2 hours ago, PhantomBigStu said:
Got this set, thought it fair to report my findings, hard to judge as I’m comparing paint to digital samples but it’s a mixed bag.
Maybe I should get the whole set and measure how much their colors match anything? I had pretty bad experience with previous gen
Their on-bottle equivalence of RAF Sky with FS 34412 is worrying.
I know that their "RAF Night" in this set in fact AK 11895 - which is IJN Q1 (anti glare blue black). I also have suspicion that the RAF Night sample from the book is not exactly right since it does not seem to contain any ultramarine blue as it should.
In my opinion, "scale reduction factor" should never be applied to the paint before deciding on what scale of model you are actually going to do. I really hope it is not just "we just got closest lighter pantone/fs/whatever commercial color match for our machines we had in databases and call it a day"
Your money and time so up to you, but will say the 3G stuff is lovely to use as brush a painter though their digital samples and what the paint can be differs, and I’ve picked up loads and in fact are replacing Vallejo with them over time
up to you,
I think that's the only way for me to get any objective opinion about their color matches :) They are not cheap though, you could get a spectrophotometer for a price of their paint set!
Edited by Casey
Certainly don’t do that on my account, though I’d appreciate the dedication….if you do it offer your services to Ak so at least their awful digital patches can be updated…..
I see many people recommending AK products as good color matches, so I'd like to measure their acrylics, considering they name the works of @Nick Millman and Jürgen Kiroff as their color references.
Edited by Casey
I can only comment on the AK Real Colors but Mike Starmer, renowned for his work on British WW2 AFV colours, said that after all the extensive work they did together to get them accurate AK went out and butchered most of the final colours with their "scale reduction factor" idea. That was Starmer's opinion of course and I'm not sure if Millman or Kiroff ever commented on the final result. I don't model AFVs so can't comment further but I have most of their British and Luftwaffe WW2 sets and, when compared to the excellent Tamiya mixes you've provided in the past, they are all off. Some more so than others (eg: their RLM76 is very poor being too grey, but their RLM65(1938) is actually an acceptable match for the RLM 76 Tamiya Mix)
Whether the AK 3G Acrylics are significantly different to the AK Real Colors range I do not know although the dreaded "scale reduction factor" pops up again in their marketing material and one would suspect they'd try and use the same pigment formulations.
it was worse, this is what I found when I went hunting
discussed here
https://www.britmodeller.com/forums/index.php?/topic/235049761-british-olive-drab-no15/page/2/#elControls_3252695_menu
relevant quote
"Regarding the AK book.  To be honest I am livid and disgusted at the way they published the British section.  My submitted original text was requested to be shortened, which I did.  They then edited that without my knowledge. I sent complete sets of camouflage diagrams with copies of the official orders.  These orders were totally ignored.   Then redrew some of the disruptive diagrams in their own style and colours transposed onto mostly American vehicles, apparently the British didn't have any of their own.  To cap it they then applied a disruptive pattern from one tank type onto another type, it doesn't fit of course.  The ultimate was putting the pattern for the Greek based A10s onto a Crusader which never carried the design nor deployed to Greece.  Samples of their paint were sent to me for assessment.  None were accurate, not even close, which I reported back with larger samples.  New samples then arrived for testing, still not right.  In discussion I discovered that they were matching under 'daylight' lighting!  FGS are they not sharp or what?  I gave them up as a waste of my time, I told them that too.  Rant over."
I have two AK sets
this
https://modelingmadness.com/scott/accessories/ak/ak2010.htm
which are not good,  perhaps of use for US made colors for the Dark Green and Dark Earth, as in 'pine green' and 'milky tan'  but way off for MAP Dark Green and Dark Earth, and  muddy MSG,  blueish Ocean Grey, muddy Sky.....  the Grey Green isn't too bad
I also have  US Navy set that is worse....
HTH
Sounds like I’ve opened a can of worms praising Ak…..also think I was overselling how close their raf dark green is (bottom row of green) still will be using it on my upcoming wimpy at least initially to see how it really looks. As for the dark earth (centre left), I think it looks good for DuPont 71-009 dark earth IMG-4158.jpg
Edited by PhantomBigStu
some of what they make maybe great, but they have made mistakes and the mangling of Mike Starmer's research is inexcusable.
Possibly....  but it's not sold as that...
Anyway, whole point of these discussions is to find out these problems and document them, so others don't have too.
cheers
T
Decided to try the ak dark green on a build, I stilll don't think its olive enough to be a great MAP Dark Green but its not too light at least as Ive finally accepted BS241 is darker, will be trying revell aqua 68 at some point to compare so for now its going to be my choice for MAP Dark Green.
I have a question, I have a decent match thanks to casey for MAP EDSG, but BS640 is a much darker grey and out of xtracrylix version (and it sold out) so am a loss what to use on my Sea Vixen
Target: BS640 Extra Dark Sea Grey
    Matches in: Humbrol (compared with 170 samples)
        DE00: 1.41 - DB0123 | No 123 | Extra Dark Sea Grey - Satin | GU 18.4
       100x100100x100
    Matches in: Revell (compared with 86 samples)
        DE00: 2.21 - 36174 | Gunship grey | GU 3.1
       100x100100x100
    Matches in: Vallejo Air (compared with 254 samples)
        DE00: 1.64 - 71.097 | Medium Gunship Gray | Gris Medio USAF | FS36118 | ANA603 | GU 3.1
       100x100100x100
    Matches in: Tamiya (compared with 40 samples)
        DE00: 2.21 - XF-24 | Dark Grey | GU 5.8
       100x100100x100
Here you go. Nothing crazy good (from what I had measured). I am working on AK Interactive 3G, that will come in a separate thread in a couple of weeks (thats a lot of paints to measure).
Thanks Casey, guess its either use the h123 I have despite being quite different or play the AK lottery....
Working on removing the lottery part. The drawdowns are drying:
I used 100 micron wet film for those, most of them cover pretty nicely, yellow is the usual exception but that is normal. RLM's look suspicious to me.
Good luck with it, I have 4 of their RLM's so I await the result, also might play the AK lottery anyway as I've now got two builds that need EDSG
I did first 30 paints (AK11801 till AK11830) which covers German WWI and RLM's till RLM78 and they are matches to nothing in particular...
I cant even pin point the single reference they use. It is not Lufwaffe Colours 1945-1945 - Michael Ullmann. It is not Official Luftwaffe Color Chart - Eagle Editions Ltd. 1998. It is not Merrick and Kiroff neither. I have some ancient publications or some coming from japaneese sources, I can to compare with that too but in reality RLM's, especially up to 74,75,76 don't differ that much between publications, those are pretty well known colors after all since actual color standard samples exist so there is no reason to reinvent them. I don't even know how to present it, they colors match quite randomly to nothing in particular.
Edited by Casey
  • Thanks 2
  • Sad 3
Officially they worked with Ullmann I believe for their Real Colors line. That's what I assume the AK 3rd Gen would also be based on. It sounds like their interpretation of "scale effect" has made them completely off though.
Sad to hear I guess to quote Troy Smith the blindfolded colourblind Vallejo baboon must have a second job.....
just for the record, I have 04, 65 (41) 72 and 73
  • Haha 2
  • Sad 1
Ok I'll show you an example. This is compared to Ullmann references. AK is on the RIGHT side
RLM74:
100x100100x100 - DE 2.63, AK is DARKER
RLM75:
100x100100x100 - DE 11.32 (!). AK is DARKER
RLM76:
100x100100x100 - DE 1.2
I'll try to get some old Ullmann publications, I swear I had some somewhere...
Edited by Casey
  • Confused 1
Bummer. I strongly suspected they were quite off and now my suspicions are confirmed.
 Unless they are based upon real samples and all the references are wrong 🤪 their Luftwaffe range is BAD!
Nevertheless, THANKS for sharing your finds with us.
( Edit: I am only happy using their RLM 02 which is a very easy color to match from different brands and very difficult to get wrong. How is their RLM04 standing up btw@Casey)
Edited by frapes75
a sobering tale regarding AK, the book is Real Colors of WW2 armour, and the British section is credited to Mike Starmer,  see https://mafva.co.uk/?p=2607  who is the leading researcher on British Armour colours, and produced books with actual paint chips,
@Casey  reason for the 'scale reduction factor' being all over the place?
"On the subject of AK paints. I have 7 samples of the Middle East colours for the desert and Italy. Greatly disappointing. Only Light Mud is reasonably close to the appearance of this in photographs but currently lacking a standard would do. Khaki Green 3 is far too light and ginger, lacks depth and the green tinge of the original. Slate 4 is too light and green, should be darker and more grey, Silver Grey 28 is not even close, being too light and very sickly yellow. Portland Stone is too light and lacks the slight green tinge it should have. Light Stone 61 is too dark and too red, Desert Pink is a bright shocking 'girly' hue nothing like SCC.11b , should be duller and earthy in appearance. SCC.14 Blue-black is dark but too red."
So, AK, despite having been in contact with Mike Starmer see https://mafva.co.uk/?p=2607  who is the leading researcher on British Armour colours, and produced books with actual paint chips,  they manage the above
Peter principle, been promoted to book editing and supervising the matching process by AK after success at Vallejo...
  • Confused 1
  • Sad 1
My hope is that by pure luck they will serendipitously match to something, like this:
(matches <3.0 DE)
Target: RAF05 - Extra Dark Sea Green | GU 2.9
    Matches in: AK Interactive - 3G Acrylics (compared with 30 samples)
        DE00: 1.24 - AK11801 - WWI German Fokker Grey | GU 0.1, 0.8, 3.2
       100x100100x100
Target: Dark Olive Drab 41 | GU 0.8
        DE00: 1.09 - AK11822 - RLM 71 | GU 0.1, 0.6, 4.0
       100x100100x100
Target: Maroon (A-N) | GU 28.4
        DE00: 2.62 - AK11810 - PC12 | GU 0.1, 0.8, 3.7
       100x100100x100
Target: Olive Drab 22 | GU 59.7
        DE00: 2.46 - AK11822 - RLM 71 | GU 0.1, 0.6, 4.0
       100x100100x100
Target: Rust Brown 34 | GU 0.7
        DE00: 1.83 - AK11805 - WWI German Red Brown | GU 0.0, 0.4, 3.0
       100x100100x100
Target: ANA504 | Olive Drab 504 | GU 60.5
        DE00: 2.52 - AK11822 - RLM 71 | GU 0.1, 0.6, 4.0
       100x100100x100
And a suspiciously lot in FS range:
Target: Medium Green 34079 | GU 0.7
        DE00: 1.68 - AK11821 - RLM 70 | GU 0.1, 0.8, 4.0
       100x100100x100
Target: Orange Yellow 13538 | GU 68.5
        DE00: 1.48 - AK11813 - RLM 04 | GU 1.4, 2.6, 5.0 | Opacity 81.54%
       100x100100x100
Target: Seaplane Gray 26081 | GU 86.8
        DE00: 1.97 - AK11826 - RLM 75 | GU 0.1, 0.9, 3.4
       100x100100x100
Target: 36375 | GU 1.7
        DE00: 2.58 - AK11806 - WWI German Light Blue | GU 1.1, 7.4, 30.9
       100x100100x100
Once I measure them all, I'll publish my findings. It's great paint otherwise, just needs new labels ;)
Edited by Casey
Latest batch of AK arrived, lottery at least when it comes to the EDSG hasn't paid off, lacks the blue tint
xtracrylix......I hate paint :( edit: should for balance say I’m happy with 3 of the others in the order (of course how they actually are is another question), though the other raf shade (msg) I’m not sure about yet shade wise its looks good but its darker than my other MSG paints, one I want to figure out as I'd like to get some more for a potential big build
edit2: from doing a totally unscientific test of sticking the MSG RGB chip in the middle of a humbrol grey from caseys data and then painting the real things suggests its potentially quite good
  • Sad 1
  • 1 month later...
As it came up in another thread again, just to note Extra Dark Sea Grey is one colour that is very much different between the wartime MAP Shade and the postwar BSc Shade
