47.64,72.50,85.41,90.29,91.18,91.43,91.78,92.13,92.33,92.51,92.67,92.72,92.78,92.82,93.05,93.34,92.82,92.76,92.62,92.61,92.56,92.54,92.58,92.64,92.84,93.06,93.11,93.23,93.08,93.00,93.08 DB0034 | No 34 | White - Matt | GU 6.5,243,244,241,-789263,96.12,-0.93,1.36,3.22RP,9.61,2.10,90.30,D65/10°,SCE,,UV400,,47.01,71.62,83.44,88.14,89.29,89.63,89.71,90.10,90.21,90.38,90.68,90.54,90.47,90.34,90.48,90.88,90.29,90.18,90.09,90.13,90.08,90.16,90.29,90.15,90.37,90.41,90.15,90.01,89.65,89.90,89.97 DB0036 | No 36 | Pastel Green - Matt | GU 6.9,169,168,64,-5658560,67.24,-13.08,51.88,2.81GY,6.74,7.76,36.96,D65/10°,SCI,,UV400,,9.62,9.07,8.57,8.13,8.04,8.11,8.24,8.73,10.40,14.79,24.87,38.19,44.46,44.68,44.24,43.69,41.67,40.62,40.61,40.13,38.14,35.77,33.95,33.38,33.59,34.21,35.39,37.16,39.13,40.88,42.48 DB0036 | No 36 | Pastel Green - Matt | GU 6.9,167,166,65,-5790143,66.75,-12.93,51.17,2.04GY,6.69,7.41,36.31,D65/10°,SCE,,UV400,,10.02,9.17,8.61,8.17,8.06,8.11,8.23,8.64,10.22,14.45,24.42,37.45,43.75,43.91,43.40,42.87,40.97,39.94,39.93,39.43,37.49,35.08,33.33,32.75,33.02,33.56,34.71,36.33,38.19,39.93,41.53 AA0037 | No 37 | Bright Green - Matt | GU 1.4 | Opacity 75.83%,0,154,48,-16737744,54.28,-68.95,42.33,2.11G,5.31,16.71,22.23,D65/10°,SCI,,UV400,,4.78,4.67,4.60,4.54,4.45,4.39,4.47,4.92,6.83,11.85,22.66,42.85,55.11,51.30,43.06,37.02,10.79,7.96,6.17,5.22,4.75,4.58,4.49,4.47,4.46,4.45,4.53,4.58,4.73,4.81,4.87 AA0037 | No 37 | Bright Green - Matt | GU 1.4 | Opacity 75.83%,0,154,49,-16737743,54.36,-69.12,42.02,2.10G,5.32,16.72,22.31,D65/10°,SCE,,UV400,,5.26,4.86,4.70,4.65,4.55,4.48,4.55,5.01,6.97,11.91,22.80,43.07,55.49,51.62,43.15,36.93,10.76,7.99,6.21,5.21,4.76,4.56,4.45,4.45,4.41,4.39,4.45,4.46,4.57,4.63,4.67 DB0038 | No 38 | Lime - Gloss | GU 82.8,142,156,67,-7431101,61.77,-18.16,44.20,2.53GY,6.15,6.33,30.14,D65/10°,SCI,,UV400,,9.05,8.53,8.13,7.78,7.68,7.68,7.80,8.22,9.69,13.72,23.08,35.46,41.57,41.75,39.19,35.65,31.30,28.97,27.84,27.19,26.46,25.94,26.35,27.92,30.10,32.16,33.29,32.80,31.05,29.52,29.42 DB0038 | No 38 | Lime - Gloss | GU 82.8,133,147,38,-8023258,58.25,-19.66,52.40,5.04GY,5.80,8.25,26.22,D65/10°,SCE,,UV400,,5.58,4.93,4.51,4.19,4.03,4.03,4.15,4.50,5.95,9.87,19.20,31.37,37.52,37.68,35.08,31.65,27.37,25.12,24.00,23.36,22.67,22.16,22.58,24.09,26.28,28.29,29.42,28.93,27.19,25.76,25.66 DB0040 | No 40 | Pale Grey - Gloss | GU 65.2,156,160,153,-6512487,65.55,-2.55,2.90,5.09G,6.46,3.44,34.74,D65/10°,SCI,,UV400,,26.05,29.65,30.62,31.38,32.39,33.07,33.27,33.37,33.46,33.61,34.01,34.53,35.05,35.54,35.85,35.92,35.80,35.54,35.08,34.55,33.91,33.44,33.03,32.79,32.58,32.48,32.54,32.75,33.04,33.23,33.45 DB0040 | No 40 | Pale Grey - Gloss | GU 65.2,149,152,145,-6973295,62.69,-2.65,3.33,5.09G,6.18,3.39,31.22,D65/10°,SCE,,UV400,,22.48,25.96,26.83,27.72,28.68,29.42,29.62,29.73,29.85,30.02,30.44,30.98,31.53,31.97,32.27,32.38,32.27,32.03,31.59,31.06,30.51,30.03,29.66,29.40,29.24,29.12,29.22,29.39,29.68,29.90,30.14 DB0041 | No 41 | Ivory - Gloss | GU 58.2,229,215,193,-1714239,86.77,1.16,12.60,10.03YR,8.71,2.28,69.54,D65/10°,SCI,,UV400,,38.55,48.02,50.97,52.73,55.11,56.67,57.15,57.33,57.65,58.42,60.01,62.23,64.88,67.83,70.59,72.62,74.17,74.76,74.82,74.73,74.50,74.21,73.86,73.59,73.35,73.15,72.88,72.85,72.72,72.66,72.57 DB0041 | No 41 | Ivory - Gloss | GU 58.2,226,212,190,-1911618,85.64,1.14,12.56,10.03YR,8.59,2.28,67.27,D65/10°,SCE,,UV400,,37.20,46.15,49.15,50.86,53.26,54.77,55.19,55.35,55.65,56.40,57.95,60.13,62.75,65.59,68.29,70.26,71.83,72.43,72.49,72.37,72.12,71.80,71.45,71.09,70.84,70.57,70.29,70.18,69.96,69.94,69.82 DB0042 | No 42 | Pastel Violet - Matt | GU 4.8,118,120,151,-9013097,51.42,6.08,-16.99,10.07PB,4.99,4.78,19.63,D65/10°,SCI,,UV400,,25.58,29.19,29.73,29.88,30.45,30.63,30.24,29.59,28.23,26.30,24.30,22.19,20.03,18.55,17.73,16.73,14.84,14.55,16.96,19.37,20.14,19.90,19.73,20.59,22.52,25.01,26.99,27.45,26.48,25.36,25.25 DB0042 | No 42 | Pastel Violet - Matt | GU 4.8,117,119,150,-9078890,51.17,6.06,-16.87,10.07PB,4.96,4.74,19.41,D65/10°,SCE,,UV400,,25.64,28.86,29.23,29.49,30.03,30.29,29.87,29.23,27.91,25.99,24.04,21.99,19.84,18.36,17.46,16.40,14.69,14.41,16.79,19.20,19.98,19.70,19.52,20.36,22.33,24.74,26.63,27.00,26.00,24.94,24.87 DB0044 | No 44 | Pastel Blue - Matt | GU 7.0,139,179,203,-7621685,71.10,-7.64,-16.72,2.08PB,6.94,5.94,42.34,D65/10°,SCI,,UV400,,40.02,51.89,55.95,57.19,58.39,59.26,59.76,59.75,58.85,57.03,54.77,52.04,48.79,45.90,43.74,41.54,37.88,35.54,34.40,33.84,32.98,32.10,31.80,32.55,33.97,35.42,36.49,36.79,36.28,35.59,35.71 DB0044 | No 44 | Pastel Blue - Matt | GU 7.0,138,178,202,-7687478,70.64,-7.62,-16.70,2.08PB,6.89,5.84,41.66,D65/10°,SCE,,UV400,,39.70,51.19,54.99,56.31,57.52,58.44,58.89,58.86,57.98,56.19,53.96,51.29,48.16,45.21,42.96,40.82,37.21,34.89,33.79,33.23,32.45,31.62,31.35,32.04,33.45,34.81,35.84,36.06,35.55,34.94,35.09 AA0046 | No 46 | Orange - Matt | GU 8.5,215,124,52,-2655180,61.08,29.47,52.42,5.03YR,6.19,10.64,29.34,D65/10°,SCI,,UV400,,6.17,6.29,6.26,6.23,6.31,6.33,6.48,6.66,6.77,6.81,7.09,7.86,9.85,14.11,19.96,26.12,35.02,41.99,47.37,51.14,53.18,54.08,54.38,54.61,54.80,55.10,55.54,56.18,56.79,57.78,59.25 AA0046 | No 46 | Orange - Matt | GU 8.5,213,123,54,-2786506,60.73,29.50,51.23,5.03YR,6.15,10.53,28.94,D65/10°,SCE,,UV400,,6.79,6.58,6.45,6.43,6.49,6.51,6.63,6.72,6.81,6.82,7.11,7.83,9.75,13.82,19.56,25.58,34.41,41.38,46.82,50.52,52.54,53.39,53.71,53.88,54.13,54.37,54.78,55.31,55.87,56.86,58.31 AB0047 | No 47 | Sea Blue - Gloss | GU 65.0,126,178,194,-8473918,69.86,-13.32,-13.60,7.05B,6.82,4.04,40.56,D65/10°,SCI,,UV400,,36.85,48.06,51.16,52.20,53.28,53.71,53.64,53.40,53.01,52.50,51.92,50.94,49.55,47.65,45.20,42.23,37.71,34.26,31.73,30.11,28.74,27.72,27.23,27.09,27.10,27.60,28.34,28.62,28.21,27.40,26.26 AB0047 | No 47 | Sea Blue - Gloss | GU 65.0,117,173,189,-9065027,67.59,-13.94,-13.99,7.06B,6.58,4.05,37.42,D65/10°,SCE,,UV400,,33.60,44.71,47.68,48.76,49.87,50.33,50.26,50.07,49.69,49.22,48.67,47.76,46.38,44.45,41.96,39.01,34.54,31.19,28.71,27.10,25.80,24.80,24.33,24.17,24.21,24.66,25.41,25.67,25.25,24.49,23.41 DB0048 | No 48 | Mediterranean Blue - Gloss | GU 71.1,61,135,160,-12744800,53.11,-15.65,-19.84,7.31B,5.09,6.11,21.15,D65/10°,SCI,,UV400,,25.33,29.30,30.46,31.42,32.80,34.22,35.00,35.48,35.70,35.33,34.12,31.93,29.05,25.93,22.85,19.85,16.26,14.21,13.11,12.48,11.93,11.52,11.48,11.94,12.61,13.27,13.68,13.64,13.11,12.64,12.58 DB0048 | No 48 | Mediterranean Blue - Gloss | GU 71.1,36,128,153,-14384999,49.80,-17.41,-21.27,7.09B,4.76,6.07,18.25,D65/10°,SCE,,UV400,,22.70,26.42,27.45,28.44,29.79,31.25,31.98,32.42,32.63,32.25,31.09,28.96,26.13,23.02,19.97,16.98,13.48,11.44,10.30,9.63,9.09,8.63,8.55,8.97,9.61,10.22,10.63,10.55,10.06,9.55,9.50 AA0549 | No 50 | Green Mist - Metallic | GU 94.3 | Metallic,59,117,101,-12880539,45.09,-23.10,2.88,10.05G,4.40,4.58,14.61,D65/10°,SCI,,UV400,,8.39,8.75,9.23,10.10,11.18,12.51,14.42,16.70,18.54,19.54,19.87,19.75,19.38,18.72,17.83,16.60,14.76,13.13,11.38,9.62,8.22,7.44,6.99,6.86,6.68,6.59,6.64,6.84,7.21,7.68,8.09 AA0549 | No 50 | Green Mist - Metallic | GU 94.3 | Metallic,2,101,81,-16620207,37.88,-30.54,4.18,10.04G,3.69,6.05,10.02,D65/10°,SCE,,UV400,,3.73,4.07,4.54,5.44,6.51,7.77,9.69,11.93,13.77,14.79,15.15,15.04,14.70,14.06,13.17,12.02,10.19,8.59,6.85,5.14,3.80,3.00,2.61,2.45,2.31,2.21,2.29,2.48,2.88,3.32,3.77 AA0552 | No 51 | Sunset Red - Metallic | GU 95.3 | Metallic,153,107,126,-6722690,50.68,21.23,-2.82,5.02RP,4.98,5.62,18.99,D65/10°,SCI,,UV400,,17.40,18.17,19.02,20.22,21.20,21.62,21.29,20.45,19.32,18.31,17.33,16.33,15.49,15.08,14.91,14.53,13.34,12.34,14.59,22.13,29.85,34.29,36.18,36.98,37.37,37.58,37.58,37.45,37.34,37.17,37.07 AA0552 | No 51 | Sunset Red - Metallic | GU 95.3 | Metallic,142,89,109,-7448211,44.35,24.68,-2.59,5.03RP,4.37,6.77,14.08,D65/10°,SCE,,UV400,,12.10,12.87,13.66,14.90,15.90,16.32,16.05,15.24,14.18,13.19,12.32,11.37,10.62,10.22,10.11,9.82,8.65,7.74,9.95,17.31,24.79,28.99,30.83,31.57,31.97,32.13,32.18,32.04,31.91,31.78,31.73 AB0052 | No 52 | Baltic Blue - Metallic | GU 78.7 | Metallic,20,121,170,-15435350,48.04,-9.13,-33.53,2.04PB,4.54,9.10,16.83,D65/10°,SCI,,UV400,,23.41,27.30,29.05,32.49,37.86,41.35,41.55,40.46,37.86,34.17,30.16,26.06,21.84,18.48,16.12,13.97,11.52,10.02,9.20,8.75,8.36,8.05,7.84,7.83,7.86,8.06,8.33,8.40,8.25,7.98,7.57 AB0052 | No 52 | Baltic Blue - Metallic | GU 78.7 | Metallic,0,98,152,-16751976,39.01,-8.02,-37.24,3.96PB,3.62,9.91,10.66,D65/10°,SCE,,UV400,,16.70,20.16,21.61,24.65,29.53,32.69,32.65,31.41,28.79,25.18,21.58,18.00,14.40,11.62,9.72,8.11,6.18,5.06,4.44,4.09,3.82,3.57,3.41,3.41,3.44,3.58,3.80,3.84,3.75,3.50,3.23 DB0053 | No 53 | Gunmetal - Metallic | GU 6.1 | Metallic,134,137,138,-7960182,57.21,-1.02,-0.88,10.10P,5.62,4.06,25.14,D65/10°,SCI,,UV400,,25.39,25.81,25.92,25.79,25.75,25.73,25.55,25.51,25.53,25.49,25.48,25.49,25.48,25.46,25.45,25.46,25.16,25.03,24.91,24.81,24.69,24.51,24.27,24.10,23.86,23.62,23.32,22.97,22.63,22.29,21.97 DB0053 | No 53 | Gunmetal - Metallic | GU 6.1 | Metallic,132,135,136,-8091768,56.23,-0.90,-0.87,10.10P,5.52,4.03,24.14,D65/10°,SCE,,UV400,,24.70,24.80,24.80,24.72,24.72,24.75,24.55,24.49,24.50,24.46,24.48,24.49,24.47,24.40,24.35,24.34,24.18,24.09,23.95,23.84,23.77,23.60,23.39,23.20,23.01,22.77,22.45,22.02,21.69,21.38,21.09 DB0054 | No 54 | Brass - Metallic | GU 8.0 | Metallic,157,123,81,-6456495,54.06,7.67,27.98,2.05Y,5.40,4.04,22.03,D65/10°,SCI,,UV400,,11.41,10.50,9.86,9.30,9.20,9.24,9.58,10.47,11.31,11.71,12.71,15.00,17.98,20.52,21.76,21.88,22.54,25.18,28.38,30.07,30.09,29.56,29.04,28.74,28.42,28.14,28.01,28.07,28.24,28.39,28.47 DB0054 | No 54 | Brass - Metallic | GU 8.0 | Metallic,154,120,79,-6653873,52.86,7.83,27.43,2.04Y,5.28,4.03,20.92,D65/10°,SCE,,UV400,,11.16,10.06,9.41,8.87,8.81,8.83,9.14,9.90,10.67,11.02,11.99,14.11,17.00,19.43,20.53,20.68,21.43,24.00,27.06,28.66,28.71,28.20,27.71,27.38,27.10,26.79,26.65,26.64,26.79,26.96,27.04 DB0055 | No 55 | Bronze - Metallic | GU 6.7 | Metallic,153,114,84,-6720940,51.39,11.73,22.65,7.41YR,5.13,4.10,19.60,D65/10°,SCI,,UV400,,11.84,10.94,10.26,9.64,9.56,9.56,9.89,10.68,11.39,11.65,12.33,13.82,15.61,17.08,17.59,17.40,18.00,20.96,25.18,28.15,29.04,28.98,28.72,28.53,28.30,28.08,27.95,27.95,28.01,28.03,28.04 DB0055 | No 55 | Bronze - Metallic | GU 6.7 | Metallic,151,111,83,-6852781,50.39,11.87,22.01,7.11YR,5.03,4.03,18.74,D65/10°,SCE,,UV400,,11.76,10.61,9.92,9.37,9.28,9.27,9.55,10.26,10.91,11.11,11.78,13.13,14.88,16.28,16.68,16.46,17.19,20.10,24.18,27.01,27.91,27.83,27.57,27.37,27.16,26.91,26.78,26.69,26.75,26.81,26.81 DB0056 | No 56 | Aluminium - Metallic | GU 14.6 | Metallic,161,166,168,-6183256,67.99,-1.37,-1.43,7.97P,6.70,2.17,37.96,D65/10°,SCI,,UV400,,38.22,39.10,39.41,39.21,39.26,39.21,38.95,38.87,38.83,38.79,38.78,38.74,38.65,38.55,38.48,38.37,37.88,37.67,37.42,37.22,37.00,36.82,36.47,36.19,35.89,35.54,35.05,34.47,33.99,33.55,33.20 DB0056 | No 56 | Aluminium - Metallic | GU 14.6 | Metallic,156,161,162,-6512222,65.95,-1.32,-1.46,7.08P,6.49,1.29,35.26,D65/10°,SCE,,UV400,,35.67,36.40,36.56,36.46,36.53,36.55,36.24,36.15,36.10,36.05,36.05,36.01,35.93,35.79,35.71,35.67,35.15,34.97,34.74,34.55,34.40,34.19,33.88,33.60,33.35,33.02,32.61,32.01,31.55,31.14,30.82 DB0057 | No 57 | Pink - Matt | GU 5.2,233,171,183,-1463369,76.23,24.20,3.10,8.84RP,7.60,6.37,50.27,D65/10°,SCI,,UV400,,38.80,48.50,50.11,49.27,48.51,47.92,47.19,46.23,45.25,44.04,42.23,40.29,39.53,39.45,38.69,37.76,39.50,46.08,57.43,68.59,74.99,77.55,78.92,80.32,81.85,83.14,83.76,83.65,82.83,82.10,82.03 DB0057 | No 57 | Pink - Matt | GU 5.2,232,170,182,-1529162,75.82,24.26,3.05,8.71RP,7.56,6.36,49.60,D65/10°,SCE,,UV400,,38.57,47.53,49.35,48.53,47.94,47.41,46.67,45.71,44.69,43.50,41.67,39.70,38.96,38.80,37.97,37.04,38.91,45.60,56.78,67.81,74.15,76.73,78.13,79.51,80.98,81.98,82.36,82.15,81.41,80.91,80.87 DB0058 | No 58 | Magenta - Matt | GU 6.4,167,88,105,-5810071,47.46,34.26,4.80,10.05RP,4.70,8.20,16.37,D65/10°,SCI,,UV400,,15.82,16.24,15.86,15.28,14.91,14.55,14.12,13.60,12.89,12.17,11.43,10.64,9.92,9.61,9.47,9.16,8.69,9.58,14.37,24.81,35.51,40.50,41.60,41.48,40.88,40.42,40.93,42.56,44.77,46.97,48.77 DB0058 | No 58 | Magenta - Matt | GU 6.4,166,87,105,-5875863,47.05,34.22,4.47,10.05RP,4.66,8.17,16.06,D65/10°,SCE,,UV400,,15.88,16.09,15.80,15.18,14.77,14.43,13.93,13.35,12.68,11.95,11.29,10.49,9.78,9.40,9.16,8.81,8.54,9.38,14.06,24.36,34.83,39.83,40.93,40.78,40.22,39.69,40.16,41.71,43.85,46.06,47.82 DB0060 | No 60 | Scarlett - Matt | GU 3.5,156,57,50,-6538958,38.38,40.94,25.79,7.02R,3.87,9.77,10.30,D65/10°,SCI,,UV400,,3.73,3.89,3.93,3.92,3.91,3.88,3.89,3.93,3.99,4.03,4.07,4.11,4.20,4.32,4.40,4.63,5.18,6.24,8.62,13.88,22.01,30.74,37.86,42.20,43.92,44.36,45.18,47.10,49.53,52.19,54.45 DB0060 | No 60 | Scarlett - Matt | GU 3.5,155,57,52,-6604492,38.30,40.74,24.93,7.02R,3.87,9.75,10.26,D65/10°,SCE,,UV400,,4.19,4.11,4.07,4.06,4.07,4.01,4.02,4.01,4.08,4.10,4.14,4.16,4.26,4.28,4.33,4.50,5.23,6.32,8.65,13.82,21.92,30.43,37.38,41.73,43.52,43.93,44.68,46.47,48.89,51.49,53.72 DB0061 | No 61 | Flesh - Matt | GU 5.9,216,144,109,-2584467,66.31,23.39,29.56,3.12YR,6.64,7.48,35.72,D65/10°,SCI,,UV400,,16.98,17.57,17.28,16.93,16.98,17.18,17.44,18.15,18.98,19.63,20.78,22.71,25.12,27.30,28.10,28.00,29.72,36.53,47.07,56.44,60.91,62.04,62.03,61.84,61.54,61.25,61.30,61.71,62.19,62.71,63.14 DB0061 | No 61 | Flesh - Matt | GU 5.9,214,143,109,-2715795,65.97,23.43,29.15,2.05YR,6.61,7.25,35.28,D65/10°,SCE,,UV400,,17.11,17.48,17.26,16.86,16.95,17.14,17.32,18.01,18.86,19.47,20.60,22.47,24.82,26.90,27.63,27.46,29.35,35.95,46.59,55.82,60.25,61.35,61.37,61.12,60.87,60.60,60.57,60.85,61.33,61.85,62.26 DB0062 | No 62 | Leather - Matt | GU 3.5,143,93,63,-7381697,44.43,17.21,25.36,6.08YR,4.48,4.82,14.14,D65/10°,SCI,,UV400,,6.04,6.27,6.21,6.08,6.06,6.01,6.02,6.09,6.19,6.30,6.55,6.89,7.32,7.91,9.10,11.37,16.18,20.57,23.48,24.42,23.45,21.99,20.96,20.40,19.87,19.49,19.62,20.28,21.19,22.05,22.72 DB0062 | No 62 | Leather - Matt | GU 3.5,143,93,65,-7381695,44.37,17.19,24.27,6.10YR,4.47,4.74,14.09,D65/10°,SCE,,UV400,,6.76,6.61,6.46,6.33,6.32,6.27,6.25,6.28,6.36,6.44,6.70,7.02,7.40,7.92,9.02,11.19,16.08,20.42,23.31,24.24,23.34,21.90,20.87,20.26,19.75,19.40,19.53,20.11,20.99,21.80,22.49 DB0063 | No 63 | Sand - Matt | GU 7.1,186,132,87,-4553641,59.77,15.48,32.39,6.99YR,5.99,6.00,27.87,D65/10°,SCI,,UV400,,12.43,12.39,11.94,11.41,11.28,11.24,11.44,12.07,12.69,13.01,14.01,16.34,19.48,22.42,24.69,26.45,29.07,32.91,37.17,40.25,41.82,42.38,42.23,42.26,42.53,42.92,43.23,43.48,43.64,43.73,43.84 DB0063 | No 63 | Sand - Matt | GU 7.1,185,131,87,-4619433,59.31,15.58,31.93,6.90YR,5.94,5.96,27.36,D65/10°,SCE,,UV400,,12.73,12.33,11.83,11.34,11.22,11.17,11.32,11.87,12.44,12.73,13.75,16.01,19.12,21.95,24.16,25.86,28.57,32.31,36.48,39.57,41.19,41.69,41.56,41.57,41.89,42.23,42.49,42.62,42.74,42.78,42.91 DB0064 | No 64 | Light Grey - Matt | GU 5.9,146,149,148,-7170668,61.60,-1.31,0.31,2.10RP,6.06,0.92,29.94,D65/10°,SCI,,UV400,,24.85,28.24,29.05,29.36,29.79,30.07,29.99,29.90,29.77,29.76,29.87,30.04,30.23,30.38,30.50,30.52,30.25,30.04,29.83,29.61,29.41,29.24,28.99,28.83,28.59,28.40,28.23,28.06,27.90,27.69,27.56 DB0064 | No 64 | Light Grey - Matt | GU 5.9,145,148,147,-7236461,61.21,-1.24,0.30,2.10RP,6.02,0.92,29.49,D65/10°,SCE,,UV400,,24.84,27.84,28.51,28.87,29.33,29.67,29.56,29.44,29.35,29.32,29.44,29.61,29.80,29.91,29.96,29.90,29.82,29.65,29.42,29.17,29.01,28.84,28.61,28.41,28.23,28.00,27.80,27.55,27.36,27.20,27.06 AB0065 | No 65 | Aircraft Blue - Matt | GU 6.3,145,181,179,-7227981,71.38,-12.78,-2.76,9.95BG,7.03,2.67,42.74,D65/10°,SCI,,UV400,,32.73,39.51,41.74,42.84,43.87,45.03,46.30,47.50,48.18,48.43,48.39,48.13,47.80,47.39,46.82,46.01,44.26,42.51,40.20,37.19,33.90,31.36,29.80,28.98,28.24,27.78,28.00,28.95,30.25,31.53,32.55 AB0065 | No 65 | Aircraft Blue - Matt | GU 6.3,144,180,178,-7293774,70.98,-12.72,-2.83,10.01BG,6.99,2.62,42.16,D65/10°,SCE,,UV400,,32.38,39.05,41.17,42.27,43.38,44.55,45.75,46.95,47.61,47.85,47.84,47.54,47.21,46.75,46.12,45.29,43.65,41.95,39.63,36.61,33.39,30.95,29.42,28.58,27.90,27.40,27.59,28.44,29.72,30.99,32.04 AA0770 | No 66 | Olive Drab - Matt | GU 5.9,74,76,74,-11908022,32.42,-1.49,1.32,5.54G,3.20,2.77,7.27,D65/10°,SCI,,UV400,,6.21,6.59,6.71,6.80,6.98,6.99,6.96,6.92,6.96,7.02,7.17,7.30,7.42,7.51,7.58,7.60,7.36,7.32,7.23,7.13,7.08,7.04,6.94,6.94,6.84,6.79,6.77,6.74,6.72,6.72,6.61 AA0770 | No 66 | Olive Drab - Matt | GU 5.9,73,75,73,-11973815,31.78,-1.24,0.78,7.14G,3.14,0.84,6.99,D65/10°,SCE,,UV400,,6.56,6.57,6.59,6.70,6.86,6.87,6.81,6.74,6.76,6.81,6.96,7.06,7.14,7.19,7.18,7.16,7.12,7.06,6.95,6.85,6.83,6.77,6.69,6.67,6.60,6.53,6.48,6.36,6.33,6.26,6.22 DB0067 | No 67 | Matt Tank Grey - Matt | GU 5.2,70,73,73,-12170935,30.81,-1.03,-0.76,2.15BG,3.04,1.01,6.57,D65/10°,SCI,,UV400,,6.26,6.70,6.78,6.77,6.86,6.80,6.77,6.68,6.66,6.62,6.61,6.62,6.69,6.75,6.81,6.83,6.56,6.54,6.44,6.36,6.31,6.27,6.19,6.19,6.10,6.07,6.06,6.03,6.04,6.02,5.98 DB0067 | No 67 | Matt Tank Grey - Matt | GU 5.2,70,72,74,-12171190,30.81,-0.79,-1.46,2.27BG,3.04,1.09,6.57,D65/10°,SCE,,UV400,,6.97,7.00,6.98,6.98,7.05,7.00,6.94,6.81,6.76,6.70,6.71,6.69,6.72,6.72,6.68,6.66,6.60,6.55,6.44,6.35,6.32,6.28,6.20,6.17,6.11,6.03,5.98,5.89,5.86,5.79,5.75 DB0068 | No 68 | Purple - Gloss | GU 79.1,92,78,99,-10727837,35.35,10.09,-10.06,5.96P,3.46,3.25,8.67,D65/10°,SCI,,UV400,,13.48,13.51,13.09,12.50,12.25,12.13,11.84,11.55,11.42,10.94,9.94,8.71,7.61,6.99,6.82,6.81,6.80,7.25,8.26,9.55,10.56,10.46,9.69,9.78,11.18,14.27,19.08,25.06,31.03,36.47,41.43 DB0068 | No 68 | Purple - Gloss | GU 79.1,76,62,88,-11780520,28.85,11.63,-12.96,5.43P,2.81,3.72,5.78,D65/10°,SCE,,UV400,,10.86,10.75,10.32,9.74,9.49,9.33,9.06,8.75,8.62,8.17,7.24,6.05,5.00,4.32,4.06,3.98,3.99,4.31,5.16,6.36,7.35,7.26,6.49,6.53,7.88,10.86,15.59,21.50,27.44,32.83,37.71 DB0069 | No 69 | Yellow - Gloss | GU 93.5,238,179,59,-1133765,76.60,10.55,65.62,2.02Y,7.77,10.02,50.87,D65/10°,SCI,,UV400,,10.52,9.64,9.18,8.72,8.60,8.67,8.82,9.41,11.51,16.89,28.01,40.49,46.57,48.41,48.85,48.93,50.55,55.80,63.50,70.41,74.37,75.01,74.02,74.54,77.33,81.31,84.93,87.38,88.57,89.33,89.89 DB0069 | No 69 | Yellow - Gloss | GU 93.5,232,171,17,-1529071,73.96,11.21,75.02,2.02Y,7.50,11.02,46.64,D65/10°,SCE,,UV400,,6.56,5.73,5.21,4.81,4.65,4.71,4.88,5.41,7.49,12.76,23.80,36.15,42.28,44.13,44.60,44.72,46.34,51.64,59.25,66.13,70.04,70.67,69.71,70.20,73.07,77.10,80.63,82.61,83.56,84.30,84.80 AA0775 | No 70 | Brick Red - Matt | GU 3.1,117,83,77,-9088179,38.89,13.41,8.98,4.74YR,3.89,2.54,10.60,D65/10°,SCI,,UV400,,8.58,8.77,8.61,8.26,8.03,7.80,7.65,7.49,7.39,7.31,7.30,7.36,7.54,7.83,8.27,9.01,10.25,11.73,13.32,14.82,15.84,16.25,16.26,16.16,15.99,15.80,15.64,15.53,15.39,15.27,15.15 AA0775 | No 70 | Brick Red - Matt | GU 3.1,117,83,78,-9088178,38.90,13.38,8.32,5.66R,3.88,3.10,10.60,D65/10°,SCE,,UV400,,9.24,9.03,8.77,8.44,8.25,8.01,7.84,7.65,7.52,7.43,7.44,7.47,7.62,7.83,8.20,8.86,10.29,11.72,13.27,14.78,15.81,16.17,16.18,16.10,15.94,15.76,15.56,15.34,15.23,15.08,14.94 DB0071 | No 71 | Oak - Satin | GU 19.7,208,182,144,-3098992,75.58,3.53,22.57,10.06YR,7.59,3.41,49.20,D65/10°,SCI,,UV400,,22.46,25.15,26.28,27.71,29.93,31.65,32.24,32.56,33.04,34.03,35.88,38.50,41.82,45.76,49.83,53.10,55.71,56.77,57.08,56.98,56.71,56.42,56.00,55.72,55.42,55.14,54.93,54.90,54.83,54.83,54.89 DB0071 | No 71 | Oak - Satin | GU 19.7,205,179,141,-3296371,74.60,3.64,22.81,10.06YR,7.49,3.43,47.64,D65/10°,SCE,,UV400,,21.71,24.05,25.04,26.49,28.63,30.36,30.90,31.19,31.64,32.60,34.41,37.00,40.32,44.22,48.23,51.48,54.05,55.14,55.48,55.39,55.15,54.81,54.40,54.07,53.80,53.52,53.26,53.11,53.03,53.06,53.11 DB0072 | No 72 | Khaki Drill - Matt | GU 6.8,136,125,109,-7832211,53.12,1.23,10.47,10.06YR,5.26,2.46,21.16,D65/10°,SCI,,UV400,,12.93,13.83,14.20,14.74,15.71,16.43,16.61,16.67,16.75,17.05,17.69,18.51,19.37,20.27,21.38,22.27,22.68,22.93,23.32,23.60,23.51,23.04,22.45,22.28,22.32,22.54,22.82,23.14,23.36,23.52,23.60 DB0072 | No 72 | Khaki Drill - Matt | GU 6.8,135,124,108,-7898004,52.75,1.40,10.22,7.73YR,5.22,1.16,20.81,D65/10°,SCE,,UV400,,13.17,13.72,14.02,14.63,15.57,16.29,16.42,16.42,16.54,16.80,17.41,18.21,19.05,19.91,20.91,21.80,22.31,22.59,22.96,23.26,23.20,22.74,22.18,21.94,22.03,22.24,22.48,22.68,22.88,23.04,23.18 AA0802 | No 73 | Wine - Matt | GU 1.3,126,66,63,-8502721,35.52,25.64,13.38,6.18R,3.56,5.70,8.76,D65/10°,SCI,,UV400,,5.21,5.52,5.56,5.49,5.42,5.35,5.31,5.28,5.26,5.23,5.24,5.22,5.27,5.43,5.59,5.83,6.03,6.67,8.11,11.64,16.45,20.34,22.61,23.83,24.42,24.89,25.40,25.93,26.47,26.99,27.53 AA0802 | No 73 | Wine - Matt | GU 1.3,126,67,65,-8502463,35.79,25.34,12.39,7.06R,3.58,5.22,8.90,D65/10°,SCE,,UV400,,5.95,5.95,5.90,5.81,5.77,5.68,5.64,5.55,5.52,5.47,5.47,5.44,5.48,5.54,5.65,5.83,6.26,6.90,8.27,11.73,16.52,20.37,22.63,23.79,24.41,24.86,25.32,25.75,26.24,26.77,27.31 AA0816 | No 74 | Linen - Matt | GU 7.9,219,182,114,-2378126,75.99,4.88,39.32,2.03Y,7.67,6.02,49.87,D65/10°,SCI,,UV400,,19.28,20.52,20.57,20.14,19.84,19.93,20.18,20.65,22.14,26.08,33.21,40.42,45.06,47.85,49.82,51.80,54.51,57.14,59.51,61.24,62.31,62.92,63.14,63.29,63.32,63.29,63.25,63.24,63.17,63.17,63.22 AA0816 | No 74 | Linen - Matt | GU 7.9,218,180,113,-2444175,75.45,5.01,39.33,2.03Y,7.61,6.02,48.99,D65/10°,SCE,,UV400,,19.16,20.05,20.02,19.60,19.38,19.49,19.72,20.14,21.60,25.46,32.44,39.56,44.21,46.94,48.89,50.84,53.50,56.18,58.56,60.33,61.41,61.97,62.23,62.33,62.42,62.39,62.32,62.19,62.09,62.10,62.11 AA0833 | No 75 | Bronze Green - Matt | GU 2.0,70,74,66,-12170686,31.14,-3.14,4.05,2.09G,3.09,1.15,6.71,D65/10°,SCI,,UV400,,5.01,5.33,5.45,5.51,5.61,5.68,5.83,5.98,6.12,6.17,6.23,6.30,6.42,6.59,6.86,7.23,7.58,8.06,7.91,7.05,6.09,5.57,5.31,5.22,5.16,5.15,5.28,5.48,5.81,6.12,6.35 AA0833 | No 75 | Bronze Green - Matt | GU 2.0,71,75,68,-12104892,31.44,-2.86,3.35,2.09G,3.12,1.10,6.84,D65/10°,SCE,,UV400,,5.65,5.70,5.74,5.80,5.91,5.98,6.11,6.21,6.34,6.38,6.44,6.50,6.58,6.69,6.86,7.17,7.75,8.21,8.04,7.19,6.27,5.70,5.44,5.36,5.28,5.25,5.35,5.50,5.81,6.06,6.31 AA0847 | No 76 | Uniform Green - Matt | GU 2.1,69,95,80,-12230832,38.19,-13.39,5.58,4.40G,3.77,2.67,10.20,D65/10°,SCI,,UV400,,5.95,6.56,6.89,7.25,7.84,8.35,8.92,9.45,9.86,10.15,10.50,10.93,11.52,12.08,12.35,12.40,11.89,11.25,9.98,8.30,6.88,6.11,5.74,5.60,5.49,5.43,5.54,5.76,6.13,6.53,6.85 AA0847 | No 76 | Uniform Green - Matt | GU 2.1,70,95,81,-12165295,38.32,-12.80,4.91,5.08G,3.78,2.85,10.27,D65/10°,SCE,,UV400,,6.79,6.98,7.19,7.58,8.14,8.62,9.18,9.65,10.02,10.30,10.64,11.04,11.59,12.07,12.28,12.26,11.96,11.33,10.08,8.44,7.07,6.29,5.90,5.77,5.64,5.56,5.64,5.81,6.16,6.51,6.88 AA0850 | No 77 | Navy Blue - Matt | GU 1.7,61,74,79,-12760497,30.71,-3.78,-4.46,10.10BG,3.00,2.69,6.53,D65/10°,SCI,,UV400,,5.97,6.53,6.82,7.14,7.66,7.95,8.04,7.95,7.89,7.81,7.77,7.65,7.44,7.18,6.89,6.57,5.87,5.65,5.56,5.55,5.51,5.53,5.57,5.72,5.84,5.96,6.04,5.98,5.92,5.84,5.90 AA0850 | No 77 | Navy Blue - Matt | GU 1.7,63,75,80,-12629168,31.16,-3.43,-4.87,2.49B,3.05,1.60,6.72,D65/10°,SCE,,UV400,,6.73,6.99,7.16,7.48,8.01,8.30,8.33,8.23,8.18,8.07,8.03,7.90,7.66,7.32,6.97,6.58,6.10,5.87,5.77,5.73,5.73,5.73,5.78,5.93,6.07,6.16,6.20,6.07,5.96,5.85,5.93 AB0078 | No 78 | Cockpit Green - Matt | GU 4.1,106,117,99,-9800349,48.04,-7.89,8.34,10.02GY,4.75,2.23,16.83,D65/10°,SCI,,UV400,,9.54,10.39,10.86,11.56,12.66,13.57,14.05,14.36,14.59,14.95,15.53,16.25,17.19,18.21,18.90,18.97,18.61,18.88,18.55,17.02,15.02,13.48,12.61,12.22,11.87,11.68,11.86,12.43,13.19,14.01,14.71 AB0078 | No 78 | Cockpit Green - Matt | GU 4.1,105,116,99,-9866141,47.87,-7.66,8.02,10.02GY,4.73,2.17,16.69,D65/10°,SCE,,UV400,,10.12,10.59,10.95,11.66,12.71,13.60,14.03,14.25,14.51,14.86,15.46,16.14,17.07,18.06,18.66,18.67,18.46,18.71,18.40,16.92,14.96,13.41,12.56,12.16,11.87,11.66,11.80,12.26,13.04,13.80,14.48 AA0878 | No 79 | Blue Grey - Matt | GU 4.3,82,88,88,-11380648,37.02,-1.94,-1.19,2.13BG,3.65,1.15,9.55,D65/10°,SCI,,UV400,,9.10,9.62,9.78,9.82,10.01,10.05,10.00,9.90,9.84,9.79,9.81,9.85,9.90,9.95,9.97,9.94,9.53,9.38,9.21,9.06,8.96,8.88,8.77,8.75,8.68,8.64,8.61,8.54,8.45,8.39,8.30 AA0878 | No 79 | Blue Grey - Matt | GU 4.3,82,87,89,-11380903,36.88,-1.70,-1.56,4.03BG,3.63,2.51,9.47,D65/10°,SCE,,UV400,,9.55,9.76,9.82,9.88,10.07,10.10,10.04,9.89,9.83,9.76,9.80,9.81,9.85,9.82,9.77,9.70,9.49,9.33,9.15,8.99,8.92,8.83,8.73,8.71,8.66,8.60,8.52,8.38,8.31,8.18,8.13 DB0080 | No 80 | Grass Green - Matt | GU 3.6,89,96,58,-10919878,39.26,-9.54,20.69,5.24GY,3.91,3.63,10.81,D65/10°,SCI,,UV400,,4.05,4.25,4.41,4.55,4.71,4.81,4.92,5.22,5.83,7.14,9.84,12.42,12.77,12.37,12.29,12.28,11.53,11.39,11.60,11.45,10.56,9.50,8.76,8.57,8.56,8.73,9.14,9.84,10.74,11.76,12.58 DB0080 | No 80 | Grass Green - Matt | GU 3.6,89,95,59,-10920133,39.17,-9.15,19.80,5.28GY,3.90,3.51,10.76,D65/10°,SCE,,UV400,,4.51,4.50,4.56,4.70,4.91,4.97,5.10,5.35,5.95,7.23,9.91,12.34,12.70,12.24,12.11,12.01,11.49,11.36,11.56,11.39,10.56,9.51,8.80,8.61,8.62,8.77,9.14,9.75,10.64,11.60,12.46 DB0081 | No 81 | Pale Yellow - Matt | GU 1.9,196,164,92,-3890084,69.08,2.60,41.46,5.01Y,6.95,6.00,39.46,D65/10°,SCI,,UV400,,12.46,13.13,13.16,13.06,13.34,13.68,13.86,14.35,16.15,19.70,24.61,29.12,33.03,37.07,41.08,44.37,46.87,47.94,48.27,48.16,47.91,47.66,47.29,47.06,46.81,46.64,46.60,46.74,46.91,47.16,47.38 DB0081 | No 81 | Pale Yellow - Matt | GU 1.9,196,164,93,-3890083,68.90,2.78,40.78,5.01Y,6.93,6.02,39.21,D65/10°,SCE,,UV400,,13.01,13.36,13.31,13.29,13.52,13.89,14.00,14.42,16.27,19.77,24.57,28.98,32.79,36.66,40.63,43.91,46.53,47.66,48.01,47.92,47.69,47.41,47.05,46.80,46.59,46.40,46.29,46.33,46.44,46.65,46.92 AA0905 | No 82 | Orange Lining - Matt | GU 4.1,179,88,60,-5023684,48.15,34.76,32.65,10.06R,4.86,8.94,16.91,D65/10°,SCI,,UV400,,6.26,6.39,6.28,6.05,5.93,5.80,5.77,5.79,5.83,5.87,5.99,6.19,6.47,6.87,7.70,9.43,13.88,19.37,25.47,32.13,37.22,39.74,40.44,40.59,40.43,40.23,40.06,39.94,39.85,39.70,39.56 AA0905 | No 82 | Orange Lining - Matt | GU 4.1,177,87,62,-5155010,47.95,34.57,31.62,10.07R,4.84,8.80,16.75,D65/10°,SCE,,UV400,,6.95,6.65,6.46,6.21,6.11,5.98,5.93,5.90,5.93,5.94,6.08,6.27,6.51,6.83,7.59,9.25,13.74,19.17,25.23,31.72,36.76,39.23,39.96,40.07,39.98,39.74,39.52,39.28,39.13,38.99,38.94 AA0919 | No 83 | Ochre - Matt | GU 5.3,148,128,91,-7045029,54.82,1.93,23.20,3.48Y,5.47,3.87,22.76,D65/10°,SCI,,UV400,,8.56,9.17,9.60,10.34,11.54,12.40,12.72,12.87,13.18,13.76,14.86,16.52,18.70,21.31,23.97,26.01,26.99,27.14,26.95,26.65,26.25,25.83,25.51,25.49,25.52,25.58,25.58,25.43,25.16,24.88,24.82 AA0919 | No 83 | Ochre - Matt | GU 5.3,147,127,90,-7110822,54.43,2.11,22.88,3.37Y,5.43,3.88,22.39,D65/10°,SCE,,UV400,,8.92,9.22,9.59,10.29,11.44,12.30,12.56,12.65,12.91,13.48,14.62,16.24,18.40,20.93,23.50,25.44,26.59,26.75,26.55,26.24,25.87,25.47,25.18,25.13,25.20,25.24,25.20,24.98,24.69,24.45,24.40 AA0922 | No 84 | Mid Stone - Matt | GU 4.1,132,120,96,-8095648,51.11,0.85,14.63,5.02Y,5.08,2.14,19.37,D65/10°,SCI,,UV400,,9.80,10.50,10.88,11.54,12.54,13.27,13.46,13.51,13.67,14.07,14.82,15.89,17.23,18.69,20.11,21.10,21.65,21.88,21.88,21.71,21.51,21.29,21.01,20.85,20.60,20.39,20.19,20.06,19.94,19.83,19.72 AA0922 | No 84 | Mid Stone - Matt | GU 4.1,132,119,96,-8095904,50.90,1.05,14.34,5.02Y,5.06,2.11,19.18,D65/10°,SCE,,UV400,,10.27,10.64,10.94,11.59,12.56,13.26,13.40,13.38,13.53,13.90,14.69,15.74,17.07,18.51,19.82,20.79,21.44,21.69,21.69,21.57,21.42,21.16,20.88,20.67,20.44,20.23,20.06,19.85,19.74,19.58,19.46 DB0085 | No 85 | Black - Satin | GU 19.5,59,60,60,-12895172,25.38,-0.06,-0.54,10.18G,2.51,3.55,4.54,D65/10°,SCI,,UV400,,4.57,4.71,4.74,4.70,4.68,4.64,4.60,4.59,4.60,4.56,4.56,4.52,4.53,4.58,4.58,4.61,4.51,4.51,4.48,4.51,4.48,4.51,4.47,4.49,4.49,4.48,4.48,4.45,4.46,4.47,4.43 DB0085 | No 85 | Black - Satin | GU 19.5,49,50,52,-13553100,20.85,0.07,-1.50,2.19BG,2.06,0.86,3.20,D65/10°,SCE,,UV400,,3.65,3.58,3.54,3.52,3.51,3.45,3.41,3.32,3.35,3.30,3.28,3.23,3.25,3.22,3.19,3.16,3.20,3.20,3.16,3.14,3.16,3.14,3.11,3.13,3.10,3.06,3.07,3.00,2.99,2.97,2.94 DB0086 | No 86 | Light Olive - Matt | GU 9.2,91,91,76,-10790068,38.55,-3.11,8.73,5.41GY,3.82,2.13,10.40,D65/10°,SCI,,UV400,,8.09,8.18,7.98,7.62,7.47,7.42,7.42,7.58,8.14,9.11,10.22,10.74,10.78,10.77,10.83,10.95,10.87,10.83,10.71,10.58,10.49,10.41,10.28,10.22,10.08,9.99,9.92,9.85,9.79,9.74,9.64 DB0086 | No 86 | Light Olive - Matt | GU 9.2,89,90,76,-10921396,37.83,-2.94,7.94,7.07GY,3.75,1.20,9.99,D65/10°,SCE,,UV400,,8.47,8.17,7.88,7.54,7.40,7.33,7.30,7.39,7.91,8.84,9.92,10.39,10.41,10.32,10.31,10.38,10.46,10.43,10.29,10.15,10.08,9.98,9.85,9.78,9.67,9.56,9.46,9.31,9.25,9.15,9.08 AA0967 | No 87 | Steel Grey - Matt | GU 6.9,116,135,132,-9140348,54.89,-7.25,-0.87,5.03BG,5.38,2.49,22.83,D65/10°,SCI,,UV400,,18.51,20.77,21.73,22.27,22.82,23.37,23.85,24.32,24.59,24.68,24.67,24.61,24.52,24.41,24.28,24.20,23.46,23.04,22.32,21.18,19.82,18.67,17.86,17.40,16.95,16.56,16.51,16.85,17.35,17.91,18.32 AA0967 | No 87 | Steel Grey - Matt | GU 6.9,115,133,131,-9206397,54.34,-7.16,-0.86,5.04BG,5.33,2.50,22.30,D65/10°,SCE,,UV400,,18.36,20.31,21.15,21.72,22.29,22.86,23.30,23.75,24.02,24.11,24.13,24.07,23.97,23.81,23.65,23.53,22.95,22.56,21.86,20.77,19.43,18.20,17.42,16.99,16.54,16.18,16.10,16.32,16.84,17.35,17.77 AA0970 | No 88 | Deck Green - Matt | GU 2.0,63,96,86,-12623786,38.19,-14.32,1.69,10.08G,3.75,2.99,10.19,D65/10°,SCI,,UV400,,6.96,7.66,7.98,8.38,8.98,9.53,10.12,10.69,11.13,11.43,11.75,12.08,12.34,12.50,12.42,12.04,10.89,9.95,8.83,7.65,6.65,6.08,5.77,5.66,5.56,5.49,5.61,5.77,6.07,6.34,6.51 AA0970 | No 88 | Deck Green - Matt | GU 2.0,64,96,87,-12558249,38.33,-13.67,1.21,10.08G,3.76,2.92,10.27,D65/10°,SCE,,UV400,,7.77,8.02,8.27,8.68,9.27,9.78,10.34,10.83,11.23,11.53,11.87,12.14,12.41,12.49,12.34,11.92,11.00,10.07,8.97,7.81,6.86,6.26,5.95,5.83,5.71,5.65,5.71,5.83,6.10,6.33,6.54 DB0089 | No 89 | Middle Blue - Matt | GU 5.4,90,139,155,-10843237,55.32,-12.01,-13.88,7.04B,5.35,4.03,23.24,D65/10°,SCI,,UV400,,25.65,29.80,30.97,31.37,31.85,32.42,32.70,32.81,32.63,32.24,31.61,30.71,29.41,27.75,25.76,23.59,20.36,18.37,17.10,16.28,15.58,15.06,14.97,15.40,15.98,16.49,16.81,16.81,16.43,16.04,16.04 DB0089 | No 89 | Middle Blue - Matt | GU 5.4,90,138,154,-10843494,54.97,-11.91,-13.78,7.04B,5.32,4.03,22.90,D65/10°,SCE,,UV400,,25.63,29.37,30.44,30.87,31.37,31.98,32.19,32.28,32.12,31.76,31.19,30.29,29.03,27.34,25.32,23.13,20.10,18.10,16.88,16.09,15.42,14.86,14.78,15.19,15.79,16.29,16.58,16.49,16.10,15.69,15.68 AB0090 | No 90 | Beige Green - Matt | GU 9.5,187,195,163,-4471901,77.53,-8.09,14.95,5.04GY,7.75,2.37,52.42,D65/10°,SCI,,UV400,,28.99,33.55,34.92,35.93,37.69,39.19,40.06,41.13,42.13,43.21,45.30,48.62,52.62,56.42,59.27,60.40,58.80,56.67,54.42,51.97,49.27,47.19,46.02,45.52,45.19,45.49,46.42,47.41,47.81,47.63,46.85 AB0090 | No 90 | Beige Green - Matt | GU 9.5,186,193,162,-4537950,77.03,-8.03,14.92,5.03GY,7.70,2.36,51.57,D65/10°,SCE,,UV400,,28.65,32.91,34.18,35.23,37.05,38.57,39.38,40.41,41.42,42.50,44.59,47.91,51.75,55.47,58.25,59.36,57.83,55.76,53.55,51.17,48.59,46.47,45.30,44.77,44.48,44.74,45.62,46.51,46.86,46.65,45.84 AB0091 | No 91 | Black Green - Matt | GU 1.6,81,89,87,-11445929,37.34,-3.64,0.19,10.10G,3.68,3.04,9.72,D65/10°,SCI,,UV400,,9.39,9.94,9.94,9.68,9.57,9.52,9.51,9.55,9.75,10.08,10.34,10.38,10.32,10.27,10.24,10.20,9.81,9.67,9.44,9.16,8.89,8.67,8.46,8.40,8.26,8.19,8.21,8.29,8.39,8.47,8.46 AB0091 | No 91 | Black Green - Matt | GU 1.6,82,90,88,-11380136,37.56,-3.28,-0.22,10.10G,3.70,3.13,9.84,D65/10°,SCE,,UV400,,10.06,10.27,10.18,9.95,9.86,9.78,9.77,9.76,9.95,10.25,10.51,10.52,10.46,10.34,10.23,10.12,9.97,9.82,9.59,9.30,9.06,8.84,8.66,8.58,8.47,8.37,8.36,8.35,8.46,8.49,8.49 DB0093 | No 93 | Desert Yellow - Matt | GU 4.5,166,134,102,-5863834,58.42,7.59,21.84,9.52YR,5.83,3.80,26.40,D65/10°,SCI,,UV400,,12.97,13.72,13.89,14.07,14.69,15.12,15.27,15.49,15.76,16.19,17.14,18.62,20.40,22.42,24.82,27.39,30.21,32.03,33.03,33.40,33.38,33.29,33.01,32.82,32.57,32.39,32.24,32.17,32.12,32.05,32.07 DB0093 | No 93 | Desert Yellow - Matt | GU 4.5,165,134,102,-5929370,58.13,7.61,21.40,9.43YR,5.80,3.77,26.10,D65/10°,SCE,,UV400,,13.35,13.75,13.86,14.11,14.67,15.15,15.26,15.40,15.70,16.09,17.02,18.47,20.22,22.16,24.47,26.95,29.90,31.66,32.61,32.96,32.99,32.88,32.64,32.43,32.26,32.05,31.90,31.71,31.68,31.62,31.63 AB0094 | No 94 | Brown Yellow - Matt | GU 2.2,173,136,98,-5404574,59.38,9.10,25.69,10.04YR,5.93,4.30,27.44,D65/10°,SCI,,UV400,,10.36,11.28,11.74,12.41,13.59,14.47,14.81,14.99,15.25,15.81,16.86,18.45,20.51,23.00,25.70,28.20,30.93,33.09,34.75,35.67,36.10,36.25,36.09,35.97,35.77,35.64,35.62,35.70,35.85,36.01,36.25 AB0094 | No 94 | Brown Yellow - Matt | GU 2.2,172,135,98,-5470366,59.19,9.03,25.08,10.03YR,5.91,4.21,27.24,D65/10°,SCE,,UV400,,10.98,11.54,11.90,12.61,13.71,14.61,14.92,15.02,15.30,15.84,16.90,18.44,20.45,22.85,25.47,27.89,30.74,32.81,34.38,35.33,35.77,35.87,35.75,35.59,35.47,35.33,35.30,35.30,35.49,35.65,35.92 DB0096 | No 96 | RAF Blue - Matt | GU 6.6,72,95,108,-12034196,39.02,-5.20,-10.16,10.09B,3.80,2.67,10.67,D65/10°,SCI,,UV400,,14.70,15.64,15.51,14.97,14.70,14.52,14.29,14.07,13.84,13.66,13.53,13.20,12.56,11.96,11.54,11.05,9.70,8.82,8.36,8.12,7.95,7.84,7.89,8.29,8.81,9.37,9.70,9.56,9.11,8.74,8.66 DB0096 | No 96 | RAF Blue - Matt | GU 6.6,71,93,107,-12100245,38.56,-4.92,-10.41,10.09B,3.75,2.69,10.41,D65/10°,SCE,,UV400,,14.73,15.50,15.36,14.81,14.49,14.34,14.06,13.76,13.52,13.33,13.24,12.89,12.28,11.63,11.16,10.62,9.51,8.66,8.17,7.93,7.78,7.66,7.70,8.08,8.61,9.13,9.42,9.22,8.75,8.34,8.32 DB0098 | No 98 | Chocolate - Matt | GU 3.0,90,78,75,-10858933,34.60,4.09,3.86,10.12RP,3.43,3.28,8.30,D65/10°,SCI,,UV400,,6.16,6.65,6.83,7.00,7.29,7.41,7.40,7.32,7.29,7.25,7.25,7.29,7.45,7.67,7.78,7.83,7.86,8.67,9.50,9.87,9.89,9.80,9.64,9.58,9.44,9.38,9.36,9.33,9.29,9.24,9.11 DB0098 | No 98 | Chocolate - Matt | GU 3.0,90,79,76,-10858676,34.80,4.22,3.18,10.11RP,3.45,3.18,8.40,D65/10°,SCE,,UV400,,6.94,7.04,7.13,7.28,7.61,7.70,7.67,7.54,7.48,7.44,7.46,7.46,7.59,7.74,7.77,7.75,8.01,8.79,9.58,9.94,9.98,9.88,9.74,9.66,9.56,9.49,9.44,9.35,9.28,9.19,9.09 DB0099 | No 99 | Lemon - Matt | GU 8.5,243,194,37,-802267,80.75,4.19,76.68,5.04Y,8.23,11.22,58.01,D65/10°,SCI,,UV400,,8.75,8.44,8.21,7.88,7.68,7.60,7.67,7.95,9.19,12.98,22.89,39.59,54.06,61.53,64.84,66.48,66.59,67.44,70.13,73.59,75.89,76.03,74.87,75.36,78.07,81.90,85.21,87.38,88.32,88.93,89.43 DB0099 | No 99 | Lemon - Matt | GU 8.5,241,192,36,-933852,80.21,4.33,76.30,5.04Y,8.17,11.15,57.06,D65/10°,SCE,,UV400,,9.02,8.39,8.08,7.77,7.58,7.48,7.53,7.76,8.96,12.58,22.41,38.76,53.12,60.46,63.73,65.27,65.49,66.39,69.10,72.53,74.83,74.95,73.81,74.25,77.06,80.81,83.35,85.00,85.70,86.35,86.82 AA1105 | No 100 | Red Brown - Matt | GU 3.8,150,74,54,-6927818,40.74,30.26,26.22,10.05R,4.11,7.58,11.70,D65/10°,SCI,,UV400,,4.22,4.37,4.42,4.41,4.47,4.51,4.61,4.72,4.84,4.94,5.07,5.17,5.33,5.64,6.10,6.90,8.66,11.23,14.83,20.11,25.68,28.95,29.92,29.93,29.50,28.97,28.46,27.85,27.04,26.46,26.36 AA1105 | No 100 | Red Brown - Matt | GU 3.8,149,74,55,-6993353,40.63,30.12,25.29,10.06R,4.10,7.44,11.64,D65/10°,SCE,,UV400,,4.71,4.60,4.58,4.59,4.64,4.67,4.75,4.81,4.94,5.01,5.16,5.25,5.40,5.61,6.00,6.75,8.69,11.17,14.72,19.99,25.45,28.65,29.62,29.61,29.23,28.68,28.14,27.46,26.66,26.09,26.04 AA1119 | No 101 | Mid Green - Matt | GU 2.9,69,109,79,-12227249,42.62,-21.40,12.69,2.07G,4.21,4.48,12.90,D65/10°,SCI,,UV400,,7.13,7.59,7.77,7.82,7.94,8.11,8.45,8.86,9.59,11.00,13.35,15.70,17.30,17.92,17.61,16.64,14.54,12.84,11.02,9.21,7.74,6.89,6.42,6.27,6.08,5.97,6.04,6.26,6.60,7.02,7.33 AA1119 | No 101 | Mid Green - Matt | GU 2.9,69,109,79,-12227249,42.53,-20.79,12.00,2.06G,4.20,4.45,12.85,D65/10°,SCE,,UV400,,7.80,7.88,7.96,8.01,8.15,8.29,8.61,9.00,9.68,11.00,13.30,15.59,17.20,17.79,17.40,16.36,14.45,12.78,11.01,9.24,7.84,6.98,6.53,6.36,6.18,6.06,6.09,6.23,6.56,6.92,7.27 DB0102 | No 102 | Army Green - Matt | GU 4.6,93,95,79,-10657969,39.85,-3.89,9.09,5.12GY,3.96,2.22,11.16,D65/10°,SCI,,UV400,,8.04,8.27,8.16,7.89,7.88,7.92,8.16,8.67,9.09,9.21,9.54,10.22,11.12,11.81,11.75,11.35,11.38,13.17,14.53,13.36,11.09,9.54,8.74,8.42,8.11,7.95,8.08,8.54,9.24,10.03,10.66 DB0102 | No 102 | Army Green - Matt | GU 4.6,93,94,79,-10658225,39.70,-3.62,8.43,7.04GY,3.94,1.46,11.07,D65/10°,SCE,,UV400,,8.66,8.48,8.30,8.03,8.03,8.06,8.27,8.72,9.14,9.24,9.57,10.21,11.06,11.66,11.55,11.07,11.30,13.04,14.40,13.24,11.03,9.50,8.73,8.41,8.12,7.94,8.05,8.42,9.10,9.85,10.52 DB0103 | No 103 | Cream - Matt | GU 6.1,200,170,127,-3626369,71.31,4.99,26.04,2.01Y,7.16,4.01,42.64,D65/10°,SCI,,UV400,,17.45,19.19,20.04,21.27,23.19,24.68,25.17,25.43,25.83,26.75,28.45,31.03,34.43,38.47,42.78,46.49,49.49,50.84,51.32,51.22,50.93,50.61,50.13,49.82,49.48,49.18,48.98,48.96,49.00,49.10,49.23 DB0103 | No 103 | Cream - Matt | GU 6.1,199,169,127,-3692161,70.97,5.10,25.84,2.01Y,7.12,4.01,42.14,D65/10°,SCE,,UV400,,17.64,19.09,19.91,21.08,22.97,24.49,24.93,25.16,25.55,26.45,28.15,30.68,33.94,37.91,42.16,45.88,48.98,50.31,50.77,50.69,50.43,50.08,49.64,49.31,49.02,48.70,48.44,48.32,48.28,48.34,48.49 AB0104 | No 104 | Oxford Blue - Matt | GU 1.4,68,77,88,-12300968,32.47,-0.70,-7.98,5.06PB,3.17,2.43,7.30,D65/10°,SCI,,UV400,,9.13,9.99,10.04,9.93,9.94,9.77,9.56,9.30,8.99,8.72,8.43,8.12,7.86,7.68,7.49,7.19,6.50,6.31,6.36,6.70,6.79,6.61,6.41,6.34,6.23,6.25,6.39,6.45,6.41,6.29,6.11 AB0104 | No 104 | Oxford Blue - Matt | GU 1.4,69,78,89,-12235175,32.87,-0.43,-8.13,5.06PB,3.21,2.42,7.48,D65/10°,SCE,,UV400,,9.83,10.31,10.29,10.21,10.20,10.04,9.84,9.54,9.23,8.93,8.68,8.34,8.06,7.82,7.53,7.19,6.75,6.54,6.56,6.91,7.02,6.83,6.64,6.55,6.48,6.48,6.57,6.56,6.48,6.32,6.13 AA1167 | No 105 | Marine Green - Matt | GU 7.1,82,88,67,-11380669,36.50,-6.67,11.56,5.04GY,3.63,2.23,9.27,D65/10°,SCI,,UV400,,5.74,6.03,6.06,5.98,5.96,5.91,5.92,5.99,6.26,7.01,8.68,10.30,10.74,10.62,10.43,10.24,9.72,9.51,9.24,8.96,8.72,8.51,8.30,8.23,8.07,7.98,7.93,7.92,7.96,7.96,7.90 AA1167 | No 105 | Marine Green - Matt | GU 7.1,81,87,67,-11446461,36.11,-6.39,11.00,5.03GY,3.59,2.18,9.06,D65/10°,SCE,,UV400,,6.13,6.07,6.04,5.97,5.95,5.90,5.90,5.91,6.18,6.90,8.57,10.11,10.52,10.35,10.09,9.85,9.54,9.32,9.03,8.77,8.56,8.35,8.16,8.07,7.94,7.83,7.76,7.66,7.67,7.64,7.61 DB0106 | No 106 | Ocean Grey - Matt | GU 4.4,100,104,106,-10196886,44.05,-1.28,-1.76,3.12BG,4.33,1.89,13.87,D65/10°,SCI,,UV400,,13.62,14.56,14.67,14.61,14.75,14.74,14.60,14.47,14.32,14.23,14.21,14.20,14.20,14.19,14.20,14.17,13.87,13.75,13.57,13.39,13.28,13.18,13.04,12.95,12.80,12.67,12.57,12.48,12.38,12.33,12.22 DB0106 | No 106 | Ocean Grey - Matt | GU 4.4,100,104,107,-10196885,43.86,-1.04,-2.09,5.13BG,4.31,3.50,13.74,D65/10°,SCE,,UV400,,13.96,14.62,14.71,14.72,14.76,14.79,14.60,14.37,14.24,14.11,14.11,14.09,14.08,14.04,13.98,13.87,13.76,13.64,13.46,13.29,13.22,13.08,12.96,12.85,12.72,12.58,12.44,12.27,12.21,12.11,12.05 DB0109 | No 109 | WWI Blue - Matt | GU 4.7,72,127,154,-12025958,50.80,-10.31,-20.04,10.04B,4.88,5.59,19.10,D65/10°,SCI,,UV400,,23.33,27.40,28.71,29.65,31.03,32.10,32.24,31.91,31.16,30.07,28.66,26.91,24.73,22.47,20.33,18.15,15.15,13.51,12.68,12.25,11.91,11.64,11.68,12.28,13.15,14.05,14.59,14.43,13.67,13.02,12.87 DB0109 | No 109 | WWI Blue - Matt | GU 4.7,72,126,153,-12026215,50.54,-10.19,-19.91,10.05B,4.86,5.55,18.88,D65/10°,SCE,,UV400,,23.51,27.11,28.25,29.29,30.62,31.72,31.82,31.48,30.77,29.70,28.36,26.62,24.48,22.19,19.99,17.81,15.02,13.39,12.56,12.15,11.84,11.56,11.61,12.17,13.07,13.94,14.42,14.16,13.44,12.76,12.66 DB0110 | No 110 | Natural Wood - Matt | GU 6.4,129,104,80,-8296368,46.17,6.17,17.60,2.12Y,4.62,0.55,15.39,D65/10°,SCI,,UV400,,7.29,7.82,8.01,8.30,8.85,9.14,9.19,9.21,9.34,9.58,10.10,10.86,11.74,12.86,14.37,16.14,17.96,18.91,19.23,19.34,19.27,19.09,18.87,18.83,18.81,18.81,18.80,18.74,18.63,18.57,18.54 DB0110 | No 110 | Natural Wood - Matt | GU 6.4,128,104,80,-8361904,45.83,6.34,16.93,2.11Y,4.58,0.70,15.14,D65/10°,SCE,,UV400,,7.85,7.97,8.09,8.37,8.91,9.16,9.22,9.19,9.29,9.51,10.04,10.74,11.56,12.58,14.02,15.72,17.69,18.58,18.93,19.06,19.03,18.80,18.57,18.52,18.52,18.54,18.51,18.38,18.27,18.15,18.09 DB0113 | No 113 | Rust - Matt | GU 4.9,118,80,74,-9023414,38.28,14.73,10.14,4.59YR,3.82,2.64,10.25,D65/10°,SCI,,UV400,,8.03,8.08,7.83,7.41,7.24,7.09,7.08,7.15,7.21,7.13,7.16,7.27,7.49,7.71,7.85,7.96,8.40,10.27,13.15,15.49,16.52,16.74,16.67,16.57,16.39,16.23,16.09,15.99,15.89,15.80,15.72 DB0113 | No 113 | Rust - Matt | GU 4.9,117,80,75,-9088949,38.15,14.74,9.37,4.54YR,3.81,2.59,10.17,D65/10°,SCE,,UV400,,8.64,8.31,7.97,7.60,7.41,7.26,7.22,7.25,7.28,7.18,7.22,7.32,7.48,7.65,7.70,7.74,8.40,10.21,13.01,15.34,16.36,16.55,16.48,16.38,16.24,16.08,15.90,15.70,15.60,15.47,15.39 AA1287 | No 116 | US Dark Green - Matt | GU 2.1,82,81,71,-11382457,34.48,-1.79,6.29,7.09GY,3.42,0.95,8.24,D65/10°,SCI,,UV400,,5.31,5.70,5.90,6.12,6.51,6.67,6.74,6.76,6.87,7.00,7.26,7.61,8.03,8.46,8.82,9.02,8.83,8.79,8.64,8.45,8.29,8.17,8.01,7.97,7.85,7.78,7.78,7.79,7.83,7.88,7.83 AA1287 | No 116 | US Dark Green - Matt | GU 2.1,83,82,72,-11316664,34.77,-1.49,5.55,8.75GY,3.45,1.91,8.38,D65/10°,SCE,,UV400,,6.00,6.09,6.20,6.46,6.84,7.00,7.05,7.02,7.11,7.22,7.49,7.82,8.20,8.56,8.83,9.01,9.00,8.94,8.77,8.59,8.47,8.33,8.19,8.13,8.04,7.96,7.92,7.84,7.88,7.86,7.87 DB0117 | No 117 | US Light Green - Matt | GU 3.5,86,86,65,-11119039,36.28,-4.17,12.11,2.03GY,3.62,1.70,9.16,D65/10°,SCI,,UV400,,5.92,6.01,5.91,5.70,5.67,5.67,5.81,6.11,6.38,6.47,6.87,7.84,9.13,10.12,10.45,10.32,9.97,10.56,10.99,10.38,9.11,8.11,7.54,7.38,7.26,7.27,7.49,7.92,8.51,9.13,9.66 DB0117 | No 117 | US Light Green - Matt | GU 3.5,86,86,67,-11119037,36.30,-3.84,11.25,3.16GY,3.62,1.93,9.17,D65/10°,SCE,,UV400,,6.56,6.33,6.12,5.93,5.90,5.88,6.02,6.27,6.54,6.59,7.00,7.94,9.17,10.07,10.32,10.12,9.99,10.56,10.97,10.37,9.16,8.17,7.62,7.44,7.35,7.33,7.50,7.84,8.43,9.02,9.56 DB0118 | No 118 | US Tan - Matt | GU 5.6,143,118,105,-7375255,51.86,7.63,10.83,7.49YR,5.15,1.77,20.02,D65/10°,SCI,,UV400,,14.62,15.39,15.32,15.11,15.08,14.97,14.78,14.65,14.61,14.75,15.10,15.53,15.90,16.52,17.86,19.86,22.32,23.70,24.31,24.56,24.58,24.50,24.34,24.25,24.07,23.92,23.81,23.71,23.60,23.45,23.34 DB0118 | No 118 | US Tan - Matt | GU 5.6,142,117,105,-7441047,51.54,7.79,10.54,7.02YR,5.12,1.58,19.74,D65/10°,SCE,,UV400,,14.72,15.36,15.27,15.07,15.00,14.90,14.65,14.45,14.41,14.52,14.91,15.28,15.66,16.25,17.51,19.43,22.04,23.40,23.99,24.23,24.31,24.22,24.07,23.93,23.79,23.63,23.49,23.31,23.18,23.04,22.93 AA1314 | No 119 | Light Earth - Matt | GU 4.5,148,117,93,-7047843,51.73,8.75,17.48,5.38YR,5.15,3.41,19.90,D65/10°,SCI,,UV400,,9.47,10.19,10.54,11.10,11.92,12.49,12.68,12.77,12.96,13.29,13.90,14.75,15.74,16.83,18.06,19.26,20.84,22.66,24.36,25.63,26.32,26.60,26.57,26.53,26.36,26.26,26.19,26.12,26.09,26.04,26.03 AA1314 | No 119 | Light Earth - Matt | GU 4.5,147,116,93,-7113635,51.39,8.88,17.19,5.07YR,5.12,3.34,19.61,D65/10°,SCE,,UV400,,9.91,10.25,10.50,11.05,11.85,12.40,12.56,12.58,12.74,13.06,13.70,14.51,15.50,16.57,17.70,18.84,20.57,22.37,24.03,25.26,25.98,26.26,26.26,26.16,26.06,25.94,25.82,25.68,25.62,25.60,25.61 AA1328 | No 120 | Light Green - Matt | GU 3.1,106,124,98,-9798558,50.20,-11.95,12.14,9.98GY,4.97,3.18,18.58,D65/10°,SCI,,UV400,,9.44,10.24,10.65,11.39,12.51,13.42,13.94,14.35,14.76,15.35,16.32,17.67,19.30,20.97,22.40,23.03,22.39,21.27,19.55,17.33,15.11,13.53,12.60,12.12,11.64,11.31,11.32,11.74,12.40,13.17,13.82 AA1328 | No 120 | Light Green - Matt | GU 3.1,106,124,98,-9798558,50.07,-11.66,11.79,9.95GY,4.96,3.08,18.47,D65/10°,SCE,,UV400,,10.08,10.47,10.79,11.53,12.57,13.48,13.96,14.30,14.73,15.29,16.28,17.60,19.19,20.81,22.12,22.73,22.26,21.16,19.45,17.27,15.11,13.51,12.61,12.11,11.69,11.35,11.33,11.66,12.31,13.05,13.71 AA1331 | No 121 | Pale Stone - Matt | GU 7.0,194,174,149,-4018539,72.35,3.33,15.61,2.03Y,7.22,1.29,44.18,D65/10°,SCI,,UV400,,22.62,26.11,27.53,29.04,30.96,32.45,33.14,33.68,34.23,35.06,36.34,37.94,39.68,41.51,43.50,45.36,46.91,48.28,49.30,49.93,50.18,50.21,50.16,50.41,50.70,50.92,50.97,50.90,50.57,50.28,50.22 AA1331 | No 121 | Pale Stone - Matt | GU 7.0,193,172,147,-4084589,71.75,3.50,15.78,2.04Y,7.16,1.21,43.29,D65/10°,SCE,,UV400,,22.39,25.42,26.69,28.27,30.15,31.64,32.29,32.79,33.34,34.15,35.45,37.03,38.75,40.59,42.48,44.37,46.05,47.44,48.49,49.11,49.38,49.40,49.37,49.58,49.89,50.09,50.10,49.93,49.55,49.21,49.16 DB0123 | No 123 | Extra Dark Sea Grey - Satin | GU 18.4,90,95,99,-10854557,40.23,-1.11,-3.13,7.04BG,3.96,1.35,11.39,D65/10°,SCI,,UV400,,12.22,12.87,12.90,12.74,12.72,12.63,12.47,12.29,12.14,11.99,11.89,11.80,11.75,11.68,11.62,11.54,11.29,11.19,11.01,10.87,10.75,10.68,10.53,10.46,10.32,10.23,10.14,10.05,9.96,9.93,9.80 DB0123 | No 123 | Extra Dark Sea Grey - Satin | GU 18.4,86,92,97,-11117471,38.93,-1.04,-3.80,9.26BG,3.83,3.17,10.62,D65/10°,SCE,,UV400,,12.09,12.40,12.34,12.25,12.17,12.08,11.88,11.63,11.47,11.31,11.23,11.11,11.02,10.90,10.76,10.62,10.54,10.41,10.23,10.07,9.99,9.87,9.75,9.65,9.53,9.42,9.30,9.12,9.05,8.91,8.85 AA1376 | No 125 | US Dark Grey - Satin | GU 11.4,92,99,104,-10722456,41.89,-1.62,-3.60,7.46BG,4.11,1.52,12.43,D65/10°,SCI,,UV400,,13.26,14.04,14.13,14.01,13.99,13.91,13.78,13.64,13.51,13.37,13.21,13.08,12.93,12.82,12.72,12.62,12.23,12.08,11.89,11.71,11.59,11.48,11.31,11.24,11.10,10.99,10.87,10.77,10.65,10.56,10.46 AA1376 | No 125 | US Dark Grey - Satin | GU 11.4,90,96,102,-10854298,40.66,-1.49,-3.85,10.10BG,3.99,3.07,11.65,D65/10°,SCE,,UV400,,12.85,13.32,13.35,13.34,13.26,13.20,13.04,12.86,12.72,12.56,12.47,12.31,12.17,12.01,11.84,11.71,11.49,11.33,11.15,10.98,10.88,10.74,10.60,10.52,10.40,10.28,10.15,9.97,9.89,9.75,9.66 AA1393 | No 126 | US Medium Grey - Satin | GU 37.9,129,134,135,-8288633,55.76,-1.94,-1.01,3.52BG,5.47,2.27,23.67,D65/10°,SCI,,UV400,,20.40,22.83,23.57,23.92,24.29,24.54,24.51,24.47,24.42,24.35,24.32,24.33,24.30,24.25,24.16,24.04,23.68,23.45,23.20,22.98,22.77,22.57,22.33,22.24,22.04,21.85,21.68,21.48,21.29,21.06,20.87 AA1393 | No 126 | US Medium Grey - Satin | GU 37.9,122,127,128,-8749184,53.02,-1.97,-0.90,2.72BG,5.20,1.64,21.06,D65/10°,SCE,,UV400,,17.93,20.06,20.75,21.18,21.57,21.82,21.82,21.77,21.73,21.67,21.67,21.67,21.65,21.58,21.49,21.35,21.10,20.87,20.65,20.44,20.27,20.06,19.84,19.70,19.52,19.34,19.18,18.92,18.74,18.51,18.32 DB0127 | No 127 | US Ghost Grey - Satin | GU 19.7,165,177,183,-5918281,71.56,-2.72,-4.89,2.02PB,7.06,1.87,43.01,D65/10°,SCI,,UV400,,37.45,46.18,48.25,48.04,47.82,47.62,47.28,46.95,46.59,46.28,45.95,45.55,45.12,44.65,44.12,43.47,42.31,41.41,40.72,40.21,39.79,39.54,39.35,39.47,39.61,39.68,39.59,39.33,38.97,38.47,38.24 DB0127 | No 127 | US Ghost Grey - Satin | GU 19.7,162,174,181,-6115659,70.51,-2.73,-5.13,2.02PB,6.95,1.89,41.48,D65/10°,SCE,,UV400,,36.37,44.75,46.71,46.61,46.46,46.25,45.88,45.54,45.15,44.81,44.49,44.07,43.62,43.11,42.49,41.83,40.77,39.89,39.21,38.71,38.31,38.00,37.84,37.91,38.09,38.11,37.99,37.64,37.22,36.77,36.60 AA1417 | No 128 | US Compass Grey - Satin | GU 31.6,94,99,103,-10591385,41.94,-0.94,-2.90,5.75BG,4.12,3.43,12.46,D65/10°,SCI,,UV400,,13.13,13.75,13.85,13.76,13.75,13.67,13.54,13.41,13.28,13.12,13.00,12.91,12.78,12.69,12.59,12.52,12.33,12.27,12.14,12.01,11.92,11.83,11.67,11.59,11.43,11.30,11.19,11.06,10.96,10.87,10.76 AA1417 | No 128 | US Compass Grey - Satin | GU 31.6,86,91,95,-11117729,38.50,-0.95,-3.23,6.71BG,3.79,1.70,10.37,D65/10°,SCE,,UV400,,11.19,11.68,11.70,11.67,11.64,11.58,11.46,11.29,11.18,11.01,10.94,10.81,10.70,10.57,10.44,10.35,10.28,10.20,10.08,9.94,9.87,9.76,9.62,9.53,9.41,9.27,9.16,8.98,8.90,8.78,8.69 AA1420 | No 129 | US Gull Grey - Satin | GU 21.6,167,167,160,-5789792,68.56,-1.34,3.64,10.09RP,6.78,3.67,38.74,D65/10°,SCI,,UV400,,26.35,31.15,32.86,34.15,35.48,36.43,36.85,37.18,37.39,37.65,37.98,38.34,38.66,38.90,39.20,39.42,39.20,39.23,39.20,39.16,39.06,38.96,38.67,38.53,38.36,38.22,38.08,37.90,37.70,37.47,37.28 AA1420 | No 129 | US Gull Grey - Satin | GU 21.6,163,163,156,-6052964,67.07,-1.30,3.78,10.09RP,6.62,3.68,36.72,D65/10°,SCE,,UV400,,24.68,29.14,30.75,32.13,33.46,34.44,34.84,35.14,35.37,35.59,35.97,36.30,36.62,36.87,37.08,37.32,37.18,37.23,37.23,37.19,37.13,36.99,36.72,36.54,36.42,36.24,36.08,35.82,35.66,35.47,35.29 DB0130 | No 130 | White - Satin | GU 27.3,249,250,243,-394509,98.11,-1.12,2.88,5.42RP,9.82,2.93,95.18,D65/10°,SCI,,UV400,,48.14,72.63,85.26,90.12,91.38,92.10,92.70,93.45,93.92,94.36,94.67,94.90,95.12,95.30,95.60,95.88,95.48,95.56,95.52,95.53,95.53,95.53,95.52,95.56,95.58,95.64,95.60,95.72,95.64,95.69,95.84 DB0130 | No 130 | White - Satin | GU 27.3,245,245,240,-657936,96.60,-1.11,2.43,5.73RP,9.66,2.58,91.46,D65/10°,SCE,,UV400,,46.56,70.67,82.37,87.08,88.49,89.21,89.61,90.30,90.65,91.02,91.51,91.49,91.55,91.55,91.71,92.01,91.61,91.57,91.60,91.68,91.62,91.74,91.85,91.62,91.71,91.61,91.22,91.09,90.84,91.19,91.24 AA1448 | No 131 | Mid Green - Satin | GU 21.1,94,119,73,-10586295,47.29,-18.13,22.28,9.12GY,4.69,4.91,16.24,D65/10°,SCI,,UV400,,7.04,7.27,7.36,7.43,7.61,7.69,7.82,8.00,8.52,10.08,13.94,19.03,22.37,23.41,22.58,20.39,16.84,14.71,13.50,12.81,12.25,11.83,11.75,12.21,12.89,13.62,14.02,13.89,13.21,12.66,12.60 AA1448 | No 131 | Mid Green - Satin | GU 21.1,87,113,64,-11046592,44.80,-19.38,24.36,7.09GY,4.45,4.97,14.40,D65/10°,SCE,,UV400,,5.68,5.68,5.68,5.80,5.96,6.04,6.16,6.31,6.83,8.34,12.11,17.14,20.46,21.46,20.60,18.44,15.00,12.89,11.71,11.03,10.51,10.07,10.01,10.45,11.16,11.85,12.24,12.05,11.45,10.88,10.83 AA1451 | No 132 | Red - Satin | GU 11.0,173,76,61,-5419971,45.01,38.28,28.28,8.43R,4.54,9.33,14.55,D65/10°,SCI,,UV400,,6.25,6.24,6.11,5.87,5.73,5.61,5.53,5.51,5.53,5.54,5.61,5.67,5.79,6.03,6.56,7.55,9.86,12.86,17.30,24.71,33.11,39.28,42.28,43.48,43.75,43.69,43.50,43.31,43.11,42.84,42.76 AA1451 | No 132 | Red - Satin | GU 11.0,171,73,58,-5551814,43.93,39.04,28.56,8.77R,4.43,9.27,13.79,D65/10°,SCE,,UV400,,6.16,5.88,5.65,5.43,5.30,5.17,5.07,5.00,5.01,4.99,5.06,5.11,5.20,5.38,5.82,6.74,9.19,12.08,16.48,23.83,32.06,38.12,41.18,42.33,42.64,42.55,42.32,42.04,41.76,41.52,41.36 AA1465 | No 133 | Brown - Satin | GU 33.0,112,72,62,-9418690,35.20,15.80,13.01,8.66R,3.53,4.16,8.60,D65/10°,SCI,,UV400,,5.64,5.63,5.56,5.43,5.36,5.29,5.22,5.22,5.24,5.25,5.28,5.31,5.39,5.58,5.95,6.65,8.21,9.86,11.55,13.27,14.27,14.54,14.49,14.54,14.59,14.64,14.64,14.51,14.27,14.01,13.90 AA1465 | No 133 | Brown - Satin | GU 33.0,104,58,46,-9946578,30.08,18.88,16.41,2.04YR,3.04,4.12,6.27,D65/10°,SCE,,UV400,,3.68,3.48,3.36,3.24,3.18,3.10,3.06,2.99,3.01,3.00,3.05,3.06,3.14,3.27,3.62,4.28,5.91,7.53,9.18,10.86,11.86,12.10,12.08,12.11,12.19,12.22,12.21,12.04,11.82,11.57,11.50 AA1523 | No 140 | Gull Grey - Matt | GU 5.4,118,124,125,-9012099,51.67,-1.79,-1.72,6.97P,5.07,1.32,19.85,D65/10°,SCI,,UV400,,18.14,19.95,20.51,20.67,20.82,20.93,20.86,20.77,20.68,20.56,20.50,20.45,20.42,20.35,20.32,20.21,19.75,19.59,19.35,19.13,18.97,18.82,18.62,18.49,18.30,18.10,17.90,17.75,17.59,17.42,17.28 AA1523 | No 140 | Gull Grey - Matt | GU 5.4,117,123,124,-9077892,51.23,-1.73,-1.78,7.05P,5.03,1.23,19.47,D65/10°,SCE,,UV400,,18.02,19.59,20.07,20.28,20.48,20.61,20.51,20.42,20.34,20.23,20.17,20.11,20.04,19.94,19.83,19.73,19.40,19.21,19.00,18.81,18.67,18.47,18.27,18.16,17.96,17.80,17.59,17.34,17.16,16.99,16.84 AA1568 | No 144 | Intermediate Blue - Matt | GU 4.8,95,109,119,-10523273,45.23,-2.88,-7.36,2.03PB,4.42,1.86,14.71,D65/10°,SCI,,UV400,,16.80,18.25,18.48,18.39,18.29,18.20,17.98,17.74,17.44,17.16,16.86,16.51,16.09,15.68,15.27,14.83,13.86,13.30,13.03,12.93,12.83,12.68,12.60,12.72,12.86,12.99,12.99,12.86,12.59,12.35,12.21 AA1568 | No 144 | Intermediate Blue - Matt | GU 4.8,94,108,118,-10589066,44.92,-2.70,-7.51,2.03PB,4.39,1.86,14.48,D65/10°,SCE,,UV400,,16.80,18.00,18.29,18.17,18.13,18.03,17.79,17.53,17.28,16.95,16.65,16.26,15.86,15.40,14.96,14.44,13.66,13.11,12.84,12.76,12.68,12.51,12.44,12.56,12.73,12.83,12.79,12.59,12.35,12.08,12.01 AB0145 | No 145 | Medium Grey - Matt | GU 2.4,117,130,131,-9076093,53.62,-4.52,-1.99,5.58BG,5.25,2.67,21.61,D65/10°,SCI,,UV400,,18.39,20.54,21.40,21.94,22.55,23.01,23.15,23.25,23.30,23.31,23.32,23.33,23.28,23.10,22.81,22.35,21.23,20.58,20.09,19.73,19.45,19.20,19.06,19.17,19.32,19.44,19.41,19.22,18.86,18.49,18.29 AB0145 | No 145 | Medium Grey - Matt | GU 2.4,114,127,128,-9273472,52.47,-4.54,-1.94,5.36BG,5.14,2.81,20.57,D65/10°,SCE,,UV400,,17.59,19.45,20.22,20.82,21.45,21.92,22.05,22.13,22.19,22.20,22.25,22.27,22.21,21.99,21.66,21.24,20.22,19.57,19.08,18.77,18.51,18.22,18.08,18.18,18.34,18.48,18.46,18.21,17.83,17.45,17.26 AA1599 | No 147 | Light Grey - Matt | GU 6.1,192,196,188,-4143940,78.78,-2.56,3.21,5.09G,7.84,3.67,54.55,D65/10°,SCI,,UV400,,33.85,43.12,46.81,48.92,50.69,51.98,52.85,53.51,54.02,54.40,54.74,55.00,55.22,55.42,55.59,55.66,54.82,54.53,54.28,54.04,53.83,53.67,53.46,53.49,53.42,53.34,53.14,52.98,52.64,52.34,52.19 AA1599 | No 147 | Light Grey - Matt | GU 6.1,191,194,187,-4209989,78.32,-2.48,3.28,9.46RP,7.79,2.82,53.76,D65/10°,SCE,,UV400,,33.45,42.56,46.08,48.16,49.91,51.10,51.96,52.63,53.18,53.56,53.95,54.20,54.42,54.57,54.66,54.82,54.04,53.76,53.53,53.33,53.16,52.97,52.81,52.78,52.78,52.69,52.46,52.18,51.85,51.58,51.41 AA1609 | No 148 | Radome Tan - Matt | GU 19.1,228,190,146,-1786222,79.32,7.63,27.02,10.04YR,8.00,4.42,55.49,D65/10°,SCI,,UV400,,22.57,25.45,26.79,28.48,31.02,33.04,33.89,34.43,35.09,36.26,38.29,41.19,44.85,49.25,53.93,57.94,61.83,64.55,66.55,67.77,68.15,68.12,68.18,68.61,69.17,69.72,70.06,70.12,70.03,70.16,70.71 AA1609 | No 148 | Radome Tan - Matt | GU 19.1,225,187,142,-1983602,78.30,7.76,27.59,10.05YR,7.89,4.52,53.72,D65/10°,SCE,,UV400,,21.41,23.99,25.19,26.93,29.41,31.42,32.23,32.76,33.43,34.58,36.65,39.54,43.19,47.56,52.09,56.13,60.02,62.71,64.69,65.93,66.33,66.31,66.38,66.75,67.37,67.89,68.14,68.17,68.01,68.22,68.73 AA1612 | No 149 | Dark Green - Matt | GU 2.9,77,91,86,-11707562,37.68,-6.62,1.44,9.19G,3.71,2.19,9.91,D65/10°,SCI,,UV400,,7.58,8.15,8.41,8.73,9.24,9.58,9.78,9.92,10.02,10.12,10.30,10.52,10.70,10.90,11.02,10.99,10.35,9.92,9.66,9.30,8.57,7.92,7.49,7.31,7.09,6.98,7.03,7.22,7.53,7.83,8.05 AA1612 | No 149 | Dark Green - Matt | GU 2.9,78,91,86,-11642026,37.70,-6.22,0.98,10.05G,3.72,2.53,9.92,D65/10°,SCE,,UV400,,8.24,8.44,8.60,8.92,9.44,9.73,9.92,10.01,10.10,10.18,10.38,10.56,10.71,10.84,10.90,10.81,10.38,9.95,9.69,9.34,8.64,8.01,7.60,7.40,7.20,7.06,7.09,7.20,7.48,7.74,7.97 AA1626 | No 150 | Forest Green - Matt | GU 1.4,94,90,65,-10593727,38.08,-3.02,15.17,10.06Y,3.80,2.34,10.13,D65/10°,SCI,,UV400,,5.69,5.97,5.94,5.79,5.74,5.70,5.75,5.91,6.17,6.56,7.44,8.80,10.30,11.27,11.59,11.61,11.20,11.04,10.85,10.64,10.50,10.38,10.22,10.13,9.95,9.84,9.78,9.75,9.70,9.65,9.56 AA1626 | No 150 | Forest Green - Matt | GU 1.4,94,90,67,-10593725,38.31,-2.70,14.12,10.03Y,3.82,2.19,10.26,D65/10°,SCE,,UV400,,6.47,6.40,6.27,6.16,6.10,6.05,6.09,6.18,6.44,6.83,7.71,9.03,10.45,11.34,11.56,11.53,11.33,11.18,10.97,10.77,10.66,10.53,10.39,10.29,10.17,10.04,9.94,9.82,9.78,9.68,9.61 DB0153 | No 153 | Insignia Red - Matt | GU 4.1,153,58,56,-6735304,38.28,39.58,22.25,5.33R,3.86,10.30,10.25,D65/10°,SCI,,UV400,,4.79,4.95,4.89,4.73,4.65,4.53,4.45,4.36,4.29,4.20,4.15,4.14,4.24,4.37,4.47,4.67,5.24,6.43,9.22,15.10,23.08,29.88,34.55,37.94,40.66,42.73,43.73,43.17,41.25,39.63,39.55 DB0153 | No 153 | Insignia Red - Matt | GU 4.1,153,58,57,-6735303,38.22,39.39,21.18,5.03R,3.85,10.15,10.21,D65/10°,SCE,,UV400,,5.44,5.25,5.10,4.96,4.88,4.73,4.64,4.49,4.41,4.28,4.22,4.21,4.31,4.35,4.39,4.55,5.30,6.51,9.24,15.05,22.98,29.61,34.13,37.46,40.25,42.29,43.22,42.55,40.56,38.96,38.94 DB0154 | No 154 | Insignia Yellow - Matt | GU 9.6,242,156,30,-877538,71.70,23.34,71.07,10.03YR,7.33,11.89,43.21,D65/10°,SCI,,UV400,,6.49,6.42,6.30,6.11,6.04,5.99,6.07,6.32,6.71,7.11,8.07,10.56,15.90,25.07,37.49,49.48,60.31,64.98,67.01,67.75,67.82,67.68,67.83,68.43,69.23,70.00,70.51,70.73,70.53,70.81,71.70 DB0154 | No 154 | Insignia Yellow - Matt | GU 9.6,240,155,28,-1008868,71.11,23.45,70.88,10.03YR,7.27,11.85,42.35,D65/10°,SCE,,UV400,,6.79,6.36,6.14,5.95,5.88,5.81,5.88,6.08,6.44,6.80,7.76,10.17,15.37,24.35,36.46,48.56,59.22,63.84,65.83,66.63,66.72,66.56,66.71,67.27,68.09,68.80,69.25,69.40,69.12,69.47,70.33 DB0155 | No 155 | Olive Drab - Matt | GU 6.2,95,87,68,-10528956,37.31,0.05,12.13,7.85Y,3.72,1.93,9.71,D65/10°,SCI,,UV400,,6.58,6.65,6.43,6.20,6.13,6.10,6.21,6.44,6.67,6.75,7.11,7.90,8.97,9.85,10.43,10.80,10.83,10.86,10.77,10.67,10.60,10.51,10.38,10.32,10.20,10.12,10.05,9.98,9.93,9.88,9.78 DB0155 | No 155 | Olive Drab - Matt | GU 6.2,94,86,69,-10594747,36.98,0.25,11.21,10.05Y,3.69,2.26,9.52,D65/10°,SCE,,UV400,,7.16,6.85,6.56,6.32,6.25,6.19,6.28,6.47,6.66,6.72,7.07,7.83,8.83,9.63,10.12,10.43,10.64,10.66,10.55,10.45,10.40,10.30,10.19,10.12,10.02,9.93,9.83,9.68,9.62,9.52,9.47 DB0156 | No 156 | Dark Camouflage Grey - Satin | GU 7.3,104,110,112,-9933200,46.24,-1.53,-2.14,5.12BG,4.54,3.44,15.44,D65/10°,SCI,,UV400,,15.37,16.39,16.51,16.49,16.54,16.53,16.38,16.25,16.10,15.99,15.93,15.90,15.88,15.84,15.81,15.74,15.44,15.31,15.09,14.87,14.69,14.52,14.34,14.21,14.05,13.91,13.82,13.76,13.70,13.65,13.55 DB0156 | No 156 | Dark Camouflage Grey - Satin | GU 7.3,103,108,112,-9999248,45.64,-1.34,-2.50,5.12BG,4.49,3.45,15.01,D65/10°,SCE,,UV400,,15.29,16.10,16.29,16.24,16.27,16.26,16.08,15.88,15.74,15.58,15.54,15.47,15.44,15.36,15.28,15.15,15.04,14.88,14.67,14.47,14.30,14.10,13.93,13.80,13.67,13.50,13.36,13.21,13.17,13.09,13.05 A1701 | No 157 | Azure Blue - Matt | GU 1.3,83,104,113,-11310991,42.93,-5.85,-7.29,7.02B,4.19,1.89,13.11,D65/10°,SCI,,UV400,,14.13,15.68,15.97,16.07,16.25,16.34,16.31,16.22,16.04,15.84,15.60,15.31,14.93,14.56,14.17,13.65,12.36,11.58,11.24,11.02,10.66,10.30,10.02,9.91,9.80,9.84,10.00,10.10,10.01,9.83,9.49 A1701 | No 157 | Azure Blue - Matt | GU 1.3,84,104,113,-11245455,43.06,-5.46,-7.42,7.64B,4.21,2.07,13.20,D65/10°,SCE,,UV400,,14.49,15.86,16.19,16.27,16.42,16.52,16.44,16.33,16.18,15.92,15.68,15.37,15.00,14.57,14.12,13.56,12.48,11.73,11.38,11.16,10.85,10.47,10.22,10.11,10.03,10.05,10.17,10.18,10.11,9.88,9.58 AA1729 | No 159 | Khaki Drab - Matt | GU 2.0,105,94,68,-9871804,40.61,-0.11,16.62,7.08Y,4.08,1.22,11.62,D65/10°,SCI,,UV400,,5.51,5.97,6.11,6.26,6.55,6.64,6.72,6.78,6.91,7.09,7.45,7.90,8.46,9.26,10.70,13.05,16.48,18.03,17.09,14.63,12.08,10.40,9.51,9.11,8.76,8.55,8.64,9.11,9.82,10.64,11.36 AA1729 | No 159 | Khaki Drab - Matt | GU 2.0,105,95,70,-9871546,40.74,0.10,15.59,7.06Y,4.09,1.45,11.70,D65/10°,SCE,,UV400,,6.32,6.37,6.43,6.60,6.89,6.99,7.03,7.05,7.16,7.31,7.67,8.11,8.63,9.35,10.67,12.92,16.49,17.98,17.08,14.68,12.17,10.50,9.66,9.26,8.94,8.71,8.79,9.15,9.86,10.65,11.40 DB0160 | No 160 | German Camouflage Red - Matt | GU 4.9,96,75,69,-10466491,34.19,7.85,6.98,10.05R,3.41,2.35,8.10,D65/10°,SCI,,UV400,,6.67,6.77,6.60,6.30,6.22,6.13,6.18,6.29,6.40,6.34,6.40,6.58,6.83,7.02,7.06,7.04,7.22,8.34,9.80,10.77,11.09,11.08,10.96,10.87,10.72,10.61,10.53,10.45,10.38,10.32,10.19 DB0160 | No 160 | German Camouflage Red - Matt | GU 4.9,96,75,70,-10466490,34.07,7.95,6.08,8.22R,3.39,1.65,8.04,D65/10°,SCE,,UV400,,7.32,7.05,6.78,6.50,6.42,6.32,6.34,6.42,6.49,6.41,6.47,6.62,6.83,6.94,6.90,6.85,7.21,8.31,9.71,10.66,10.99,10.95,10.85,10.75,10.63,10.50,10.40,10.24,10.18,10.08,10.00 DB0163 | No 163 | Dark Green - Satin | GU 21.8,83,83,78,-11316402,35.49,-1.23,2.98,2.13G,3.51,0.69,8.74,D65/10°,SCI,,UV400,,8.32,8.40,8.23,7.93,7.83,7.73,7.67,7.70,7.98,8.33,8.68,8.80,8.79,8.79,8.90,9.02,9.01,9.02,8.92,8.81,8.75,8.69,8.57,8.55,8.43,8.36,8.32,8.25,8.21,8.19,8.11 DB0163 | No 163 | Dark Green - Satin | GU 21.8,76,77,73,-11776695,32.84,-1.21,2.28,2.13G,3.25,0.66,7.46,D65/10°,SCE,,UV400,,7.71,7.52,7.29,6.99,6.85,6.72,6.65,6.63,6.85,7.16,7.51,7.61,7.55,7.51,7.53,7.61,7.74,7.73,7.61,7.49,7.43,7.36,7.24,7.19,7.09,7.00,6.91,6.79,6.73,6.65,6.57 AA1780 | No 164 | Dark Sea Grey - Satin | GU 25.9,97,101,104,-10394264,42.86,-1.16,-2.21,5.13BG,4.21,3.47,13.07,D65/10°,SCI,,UV400,,13.02,13.81,13.99,13.98,14.03,14.03,13.98,13.89,13.79,13.68,13.58,13.49,13.38,13.32,13.25,13.17,12.97,12.89,12.77,12.63,12.54,12.45,12.29,12.20,12.04,11.91,11.78,11.66,11.55,11.45,11.32 AA1780 | No 164 | Dark Sea Grey - Satin | GU 25.9,89,94,97,-10920351,39.68,-1.13,-2.41,4.84BG,3.90,3.19,11.06,D65/10°,SCE,,UV400,,11.23,11.78,11.91,11.98,12.03,12.02,11.95,11.83,11.75,11.62,11.57,11.47,11.38,11.27,11.16,11.09,10.98,10.91,10.80,10.66,10.59,10.48,10.34,10.24,10.11,9.97,9.86,9.67,9.59,9.47,9.38 AB0165 | No 165 | Medium Sea Grey - Satin | GU 17.2,130,138,140,-8222068,56.99,-2.18,-2.00,6.28BG,5.59,2.23,24.92,D65/10°,SCI,,UV400,,22.54,25.16,25.81,25.96,26.22,26.41,26.31,26.16,26.04,25.94,25.91,25.90,25.86,25.76,25.63,25.42,24.75,24.30,23.97,23.75,23.55,23.33,23.19,23.30,23.35,23.40,23.40,23.26,22.98,22.72,22.59 AB0165 | No 165 | Medium Sea Grey - Satin | GU 17.2,128,135,137,-8353911,55.89,-2.14,-2.13,6.06BG,5.48,2.46,23.80,D65/10°,SCE,,UV400,,21.92,24.16,24.66,24.87,25.14,25.38,25.23,25.08,24.96,24.85,24.83,24.82,24.75,24.61,24.41,24.16,23.65,23.20,22.87,22.67,22.52,22.29,22.17,22.20,22.28,22.31,22.27,22.05,21.78,21.52,21.42 AA1804 | No 166 | Light Aircraft Grey - Satin | GU 54.6,171,170,154,-5526886,69.43,-2.37,8.43,7.07GY,6.88,0.89,39.95,D65/10°,SCI,,UV400,,23.61,27.19,28.87,30.57,32.35,33.79,34.77,35.62,36.32,37.02,37.82,38.72,39.60,40.39,41.05,41.54,41.20,41.16,41.03,40.84,40.68,40.57,40.30,40.11,39.86,39.63,39.39,39.20,39.04,38.76,38.57 AA1804 | No 166 | Light Aircraft Grey - Satin | GU 54.6,164,162,144,-5987696,66.40,-2.49,9.43,7.06GY,6.57,1.02,35.84,D65/10°,SCE,,UV400,,19.43,22.86,24.47,26.23,28.00,29.49,30.48,31.32,32.06,32.76,33.62,34.54,35.45,36.25,36.89,37.48,37.08,37.10,36.98,36.81,36.67,36.54,36.32,36.10,35.91,35.64,35.44,35.19,35.06,34.85,34.68 AB0167 | No 167 | RAF Barley Grey - Satin | GU 9.2,148,153,151,-7038569,62.94,-2.09,0.40,10.10G,6.19,3.59,31.52,D65/10°,SCI,,UV400,,25.46,29.51,30.47,30.77,31.21,31.52,31.53,31.53,31.51,31.59,31.71,31.94,32.14,32.30,32.40,32.31,31.89,31.49,31.10,30.76,30.47,30.26,30.03,29.93,29.79,29.76,29.78,29.73,29.56,29.34,29.12 AB0167 | No 167 | RAF Barley Grey - Satin | GU 9.2,146,151,149,-7170155,62.13,-2.05,0.49,10.10G,6.11,3.58,30.56,D65/10°,SCE,,UV400,,24.87,28.49,29.33,29.72,30.16,30.54,30.51,30.52,30.53,30.58,30.76,30.98,31.18,31.29,31.32,31.23,30.95,30.57,30.18,29.84,29.61,29.38,29.19,29.04,28.96,28.90,28.90,28.73,28.59,28.38,28.16 AB0168 | No 168 | Hemp - Satin | GU 33.8,164,153,134,-5990010,63.80,0.82,11.41,10.05YR,6.32,2.41,32.56,D65/10°,SCI,,UV400,,18.85,21.11,22.06,23.04,24.40,25.49,25.95,26.29,26.74,27.30,28.14,29.27,30.49,31.73,32.87,33.70,34.43,34.92,35.18,35.26,35.24,35.24,35.11,35.06,34.99,35.03,35.10,35.17,35.22,35.19,35.21 AB0168 | No 168 | Hemp - Satin | GU 33.8,159,147,127,-6319233,61.69,0.88,12.05,2.04Y,6.11,1.39,30.04,D65/10°,SCE,,UV400,,16.70,18.70,19.55,20.56,21.94,23.02,23.47,23.82,24.26,24.82,25.68,26.79,28.01,29.21,30.28,31.15,31.90,32.36,32.61,32.71,32.71,32.69,32.61,32.54,32.55,32.56,32.68,32.67,32.74,32.74,32.77 DB0171 | No 171 | Antique Bronze - Metallic | GU 7.1 | Metallic,156,123,98,-6522014,54.36,8.94,18.33,5.86YR,5.40,3.61,22.31,D65/10°,SCI,,UV400,,15.56,14.59,13.87,13.13,12.99,12.99,13.19,13.88,14.69,15.32,16.20,17.51,18.99,20.17,20.46,20.08,20.57,23.62,28.05,30.75,30.97,30.24,29.55,29.20,28.74,28.39,28.30,28.55,28.93,29.32,29.57 DB0171 | No 171 | Antique Bronze - Metallic | GU 7.1 | Metallic,153,120,96,-6719392,53.26,9.04,18.16,5.65YR,5.30,3.56,21.28,D65/10°,SCE,,UV400,,15.04,13.91,13.15,12.55,12.35,12.40,12.55,13.10,13.91,14.50,15.40,16.64,18.08,19.18,19.39,19.03,19.61,22.60,26.88,29.48,29.70,28.97,28.32,27.92,27.53,27.15,27.07,27.20,27.57,27.99,28.25 AA0173 | No 173 | Track Colour - Matt | GU 1.3,77,72,70,-11712442,31.27,1.79,2.24,7.47RP,3.10,0.51,6.77,D65/10°,SCI,,UV400,,5.86,6.27,6.32,6.27,6.27,6.19,6.21,6.18,6.20,6.17,6.18,6.21,6.28,6.40,6.60,6.87,6.87,7.13,7.26,7.31,7.33,7.32,7.23,7.22,7.09,7.05,7.05,7.04,7.04,7.03,6.97 AA0173 | No 173 | Track Colour - Matt | GU 1.3,79,73,72,-11581112,31.75,2.02,1.61,7.16RP,3.15,0.28,6.97,D65/10°,SCE,,UV400,,6.65,6.70,6.67,6.64,6.63,6.58,6.55,6.48,6.49,6.44,6.47,6.47,6.51,6.57,6.68,6.90,7.13,7.37,7.48,7.51,7.56,7.55,7.47,7.44,7.35,7.27,7.23,7.15,7.12,7.08,7.03 DB0174 | No 174 | Signal Red - Satin | GU 25.2,181,66,59,-4898245,44.53,45.93,29.05,7.04R,4.48,10.99,14.21,D65/10°,SCI,,UV400,,5.18,5.20,5.21,5.19,5.22,5.23,5.27,5.40,5.67,5.93,6.11,6.04,5.99,5.96,5.92,6.00,6.67,8.07,11.58,19.17,30.53,42.10,51.85,58.80,63.02,65.45,67.01,67.89,67.97,68.45,69.68 DB0174 | No 174 | Signal Red - Satin | GU 25.2,177,57,51,-5162701,42.16,48.42,30.87,7.04R,4.26,12.55,12.60,D65/10°,SCE,,UV400,,4.44,4.26,4.16,4.12,4.13,4.08,4.08,4.14,4.37,4.61,4.79,4.69,4.58,4.47,4.38,4.39,5.12,6.45,9.84,17.40,28.60,40.04,49.80,56.64,60.90,63.29,64.73,65.52,65.58,66.12,67.25 DB0186 | No 186 | Brown - Matt | GU 4.5,116,81,62,-9154242,37.87,12.05,16.60,5.46YR,3.81,2.99,10.01,D65/10°,SCI,,UV400,,5.12,5.38,5.44,5.47,5.55,5.54,5.52,5.54,5.60,5.67,5.82,5.99,6.23,6.67,7.47,8.89,11.34,13.31,14.41,14.89,14.91,14.67,14.36,14.13,13.87,13.67,13.56,13.53,13.50,13.48,13.45 DB0186 | No 186 | Brown - Matt | GU 4.5,115,80,63,-9220033,37.71,12.10,15.76,3.12YR,3.79,3.41,9.93,D65/10°,SCE,,UV400,,5.65,5.61,5.57,5.62,5.71,5.69,5.65,5.61,5.66,5.71,5.87,6.04,6.25,6.60,7.32,8.67,11.26,13.16,14.27,14.75,14.78,14.51,14.23,13.99,13.76,13.54,13.39,13.27,13.26,13.21,13.21 A6238 | No 187 | Dark Stone - Matt | GU 1.5,136,123,103,-7832729,52.56,1.77,12.61,2.02Y,5.21,1.69,20.65,D65/10°,SCI,,UV400,,11.59,12.71,13.06,13.54,14.37,14.94,15.18,15.29,15.45,15.78,16.42,17.34,18.48,19.73,20.97,21.85,22.48,22.91,23.12,23.14,23.10,22.99,22.81,22.72,22.51,22.38,22.31,22.27,22.21,22.15,22.08 A6238 | No 187 | Dark Stone - Matt | GU 1.5,137,123,104,-7767192,52.58,1.94,12.23,2.03Y,5.21,1.67,20.67,D65/10°,SCE,,UV400,,12.28,12.96,13.22,13.77,14.58,15.16,15.33,15.38,15.57,15.86,16.52,17.40,18.53,19.72,20.87,21.74,22.49,22.92,23.12,23.18,23.16,23.05,22.90,22.74,22.60,22.46,22.36,22.23,22.16,22.09,22.07 DB0189 | No 189 | Chrome Silver - Metallic | GU 89.6 | Metallic | Opacity 88.33%,196,196,196,-3881788,79.43,-0.21,0.05,2.05RP,7.90,1.39,55.67,D65/10°,SCI,,UV400,,52.21,54.03,55.43,55.39,55.72,55.92,55.64,55.62,55.66,55.72,55.79,55.80,55.74,55.66,55.61,55.48,55.86,55.78,55.76,55.74,55.75,55.66,55.42,55.42,55.34,55.17,54.67,54.13,53.50,53.12,52.82 DB0189 | No 189 | Chrome Silver - Metallic | GU 89.6 | Metallic | Opacity 88.33%,179,179,179,-5000269,73.25,-0.13,0.35,2.06RP,7.26,1.28,45.54,D65/10°,SCE,,UV400,,41.83,43.79,44.67,44.89,45.31,45.52,45.33,45.34,45.41,45.45,45.55,45.55,45.51,45.41,45.39,45.44,45.72,45.70,45.69,45.69,45.73,45.65,45.51,45.51,45.52,45.40,45.07,44.63,44.25,43.99,43.88 AA6330 | No 195 | Dark Green - Satin | GU 31.5,74,82,72,-11906488,34.13,-5.47,4.76,2.05G,3.38,1.51,8.07,D65/10°,SCI,,UV400,,5.86,6.06,6.16,6.36,6.70,6.84,6.93,7.00,7.16,7.34,7.70,8.10,8.49,8.83,9.05,9.06,8.84,8.57,8.16,7.67,7.18,6.83,6.56,6.46,6.30,6.23,6.23,6.30,6.42,6.58,6.63 AA6330 | No 195 | Dark Green - Satin | GU 31.5,60,69,57,-12827335,28.45,-6.67,5.98,10.01GY,2.83,2.06,5.62,D65/10°,SCE,,UV400,,3.63,3.67,3.76,3.99,4.29,4.44,4.53,4.58,4.73,4.90,5.27,5.65,6.04,6.34,6.51,6.53,6.40,6.14,5.73,5.25,4.79,4.43,4.18,4.07,3.96,3.85,3.85,3.88,4.01,4.12,4.23 AA6344 | No 196 | Light Grey - Satin | GU 29.9,188,192,187,-4407109,77.55,-2.36,2.38,5.08RP,7.71,3.95,52.45,D65/10°,SCI,,UV400,,35.33,44.09,47.12,48.48,49.60,50.52,51.18,51.69,52.07,52.47,52.89,53.09,53.20,53.27,53.30,53.22,52.74,52.51,52.26,51.97,51.74,51.53,51.23,51.04,50.74,50.47,50.14,49.92,49.67,49.43,49.22 AA6344 | No 196 | Light Grey - Satin | GU 29.9,184,188,182,-4670282,76.01,-2.34,2.58,6.18RP,7.55,2.40,49.90,D65/10°,SCE,,UV400,,32.87,41.48,44.36,45.79,46.98,47.85,48.49,49.02,49.43,49.80,50.25,50.49,50.60,50.62,50.62,50.68,50.20,50.01,49.76,49.50,49.30,49.10,48.83,48.59,48.37,48.04,47.71,47.42,47.11,46.88,46.67 AA6389 | No 200 | Pink - Gloss | GU 91.8,232,164,173,-1530707,74.19,26.41,5.61,10.04RP,7.40,6.85,47.01,D65/10°,SCI,,UV400,,33.81,40.49,42.56,43.28,43.57,43.40,42.55,41.13,39.50,38.22,37.06,36.51,36.84,37.28,37.26,37.39,38.56,40.22,45.77,57.24,69.66,79.06,84.88,87.87,89.51,90.49,90.99,91.37,91.22,91.19,91.32 AA6389 | No 200 | Pink - Gloss | GU 91.8,226,155,163,-1926237,71.17,27.97,6.36,10.03RP,7.09,7.35,42.43,D65/10°,SCE,,UV400,,28.85,35.59,37.50,38.35,38.74,38.58,37.77,36.37,34.80,33.51,32.40,31.87,32.24,32.70,32.70,32.88,34.05,35.77,41.37,52.85,65.16,74.53,80.44,83.01,84.46,85.27,85.57,85.75,85.59,85.76,85.85 AA6392 | No 201 | Black - Metallic | GU 91.3 | Metallic,63,63,64,-12632256,26.96,0.05,-0.45,10.18G,2.66,3.60,5.08,D65/10°,SCI,,UV400,,5.27,5.26,5.26,5.21,5.21,5.17,5.12,5.13,5.14,5.12,5.10,5.08,5.07,5.11,5.09,5.06,5.08,5.06,5.05,5.07,5.04,5.07,5.05,5.06,5.06,5.05,5.08,5.03,5.07,5.05,5.02 AA6392 | No 201 | Black - Metallic | GU 91.3 | Metallic,23,23,23,-15263977,7.86,0.15,0.07,9.62G,0.76,2.48,0.87,D65/10°,SCE,,UV400,,0.86,0.87,0.86,0.88,0.88,0.85,0.87,0.85,0.87,0.86,0.87,0.83,0.87,0.88,0.87,0.85,0.88,0.88,0.87,0.88,0.87,0.87,0.87,0.88,0.89,0.90,0.93,0.91,0.95,0.94,0.96 DB0208 | No 208 | Fluorescent Signal Green - Gloss | GU 11.3 | Fluorescent | Opacity 42.64%,0,180,40,-16731096,63.19,-75.14,54.62,2.15G,6.23,18.58,31.81,D65/10°,SCI,,UV400,,5.30,5.10,5.04,4.97,4.84,4.77,4.82,5.27,7.12,12.46,27.26,54.61,72.03,71.85,64.20,56.82,21.82,15.91,11.31,7.98,6.09,5.38,5.07,4.99,4.95,4.92,5.02,5.17,5.52,5.92,6.30 DB0208 | No 208 | Fluorescent Signal Green - Gloss | GU 11.3 | Fluorescent | Opacity 42.64%,0,179,32,-16731360,62.61,-77.25,56.54,2.18G,6.17,18.82,31.12,D65/10°,SCE,,UV400,,4.96,4.45,4.31,4.25,4.14,4.04,4.10,4.54,6.43,11.68,26.53,54.06,71.76,71.53,63.68,56.21,20.83,14.96,10.43,7.20,5.36,4.59,4.29,4.21,4.14,4.10,4.17,4.29,4.64,5.00,5.40 DB0209 | No 209 | Fire Orange - Gloss | GU 20.2 | Fluorescent | Opacity 34.55%,243,55,49,-837839,54.11,69.40,48.52,7.04R,5.45,17.84,22.08,D65/10°,SCI,,UV400,,6.32,5.44,5.10,4.91,4.72,4.62,4.58,4.62,4.65,4.64,4.61,4.54,4.51,4.71,5.26,7.12,5.83,7.75,12.65,25.92,57.43,94.85,113.26,116.18,115.95,114.56,110.11,104.46,100.15,97.83,97.23 DB0209 | No 209 | Fire Orange - Gloss | GU 20.2 | Fluorescent | Opacity 34.55%,241,43,37,-971995,52.67,71.60,53.13,7.02R,5.32,19.29,20.75,D65/10°,SCE,,UV400,,5.43,4.28,3.82,3.67,3.48,3.35,3.33,3.34,3.38,3.35,3.33,3.25,3.23,3.33,3.86,5.71,4.59,6.48,11.27,24.33,55.82,93.71,112.54,115.08,114.65,112.99,108.33,103.06,98.68,96.27,95.55 AA6608 | No 220 | Racing Red - Gloss | GU 100.0,149,62,64,-6996416,38.26,36.92,17.22,5.06R,3.84,8.86,10.24,D65/10°,SCI,,UV400,,5.68,5.67,5.68,5.61,5.60,5.55,5.52,5.51,5.51,5.47,5.46,5.42,5.41,5.44,5.42,5.44,5.75,6.06,7.05,10.65,17.67,26.92,35.68,41.48,44.68,46.22,46.87,47.20,47.26,47.35,47.43 AA6608 | No 220 | Racing Red - Gloss | GU 100.0,139,20,25,-7662567,29.72,47.66,30.56,7.05R,3.03,12.10,6.12,D65/10°,SCE,,UV400,,1.50,1.46,1.45,1.44,1.44,1.39,1.39,1.37,1.40,1.34,1.35,1.33,1.37,1.32,1.32,1.38,1.72,2.04,3.00,6.54,13.49,22.68,31.31,37.10,40.37,41.87,42.56,42.85,42.94,43.01,43.16 AA7222 | No 222 | Moonlight Blue - Metallic | GU 95.0 | Metallic,63,81,122,-12627590,34.77,5.40,-25.56,7.06PB,3.33,6.70,8.39,D65/10°,SCI,,UV400,,13.45,15.18,16.28,17.71,19.18,20.08,19.72,18.41,16.23,13.75,11.54,9.79,8.42,7.61,7.22,6.88,6.49,6.36,6.42,6.58,6.67,6.64,6.55,6.81,7.26,7.98,8.63,8.92,8.77,8.56,8.47 AA7222 | No 222 | Moonlight Blue - Metallic | GU 95.0 | Metallic,26,56,107,-15058837,24.31,8.03,-33.00,7.03PB,2.24,8.50,4.20,D65/10°,SCE,,UV400,,8.73,10.50,11.57,13.02,14.49,15.44,15.13,13.79,11.71,9.28,7.19,5.52,4.24,3.45,3.05,2.76,2.41,2.28,2.32,2.45,2.56,2.51,2.47,2.69,3.14,3.78,4.44,4.69,4.60,4.35,4.34 AA7224 | No 224 | Dark Slate Grey - Matt | GU 3.0,97,97,90,-10395302,41.31,-1.53,3.93,2.12G,4.08,0.78,12.06,D65/10°,SCI,,UV400,,8.77,9.42,9.69,10.07,10.64,10.93,10.95,10.92,10.94,11.03,11.27,11.61,11.97,12.31,12.59,12.74,12.55,12.49,12.35,12.18,12.06,11.94,11.79,11.68,11.51,11.38,11.29,11.21,11.10,11.06,10.95 AA7224 | No 224 | Dark Slate Grey - Matt | GU 3.0,97,97,91,-10395301,41.23,-1.27,3.49,2.12G,4.08,0.73,12.01,D65/10°,SCE,,UV400,,9.36,9.66,9.84,10.22,10.78,11.04,11.04,10.96,10.98,11.04,11.31,11.61,11.94,12.22,12.43,12.51,12.51,12.45,12.31,12.15,12.07,11.93,11.79,11.68,11.55,11.41,11.29,11.12,11.04,10.96,10.89 AA7225 | No 225 | Middle Stone - Matt | GU 2.6,155,121,74,-6588086,53.25,7.57,30.61,2.07Y,5.34,4.74,21.28,D65/10°,SCI,,UV400,,6.03,6.60,6.92,7.50,8.36,8.93,9.14,9.25,9.53,10.00,10.91,12.39,14.45,17.21,20.58,23.70,26.49,27.86,28.32,28.24,27.89,27.45,26.94,26.55,26.14,25.88,25.76,25.68,25.69,25.71,25.86 AA7225 | No 225 | Middle Stone - Matt | GU 2.6,155,120,76,-6588340,53.15,7.66,29.60,2.06Y,5.33,4.71,21.19,D65/10°,SCE,,UV400,,6.81,7.00,7.22,7.79,8.66,9.18,9.38,9.48,9.69,10.12,11.04,12.43,14.44,17.17,20.39,23.42,26.35,27.70,28.14,28.06,27.75,27.31,26.83,26.39,26.06,25.77,25.61,25.46,25.43,25.51,25.64 AB0226 | No 226 | Interior Green - Matt | GU 2.3,110,105,73,-9541303,44.14,-3.51,18.57,7.12Y,4.41,0.73,13.93,D65/10°,SCI,,UV400,,5.46,5.93,6.17,6.61,7.35,7.83,8.04,8.18,8.45,8.86,9.63,10.81,12.40,14.31,16.16,17.28,17.07,16.37,15.52,14.80,14.12,13.57,13.23,13.08,12.97,13.14,13.51,13.74,13.61,13.32,12.81 AB0226 | No 226 | Interior Green - Matt | GU 2.3,109,105,74,-9606838,44.13,-3.25,17.64,7.10Y,4.41,0.94,13.93,D65/10°,SCE,,UV400,,6.19,6.30,6.45,6.92,7.64,8.10,8.28,8.39,8.62,9.01,9.79,10.90,12.42,14.24,16.03,17.09,17.02,16.32,15.50,14.80,14.17,13.57,13.26,13.10,13.04,13.18,13.50,13.64,13.53,13.23,12.74 AB0230 | No 230 | Pru Blue - Matt | GU 1.3,90,112,120,-10850184,45.84,-6.05,-7.12,7.03B,4.48,1.86,15.15,D65/10°,SCI,,UV400,,16.73,18.49,18.69,18.64,18.57,18.50,18.38,18.26,18.06,17.88,17.71,17.50,17.22,16.87,16.46,15.87,14.63,13.72,13.01,12.55,12.16,11.86,11.67,11.63,11.57,11.70,11.91,11.99,11.82,11.59,11.16 AB0230 | No 230 | Pru Blue - Matt | GU 1.3,90,112,120,-10850184,45.91,-5.81,-7.17,7.03B,4.49,1.87,15.21,D65/10°,SCE,,UV400,,17.05,18.51,18.76,18.68,18.68,18.63,18.46,18.30,18.15,17.95,17.78,17.53,17.27,16.90,16.41,15.77,14.70,13.81,13.10,12.65,12.30,11.97,11.81,11.77,11.75,11.85,12.03,12.04,11.91,11.62,11.26 AA0234 | No 234 | Dark Flesh - Matt | GU 4.4,146,114,98,-7179678,50.77,10.24,13.40,10.08R,5.04,3.32,19.07,D65/10°,SCI,,UV400,,12.21,12.91,12.98,12.84,12.87,12.92,13.06,13.26,13.53,14.17,15.04,15.63,15.85,16.02,16.37,17.01,18.33,20.33,22.63,24.55,25.46,25.67,26.01,26.92,28.00,29.07,29.95,30.39,30.20,29.98,30.41 AA0234 | No 234 | Dark Flesh - Matt | GU 4.4,145,113,97,-7245471,50.37,10.40,13.25,10.07R,5.00,3.29,18.73,D65/10°,SCE,,UV400,,12.42,12.76,12.75,12.71,12.68,12.76,12.87,12.95,13.23,13.84,14.78,15.33,15.55,15.68,15.97,16.56,18.01,20.00,22.28,24.19,25.10,25.31,25.66,26.51,27.63,28.64,29.49,29.83,29.64,29.41,29.85 AB0237 | No 237 | Desert Tan - Matt | GU 1.3,184,159,128,-4677760,67.10,4.60,19.48,2.09Y,6.69,3.00,36.76,D65/10°,SCI,,UV400,,17.27,19.78,20.60,21.54,22.99,24.14,24.56,24.78,25.11,25.79,27.02,28.86,31.15,33.82,36.47,38.64,40.67,41.97,42.80,43.19,43.28,43.30,43.09,42.96,42.75,42.62,42.55,42.63,42.72,42.77,42.91 AB0237 | No 237 | Desert Tan - Matt | GU 1.3,184,158,128,-4678016,66.89,4.69,19.21,2.10Y,6.67,2.94,36.49,D65/10°,SCE,,UV400,,17.64,19.81,20.56,21.51,22.97,24.11,24.50,24.71,25.04,25.69,26.95,28.74,30.99,33.50,36.03,38.17,40.33,41.68,42.53,42.90,43.05,43.01,42.84,42.67,42.53,42.36,42.24,42.19,42.21,42.26,42.40 AB0238 | No 238 | Arrow Red - Gloss | GU 65.7,193,57,63,-4114113,45.39,54.06,28.40,5.05R,4.57,13.89,14.83,D65/10°,SCI,,UV400,,6.24,6.26,6.19,6.05,5.95,5.79,5.67,5.61,5.56,5.49,5.46,5.41,5.39,5.41,5.40,5.44,5.93,6.49,8.75,16.37,30.37,46.74,62.38,75.01,82.76,86.64,88.30,89.19,89.26,89.37,89.57 AB0238 | No 238 | Arrow Red - Gloss | GU 65.7,188,28,39,-4449241,40.79,60.28,36.84,6.78R,4.14,14.77,11.73,D65/10°,SCE,,UV400,,3.51,3.33,3.20,3.11,2.99,2.84,2.74,2.62,2.58,2.49,2.45,2.41,2.43,2.37,2.34,2.38,2.93,3.50,5.72,13.26,27.13,43.36,58.98,71.40,79.30,82.75,84.03,84.61,84.64,84.87,85.03 AB0239 | No 239 | British Racing Green - Gloss | GU 56.0,57,67,65,-13024447,27.87,-4.84,0.28,10.08G,2.74,2.75,5.41,D65/10°,SCI,,UV400,,5.33,5.37,5.34,5.26,5.24,5.19,5.19,5.30,5.63,6.11,6.51,6.44,6.20,5.95,5.71,5.48,5.15,4.97,4.83,4.77,4.71,4.71,4.69,4.69,4.70,4.71,4.74,4.70,4.67,4.66,4.63 AB0239 | No 239 | British Racing Green - Gloss | GU 56.0,32,48,44,-14667732,18.46,-7.83,0.52,10.04G,1.81,2.25,2.62,D65/10°,SCE,,UV400,,2.68,2.61,2.52,2.49,2.47,2.40,2.41,2.48,2.80,3.27,3.72,3.64,3.42,3.13,2.88,2.64,2.41,2.25,2.10,2.00,1.98,1.94,1.90,1.92,1.89,1.87,1.89,1.84,1.85,1.79,1.75 AB0240 | No 240 | RLM 02 Grau - Matt | GU 1.3,123,119,105,-8685719,50.28,-0.92,8.20,7.08GY,4.97,0.87,18.65,D65/10°,SCI,,UV400,,12.22,13.26,13.57,13.98,14.65,15.14,15.32,15.38,15.47,15.70,16.19,16.86,17.67,18.52,19.35,19.88,20.18,20.36,20.25,19.87,19.38,18.90,18.54,18.36,18.15,18.01,18.02,18.21,18.40,18.52,18.59 AB0240 | No 240 | RLM 02 Grau - Matt | GU 1.3,124,119,106,-8620182,50.31,-0.75,7.89,7.08GY,4.98,0.83,18.68,D65/10°,SCE,,UV400,,12.81,13.47,13.69,14.16,14.83,15.33,15.46,15.47,15.58,15.77,16.27,16.92,17.72,18.54,19.26,19.76,20.19,20.37,20.27,19.94,19.47,18.94,18.58,18.41,18.21,18.11,18.13,18.21,18.37,18.46,18.49 AB0241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 4.0,69,72,69,-12236731,30.44,-1.82,1.68,5.13G,3.01,3.14,6.42,D65/10°,SCI,,UV400,,5.98,6.28,6.21,6.04,5.97,5.89,5.92,6.03,6.12,6.12,6.22,6.39,6.62,6.74,6.80,6.82,6.51,6.47,6.36,6.25,6.18,6.14,6.05,6.03,5.96,5.93,5.95,5.93,5.99,5.98,5.97 AB0241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 4.0,70,72,70,-12171194,30.55,-1.51,0.93,7.14G,3.02,0.89,6.46,D65/10°,SCE,,UV400,,6.72,6.60,6.45,6.28,6.20,6.13,6.15,6.20,6.27,6.24,6.34,6.51,6.69,6.74,6.72,6.68,6.59,6.54,6.41,6.31,6.26,6.18,6.09,6.07,6.00,5.94,5.93,5.85,5.86,5.82,5.79 AB0242 | No 242 | RLM 71 Dunkelgrun - Matt | GU 1.5,81,80,74,-11448246,34.30,-0.94,4.07,10.13GY,3.40,2.92,8.15,D65/10°,SCI,,UV400,,5.91,6.43,6.59,6.73,7.01,7.12,7.19,7.20,7.27,7.35,7.48,7.70,7.97,8.25,8.47,8.64,8.50,8.55,8.49,8.38,8.27,8.16,8.05,8.01,7.92,7.91,7.96,8.00,8.01,7.96,7.82 AB0242 | No 242 | RLM 71 Dunkelgrun - Matt | GU 1.5,82,81,76,-11382452,34.65,-0.65,3.39,2.14G,3.43,0.60,8.32,D65/10°,SCE,,UV400,,6.70,6.88,6.94,7.09,7.36,7.48,7.52,7.49,7.52,7.57,7.74,7.93,8.16,8.37,8.52,8.64,8.71,8.73,8.64,8.54,8.47,8.36,8.25,8.21,8.13,8.11,8.13,8.07,8.06,7.98,7.88 AB0243 | No 243 | RLM 72 Grun - Matt | GU 1.5,65,69,69,-12499643,29.12,-1.29,-0.88,10.15G,2.87,3.37,5.88,D65/10°,SCI,,UV400,,5.65,6.07,6.14,6.10,6.13,6.09,6.09,6.06,6.05,6.00,5.98,5.97,6.01,6.06,6.11,6.14,5.87,5.84,5.75,5.68,5.57,5.52,5.46,5.42,5.39,5.35,5.39,5.41,5.46,5.48,5.46 AB0243 | No 243 | RLM 72 Grun - Matt | GU 1.5,66,70,71,-12433849,29.58,-1.02,-1.47,2.15BG,2.92,1.03,6.07,D65/10°,SCE,,UV400,,6.40,6.50,6.48,6.46,6.48,6.43,6.41,6.33,6.32,6.25,6.25,6.22,6.22,6.21,6.18,6.16,6.09,6.05,5.95,5.84,5.79,5.71,5.63,5.62,5.56,5.51,5.50,5.46,5.50,5.46,5.46 AB0244 | No 244 | RLM 73 Grun - Matt | GU 1.4,66,75,73,-12432567,31.32,-4.15,0.03,10.09G,3.09,2.86,6.79,D65/10°,SCI,,UV400,,5.81,6.31,6.45,6.53,6.71,6.79,6.90,6.96,7.03,7.03,7.07,7.11,7.21,7.30,7.35,7.37,6.97,6.81,6.56,6.24,5.94,5.74,5.59,5.54,5.48,5.44,5.53,5.62,5.77,5.87,5.91 AB0244 | No 244 | RLM 73 Grun - Matt | GU 1.4,67,76,75,-12366773,31.73,-3.77,-0.57,2.10BG,3.13,1.37,6.97,D65/10°,SCE,,UV400,,6.60,6.74,6.79,6.91,7.07,7.14,7.22,7.23,7.28,7.27,7.32,7.34,7.41,7.42,7.40,7.35,7.20,7.03,6.76,6.43,6.16,5.93,5.78,5.73,5.66,5.60,5.65,5.69,5.80,5.87,5.91 AB0245 | No 245 | RLM 74 Graugrun - Matt | GU 0.9,81,82,79,-11447729,34.92,-1.15,1.61,5.14G,3.45,3.33,8.46,D65/10°,SCI,,UV400,,6.96,7.59,7.74,7.82,8.00,8.05,8.09,8.06,8.10,8.11,8.19,8.30,8.46,8.64,8.78,8.85,8.63,8.60,8.51,8.39,8.32,8.28,8.17,8.16,8.06,8.02,8.05,8.08,8.10,8.12,8.08 AB0245 | No 245 | RLM 74 Graugrun - Matt | GU 0.9,82,83,81,-11381935,35.32,-0.85,1.10,7.15G,3.49,0.80,8.66,D65/10°,SCE,,UV400,,7.80,8.03,8.08,8.18,8.36,8.40,8.43,8.37,8.38,8.38,8.46,8.56,8.68,8.79,8.84,8.88,8.87,8.83,8.72,8.60,8.56,8.50,8.42,8.40,8.33,8.27,8.26,8.20,8.22,8.20,8.17 AB0246 | No 246 | RLM 75 Grauviolett - Matt | GU 1.3,95,99,103,-10525849,41.92,-0.53,-3.02,6.88P,4.12,1.41,12.45,D65/10°,SCI,,UV400,,12.97,13.93,13.98,13.84,13.77,13.68,13.57,13.43,13.29,13.13,13.01,12.91,12.73,12.59,12.52,12.51,12.16,12.11,12.12,12.08,12.02,11.95,11.84,11.77,11.66,11.60,11.60,11.59,11.55,11.50,11.38 AB0246 | No 246 | RLM 75 Grauviolett - Matt | GU 1.3,96,99,104,-10460312,42.03,-0.29,-3.16,6.86P,4.13,1.45,12.52,D65/10°,SCE,,UV400,,13.51,14.11,14.13,14.02,13.92,13.85,13.69,13.48,13.35,13.18,13.12,12.99,12.83,12.61,12.49,12.40,12.28,12.22,12.22,12.20,12.17,12.07,11.98,11.91,11.83,11.75,11.72,11.64,11.61,11.55,11.45 AB0247 | No 247 | RLM 76 Lichtblau - Matt | GU 12.9,147,163,155,-7101541,65.70,-7.25,2.20,10.04G,6.47,2.71,34.94,D65/10°,SCI,,UV400,,23.85,27.82,29.44,30.77,32.05,33.29,34.48,35.71,36.53,37.01,37.29,37.21,36.59,36.22,36.59,37.14,35.89,35.09,34.58,33.69,31.87,30.01,28.85,28.64,28.75,29.03,29.67,30.60,31.54,32.41,33.44 AB0247 | No 247 | RLM 76 Lichtblau - Matt | GU 12.9,144,160,152,-7298920,64.50,-7.24,2.29,10.04G,6.34,2.71,33.42,D65/10°,SCE,,UV400,,22.76,26.39,27.85,29.24,30.51,31.78,32.94,34.14,34.98,35.43,35.76,35.64,35.04,34.63,34.95,35.53,34.33,33.56,33.07,32.22,30.52,28.69,27.57,27.33,27.50,27.74,28.36,29.20,30.12,30.99,32.03 AA2248 | No 248 | RLM 78 Himmelblau - Matt | GU 3.0,112,136,138,-9402230,55.17,-8.30,-3.95,2.02B,5.38,1.91,23.09,D65/10°,SCI,,UV400,,17.64,20.12,21.38,22.91,24.85,26.39,26.96,27.00,26.79,26.68,26.66,26.83,27.18,26.97,25.84,24.13,21.16,19.51,18.90,18.83,18.58,18.29,18.57,19.73,21.40,23.05,24.05,23.74,22.33,21.08,20.87 AA2248 | No 248 | RLM 78 Himmelblau - Matt | GU 3.0,111,136,138,-9467766,54.98,-8.13,-3.91,2.02B,5.37,1.90,22.91,D65/10°,SCE,,UV400,,17.79,20.00,21.16,22.68,24.65,26.19,26.73,26.76,26.57,26.43,26.45,26.63,26.94,26.70,25.52,23.82,21.06,19.39,18.80,18.76,18.53,18.20,18.49,19.65,21.35,22.99,23.92,23.53,22.16,20.93,20.75 AB0249 | No 249 | RLM 79 Sandgelb - Matt | GU 1.5,141,109,91,-7508645,48.96,9.95,15.14,3.05YR,4.88,3.86,17.56,D65/10°,SCI,,UV400,,9.18,10.01,10.26,10.60,11.14,11.48,11.65,11.75,11.88,12.09,12.50,13.07,13.75,14.49,15.34,16.33,17.91,19.78,21.53,22.89,23.70,24.11,24.22,24.31,24.28,24.31,24.39,24.50,24.58,24.63,24.71 AB0249 | No 249 | RLM 79 Sandgelb - Matt | GU 1.5,141,109,92,-7508644,48.98,10.06,14.60,2.68YR,4.88,3.72,17.58,D65/10°,SCE,,UV400,,9.85,10.33,10.51,10.84,11.37,11.72,11.84,11.86,11.99,12.18,12.62,13.15,13.79,14.48,15.29,16.18,17.93,19.76,21.54,22.90,23.72,24.12,24.25,24.29,24.32,24.30,24.35,24.37,24.41,24.48,24.59 AB0251 | No 251 | RLM 81 Dunkelbraun - Matt | GU 0.7,81,73,71,-11450041,31.96,2.81,2.59,7.66RP,3.17,0.83,7.07,D65/10°,SCI,,UV400,,5.94,6.42,6.50,6.46,6.48,6.40,6.42,6.38,6.37,6.35,6.35,6.37,6.47,6.60,6.77,6.96,7.06,7.42,7.69,7.84,7.91,7.95,7.89,7.89,7.79,7.75,7.76,7.79,7.81,7.79,7.73 AB0251 | No 251 | RLM 81 Dunkelbraun - Matt | GU 0.7,82,74,73,-11384247,32.48,3.00,1.93,7.80RP,3.22,1.03,7.30,D65/10°,SCE,,UV400,,6.80,6.92,6.88,6.85,6.88,6.81,6.79,6.72,6.71,6.65,6.68,6.68,6.74,6.79,6.86,7.02,7.33,7.67,7.91,8.06,8.17,8.20,8.15,8.14,8.06,8.00,7.98,7.91,7.91,7.86,7.84 AB0252 | No 252 | RLM 82 Olivgrun - Matt | GU 0.7,96,96,73,-10461111,40.41,-4.27,13.30,2.03GY,4.03,1.63,11.50,D65/10°,SCI,,UV400,,5.19,5.72,5.98,6.40,7.09,7.54,7.75,7.87,8.09,8.41,9.01,9.90,10.98,12.16,13.15,13.66,13.40,12.95,12.36,11.79,11.27,10.86,10.56,10.43,10.28,10.28,10.42,10.57,10.60,10.56,10.32 AB0252 | No 252 | RLM 82 Olivgrun - Matt | GU 0.7,97,97,75,-10395317,40.64,-3.92,12.31,2.01GY,4.05,1.88,11.64,D65/10°,SCE,,UV400,,5.96,6.19,6.36,6.80,7.50,7.92,8.12,8.19,8.38,8.68,9.31,10.13,11.16,12.24,13.13,13.58,13.51,13.06,12.48,11.94,11.46,11.03,10.76,10.63,10.51,10.48,10.59,10.66,10.70,10.62,10.44 AB0253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 0.8,88,86,73,-10987959,36.45,-1.55,7.86,5.83GY,3.62,1.89,9.24,D65/10°,SCI,,UV400,,5.49,6.01,6.20,6.45,6.90,7.14,7.26,7.30,7.42,7.58,7.89,8.34,8.86,9.40,9.85,10.15,10.06,10.03,9.89,9.68,9.45,9.26,9.10,9.06,8.97,9.00,9.11,9.20,9.17,9.12,8.92 AB0253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 0.8,89,86,75,-10922421,36.80,-1.25,7.05,7.09GY,3.66,0.90,9.43,D65/10°,SCE,,UV400,,6.28,6.47,6.58,6.85,7.30,7.53,7.62,7.63,7.73,7.86,8.18,8.59,9.09,9.55,9.90,10.14,10.25,10.22,10.06,9.86,9.68,9.47,9.33,9.27,9.22,9.22,9.32,9.31,9.30,9.16,9.04 MET27001 | No 27001 | Aluminium - Metalcote | GU 5.2 | Metallic,200,202,203,-3618101,81.32,-0.42,-1.05,7.05P,8.09,1.54,59.05,D65/10°,SCI,,UV400,,59.26,59.97,60.80,60.38,60.35,60.30,59.99,59.86,59.76,59.65,59.60,59.51,59.43,59.35,59.32,59.25,58.85,58.75,58.63,58.57,58.49,58.43,58.23,58.17,58.06,57.88,57.58,57.24,56.90,56.67,56.49 MET27001 | No 27001 | Aluminium - Metalcote | GU 5.2 | Metallic,198,200,201,-3749687,80.59,-0.33,-0.98,7.05P,8.02,1.54,57.73,D65/10°,SCE,,UV400,,58.10,58.61,59.23,58.89,58.99,58.91,58.62,58.46,58.39,58.26,58.26,58.20,58.10,57.96,57.86,57.82,57.51,57.44,57.37,57.35,57.33,57.21,57.06,56.96,56.93,56.71,56.36,55.92,55.56,55.36,55.14 MET27002 | No 27002 | Polished Aluminium - Metalcote | GU 10.8 | Metallic,208,210,213,-3091755,84.27,-0.34,-1.60,7.04P,8.40,1.59,64.58,D65/10°,SCI,,UV400,,66.18,66.65,67.35,66.84,66.75,66.63,66.11,65.85,65.60,65.45,65.33,65.22,65.03,64.88,64.77,64.70,64.34,64.22,64.10,64.01,63.91,63.76,63.50,63.38,63.27,63.04,62.59,62.02,61.52,61.20,60.91 MET27002 | No 27002 | Polished Aluminium - Metalcote | GU 10.8 | Metallic,204,206,209,-3354927,82.93,-0.23,-1.48,7.04P,8.26,1.59,62.04,D65/10°,SCE,,UV400,,63.82,63.95,64.45,64.01,64.04,63.92,63.40,63.15,62.98,62.79,62.73,62.57,62.41,62.22,62.09,62.13,61.83,61.72,61.64,61.64,61.57,61.38,61.17,61.01,60.94,60.72,60.24,59.59,59.11,58.77,58.47 MET27003 | No 27003 | Polished Steel - Metalcote | GU 47.4 | Metallic,89,92,97,-10920863,39.13,-0.22,-3.11,6.85BG,3.85,1.51,10.73,D65/10°,SCI,,UV400,,11.35,11.62,11.67,11.66,11.83,11.97,12.01,11.91,11.76,11.56,11.33,11.13,10.95,10.84,10.75,10.70,10.39,10.31,10.19,10.10,10.19,10.49,10.66,10.72,10.59,10.44,10.47,10.85,11.49,12.24,13.08 MET27003 | No 27003 | Polished Steel - Metalcote | GU 47.4 | Metallic,88,91,96,-10986656,38.63,-0.04,-3.30,7.74P,3.80,1.85,10.45,D65/10°,SCE,,UV400,,11.51,11.46,11.45,11.47,11.60,11.76,11.77,11.61,11.45,11.25,11.09,10.86,10.70,10.51,10.36,10.27,10.15,10.08,9.95,9.84,9.96,10.22,10.40,10.46,10.35,10.20,10.19,10.48,11.11,11.84,12.68 MET27004 | No 27004 | Gunmetal - Metalcote | GU 5.2 | Metallic,90,92,96,-10855328,39.20,0.22,-2.42,10.13P,3.86,3.95,10.78,D65/10°,SCI,,UV400,,11.74,11.74,11.68,11.60,11.71,11.75,11.69,11.55,11.40,11.25,11.10,10.98,10.89,10.81,10.75,10.70,10.61,10.56,10.47,10.33,10.34,10.56,10.76,10.93,10.90,10.75,10.64,10.91,11.90,13.76,16.06 MET27004 | No 27004 | Gunmetal - Metalcote | GU 5.2 | Metallic,77,78,83,-11710893,33.58,0.38,-2.81,9.24P,3.31,3.24,7.81,D65/10°,SCE,,UV400,,8.77,8.70,8.62,8.57,8.69,8.72,8.69,8.55,8.41,8.24,8.12,8.00,7.91,7.80,7.75,7.68,7.68,7.63,7.52,7.39,7.42,7.62,7.83,8.00,7.99,7.82,7.73,7.97,8.98,10.78,13.08 Edited January 12 by Casey 1
TheKinksFan Posted January 13 Posted January 13 (edited) @Casey, do happen to have paint chips for Dupont MAP colours? If there even exist samples of them, I'm not sure. Especially the Dark Earth, Dark Green and Sky equivalents 71-009, 71-013 and 71-021 are paints that are needed quite often, but there are no dedicated hobby paints for them. According to Nick Millman 71-013 is pretty close to fs 34052 or 34077, and 71-009 to fs 30145. I have Hataka's C246 and C285 which are supposed to match fs 14077 and 30145, but I'm not entirely convinced that they match what they are supposed to. Edited January 13 by TheKinksFan
PhantomBigStu Posted January 13 Author Posted January 13 2 hours ago, TheKinksFan said: @Casey, do happen to have paint chips for Dupont MAP colours? If there even exist samples of them, I'm not sure. Especially the Dark Earth, Dark Green and Sky equivalents 71-009, 71-013 and 71-021 are paints that are needed quite often, but there are no dedicated hobby paints for them. According to Nick Millman 71-013 is pretty close to fs 34052 or 34077, and 71-009 to fs 30145. I have Hataka's C246 and C285 which are supposed to match fs 14077 and 30145, but I'm not entirely convinced that they match what they are supposed to. Not Casey but I have a set of digital chips but no idea how accurate they are, will post them later. 1
PhantomBigStu Posted January 13 Author Posted January 13 (edited) On 1/13/2025 at 10:24 AM, PhantomBigStu said: Not Casey but I have a set of digital chips but no idea how accurate they are, will post them later. Here we go, the roundel colours have no close equivalents in any standard (which makes me even more sceptical they are real) btw for 71-062 vallejo model color Azure blue is close edit: also thanks for the data casey, couldn't get it to work last time you sent me data, have this time, had to use text to columns on it, took a while to figure that out Edited January 30 by PhantomBigStu
Casey Posted January 13 Posted January 13 I do have many original FS chips, in multiple versions from multiple years (the colors differ!). I could give some information there too
PhantomBigStu Posted January 27 Author Posted January 27 (edited) On 1/13/2025 at 11:11 AM, PhantomBigStu said: Here we go, the roundel colours have no close equivalents in any standard (which makes me even more sceptical they are real) btw for 71-062 vallejo model color Azure blue is close edit: also thanks for the data casey, couldn't get it to work last time you sent me data, have this time, had to use text to columns on it, took a while to figure that out Managed to delete the original and took this opportunity to add the two very good revell aqua matches to the reupload, had also discovered I had made a typo in the dark green so updated with the new shade and its new match Edited January 29 by PhantomBigStu 1
stevehnz Posted January 27 Posted January 27 Remind me again please Stu, what are you matching to what there. I can't find make sense of any of those numbers above. I thought the 71-s would be Vallejo Model air but they don't agree with my list. The RAL one is clear obviously & the ones starting with 3 are FS but it all gets a bit hazy from there on. Steve.
PhantomBigStu Posted January 27 Author Posted January 27 (edited) 20 minutes ago, stevehnz said: Remind me again please Stu, what are you matching to what there. I can't find make sense of any of those numbers above. I thought the 71-s would be Vallejo Model air but they don't agree with my list. Steve. Ah sorry right yes, added a title, they are DuPont RAF equivalent colours used in lend lease aircraft Edited January 27 by PhantomBigStu 1
Graham Boak Posted January 27 Posted January 27 Strictly the Air Ministry (including the Fleet Air Arm) equivalent colours used on aircraft paid for by the UK pre-Lend-Lease. The terms of Lease-Lend (as the US called it) required aircraft to be delivered in standard US colour schemes, but some companies continued to use the equivalent colours.
Olmec Head Posted January 28 Posted January 28 On 17/12/2024 at 21:22, Casey said: Thank you for kind words! I have those paints, I just never got to measure them in any way. After I finish with ICM, I'll get back to Tamiya and finish the range. Dear @Casey, sorry where you able to measure the Tamiya RAF paints please?
Troy Smith Posted January 28 Posted January 28 40 minutes ago, Olmec Head said: Dear @Casey, sorry where you able to measure the Tamiya RAF paints please? Do you mean XF-81,82, 83? By eye against the RAF museum chips 81 Dark Green is a bit too brown, but nothing terrible 82 Ocean Grey is too dark and too blue. Ocean Grey has a subtle green blue hue. 83 Medium Sea Grey is an olive hued grey, MSG like all the sea grey family has a subtle purple blue. I made eye mixes of OG by adding white and dash of yellow to 82, and MSG by adding a lot of white and dab of red to 82. The subtle green is obvious when not next to green This perhaps overemphasised the purple blue of MSG Bur looks much greyer against blue sky Mixing the colours made me appreciate how carefully they had been selected, they work very well for their intended purpose. HTH
TheKinksFan Posted January 28 Posted January 28 What kind of white did RAF use during the war? I have a Special Hobby Sunderland ordered, and I'm wondering should I use US Insignia White or something else.
Graham Boak Posted January 28 Posted January 28 The RAF and FAA had their own Air Ministry colours, one of which was White. For a Sunderland you will need both gloss and matt. 1
JonFlim2 Posted January 28 Posted January 28 On 1/13/2025 at 8:05 AM, TheKinksFan said: @Casey, do happen to have paint chips for Dupont MAP colours? If there even exist samples of them, I'm not sure. Especially the Dark Earth, Dark Green and Sky equivalents 71-009, 71-013 and 71-021 are paints that are needed quite often, but there are no dedicated hobby paints for them. Colourcoats do/did them: 1
TheKinksFan Posted January 28 Posted January 28 1 hour ago, JonFlim2 said: Colourcoats do/did them It's a pity that that they are enamels, which I don't use. And the shipping to Finland would also be a problem. They are also a Bronze Green 9. Real Colors does have too, but I think it looks somehow bluish. 1
Casey Posted January 28 Posted January 28 10 hours ago, Olmec Head said: Dear @Casey, sorry where you able to measure the Tamiya RAF paints please? Not yet and I definitely should move my butt to do that... I am now focused on one paint related activity that I hope will bear larger fruit for the community, but I should do it at least as a side hobby 5
Casey Posted January 29 Posted January 29 (edited) XF81, XF82 and XF83, so now you know: Quite good match overall but very slightly too yellow and too red. (meaning, too brown) Using industry standard 2.0DE it is borderline good - it is bit too light and too blue. That one is not good. It is way too yellow. @Troy Smith was almost spot on there (exception: my XF82 is slightly too light compared to Ocean Grey, but it is still too blue. Can be either the batch difference or the fact I do not spray them anywhere but use drawdown cards) Edited January 29 by Casey 1 3
PhantomBigStu Posted January 29 Author Posted January 29 (edited) On 1/27/2025 at 1:14 PM, PhantomBigStu said: Managed to delete the original and took this opportunity to add the two very good revell aqua matches to the reupload, had also discovered I had made a typo in the dark green so updated with the new shade and its new match Happened again, changed the filename just in case it was deleted for bs copyright reasons Edited January 31 by PhantomBigStu
