Casey Posted February 13, 2023 Share Posted February 13, 2023 (edited) 9 hours ago, Yes_Man said: Apparently the best match for these were given by Ian Huntley as Methuen 7F4, 7E5 and 5E3 respectively. Here are them in the book: Those are really interesting colors. I've measured them with spectrophotometer and tried to run a search. Here is what I got: Target: 5E3, RGB: #867E6D (L*=52.79, a=1.08, b=10.28) DE00: 0.63 - #88806E - Humbrol - DB0072 | No 72 | Khaki Drill - Matt | GU 6.8 (L*=53.30, a=1.36, b=10.46) DE00: 1.56 - #897E6A - Humbrol - A6238 | No 187 | Dark Stone - Matt | GU 1.5 (L*=52.86, a=1.90, b=12.17) DE00: 2.67 - #858271 - Hataka - HTK-A023 | Grey (RLM02) | GU 14.1 (L*=53.77, a=-0.71, b=9.39) Target: 7E5, RGB: #8C6C5C (L*=47.76, a=11.41, b=12.87) DE00: 2.56 - #8F705D - Humbrol - AB0249 | No 249 | RLM 79 Sandgelb - Matt | GU 1.5 (L*=49.29, a=10.21, b=14.76) Target: 7F4, RGB: #6A5D56 (L*=40.40, a=4.31, b=6.03) No matches with DE00<=3.00 So I did some simple mixes. I've used Tamiya because I don't expect you to go full on with Golden Fluids Those are theoretical matches and all ratios are using MASS not volume, so you'd need to measure the paint on the scales. 5E3 Target: #867E6D, Mixture: #877D69 XF-2 Flat White: 7 XF-1 Flat Black: 1 XF-4 Yellow Green: 4 XF-7 Flat Red: 1 DE00: 1.11 7E5 Target: #8C6C5C, Mixture: #8B685A XF-4 Yellow Green: 2 XF-7 Flat Red: 3 XF-12 J.N. Grey: 3 XF-13 J.A. Green: 1 DE00: 1.08 7F4 Target: #6A5D56, Mixture: #6B5E55 XF-2 Flat White: 2 XF-7 Flat Red: 2 XF-13 J.A. Green: 3 DE00: 0.74 Here are a bit simpler but less accurate recipes. Considering Lifecolor calls 5.40 DE a "match" I think they are not bad neither, even if you mix those by volume.. 5E3 Target: #867E6D, Mixture: #827B6C XF-10 Flat Brown: 1 XF-13 J.A. Green: 1 XF-14 J.A. Grey: 5 DE00: 1.50 7E5 Target: #8C6C5C, Mixture: #8C6E5E XF-10 Flat Brown: 1 XF-15 Flat Flesh: 2 DE00: 2.21 7F4 Target: #6A5D56, Mixture: #6F5D56 XF-7 Flat Red: 1 XF-12 J.N. Grey: 1 XF-13 J.A. Green: 1 DE00: 1.83 Edited February 13, 2023 by Casey 2 3 Link to comment Share on other sites More sharing options...
Yes_Man Posted February 13, 2023 Share Posted February 13, 2023 Spoiler 8 minutes ago, Casey said: Here are them in the book: Those are really interesting colors. I've measured them with spectrophotometer and tried to run a search. Here is what I got: Target: 5E3, RGB: #867E6D (L*=52.79, a=1.08, b=10.28) DE00: 0.63 - #88806E - Humbrol - DB0072 | No 72 | Khaki Drill - Matt | GU 6.8 (L*=53.30, a=1.36, b=10.46) DE00: 1.56 - #897E6A - Humbrol - A6238 | No 187 | Dark Stone - Matt | GU 1.5 (L*=52.86, a=1.90, b=12.17) DE00: 2.67 - #858271 - Hataka - HTK-A023 | Grey (RLM02) | GU 14.1 (L*=53.77, a=-0.71, b=9.39) Target: 7E5, RGB: #8C6C5C (L*=47.76, a=11.41, b=12.87) DE00: 2.56 - #8F705D - Humbrol - AB0249 | No 249 | RLM 79 Sandgelb - Matt | GU 1.5 (L*=49.29, a=10.21, b=14.76) Target: 7F4, RGB: #6A5D56 (L*=40.40, a=4.31, b=6.03) No matches with DE00<=3.00 So I did some simple mixes. I've used Tamiya because I don't expect you to go full on with Golden Fluids Those are theoretical matches and all ratios are using MASS not volume, so you'd need to measure the paint on the scales. 5E3 Target: #867E6D, Mixture: #877D69 XF-2 Flat White: 7 XF-1 Flat Black: 1 XF-4 Yellow Green: 4 XF-7 Flat Red: 1 DE00: 1.11 7E5 Target: #8C6C5C, Mixture: #8B685A XF-4 Yellow Green: 2 XF-7 Flat Red: 3 XF-12 J.N. Grey: 3 XF-13 J.A. Green: 1 Spoiler DE00: 1.08 7F4 Target: #6A5D56, Mixture: #6B5E55 XF-2 Flat White: 2 XF-7 Flat Red: 2 XF-13 J.A. Green: 3 DE00: 0.74 Here are a bit simpler but less accurate recipes. Considering Lifecolor calls 5.40 DE a "match" I think they are not bad neither, even if you mix those by volume.. 5E3 Target: #867E6D, Mixture: #827B6C XF-10 Flat Brown: 1 XF-13 J.A. Green: 1 XF-14 J.A. Grey: 5 DE00: 1.50 7E5 Target: #8C6C5C, Mixture: #8C6E5E XF-10 Flat Brown: 1 XF-15 Flat Flesh: 2 DE00: 2.21 7F4 Target: #6A5D56, Mixture: #6F5D56 XF-7 Flat Red: 1 XF-12 J.N. Grey: 1 XF-13 J.A. Green: 1 DE00: 1.83 I really cannot thank you enough for your help, especially with the Tamiya mixes! You're doing us all a great service with all the paint data. 1 Link to comment Share on other sites More sharing options...
Casey Posted February 17, 2023 Share Posted February 17, 2023 (edited) I've hid content of this post (you can still see it if you open the spoiler) but please look at the most updated entry in this forum thread to see most current measurements Spoiler I am working on measuring all Tamiya paints for my virtual Tamiya mixer, so as a side effect I get the unmixed measurements too Currently got them up to XF-54, so here is the updated RAF MAP chart. Paints measured and compared, in addition to the previous post: XF-13 | J.A. Green XF-14 | J.A. Grey XF-15 | Flat Flesh XF-16 | Flat Aluminum | Metallic XF-17 | Sea Blue XF-18 | Medium Blue XF-19 | Sky Grey XF-20 | Medium Grey XF-21 | Sky XF-22 | RLM Grey XF-23 | Light Blue XF-24 | Dark Grey XF-25 | Light Sea Grey XF-26 | Deep Green XF-27 | Black Green XF-28 | Dark Copper | Metallic XF-49 | Khaki XF-50 | Field Blue XF-51 | Khaki Drab XF-52 | Flat Earth XF-53 | Neutral Grey XF-54 | Dark Sea Grey Targets set: British Aviation Colours of World War Two - Blue Target: RAF01 - Light Earth | GU 4.0, RGB: #A98C68 (L*=59.33, a=8.24, b=22.00) Found a match in: Humbrol (compared with 182 paints) DE00: 0.93 - #A68A67 - Humbrol - DB0093 | No 93 | Desert Yellow - Matt | GU 4.5 (L*=58.41, a=7.73, b=21.68) Found a match in: Revell (compared with 86 paints) DE00: 2.45 - #B08B64 - Revell - 36117 | Africa brown | GU 3.1 (L*=59.57, a=11.29, b=24.94) Target: RAF02 - Dark Earth | GU 3.3, RGB: #77634D (L*=42.79, a=6.21, b=14.76) Found a match in: Humbrol (compared with 182 paints) DE00: 0.72 - #76644F - Humbrol - DB0029 | No 29 | Dark Earth - Matt | GU 3.6 (L*=42.99, a=5.84, b=13.66) Found a match in: Revell (compared with 86 paints) DE00: 2.51 - #776347 - Revell - 36182 | Dark earth RAF | GU 2.1 (L*=42.53, a=5.36, b=18.01) Found a match in: Hataka (compared with 10 paints) DE00: 2.97 - #7A6757 - Hataka - HTK-A009 | Dark Earth | GU 9.1 (L*=44.46, a=6.03, b=10.99) Found a match in: Lifecolor (compared with 6 paints) DE00: 0.84 - #7A644D - Lifecolor - UA 547 | Dark Earth | *FS 30118 | GU 6.3 (L*=43.37, a=6.66, b=15.72) Target: RAF03 - Light Green | GU 2.9, RGB: #646857 (L*=42.92, a=-3.11, b=8.69) Found a match in: Humbrol (compared with 182 paints) DE00: 0.82 - #626755 - Humbrol - AA2252 | No 252 | RLM 82 Olivgrun - Matt | GU 2.2 (L*=42.38, a=-3.59, b=9.28) Found a match in: Vallejo (compared with 34 paints) DE00: 1.69 - #676B5D - Vallejo - 71.260 | Light Grey RLM63 | RLM63 Hellgrau | RLM63 | GU 1.5 (L*=44.18, a=-3.05, b=7.04) Found a match in: Lifecolor (compared with 6 paints) DE00: 1.21 - #616553 - Lifecolor - UA 548 | Light Green | FS 34102 | GU 6.4 (L*=41.73, a=-3.57, b=8.95) Target: RAF04 - Dark Green | GU 2.6, RGB: #55584C (L*=36.49, a=-2.32, b=6.25) Found a match in: Humbrol (compared with 182 paints) DE00: 1.56 - #58584B - Humbrol - AB0253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 0.8 (L*=36.68, a=-1.32, b=7.09) Found a match in: Revell (compared with 86 paints) DE00: 2.29 - #54544C - Revell - 36142 | Yellowish olive | GU 1.8 (L*=35.30, a=-1.02, b=4.63) Found a match in: Hataka (compared with 10 paints) DE00: 1.64 - #525347 - Hataka - HTK-A016 | Dark Green | GU 9.6 (L*=34.74, a=-2.00, b=7.00) Found a match in: Tamiya (compared with 34 paints) DE00: 2.43 - #4E5447 - Tamiya - XF-13 | J.A. Green (L*=34.77, a=-3.93, b=6.77) Target: RAF05 - Extra Dark Sea Green | GU 2.9, RGB: #526059 (L*=39.26, a=-5.90, b=2.28) Found a match in: Humbrol (compared with 182 paints) DE00: 1.69 - #4D5C57 - Humbrol - AA1612 | No 149 | Dark Green - Matt | GU 2.9 (L*=37.84, a=-6.41, b=1.11) Found a match in: Revell (compared with 86 paints) DE00: 2.63 - #505F52 - Revell - 36139 | Dark green | GU 2.2 (L*=38.49, a=-7.02, b=5.24) Target: RAF06 - Grey Green | GU 3.2, RGB: #738971 (L*=54.38, a=-9.96, b=10.13) No matches with DE00<=3.00 Target: RAF07 - Medium Sea Grey | GU 3.0, RGB: #889098 (L*=59.60, a=-1.97, b=-5.01) Found a match in: Revell (compared with 86 paints) DE00: 2.35 - #808C93 - Revell - 36157 | Grey | RAL 7000 | GU 3.5 (L*=57.66, a=-3.24, b=-5.09) Target: RAF08 - Dark Sea Grey | GU 3.5, RGB: #6A7078 (L*=47.08, a=-0.75, b=-5.23) Found a match in: Humbrol (compared with 182 paints) DE00: 2.69 - #696E71 - Humbrol - DB0156 | No 156 | Dark Camouflage Grey - Satin | GU 7.3 (L*=46.32, a=-1.22, b=-2.34) Target: RAF09 - Extra Dark Sea Grey | GU 4.4, RGB: #5C626A (L*=41.40, a=-0.76, b=-5.06) Found a match in: Humbrol (compared with 182 paints) DE00: 1.06 - #5D6369 - Humbrol - AA1376 | No 125 | US Dark Grey - Satin | GU 11.4 (L*=41.86, a=-1.20, b=-4.16) Found a match in: Revell (compared with 86 paints) DE00: 0.49 - #5E626A - Revell - 36174 | Gunship grey | GU 3.1 (L*=41.71, a=-0.66, b=-4.58) Found a match in: Tamiya (compared with 34 paints) DE00: 2.59 - #5A5D61 - Tamiya - XF-24 | Dark Grey (L*=39.52, a=-0.44, b=-2.77) Target: RAF10 - Ocean Grey | GU 5.5, RGB: #6A7277 (L*=47.77, a=-2.68, b=-3.25) Found a match in: Humbrol (compared with 182 paints) DE00: 1.51 - #6B7374 - Humbrol - AA0059 | No 5 | Dark Admiralty Grey - Gloss | GU 90.8 (L*=47.89, a=-2.95, b=-1.64) Found a match in: Revell (compared with 86 paints) DE00: 1.76 - #646F75 - Revell - 36179 | Greyish blue | RAL 7031 | GU 1.9 (L*=46.29, a=-2.90, b=-4.43) Target: RAF11 - Light Slate Grey | GU 3.0, RGB: #677267 (L*=46.63, a=-5.35, b=4.49) Found a match in: Humbrol (compared with 182 paints) DE00: 2.08 - #636C63 - Humbrol - AA0343 | No 31 | Slate Grey - Matt | GU 7.5 (L*=44.65, a=-4.58, b=4.22) Found a match in: Hataka (compared with 10 paints) DE00: 3.00 - #66776C - Hataka - HTK-A025 | Interior Grey-Green | GU 17.4 (L*=48.37, a=-7.70, b=4.51) Target: RAF12 - Dark Slate Grey | GU 4.2, RGB: #676960 (L*=43.76, a=-1.34, b=4.17) Found a match in: Humbrol (compared with 182 paints) DE00: 2.40 - #60625B - Humbrol - AA7224 | No 224 | Dark Slate Grey - Matt | GU 3.0 (L*=41.19, a=-1.47, b=3.58) Found a match in: Revell (compared with 86 paints) DE00: 2.20 - #626660 - Revell - 36167 | Greenish grey | RAL 7009 | GU 2.3 (L*=42.63, a=-2.58, b=3.12) Target: RAF13 - Sky Grey | GU 3.0, RGB: #A5A9AA (L*=69.08, a=-1.21, b=-0.68) No matches with DE00<=3.00 Target: RAF14 - Sky | GU 3.3, RGB: #B3BBA3 (L*=74.26, a=-5.19, b=11.14) Found a match in: Revell (compared with 86 paints) DE00: 1.72 - #B0BDA5 - Revell - 36159 | Sky RAF | GU 3.4 (L*=74.60, a=-6.50, b=10.16) Target: RAF15 - Deep Sky | GU 4.8, RGB: #385379 (L*=36.04, a=-2.70, b=-22.79) Found a match in: Revell (compared with 86 paints) DE00: 1.58 - #425679 - Revell - 36156 | Blue | RAL 5000 | GU 2.2 (L*=37.26, a=-1.39, b=-20.70) Target: RAF16 - Sky Blue | GU 4.4, RGB: #B6C3C8 (L*=78.06, a=-3.78, b=-3.60) No matches with DE00<=3.00 Target: RAF17 - Azure Blue | GU 3.3, RGB: #899DC6 (L*=65.56, a=-1.32, b=-22.16) No matches with DE00<=3.00 Target: RAF18 - Light Mediterranean Blue | GU 3.2, RGB: #5F7290 (L*=48.39, a=-2.32, b=-17.30) No matches with DE00<=3.00 Target: RAF19 - Dark Mediterranean Blue | GU 2.7, RGB: #415373 (L*=36.05, a=-1.06, b=-19.18) Found a match in: Humbrol (compared with 182 paints) DE00: 2.77 - #3C4D76 - Humbrol - DB0025 | No 25 | Blue - Matt | GU 5.1 (L*=34.35, a=0.98, b=-23.90) Found a match in: Revell (compared with 86 paints) DE00: 1.27 - #425679 - Revell - 36156 | Blue | RAL 5000 | GU 2.2 (L*=37.26, a=-1.39, b=-20.70) Target: RAF20 - P.R.U. Blue | GU 2.9, RGB: #536E79 (L*=45.13, a=-7.73, b=-8.87) Found a match in: Humbrol (compared with 182 paints) DE00: 2.42 - #5B6F79 - Humbrol - AB0230 | No 230 | Pru Blue - Matt | GU 1.3 (L*=46.03, a=-5.55, b=-7.54) Target: RAF21 - Middle Stone | GU 3.1, RGB: #A6864C (L*=56.71, a=8.21, b=34.64) No matches with DE00<=3.00 Target: RAF22 - Night | GU 2.2, RGB: #3A3C3D (L*=25.10, a=-0.20, b=-1.08) Found a match in: Humbrol (compared with 182 paints) DE00: 0.14 - #3A3B3D - Humbrol - DB0021 | No 21 | Black - Gloss | GU 45.3 (L*=25.05, a=-0.28, b=-1.01) Found a match in: Revell (compared with 86 paints) DE00: 0.97 - #38393A - Revell - 36302 | Black | RAL 9005 | GU 11.1 (L*=23.78, a=-0.19, b=-0.92) Found a match in: Tamiya (compared with 34 paints) DE00: 0.33 - #393B3D - Tamiya - XF-1 | Flat Black | GU 3.9 (L*=24.80, a=-0.36, b=-1.18) Target: RAF23 - Yellow | GU 4.6, RGB: #E7A434 (L*=70.29, a=20.02, b=61.72) Found a match in: Humbrol (compared with 182 paints) DE00: 2.65 - #F1A618 - Humbrol - DB0154 | No 154 | Insignia Yellow - Matt | GU 9.6 (L*=71.51, a=23.83, b=71.17) Found a match in: Vallejo (compared with 34 paints) DE00: 2.61 - #DBA02C - Vallejo - 71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.5 (L*=68.10, a=16.99, b=62.34) Target: RAF24 - Red | GU 2.7, RGB: #8D4C3F (L*=39.34, a=25.19, b=19.00) No matches with DE00<=3.00 Target: RAF25 - Blue | GU 2.4, RGB: #3B475A (L*=30.36, a=-1.24, b=-12.26) Found a match in: Vallejo (compared with 34 paints) DE00: 2.59 - #444E61 - Vallejo - 71.005 | Grey Blue | Azul Gris | RAL5008 | GU 1.5 (L*=33.44, a=-0.59, b=-11.57) Target: RAF26 - Aluminium | GU 58.9 | Metallic, RGB: #CECED0 (L*=82.90, a=-0.01, b=-0.91) Found a match in: Humbrol (compared with 182 paints) DE00: 0.93 - #D1D2D4 - Humbrol - MET27002 | No 27002 | Polished Aluminium - Metalcote | GU 10.8 | Metallic (L*=84.26, a=0.04, b=-1.08) Found a match in: Tamiya (compared with 34 paints) DE00: 0.85 - #CACBCD - Tamiya - XF-16 | Flat Aluminum | Metallic (L*=81.66, a=0.01, b=-1.09) Target: RAF27 - Matt Red | GU 2.8, RGB: #A5353B (L*=38.79, a=42.87, b=21.06) Found a match in: Humbrol (compared with 182 paints) DE00: 1.10 - #A0383A - Humbrol - DB0153 | No 153 | Insignia Red - Matt | GU 4.1 (L*=38.25, a=40.22, b=20.78) Found a match in: Revell (compared with 86 paints) DE00: 1.45 - #A52C37 - Revell - 36134 | Italian Red | GU 88.5 (L*=37.37, a=45.10, b=22.20) Found a match in: Tamiya (compared with 34 paints) DE00: 2.60 - #A42B31 - Tamiya - XF-7 | Flat Red | GU 1.0 (L*=36.83, a=45.63, b=25.20) Target: RAF28 - Matt Blue | GU 5.4, RGB: #40517A (L*=35.74, a=1.66, b=-24.28) Found a match in: Humbrol (compared with 182 paints) DE00: 1.26 - #3C4D76 - Humbrol - DB0025 | No 25 | Blue - Matt | GU 5.1 (L*=34.35, a=0.98, b=-23.90) Found a match in: Revell (compared with 86 paints) DE00: 2.91 - #425679 - Revell - 36156 | Blue | RAL 5000 | GU 2.2 (L*=37.26, a=-1.39, b=-20.70) Target: RAF29 - Semi Matt Black | GU 5.0, RGB: #3B3C3D (L*=25.22, a=-0.20, b=-0.77) Found a match in: Humbrol (compared with 182 paints) DE00: 0.19 - #3B3C3D - Humbrol - DB0085 | No 85 | Black - Satin | GU 19.5 (L*=25.23, a=-0.23, b=-0.96) Found a match in: Revell (compared with 86 paints) DE00: 1.05 - #3E3F40 - Revell - 36106 | Tar black | RAL 9021 | GU 2.3 (L*=26.62, a=-0.32, b=-0.66) Found a match in: Tamiya (compared with 34 paints) DE00: 0.55 - #393B3D - Tamiya - XF-1 | Flat Black | GU 3.9 (L*=24.80, a=-0.36, b=-1.18) Paints checked list: Spoiler Paint set: Humbrol (6 paints) A1701 | No 157 | Azure Blue - Matt | GU 1.3 A6238 | No 187 | Dark Stone - Matt | GU 1.5 AA0046 | No 46 | Orange - Matt | GU 8.5 AA0059 | No 5 | Dark Admiralty Grey - Gloss | GU 90.8 AA0076 | No 7 | Light Buff - Gloss| GU 95.2 AA0134 | No 12 | Copper - Metallic | GU 8.7 | Metallic AA0173 | No 173 | Track Colour - Matt | GU 1.3 AA0234 | No 234 | Dark Flesh - Matt | GU 4.4 AA0343 | No 31 | Slate Grey - Matt | GU 7.5 AA0360 | No 33 | Black - Matt | GU 2.2 AA0549 | No 50 | Green Mist - Metallic | GU 94.3 | Metallic AA0552 | No 51 | Sunset Red - Metallic | GU 95.3 | Metallic AA0583 | No 53 | Gunmetal - Metallic | GU 1.2 | Metallic AA0727 | No 65 | Aircraft Blue - Matt | GU 5.0 AA0770 | No 66 | Olive Drab - Matt | GU 5.9 AA0775 | No 70 | Brick Red - Matt | GU 3.1 AA0802 | No 73 | Wine - Matt | GU 1.3 AA0816 | No 74 | Linen - Matt | GU 7.9 AA0833 | No 75 | Bronze Green - Matt | GU 2.0 AA0847 | No 76 | Uniform Green - Matt | GU 2.1 AA0850 | No 77 | Navy Blue - Matt | GU 1.7 AA0878 | No 79 | Blue Grey - Matt | GU 4.3 AA0905 | No 82 | Orange Lining - Matt | GU 4.1 AA0919 | No 83 | Ochre - Matt | GU 5.3 AA0922 | No 84 | Mid Stone - Matt | GU 4.1 AA0967 | No 87 | Steel Grey - Matt | GU 6.9 AA0970 | No 88 | Deck Green - Matt | GU 2.0 AA1105 | No 100 | Red Brown - Matt | GU 3.8 AA1119 | No 101 | Mid Green - Matt | GU 2.9 AA1167 | No 105 | Marine Green - Matt | GU 7.1 AA1287 | No 116 | US Dark Green - Matt | GU 2.1 AA1314 | No 119 | Light Earth - Matt | GU 4.5 AA1328 | No 120 | Light Green - Matt | GU 3.1 AA1331 | No 121 | Pale Stone - Matt | GU 7.0 AA1376 | No 125 | US Dark Grey - Satin | GU 11.4 AA1393 | No 126 | US Medium Grey - Satin | GU 37.9 AA1417 | No 128 | US Compass Grey - Satin | GU 31.6 AA1420 | No 129 | US Gull Grey - Satin | GU 21.6 AA1448 | No 131 | Mid Green - Satin | GU 21.1 AA1451 | No 132 | Red - Satin | GU 11.0 AA1465 | No 133 | Brown - Satin | GU 33.0 AA1496 | No 28 | Camouflage Grey - Matt | GU 17.2 AA1523 | No 140 | Gull Grey - Matt | GU 5.4 AA1568 | No 144 | Intermediate Blue - Matt | GU 4.8 AA1571 | No 145 | Medium Grey - Matt | GU 11.6 AA1599 | No 147 | Light Grey - Matt | GU 6.1 AA1609 | No 148 | Radome Tan - Matt | GU 19.1 AA1612 | No 149 | Dark Green - Matt | GU 2.9 AA1626 | No 150 | Forest Green - Matt | GU 1.4 AA1729 | No 159 | Khaki Drab - Matt | GU 2.0 AA1780 | No 164 | Dark Sea Grey - Satin | GU 25.9 AA1804 | No 166 | Light Aircraft Grey - Satin | GU 54.6 AA2240 | No 240 | RLM 02 Grau - Matt | GU 3.9 AA2241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 2.2 AA2241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 3.0 AA2242 | No 242 | RLM 71 Dunkelgrun - Matt | GU 1.0 AA2247 | No 247 | RLM 76 Lichtblau - Matt | GU 13.9 AA2248 | No 248 | RLM 78 Himmelblau - Matt | GU 3.0 AA2252 | No 252 | RLM 82 Olivgrun - Matt | GU 2.2 AA2253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 2.4 AA6330 | No 195 | Dark Green - Satin | GU 31.5 AA6344 | No 196 | Light Grey - Satin | GU 29.9 AA6389 | No 200 | Pink - Gloss | GU 91.8 AA6392 | No 201 | Black - Metallic | GU 91.3 | Metallic AA6608 | No 220 | Racing Red - Gloss | GU 100.0 AA7222 | No 222 | Moonlight Blue - Metallic | GU 95.0 | Metallic AA7224 | No 224 | Dark Slate Grey - Matt | GU 3.0 AA7225 | No 225 | Middle Stone - Matt | GU 2.6 AB0047 | No 47 | Sea Blue - Gloss | GU 65.0 AB0052 | No 52 | Baltic Blue - Metallic | GU 78.7 | Metallic AB0065 | No 65 | Aircraft Blue - Matt | GU 6.3 AB0078 | No 78 | Cockpit Green - Matt | GU 4.1 AB0090 | No 90 | Beige Green - Matt | GU 9.5 AB0091 | No 91 | Black Green - Matt | GU 1.6 AB0094 | No 94 | Brown Yellow - Matt | GU 2.2 AB0104 | No 104 | Oxford Blue - Matt | GU 1.4 AB0145 | No 145 | Medium Grey - Matt | GU 2.4 AB0165 | No 165 | Medium Sea Grey - Satin | GU 17.2 AB0167 | No 167 | RAF Barley Grey - Satin | GU 9.2 AB0168 | No 168 | Hemp - Satin | GU 33.8 AB0226 | No 226 | Interior Green - Matt | GU 2.3 AB0230 | No 230 | Pru Blue - Matt | GU 1.3 AB0237 | No 237 | Desert Tan - Matt | GU 1.3 AB0238 | No 238 | Arrow Red - Gloss | GU 65.7 AB0239 | No 239 | British Racing Green - Gloss | GU 56.0 AB0240 | No 240 | RLM 02 Grau - Matt | GU 1.3 AB0241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 4.0 AB0243 | No 243 | RLM 72 Grun - Matt | GU 1.5 AB0244 | No 244 | RLM 73 Grun - Matt | GU 1.4 AB0245 | No 245 | RLM 74 Graugrun - Matt | GU 0.9 AB0246 | No 246 | RLM 75 Grauviolett - Matt | GU 1.3 AB0247 | No 247 | RLM 76 Lichtblau - Matt | GU 12.9 AB0249 | No 249 | RLM 79 Sandgelb - Matt | GU 1.5 AB0251 | No 251 | RLM 81 Dunkelbraun - Matt | GU 0.7 AB0252 | No 252 | RLM 82 Olivgrun - Matt | GU 0.7 AB0253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 0.8 DB0001 | No 1 | Primer | GU 5.6 DB0002 | No 2 | Emerald Green - Gloss | GU 79.8 DB0003 | No 3 | Brunswick Green - Gloss | GU 63.0 DB0009 | No 9 | Tan - Gloss | GU 76.9 DB0010 | No 10 | Service Brown - Gloss | GU 78.0 DB0011 | No 11 | Silver - Metallic | GU 6.7 | Metallic DB0012 | No 12 | Copper - Metallic | GU 48.2 | Metallic DB0014 | No 14 | French Blue - Gloss | GU 80.5 DB0015 | No 15 | Midnight Blue - Gloss | GU 79.7 DB0016 | No 16 | Gold - Metallic | GU 6.4 | Metallic DB0018 | No 18 | Orange - Gloss | GU 78.0 DB0019 | No 19 | Red - Gloss | GU 90.2 DB0020 | No 20 | Crimson - Gloss | GU 84.2 DB0021 | No 21 | Black - Gloss | GU 45.3 DB0022 | No 22 | White - Gloss | GU 65.9 DB0023 | No 23 | Duck Egg Blue - Matt | GU 4.3 DB0024 | No 24 | Trainer Yellow - Matt | GU 3.6 DB0025 | No 25 | Blue - Matt | GU 5.1 DB0026 | No 26 | Khaki - Matt | GU 3.4 DB0027 | No 27 | Sea Grey - Matt | GU 10.5 DB0029 | No 29 | Dark Earth - Matt | GU 3.6 DB0030 | No 30 | Dark Green - Matt | GU 3.2 DB0032 | No 32 | Dark Grey - Matt | GU 11.2 DB0033 | No 33 | Black - Matt | GU 3.9 DB0034 | No 34 | White - Matt | GU 6.5 DB0036 | No 36 | Pastel Green - Matt | GU 6.9 DB0037 | No 37 | Bright Green - Matt | GU 3.9 DB0038 | No 38 | Lime - Gloss | GU 82.8 DB0040 | No 40 | Pale Grey - Gloss | GU 65.2 DB0041 | No 41 | Ivory - Gloss | GU 58.2 DB0042 | No 42 | Pastel Violet - Matt | GU 4.8 DB0044 | No 44 | Pastel Blue - Matt | GU 7.0 DB0048 | No 48 | Mediterranean Blue - Gloss | GU 71.1 DB0053 | No 53 | Gunmetal - Metallic | GU 6.1 | Metallic DB0054 | No 54 | Brass - Metallic | GU 8.0 | Metallic DB0055 | No 55 | Bronze - Metallic | GU 6.7 | Metallic DB0056 | No 56 | Aluminium - Metallic | GU 14.6 | Metallic DB0057 | No 57 | Pink - Matt | GU 5.2 DB0058 | No 58 | Magenta - Matt | GU 6.4 DB0060 | No 60 | Scarlett - Matt | GU 3.5 DB0061 | No 61 | Flesh - Matt | GU 5.9 DB0062 | No 62 | Leather - Matt | GU 3.5 DB0063 | No 63 | Sand - Matt | GU 7.1 DB0064 | No 64 | Light Grey - Matt | GU 5.9 DB0067 | No 67 | Matt Tank Grey - Matt | GU 5.2 DB0068 | No 68 | Purple - Gloss | GU 79.1 DB0069 | No 69 | Yellow - Gloss | GU 93.5 DB0071 | No 71 | Oak - Satin | GU 19.7 DB0072 | No 72 | Khaki Drill - Matt | GU 6.8 DB0080 | No 80 | Grass Green - Matt | GU 3.6 DB0081 | No 81 | Pale Yellow - Matt | GU 1.9 DB0085 | No 85 | Black - Satin | GU 19.5 DB0085 | No 86 | Light Olive - Matt | GU 9.2 DB0089 | No 89 | Middle Blue - Matt | GU 5.4 DB0093 | No 93 | Desert Yellow - Matt | GU 4.5 DB0096 | No 96 | RAF Blue - Matt | GU 6.6 DB0098 | No 98 | Chocolate - Matt | GU 3.0 DB0099 | No 99 | Lemon - Matt | GU 8.5 DB0102 | No 102 | Army Green - Matt | GU 4.6 DB0103 | No 103 | Cream - Matt | GU 6.1 DB0106 | No 106 | Ocean Grey - Matt | GU 4.4 DB0109 | No 109 | WWI Blue - Matt | GU 4.7 DB0110 | No 110 | Natural Wood - Matt | GU 6.4 DB0113 | No 113 | Rust - Matt | GU 4.9 DB0117 | No 117 | US Light Green - Matt | GU 3.5 DB0118 | No 118 | US Tan - Matt | GU 5.6 DB0123 | No 123 | Extra Dark Sea Grey - Satin | GU 18.4 DB0127 | No 127 | US Ghost Grey - Satin | GU 19.7 DB0130 | No 130 | White - Satin | GU 27.3 DB0153 | No 153 | Insignia Red - Matt | GU 4.1 DB0154 | No 154 | Insignia Yellow - Matt | GU 9.6 DB0155 | No 155 | Olive Drab - Matt | GU 6.2 DB0156 | No 156 | Dark Camouflage Grey - Satin | GU 7.3 DB0160 | No 160 | German Camouflage Red - Matt | GU 4.9 DB0163 | No 163 | Dark Green - Satin | GU 21.8 DB0171 | No 171 | Antique Bronze - Metallic | GU 7.1 | Metallic DB0174 | No 174 | Signal Red - Satin | GU 25.2 DB0186 | No 186 | Brown - Matt | GU 4.5 DB0189 | No 189 | Chrome Silver - Metallic | GU 89.6 | Metallic DB0208 | No 208 | Fluorescent Signal Green - Gloss | GU 11.3 | Fluorescent DB0209 | No 209 | Fire Orange - Gloss | GU 20.2 | Fluorescent DB0242 | No 242 | RLM 71 Dunkelgrun - Matt | GU 1.5 MET27001 | No 27001 | Aluminium - Metalcote | GU 5.2 | Metallic MET27002 | No 27002 | Polished Aluminium - Metalcote | GU 10.8 | Metallic MET27003 | No 27003 | Polished Steel - Metalcote | GU 47.4 | Metallic MET27004 | No 27004 | Gunmetal - Metalcote | GU 5.2 | Metallic Paint set: Revell (6 paints) 36104 | White | RAL 9010 | GU 72.8 36105 | White | RAL 9001 | GU 5.7 36106 | Tar black | RAL 9021 | GU 2.3 36107 | Black | RAL 9005 | GU 79.8 36108 | Black | RAL 9011 | GU 1.4 36109 | Anthracite | RAL 7021 | GU 4.7 36112 | Yellow | RAL 1018 | GU 79.5 36115 | Yellow | RAL 1017 | GU 6.5 36116 | Sandy yellow | RAL 1024 | GU 2.6 36117 | Africa brown | GU 3.1 36125 | Luminous orange | GU 3.5 | Fluorescent 36130 | Orange | RAL 2004 | GU 87.7 36131 | Fiery red | RAL 3000 | GU 90.5 36134 | Italian Red | GU 88.5 36135 | Flesh | GU 5.9 36136 | Carmine red | RAL 3002 | GU 3.0 36137 | Reddish brown | RAL 3009 | GU 1.8 36139 | Dark green | GU 2.2 36140 | Black green | GU 2.1 36142 | Yellowish olive | GU 1.8 36143 | Medium grey USAF | GU 2.9 36145 | Light olive | RAL 7003 | GU 2.2 36146 | Nato olive | RAL 7013 | GU 1.6 36147 | Mouse grey | RAL 7005 | GU 2.4 36148 | Sea green | RAL 6028 | GU 2.1 36149 | Light blue | GU 3.1 36150 | Light blue | RAL 5012 | GU 72.9 36151 | Ultramarine | RAL 5002 | GU 85.4 36152 | Blue | RAL 5005 | GU 82.7 36154 | Night blue | RAL 5022 | GU 85.3 36155 | Light green | RAL 6027 | GU 3.3 36156 | Blue | RAL 5000 | GU 2.2 36157 | Grey | RAL 7000 | GU 3.5 36159 | Sky RAF | GU 3.4 36161 | Emerald green | RAL 6029 | GU 82.3 36162 | Sea green | RAL 6005 | GU 88.5 36165 | Bronze green | RAL 6031 | GU 2.9 36166 | Olive grey | RAL 7010 | GU 2.2 36167 | Greenish grey | RAL 7009 | GU 2.3 36168 | Dark green RAF | GU 2.1 36169 | Granite grey | RAL 7026 | GU 1.6 36174 | Gunship grey | GU 3.1 36175 | Stone grey | RAL 7030 | GU 3.5 36176 | Light grey USAF | GU 4.1 36177 | Dust grey | RAL 7012 | GU 3.8 36178 | Tank grey | RAL 7024 | GU 2.9 36179 | Greyish blue | RAL 7031 | GU 1.9 36180| Mud brown | RAL 8003 | GU 82.2 36182 | Dark earth RAF | GU 2.1 36183 | Rust | GU 1.9 36184 | Leather brown | RAL 8027 | GU 1.9 36185 | Brown | RAL 8023 | GU 2.5 36186 | Olive brown | RAL 7008 | GU 2.2 36187 | Earth brown | RAL 7006 | GU 4.8 36188 | Ochre brown | RAL 1011 | GU 2.4 36189 | Beige | RAL 1019 | GU 2.9 36190 | Silver | GU 76.6 | Metallic 36191 | Steel | GU 4.9 | Metallic 36192 | Brass | GU 54.8 | Metallic 36193 | Copper | GU 60.8 | Metallic 36194 | Gold | GU 53.0 | Metallic 36195 | Bronze | GU 61.5 | Metallic 36199 | Aluminium | GU 9.6 | Metallic 36301 | White | RAL 9010 | GU 20.9 36302 | Black | RAL 9005 | GU 11.1 36310 | Lufthansa Yellow | RAL 1028 | GU 25.6 36312 | Luminous yellow | RAL 1026 | GU 4.9 | Fluorescent 36314 | Beige | RAL 1001 | GU 18.8 36330 | Fiery red | RAL 3000 | GU 16.2 36331 | Purple red | RAL 3004 | GU 17.8 36332 | Luminous red | RAL 3026 | GU 3.7 | Fluorescent 36350 | Lufthansa blue | RAL 5013 | GU 19.6 36360 | Fern green | RAL 6025 | GU 22.2 36361 | Olive green | RAL 6003 | GU 24.5 36362 | Greyish green | RAL 6013 | GU 12.4 36363 | Dark green | RAL 6020 | GU 21.6 36364 | Leaf green | RAL 6001 | GU 20.4 36365 | Patina green | RAL 6000 | GU 38.1 36371 | Light grey | RAL 7035 | GU 17.8 36374 | Grey | RAL 7001 | GU 20.7 36378 | Dark grey | RAL 7012 | GU 28.0 36381 | Brown | RAL 8025 | GU 42.5 36382 | Wood brown | RAL 8001 | GU 24.0 36730 | Orange | GU 87.2 | Opacity 34.45% | Transparent 36731 | Red | GU 93.0 | Opacity 42.21% | Transparent 36752 | Blue | GU 88.5 | Opacity 48.3 | Transparent Paint set: Vallejo (6 paints) 71.001 | White | Blanco | FS37925 | RAL9016 | RLM21 | GU 3.5 71.002 | Medium Yellow | Amarillo Medio | GU 3.0 71.003 | Red RLM 23 | RLM23 Rot | RLM23 | GU 1.6 71.004 | Blue | Azul | GU 1.4 71.005 | Grey Blue | Azul Gris | RAL5008 | GU 1.5 71.006 | Light Green Chromate | Verde Claro Chromo | GU 1.3 71.007 | Olive Green | Verde Oliva | GU 1.2 71.008 | Pale Blue | Azul Claro | FS35414 | GU 2.0 71.009 | Eau De Nil "D.E. Green" | Verde Huevo Pato | BS216 | GU 1.8 71.010 | Interior Green | Verde Interior | FS34098 | GU 3.5 71.011 | Dark Green RLM83 | RLM83 Dunkelgrün | RLM83 | GU 1.2 71.015 | Dark Green RLM71 | RLM71 Dunkelgrün | RLM71 | GU 2.0 71.021 | Black Green RLM70 | RLM70 Schwarzgrün | RLM70 | GU 0.6 71.022 | Light Green RLM82 | RLM82 Hellgrün | RLM82 | GU 0.8 71.042 | Dark Brown RLM61 | RLM61 Dunkelbraun | RLM61 | GU 1.6 71.044 | Grey RLM02 | RLM02 Grau | RLM02 | GU 1.9 71.055 | Black Grey RLM66 | RLM66 Schwarzgrau | RLM66 | GU 1.7 71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.5 71.103 | Grey Blue RLM84 | RLM84 Graublau | FS36559 | RLM84 | GU 1.7 71.104 | Green RLM62 | RLM62 Grün | RLM62 | GU 3.4 71.109 | Faded P.R.U. Blue | M485 Blue Gray | FS35189 | BS636 | GU 1.6 71.121 | Light Gull Gray | Gris Gaviota USN | FS36440 | ANA620 | GU 2.6 71.255 | Light Blue RLM65 | RLM65 Hellblau | RLM65 | GU 1.7 71.257 | Light Blue RLM76 | RLM76 Lichtblau | RLM76 | GU 1.7 71.258 | Grey Green RLM74 | RLM74 Graugrün | RLM74 | GU 1.4 71.259 | Grey Violet RLM75 | RLM75 Grauviolett | RLM75 | GU 1.5 71.260 | Light Grey RLM63 | RLM63 Hellgrau | RLM63 | GU 1.5 71.264 | Brown Violet RLM81 | RLM81 Braunviolett | RLM81 | GU 1.2 71.277 | Dark Gull Gray | Gris Gaviota Oscuro | FS36231 | ANA621 | GU 1.7 71.279 | Insignia White | Blanco Insignia | FS37875 | ANA601 | GU 5.2 71.295 | USN Sea Blue | USN Azul Marino | FS35042 | ANA607 | GU 2.2 71.298 | M495 Light Gray | M495 Gris Claro | FS36357 | GU 1.8 71.299 | Intermediate Blue | Azul Intermedio | FS35164 | ANA608 | GU 2.5 71.300 | Glossy Sea Blue | Azul Mar Brillante | FS15042 | ANA623 | GU 24.6 Paint set: Hataka (6 paints) HTK-A009 | Dark Earth | GU 9.1 HTK-A015 | Black-Green (RLM70) | GU 7.9 HTK-A016 | Dark Green | GU 9.6 HTK-A017 | Dark Green (RLM71) | GU 10.5 HTK-A023 | Grey (RLM02) | GU 14.1 HTK-A025 | Interior Grey-Green | GU 17.4 HTK-A026 | Sky "Type S" | GU 13.1 HTK-A029 | Light Blue (RLM65/78) | GU 13.2 HTK-A032 | Ocean Grey | GU 13.3 HTK-A034 | Medium Sea Grey | GU 14.2 Paint set: Tamiya (6 paints) XF-1 | Flat Black | GU 3.9 XF-10 | Flat Brown | GU 4.4 XF-11 | J.N. Flat Green | GU 4.2 XF-12 | J.N. Gray | GU 2.1 XF-13 | J.A. Green XF-14 | J.A. Grey XF-15 | Flat Flesh XF-16 | Flat Aluminum | Metallic XF-17 | Sea Blue XF-18 | Medium Blue XF-19 | Sky Grey XF-2 | Flat White | GU 9.8 XF-20 | Medium Grey XF-21 | Sky XF-22 | RLM Grey XF-23 | Light Blue XF-24 | Dark Grey XF-25 | Light Sea Grey XF-26 | Deep Green XF-27 | Black Green XF-28 | Dark Copper | Metallic XF-3 | Flat Yellow | GU 4.8 XF-4 | Yellow Green | GU 6.3 XF-49 | Khaki XF-5 | Flat Green | GU 3.5 XF-50 | Field Blue XF-51 | Khaki Drab XF-52 | Flat Earth XF-53 | Neutral Grey XF-54 | Dark Sea Grey XF-6 | Flat Copper | GU 4.9 | Metallic XF-7 | Flat Red | GU 1.0 XF-8 | Flat Blue | GU 4.1 XF-9 | Hull Red | GU 5.0 Paint set: Lifecolor (6 paints) UA 546 | Dark Green | *FS 34079 | GU 7.0 UA 547 | Dark Earth | *FS 30118 | GU 6.3 UA 548 | Light Green | FS 34102 | GU 6.4 UA 549 | Light Earth | FS 30257 | GU 6.8 UA 550 | Sky | FS 34424 | GU 6.4 UA 551 | Grey Green | FS 34226 | GU 9.0 Edited February 24, 2023 by Casey Hid the content to reduce confussion 3 1 Link to comment Share on other sites More sharing options...
stevehnz Posted February 17, 2023 Share Posted February 17, 2023 Blue Blazes Casey, that is a job of work & a half. This really is the sort of cross reference stuff that I & I'm sure many others have been hanging out for for ages. I can but hope for a wider range of paint makes to be included down the track maybe, at risk of sounding ungrateful, but trust me when I say, as one who has made up various paint swatches for eyeball comparison, I don't underestimate for a moment to work you have put into this, many many thanks. As an aside, I mentioned recently my impression that Hu86 was a decent match for RAF Light Green, sorry, but I was heading down the wrong road on this. Some years ago I built a Burma based RAF P-47 & wishing to represent it as a machine with a faded finish after tropical service, I chose 86 & 110 as lighter but similar shades, to my eye, for weathered RAF Dark green & Dark Earth. Fwiw, I thought it worked quite well but it was never, now I think of it, 'sposed to represent the actual shades of Light green & Light earth. Steve. 1 Link to comment Share on other sites More sharing options...
Casey Posted February 17, 2023 Share Posted February 17, 2023 (edited) 1 hour ago, stevehnz said: I can but hope for a wider range of paint Working on it. In plans: Whole range of Tamiya, most of Vallejo I got (around 100 of them) and any potential matches I can find on some other paints - I've already went through some in Lifecolor and Hataka. Edited February 17, 2023 by Casey 1 Link to comment Share on other sites More sharing options...
Casey Posted February 19, 2023 Share Posted February 19, 2023 (edited) 2023-04-19 Measured the following paints: 71.315 | Tire Black | Negro Caucho | GU 1.2 71.317 | AII SV. Gol Light Blue | AII SV. Gol Azul Claro | GU 3.2 71.318 | Amt-7 Greyish Blue | Amt-7 Azul Grisáceo | GU 1.7 71.319 | A-28M Greyish Blue | A-28M Azul Grisáceo | GU 2.8 71.321 | Sky Green | IJA Light Grey Green | FS34424 | ANA610 | GU 2.4 71.322 | IJN Black Green | IJN Verde Negro | GU 1.3 71.323 | BS Dark Earth | BS Tierra Oscura | BS450 | GU 1.6 71.324 | BS Dark Green | BS Verde Oscuro | BS241 | GU 1.7 71.325 | IJN Dark Black Green | IJN Verde Negro Oscuro | GU 2.4 71.326 | IJA Grey Green | IJA Gris Verdoso | GU 7.2 71.327 | IAF Sand | Arena IAF | FS33531 | GU 1.7 71.328 | Light Blue | Azul Claro | FS35622 | GU 2.6 71.329 | Green | Verde | FS34159 | GU 5.0 71.330 | Khaki Green Num. 3 | Verde Caqui Nº3 | GU 2.1 71.331 | Cockpit Eme. Green “Faded” | Verde Interior Cabina | GU 1.6 71.332 | Underside Blue “Faded” | Azul Desgastado | FS35450 | GU 2.3 71.333 | Russian AF Blue | Azul AF Ruso | GU 2.0 71.334 | Flanker Light Blue | Azul Claro Flanker | GU 2.9 71.335 | Flanker Light Gray | Gris Claro Flanker | GU 3.8 71.336 | A-14 Steel Grey | A-14 Gris Acero | GU 1.7 71.337 | Flanker Blue | Azul Flanker | GU 3.0 71.338 | Russian AF Grey Blue | Gris Azul AF Ruso | GU 2.7 71.339 | Russian AF Grey N.3 | Gris N.3 AF Ruso | FS36373 | GU 2.3 71.340 | Grey Green | Gris Verdoso | GU 1.8 71.341 | Green Grey | Verde Grisáceo | GU 1.8 71.342 | Russian AF Light Blue | Azul Claro AF Ruso | GU 2.6 71.343 | Russian AF Grey N.7 | Gris N.7 AF Ruso | GU 1.9 71.344 | Russian AF Grey Prot. Coat | Gris AF Ruso | GU 2.8 71.345 | Russian AF Grey N.8 | Gris N.8 AF Ruso | GU 2.3 71.346 | Russian AF Grey N.4 | Gris N.4 AF Ruso | GU 2.5 71.347 | Russian AF Dark Green | Verde Oscuro AF Ruso | GU 1.4 71.348 | USAF Tan | USAF Marrón Arena | FS20400 | GU 2.0 71.401 | Uk Bsc 28 Sil. Grey | Uk Bsc28 Gris Plata | GU 1.8 71.402 | Uk Bsc 49 L. Purple Br. | Uj Bsc49 Mr. Purpura | GU 2.5 71.403 | Light Green | Verde Claro | GU 2.0 71.404 | No. 1 "Duck Egg Blue" | Azul Huevo De Pato | GU 1.8 71.408 | PRU Pink | PRU Rosa | GU 3.7 71.409 | Zaschchitnyi Khaki | Verde Zaschcitnyi | GU 1.3 71.410 | AII Zashchitnyi Cam. Green | AII Verde Zaschitnyi | GU 1.2 71.411 | A-19F Grass Green | A-19F Verde Hierba | GU 1.5 71.412 | VVS Grey Blue | VVS Gris Azulado | GU 7.4 71.413 | A-18F Light Blue | A-18F Azul Claro | GU 8.8 71.414 | AEH-9 Light Grey | AEH-9 Gris Claro | GU 2.7 71.415 | A-21 Light Greyish Br. | A-21 Mr. Gris. Claro | GU 1.7 71.416 | IJA Dark Beige | IJA Beige Oscuro | GU 1.3 71.417 | "Aotake" Trans. Green | "Aotake" Verde Trans | GU 31.2 | Opacity 56.37% 71.418 | IJN Medium Brown | IJN Maroon Medio | GU 1.3 71.419 | "Aotake" Trans. Blue | "Aotake" Azul Trans. | GU 17.3 | Opacity 87.81% Updates history: Spoiler 2023-04-02 Measured the following paints: 71.129 | Light Rust | Óxido Claro | GU 3.2 71.130 | Orange Rust | Óxido Aanaranjado | RAL2010 | GU 4.5 71.131 | Concrete | Cemento | GU 3.4 71.132 | Aged White | Blanco Envejecido | FS37769 | RAL1015 | GU 4.9 71.133 | Suciedad | Dirt | GU 6.0 71.134 | IJA Midouri Green | IJA Verde Midouri | GU 5.3 71.135 | IJA Chrome Yellow | IJA Amarillo Cromado | FS33655 | RAL1003 | GU 3.4 | Opacity 67.5% 71.136 | IJA Earth Brown | IJA Marrón Tierra | GU 1.9 71.138 | US Sand | US Arena | FS30277 | GU 3.2 71.141 | IDF Sand Grey 73 | IDF Gris Arena 73 | GU 4.0 71.142 | IDF Sinai Grey 82 | IDF Gris Sinai 82 | GU 3.6 71.143 | UK Light Stone | UK Piedra Clara | BS361 | GU 3.9 71.244 | Sand Beige | Sandbeige | RAL1039 | GU 1.8 71.245 | Loam Beige | Lehmbeige | RAL1040 | GU 3.9 71.246 | Yellow Brown | Sandbraun | RAL8031 | GU 4.3 71.247 | Light Olive | Helloliv | RAL6040 | GU 4.2 71.248 | Brown Grey | Gris Marrón | RAL7050 | GU 5.6 71.249 | Nato Brown | Lederbraun | FS30051 | RAL8027 | GU 1.9 71.250 | Bronze Green | Bronzegrün | RAL6031 | GU 2.3 71.251 | Nato Black | Teerschwarz | FS37030 | RAL9021 | GU 0.4 71.265 | Olive Green RLM80 | RLM80 Olivgrün | RLM80 | GU 2.9 71.266 | Dark Blue RLM24 | RLM24 Dunkelblau | RLM24 | GU 4.9 71.267 | Light Green RLM25 | RLM25 Hellgrün | RLM25 | GU 4.7 71.269 | Red | RAL3000 Rot | RAL3000 | GU 5.3 71.273 | Ocean Gray | Gris Oceano | FS36176 | BS629 | GU 3.9 71.274 | Aggressor Gray | Gris Aggressor | FS36251 | GU 4.7 71.275 | USAF Medium Gray | USAF Gris Medio | FS36270 | GU 5.5 71.276 | USAF Light Gray | Gris Claro | FS36495 | GU 6.2 71.280 | Camouflage Gray | Gris Camuflaje | FS36170 | GU 5.0 71.281 | 3B Russian Green | 3B Verde Ruso | GU 6.7 71.282 | 6K Russian Brown | 6K Marrón Ruso | GU 5.5 71.283 | 7K Russian Tan | 7K Tierra Rusa | GU 8.6 71.284 | Uk Light Mud | Uk Marrón Claro | GU 9.3 71.285 | IJA Dark Green | IJA Verde Oscuro | GU 10.3 71.286 | IJA Olive Green | IJA Verde Oliva | GU 6.9 71.287 | IJA Khaki Brown | IJA Marrón Caqui | GU 4.7 71.288 | UK BSC 64 Portland Stone | UK BSC 64 Piedra Portland | GU 9.9 71.289 | US Dark Green | US Verde Oscuro | FS34102 | GU 4.4 71.290 | US Earth Brown | US Tierra Marrón | FS30099 | GU 5.1 71.291 | US Earth Yellow | US Tierra Amarilla | FS30257 | GU 4.6 71.292 | US Loam | US Marrón Barro | FS34086 | GU 7.6 71.293 | US Earth Red | US Tierra Roja | FS30117 | GU 6.8 71.297 | JGSD Brown 3606 | JGSD Marrón 3606 | GU 6.4 71.301 | Amt-4 Camouflage Green | Amt-4 Camuflaje Verde | GU 5.8 71.303 | A-24M Camouflage Green | A-24M Verde Camuflaje | GU 7.1 71.304 | Amt-11 Blue Grey | Amt-11 Azul Grisáceo | GU 6.7 71.305 | Interior Grey Green | Interior Gris Verde | FS34373 | GU 3.7 71.307 | BS Medium Sea Grey | BS Gris Mar Medio | BS637 | GU 5.3 2023-03-30 Measured the following paints: 71.073 | Black | Negro | GU 14.6 | Metallic 71.085 | Ferrari Red | Rojo Ferrari | GU 2.9 | Opacity 95.6% 71.086 | Light Red | Rojo Claro | GU 3.2 | Opacity 68.56% 71.087 | Steel Blue | Azul Acero | RAL5013 | GU 2.3 71.088 | French Blue | Azul Francés | GU 3.0 71.089 | Light Sea Blue | Azul Mar Claro | GU 3.5 71.093 | Nato Green | Verde Otan | FS34094 | GU 2.0 71.094 | Green Zinc Chromate | Verde Zinc | GU 2.0 71.095 | Pale Green | Verde Pálido | RAL6011 | GU 2.4 71.096 | Olive Grey | Verde Oliva Grisáceo | GU 4.6 71.102 | Red | Rojo | GU 3.6 | Opacity 91.71% 71.105 | Brown RLM26 | RLM26 Braun | RLM26 | GU 2.6 71.106 | Ivory RLM05 | RLM05 Elfenbein | GU 6.3 71.110 | Dark Grey | Gris Oscuro | BS640 | GU 3.7 71.112 | Sand | Arena | GU 3.5 71.113 | IDF Blue | Azul IDF | FS35177 | GU 2.4 71.114 | Medium Gray | Gris Medio | FS35237 | GU 4.2 71.120 | Dark Ghost Gray | Gris Oscuro USAF | FS36320 | GU 5.9 71.122 | US Desert Armour 686 | US Camuflaje Moderno 686 | FS33446 | ANA620 | GU 8.0 71.123 | Dark Grey RLM42 | RLM42 Dunkelgrau | RLM42 | GU 3.2 71.126 | IDF/IAF Green | Verde IDF/IAF | FS34227 | BS283 | GU 4.1 71.128 | Gris Violeta | Gray Violet | FS36134 | GU 4.0 2023-03-29 Measured the following paints: 71.074 | Beige | Beige | FS33695 | GU 2.7 71.077 | Wood | Madera | GU 1.7 71.079 | Tan Earth | Tierra | GU 2.4 71.081 | Ochre | Ocre | GU 2.1 71.082 | Fluorescent Red | Rojo Fluorescente | FS38903 | RAL2005 | GU 2.5 | Fluorescent | Opacity 32.63% 71.083 | Orange | Naranja | GU 2.5 | Opacity 64.68% 71.302 | Sky Type S | Verde Cielo | BS210 | GU 2.5 71.309 | Dark Slate Grey | Gris Pizarra Oscuro | FS34096 | BS634 | GU 1.9 71.405 | BS Dark Sea Grey | BS Gris Mar Osc. | GU 1.3 71.406 | Light Slate Grey | Gris Pizarra Claro | GU 1.5 71.407 | Sky Grey | Gris Cielo | FS36463 | GU 3.8 I've measured most of the FAA (Fleet AIR ARM) Colors 1939-1945 'Air War Color Series' Model Paint Kit and found one good match for RAF colors - Sky Grey. The rest I've checked are not even a close match to anything there. 2023-03-08 I've added measurements for (I hope) the full Army Painter - Warpaints range (104 colors). There are some interesting accidental matches. 2023-02-28 Added measurements for the following Tamiya paints: XF-55 | Deck Tan | GU 19.1 XF-56 | Metallic Grey | GU 6.3 | Metallic XF-57 | Buff | GU 18.2 XF-58 | Olive Green | GU 6.1 XF-59 | Desert Yellow | GU GU 20.7 XF-60 | Dark Yellow | GU 13.0 2023-02-24 Added measurements for following Vallejo paints: 71.075 | Ivory | RAL1001 Elfenbein | RAL1001 | GU 3.9 71.076 | Skin Tone | Color Piel | GU 5.1 71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.7 71.080 | Rust | Oxido | FS30111 | BS435 | GU 2.7 71.084 | Fire Red | Rojo Fuego | GU 3.1 71.090 | Deep Sky | Azul Oscuro | FS35056 | GU 1.9 71.092 | Medium Olive | RAL6003 Olivgrün | RAL6003 | GU 1.9 71.097 | Medium Gunship Gray | Gris Medio USAF | FS36118 | ANA603 | GU 3.1 71.101 | Light Blue RLM78 | RLM78 Hellblau | RLM78 | GU 5.3 71.107 | US Interior Green | US Amarillo Inter. | GU 3.0 71.108 | Uk Azure Blue | Uk Azul Azure | FS35231 | ANA609 | GU 3.1 71.115 | Blue Grey | RAL7016 Blaugrau | RAL7016 | GU 2.0 71.116 | Camouflage Grey Green | RAL7008 Graugrün | RAL7008 | GU 2.3 71.117 | Camouflage Brown | RAL8020 Braun | RAL8020 | GU 3.0 71.118 | Camouflage Grey | RAL7027 Grau | RAL7027 | GU 2.7 71.119 | White Grey | RAL9002 Grauweiss | RAL9002 | GU 5.2 71.124 | USAF Green | Verde USAF | FS34092-ANA612 | GU 2.7 71.125 | USAF Brown | Marrón USAF | FS30219 | ANA628 | GU 2.6 71.137 | US Light Green | US Verde Claro | FS34151 | ANA611 | GU 3.1 71.139 | US Field Drab | US Marrón Verdoso | FS30118 | ANA617 | GU 3.9 71.140 | US Desert Sand | US Arena Desierto | FS30279 | ANA616 | GU 3.1 71.256 | Green RLM73 | RLM73 Grün | RLM73 | GU 3.2 71.263 | Green RLM72 | RLM72 Grün | RLM72 | GU 2.6 71.268 | German Grey | RAL6006 Feldgrau | RAL6006 | GU 2.2 71.270 | Off-White | RAL9001 Weiss | RAL9001 | GU 4.9 71.271 | German Red Brown | RAL8012 Rotbraun | RAL8012 | GU 3.2 71.272 | German Yellow Brown | RAL8000 Gelbbraun | RAL8000 | GU 2.3 71.278 | Sand Yellow RLM79 | RLM79 Sandgelb | RLM79 | GU 3.7 71.294 | US Forest Green | US Verde Bosque | FS34079 | ANA631 | GU 3.1 71.296 | USAAF Light Gray | Curtiss Grey | FS36622 | GU 5.1 71.316 | N. 41 Dark Olive Drab | N. 41 Verde Oliva Oscuro | GU 2.9 2023-02-23 Added measurements for Vallejo range 71.029-71.072. It was crazy amount of browns, grays (and greys), plus some paints called suspiciously like RAF targets, but not many matches really. Paints measured: 71.029 | Dark Earth | Tierra Oscura | GU 1.0 71.030 | Brown Green | Marron Verdoso | GU 1.7 71.031 | Middlestone | Piedra Medio | GU 1.5 71.032 | Golden Brown | Marron Dorado | GU 1.2 71.033 | Yellow Ochre | RAL1006 Gelb | RAL1006 | GU 1.7 71.034 | Sand Brown | Marron Arena | GU 1.6 71.035 | Cam. Pale Brown | Cam. Pardo Claro | FS30140 | RAL8025 | GU 2.1 71.036 | Mahogany | Caoba | GU 1.9 71.037 | Mud Brown | Marron Lodo | GU 2.0 71.038 | Cam. Medium Brown | Cam Pardo Medio | FS30097 | GU 1.3 71.039 | Hull Red | Marron Rojizo | GU 2.6 71.040 | Burnt Umber | Sombra Tostada | RAL8014 | GU 1.6 71.041 | Armour Brown | RAL8017 Rotbraun | RAL8017 | GU 1.1 71.042 | Dark Brown RLM61 | RLM61 Dunkelbraun | RLM61 | GU 1.3 71.043 | US Olive Drab | US Verde Oliva | FS34087 | GU 3.0 71.044 | Grey RLM02 | RLM02 Grau | RLM02 | GU 1.8 71.045 | Cement Grey | Gris Cemento | RAL7033 | GU 2.8 71.046 | Pale Blue Grey | Azul Gris Claro | GU 3.6 71.047 | Grey | Gris | GU 2.0 71.048 | Engine Grey | Gris Motor | FS36076 | GU 2.2 71.049 | Sea Grey | Gris Mar | GU 3.2 71.050 | Light Gray | Gris Claro | FS36300 | RAL7046 | GU 3.1 71.051 | Neutral Gray | Gris Neutral | FS36173 | GU 3.4 71.052 | Anthracite Grey | Gris Antracita | GU 2.2 71.053 | Dark Sea Grey | Gris Mar Osc. | FS36099 | RAL7011 | GU 2.9 71.054 | Dark Grey Blue | Gris Azul Oscuro | RAL7024 | GU 2.2 71.055 | Black Grey RLM66 | RLM66 Schwarzgrau | RLM66 | GU 3.3 71.056 | Panzer Dk. Grey | RAL7021 Dunkelgrau | RAL7021 | GU 1.6 71.057 | Black | Negro | FS37038 | RAL9004 | RLM22 | ANA604 | BS642 | GU 1.3 71.062 | Aluminium | Aluminio | GU 45.5 | Metallic 71.063 | Silver RLM01 | RLM01 Silber | RLM01 | GU 38.8 | Metallic 71.064 | Chrome | Cromo | FS17178 | GU 41.7 | Metallic 71.065 | Steel | Acero | GU 29.0 | Metallic 71.066 | Gold | Oro | FS17043 | GU 19.8 | Metallic 71.067 | Bright Brass | Laton | GU 32.1 | Metallic 71.068 | Copper | Cobre | GU 11.1 | Metallic 71.069 | Rust | Oxido | GU 7.1 | Metallic 71.070 | Signal Red | Rojo Señal | GU 6.2 | Metallic 71.071 | Arctic Blue | Azul Artico | GU 6.3 | Metallic 71.072 | Gunmetal | Fusil | FS37200 | GU 17.3 | Metallic 2023-02-22 Added measurements for Vallejo range 71.012-71.028. Found one potential match for RAF Light Earth Paints measured: 71.012 | Dark Green | Verde Oscuro | GU 2.6 71.013 | Yellow Olive | Oliva Amarillo | FS34062 | RAL6016 | GU 3.7 71.014 | Gunship Green | Verde Acorazado | GU 2.7 71.015 | Dark Green RLM71 | RLM71 Dunkelgrün | RLM71 | GU 2.6 71.016 | USAF Olive Drab | USAF Verde Oliva | FS34088 | ANA613 | GU 2.6 71.017 | Russian Green 4BO | Verde Ruso 4BO | FS34082 | GU 2.6 71.018 | Black Green | Verde Negro | GU 3.2 71.019 | Cam. Dark Green | RAL6007 Grün | FS34083 | RAL6007 | GU 3.5 71.020 | Green Brown | Verde Pardo | GU 2.0 71.021 | Black Green RLM70 | RLM70 Schwarzgrün | RLM70 | GU 3.3 71.022 | Light Green RLM82 | RLM82 Hellgrün | RLM82 | GU 1.3 71.023 | Hemp | Tan Green | FS34201 | GU 2.8 71.024 | Khaki Brown | Marron Caqui | GU 2.4 71.025 | Dark Yellow | RAL7028 Dunkelgelb | RAL7028 | GU 3.0 71.026 | US Flat Brown | Marron US | FS30215 | GU 2.5 71.027 | Light Brown | Marron Claro | GU 5.2 71.028 | Sand Yellow | Amarillo Arena | GU 4.2 2023-02-19 Added a measured good match for RAF Dark Green from Lifecolor RLM range. Paints measured: UA 501 | RLM 70 - Schwarzgrün | GU 9.2 UA 502 | RLM 71 - Dunkelgrün | GU 11.3 UA 503 | RLM 65 - Hellblau | GU 9.1 UA 504 | RLM 02 Grau | GU 6.5 UA 505 | RLM 79 - Sandgelb II | GU 8.7 UA 506 | RLM 80 Olivgrün | GU 8.1 2023-02-18 I completely forgot Golden Fluids are acrylics paints too, and there is one very surprising direct match: Titan Green Pale is a better match for RAF Sky than anything else from the tested paints list except Revell . Paints checked (Golden Fluid Acrylics) 2005 | Anthraquinone Blue 2008 | Benzimidazolone Yellow Medium 2009 | Benzimidazolone Yellow Light 2010 | Bone Black 2020 | Burnt Sienna 2035 | Burnt Umber Light 2040 | Carbon Black 2050 | Cerulean Blue, Chromium 2051 | Cerulean Blue Deep 2060 | Chromium Oxide Green 2140 | Cobalt Blue 2147 | Diarylide Yellow 2150 | Dioxazine Purple 2191 | Hansa Yellow Opaque 2210 | Naphthol Red Light 2220 | Naphthol Red Medium 2240 | Payne's Gray 2250B | Permanent Green Light 2255 | Phthalo Blue (Green Shade) 2270 | Phthalo Green (Blue Shade) 2275 | Phthalo Green (Yellow Shade) 2276 | Pyrrole Orange 2277 | Pyrrole Red 2279 | Pyrrole Red Light 2290 | Quinacridone Crimson 2301 | Quinacridone/Nickel Azo Gold 2305 | Quinacridone Magenta 2310 | Quinacridone Red 2330 | Quinacridone Violet 2340 | Raw Sienna 2350 | Raw Umber 2360 | Red Oxide 2369 | Teal 2370 | Titan Buff 2371 | Titan Green Pale 2380 | Titanium White 2385 | Transparent Red Iron Oxide 2386 | Transparent Yellow Iron Oxide 2400 | Ultramarine Blue 2401 | Ultramarine Violet 2403 | Vat Orange 2407 | Yellow Ochre 2410 | Yellow Oxide 2420 | Primary Cyan 2421 | Primary Magenta 2422B | Primary Yellow 2425 | Cadmium Red Medium Hue 2428B | Cadmium Yellow Medium Hue 2436B | Indian Yellow Hue 2439 | Prussian Blue Hue 2440 | Sap Green Hue 2442 | Van Dyke Brown Hue 5002390 | Turquoise (Phthalo) Targets set: British Aviation Colours of World War Two - Blue Target: RAF01 - Light Earth | GU 4.0 Matches in: Humbrol (compared with 182 samples) DE00: 0.93 - Humbrol - DB0093 | No 93 | Desert Yellow - Matt | GU 4.5 Matches in: Revell (compared with 86 samples) DE00: 2.45 - Revell - 36117 | Africa brown | GU 3.1 Matches in: Vallejo (compared with 260 samples) DE00: 1.20 - Vallejo - 71.117 | Camouflage Brown | RAL8020 Braun | RAL8020 | GU 3.0 Matches in: Tamiya (compared with 40 samples) DE00: 0.54 - Tamiya - XF-59 | Desert Yellow | GU GU 20.7 Target: RAF02 - Dark Earth | GU 3.3 Matches in: Humbrol (compared with 182 samples) DE00: 0.72 - Humbrol - DB0029 | No 29 | Dark Earth - Matt | GU 3.6 Matches in: Revell (compared with 86 samples) DE00: 2.51 - Revell - 36182 | Dark earth RAF | GU 2.1 Matches in: Vallejo (compared with 260 samples) DE00: 1.25 - Vallejo - 71.323 | BS Dark Earth | BS Tierra Oscura | BS450 | GU 1.6 Matches in: Hataka (compared with 10 samples) DE00: 2.97 - Hataka - HTK-A009 | Dark Earth | GU 9.1 Matches in: Lifecolor (compared with 12 samples) DE00: 0.84 - Lifecolor - UA 547 | Dark Earth | *FS 30118 | GU 6.3 Target: RAF03 - Light Green | GU 2.9 Matches in: Humbrol (compared with 182 samples) DE00: 0.82 - Humbrol - AA2252 | No 252 | RLM 82 Olivgrun - Matt | GU 2.2 Matches in: Vallejo (compared with 260 samples) DE00: 1.69 - Vallejo - 71.260 | Light Grey RLM63 | RLM63 Hellgrau | RLM63 | GU 1.5 Matches in: Lifecolor (compared with 12 samples) DE00: 1.21 - Lifecolor - UA 548 | Light Green | FS 34102 | GU 6.4 Target: RAF04 - Dark Green | GU 2.6 Matches in: Humbrol (compared with 182 samples) DE00: 1.56 - Humbrol - AB0253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 0.8 Matches in: Revell (compared with 86 samples) DE00: 2.29 - Revell - 36142 | Yellowish olive | GU 1.8 Matches in: Vallejo (compared with 260 samples) DE00: 1.66 - Vallejo - 71.294 | US Forest Green | US Verde Bosque | FS34079 | ANA631 | GU 3.1 Matches in: Hataka (compared with 10 samples) DE00: 1.64 - Hataka - HTK-A016 | Dark Green | GU 9.6 Matches in: Tamiya (compared with 40 samples) DE00: 2.23 - Tamiya - XF-13 | J.A. Green | GU 8.2 Matches in: Lifecolor (compared with 12 samples) DE00: 1.64 - Lifecolor - UA 506 | RLM 80 Olivgrün | GU 8.1 Target: RAF05 - Extra Dark Sea Green | GU 2.9 Matches in: Humbrol (compared with 182 samples) DE00: 1.69 - Humbrol - AA1612 | No 149 | Dark Green - Matt | GU 2.9 Matches in: Revell (compared with 86 samples) DE00: 2.63 - Revell - 36139 | Dark green | GU 2.2 Target: RAF06 - Grey Green | GU 3.2 Matches in: Vallejo (compared with 260 samples) DE00: 2.68 - Vallejo - 71.126 | IDF/IAF Green | Verde IDF/IAF | FS34227 | BS283 | GU 4.1 Target: RAF07 - Medium Sea Grey | GU 3.0 Matches in: Revell (compared with 86 samples) DE00: 2.35 - Revell - 36157 | Grey | RAL 7000 | GU 3.5 Matches in: Vallejo (compared with 260 samples) DE00: 1.59 - Vallejo - 71.050 | Light Gray | Gris Claro | FS36300 | RAL7046 | GU 3.1 Matches in: Army Painter Warpaints (compared with 104 samples) DE00: 2.73 - Army Painter Warpaints - WP1117 | Ash Grey | GU 1.4 Target: RAF08 - Dark Sea Grey | GU 3.5 Matches in: Humbrol (compared with 182 samples) DE00: 2.69 - Humbrol - DB0156 | No 156 | Dark Camouflage Grey - Satin | GU 7.3 Matches in: Vallejo (compared with 260 samples) DE00: 2.42 - Vallejo - 71.273 | Ocean Gray | Gris Oceano | FS36176 | BS629 | GU 3.9 Matches in: Army Painter Warpaints (compared with 104 samples) DE00: 0.45 - Army Painter Warpaints - WP1118 | Uniform Grey | GU 1.6 Target: RAF09 - Extra Dark Sea Grey | GU 4.4 Matches in: Humbrol (compared with 182 samples) DE00: 1.06 - Humbrol - AA1376 | No 125 | US Dark Grey - Satin | GU 11.4 Matches in: Revell (compared with 86 samples) DE00: 0.49 - Revell - 36174 | Gunship grey | GU 3.1 Matches in: Vallejo (compared with 260 samples) DE00: 0.90 - Vallejo - 71.097 | Medium Gunship Gray | Gris Medio USAF | FS36118 | ANA603 | GU 3.1 Matches in: Tamiya (compared with 40 samples) DE00: 2.58 - Tamiya - XF-24 | Dark Grey | GU 5.8 Matches in: Army Painter Warpaints (compared with 104 samples) DE00: 2.52 - Army Painter Warpaints - WP1418 | Dungeon Grey | GU 1.1 Target: RAF10 - Ocean Grey | GU 5.5 Matches in: Humbrol (compared with 182 samples) DE00: 1.51 - Humbrol - AA0059 | No 5 | Dark Admiralty Grey - Gloss | GU 90.8 Matches in: Revell (compared with 86 samples) DE00: 1.76 - Revell - 36179 | Greyish blue | RAL 7031 | GU 1.9 Target: RAF11 - Light Slate Grey | GU 3.0 Matches in: Humbrol (compared with 182 samples) DE00: 2.08 - Humbrol - AA0343 | No 31 | Slate Grey - Matt | GU 7.5 Matches in: Hataka (compared with 10 samples) DE00: 3.00 - Hataka - HTK-A025 | Interior Grey-Green | GU 17.4 Target: RAF12 - Dark Slate Grey | GU 4.2 Matches in: Humbrol (compared with 182 samples) DE00: 2.40 - Humbrol - AA7224 | No 224 | Dark Slate Grey - Matt | GU 3.0 Matches in: Revell (compared with 86 samples) DE00: 2.20 - Revell - 36167 | Greenish grey | RAL 7009 | GU 2.3 Matches in: Vallejo (compared with 260 samples) DE00: 2.46 - Vallejo - 71.128 | Gris Violeta | Gray Violet | FS36134 | GU 4.0 Matches in: Army Painter Warpaints (compared with 104 samples) DE00: 1.48 - Army Painter Warpaints - WP1481 | Field Grey | GU 2.3 Target: RAF13 - Sky Grey | GU 3.0 Matches in: Vallejo (compared with 260 samples) DE00: 0.59 - Vallejo - 71.407 | Sky Grey | Gris Cielo | FS36463 | GU 3.8 Target: RAF14 - Sky | GU 3.3 Matches in: Revell (compared with 86 samples) DE00: 1.72 - Revell - 36159 | Sky RAF | GU 3.4 Matches in: Golden Fluid Acrylics (compared with 53 samples) DE00: 2.25 - Golden Fluid Acrylics - 2371 | Titan Green Pale Target: RAF15 - Deep Sky | GU 4.8 Matches in: Revell (compared with 86 samples) DE00: 1.58 - Revell - 36156 | Blue | RAL 5000 | GU 2.2 Matches in: Vallejo (compared with 260 samples) DE00: 1.38 - Vallejo - 71.266 | Dark Blue RLM24 | RLM24 Dunkelblau | RLM24 | GU 4.9 Matches in: Army Painter Warpaints (compared with 104 samples) DE00: 0.78 - Army Painter Warpaints - WP1116 | Deep Blue | GU 4.3 Target: RAF16 - Sky Blue | GU 4.4 No matches with DE00<=3.00 Target: RAF17 - Azure Blue | GU 3.3 No matches with DE00<=3.00 Target: RAF18 - Light Mediterranean Blue | GU 3.2 No matches with DE00<=3.00 Target: RAF19 - Dark Mediterranean Blue | GU 2.7 Matches in: Humbrol (compared with 182 samples) DE00: 2.77 - Humbrol - DB0025 | No 25 | Blue - Matt | GU 5.1 Matches in: Revell (compared with 86 samples) DE00: 1.27 - Revell - 36156 | Blue | RAL 5000 | GU 2.2 Matches in: Vallejo (compared with 260 samples) DE00: 2.57 - Vallejo - 71.266 | Dark Blue RLM24 | RLM24 Dunkelblau | RLM24 | GU 4.9 Matches in: Army Painter Warpaints (compared with 104 samples) DE00: 2.51 - Army Painter Warpaints - WP1116 | Deep Blue | GU 4.3 Target: RAF20 - P.R.U. Blue | GU 2.9 Matches in: Humbrol (compared with 182 samples) DE00: 2.42 - Humbrol - AB0230 | No 230 | Pru Blue - Matt | GU 1.3 Target: RAF21 - Middle Stone | GU 3.1 Matches in: Army Painter Warpaints (compared with 104 samples) DE00: 1.71 - Army Painter Warpaints - WP1431 | Hemp Rope | GU 3 Target: RAF22 - Night | GU 2.2 Matches in: Humbrol (compared with 182 samples) DE00: 0.14 - Humbrol - DB0021 | No 21 | Black - Gloss | GU 45.3 Matches in: Revell (compared with 86 samples) DE00: 0.97 - Revell - 36302 | Black | RAL 9005 | GU 11.1 Matches in: Vallejo (compared with 260 samples) DE00: 1.90 - Vallejo - 71.057 | Black | Negro | FS37038 | RAL9004 | RLM22 | ANA604 | BS642 | GU 1.3 Matches in: Tamiya (compared with 40 samples) DE00: 0.23 - Tamiya - XF-1 | Flat Black | GU 3.5 Matches in: Army Painter Warpaints (compared with 104 samples) DE00: 1.42 - Army Painter Warpaints - WP1101 | Matt Black | GU 0.7 Matches in: Golden Fluid Acrylics (compared with 53 samples) DE00: 0.72 - Golden Fluid Acrylics - 2040 | Carbon Black Target: RAF23 - Yellow | GU 4.6 Matches in: Humbrol (compared with 182 samples) DE00: 2.65 - Humbrol - DB0154 | No 154 | Insignia Yellow - Matt | GU 9.6 Matches in: Vallejo (compared with 260 samples) DE00: 2.18 - Vallejo - 71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.7 Target: RAF24 - Red | GU 2.7 Matches in: Golden Fluid Acrylics (compared with 53 samples) DE00: 2.48 - Golden Fluid Acrylics - 2360 | Red Oxide Target: RAF25 - Blue | GU 2.4 Matches in: Vallejo (compared with 260 samples) DE00: 2.59 - Vallejo - 71.005 | Grey Blue | Azul Gris | RAL5008 | GU 1.5 Target: RAF26 - Aluminium | GU 58.9 | Metallic Matches in: Humbrol (compared with 182 samples) DE00: 0.93 - Humbrol - MET27002 | No 27002 | Polished Aluminium - Metalcote | GU 10.8 | Metallic Matches in: Vallejo (compared with 260 samples) DE00: 1.08 - Vallejo - 71.063 | Silver RLM01 | RLM01 Silber | RLM01 | GU 38.8 | Metallic Matches in: Tamiya (compared with 40 samples) DE00: 0.31 - Tamiya - XF-16 | Flat Aluminum | GU 6.7 | Metallic Matches in: Army Painter Warpaints (compared with 104 samples) DE00: 2.05 - Army Painter Warpaints - WP1129 | Shining Silver | GU 28.6 | Metallic Target: RAF27 - Matt Red | GU 2.8 Matches in: Humbrol (compared with 182 samples) DE00: 1.10 - Humbrol - DB0153 | No 153 | Insignia Red - Matt | GU 4.1 Matches in: Revell (compared with 86 samples) DE00: 1.45 - Revell - 36134 | Italian Red | GU 88.5 Matches in: Vallejo (compared with 260 samples) DE00: 1.47 - Vallejo - 71.269 | Red | RAL3000 Rot | RAL3000 | GU 5.3 Matches in: Tamiya (compared with 40 samples) DE00: 2.84 - Tamiya - XF-7 | Flat Red | GU 0.9 Matches in: Golden Fluid Acrylics (compared with 53 samples) DE00: 1.34 - Golden Fluid Acrylics - 2421 | Primary Magenta Target: RAF28 - Matt Blue | GU 5.4 Matches in: Humbrol (compared with 182 samples) DE00: 1.26 - Humbrol - DB0025 | No 25 | Blue - Matt | GU 5.1 Matches in: Revell (compared with 86 samples) DE00: 2.91 - Revell - 36156 | Blue | RAL 5000 | GU 2.2 Target: RAF29 - Semi Matt Black | GU 5.0 Matches in: Humbrol (compared with 182 samples) DE00: 0.19 - Humbrol - DB0085 | No 85 | Black - Satin | GU 19.5 Matches in: Revell (compared with 86 samples) DE00: 1.05 - Revell - 36106 | Tar black | RAL 9021 | GU 2.3 Matches in: Vallejo (compared with 260 samples) DE00: 2.00 - Vallejo - 71.057 | Black | Negro | FS37038 | RAL9004 | RLM22 | ANA604 | BS642 | GU 1.3 Matches in: Tamiya (compared with 40 samples) DE00: 0.50 - Tamiya - XF-1 | Flat Black | GU 3.5 Matches in: Army Painter Warpaints (compared with 104 samples) DE00: 1.24 - Army Painter Warpaints - WP1101 | Matt Black | GU 0.7 Matches in: Golden Fluid Acrylics (compared with 53 samples) DE00: 0.45 - Golden Fluid Acrylics - 2040 | Carbon Black List of paints used to compare with targets: Spoiler Sample set: Humbrol (182 samples) A1701 | No 157 | Azure Blue - Matt | GU 1.3 A6238 | No 187 | Dark Stone - Matt | GU 1.5 AA0046 | No 46 | Orange - Matt | GU 8.5 AA0059 | No 5 | Dark Admiralty Grey - Gloss | GU 90.8 AA0076 | No 7 | Light Buff - Gloss| GU 95.2 AA0134 | No 12 | Copper - Metallic | GU 8.7 | Metallic AA0173 | No 173 | Track Colour - Matt | GU 1.3 AA0234 | No 234 | Dark Flesh - Matt | GU 4.4 AA0343 | No 31 | Slate Grey - Matt | GU 7.5 AA0360 | No 33 | Black - Matt | GU 2.2 AA0549 | No 50 | Green Mist - Metallic | GU 94.3 | Metallic AA0552 | No 51 | Sunset Red - Metallic | GU 95.3 | Metallic AA0583 | No 53 | Gunmetal - Metallic | GU 1.2 | Metallic AA0727 | No 65 | Aircraft Blue - Matt | GU 5.0 AA0770 | No 66 | Olive Drab - Matt | GU 5.9 AA0775 | No 70 | Brick Red - Matt | GU 3.1 AA0802 | No 73 | Wine - Matt | GU 1.3 AA0816 | No 74 | Linen - Matt | GU 7.9 AA0833 | No 75 | Bronze Green - Matt | GU 2.0 AA0847 | No 76 | Uniform Green - Matt | GU 2.1 AA0850 | No 77 | Navy Blue - Matt | GU 1.7 AA0878 | No 79 | Blue Grey - Matt | GU 4.3 AA0905 | No 82 | Orange Lining - Matt | GU 4.1 AA0919 | No 83 | Ochre - Matt | GU 5.3 AA0922 | No 84 | Mid Stone - Matt | GU 4.1 AA0967 | No 87 | Steel Grey - Matt | GU 6.9 AA0970 | No 88 | Deck Green - Matt | GU 2.0 AA1105 | No 100 | Red Brown - Matt | GU 3.8 AA1119 | No 101 | Mid Green - Matt | GU 2.9 AA1167 | No 105 | Marine Green - Matt | GU 7.1 AA1287 | No 116 | US Dark Green - Matt | GU 2.1 AA1314 | No 119 | Light Earth - Matt | GU 4.5 AA1328 | No 120 | Light Green - Matt | GU 3.1 AA1331 | No 121 | Pale Stone - Matt | GU 7.0 AA1376 | No 125 | US Dark Grey - Satin | GU 11.4 AA1393 | No 126 | US Medium Grey - Satin | GU 37.9 AA1417 | No 128 | US Compass Grey - Satin | GU 31.6 AA1420 | No 129 | US Gull Grey - Satin | GU 21.6 AA1448 | No 131 | Mid Green - Satin | GU 21.1 AA1451 | No 132 | Red - Satin | GU 11.0 AA1465 | No 133 | Brown - Satin | GU 33.0 AA1496 | No 28 | Camouflage Grey - Matt | GU 17.2 AA1523 | No 140 | Gull Grey - Matt | GU 5.4 AA1568 | No 144 | Intermediate Blue - Matt | GU 4.8 AA1571 | No 145 | Medium Grey - Matt | GU 11.6 AA1599 | No 147 | Light Grey - Matt | GU 6.1 AA1609 | No 148 | Radome Tan - Matt | GU 19.1 AA1612 | No 149 | Dark Green - Matt | GU 2.9 AA1626 | No 150 | Forest Green - Matt | GU 1.4 AA1729 | No 159 | Khaki Drab - Matt | GU 2.0 AA1780 | No 164 | Dark Sea Grey - Satin | GU 25.9 AA1804 | No 166 | Light Aircraft Grey - Satin | GU 54.6 AA2240 | No 240 | RLM 02 Grau - Matt | GU 3.9 AA2241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 2.2 AA2241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 3.0 AA2242 | No 242 | RLM 71 Dunkelgrun - Matt | GU 1.0 AA2247 | No 247 | RLM 76 Lichtblau - Matt | GU 13.9 AA2248 | No 248 | RLM 78 Himmelblau - Matt | GU 3.0 AA2252 | No 252 | RLM 82 Olivgrun - Matt | GU 2.2 AA2253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 2.4 AA6330 | No 195 | Dark Green - Satin | GU 31.5 AA6344 | No 196 | Light Grey - Satin | GU 29.9 AA6389 | No 200 | Pink - Gloss | GU 91.8 AA6392 | No 201 | Black - Metallic | GU 91.3 | Metallic AA6608 | No 220 | Racing Red - Gloss | GU 100.0 AA7222 | No 222 | Moonlight Blue - Metallic | GU 95.0 | Metallic AA7224 | No 224 | Dark Slate Grey - Matt | GU 3.0 AA7225 | No 225 | Middle Stone - Matt | GU 2.6 AB0047 | No 47 | Sea Blue - Gloss | GU 65.0 AB0052 | No 52 | Baltic Blue - Metallic | GU 78.7 | Metallic AB0065 | No 65 | Aircraft Blue - Matt | GU 6.3 AB0078 | No 78 | Cockpit Green - Matt | GU 4.1 AB0090 | No 90 | Beige Green - Matt | GU 9.5 AB0091 | No 91 | Black Green - Matt | GU 1.6 AB0094 | No 94 | Brown Yellow - Matt | GU 2.2 AB0104 | No 104 | Oxford Blue - Matt | GU 1.4 AB0145 | No 145 | Medium Grey - Matt | GU 2.4 AB0165 | No 165 | Medium Sea Grey - Satin | GU 17.2 AB0167 | No 167 | RAF Barley Grey - Satin | GU 9.2 AB0168 | No 168 | Hemp - Satin | GU 33.8 AB0226 | No 226 | Interior Green - Matt | GU 2.3 AB0230 | No 230 | Pru Blue - Matt | GU 1.3 AB0237 | No 237 | Desert Tan - Matt | GU 1.3 AB0238 | No 238 | Arrow Red - Gloss | GU 65.7 AB0239 | No 239 | British Racing Green - Gloss | GU 56.0 AB0240 | No 240 | RLM 02 Grau - Matt | GU 1.3 AB0241 | No 241 | RLM 70 Schwartzgrun - Matt | GU 4.0 AB0243 | No 243 | RLM 72 Grun - Matt | GU 1.5 AB0244 | No 244 | RLM 73 Grun - Matt | GU 1.4 AB0245 | No 245 | RLM 74 Graugrun - Matt | GU 0.9 AB0246 | No 246 | RLM 75 Grauviolett - Matt | GU 1.3 AB0247 | No 247 | RLM 76 Lichtblau - Matt | GU 12.9 AB0249 | No 249 | RLM 79 Sandgelb - Matt | GU 1.5 AB0251 | No 251 | RLM 81 Dunkelbraun - Matt | GU 0.7 AB0252 | No 252 | RLM 82 Olivgrun - Matt | GU 0.7 AB0253 | No 253 | RLM 83 Dunkelgrun - Matt | GU 0.8 DB0001 | No 1 | Primer | GU 5.6 DB0002 | No 2 | Emerald Green - Gloss | GU 79.8 DB0003 | No 3 | Brunswick Green - Gloss | GU 63.0 DB0009 | No 9 | Tan - Gloss | GU 76.9 DB0010 | No 10 | Service Brown - Gloss | GU 78.0 DB0011 | No 11 | Silver - Metallic | GU 6.7 | Metallic DB0012 | No 12 | Copper - Metallic | GU 48.2 | Metallic DB0014 | No 14 | French Blue - Gloss | GU 80.5 DB0015 | No 15 | Midnight Blue - Gloss | GU 79.7 DB0016 | No 16 | Gold - Metallic | GU 6.4 | Metallic DB0018 | No 18 | Orange - Gloss | GU 78.0 DB0019 | No 19 | Red - Gloss | GU 90.2 DB0020 | No 20 | Crimson - Gloss | GU 84.2 DB0021 | No 21 | Black - Gloss | GU 45.3 DB0022 | No 22 | White - Gloss | GU 65.9 DB0023 | No 23 | Duck Egg Blue - Matt | GU 4.3 DB0024 | No 24 | Trainer Yellow - Matt | GU 3.6 DB0025 | No 25 | Blue - Matt | GU 5.1 DB0026 | No 26 | Khaki - Matt | GU 3.4 DB0027 | No 27 | Sea Grey - Matt | GU 10.5 DB0029 | No 29 | Dark Earth - Matt | GU 3.6 DB0030 | No 30 | Dark Green - Matt | GU 3.2 DB0032 | No 32 | Dark Grey - Matt | GU 11.2 DB0033 | No 33 | Black - Matt | GU 3.9 DB0034 | No 34 | White - Matt | GU 6.5 DB0036 | No 36 | Pastel Green - Matt | GU 6.9 DB0037 | No 37 | Bright Green - Matt | GU 3.9 DB0038 | No 38 | Lime - Gloss | GU 82.8 DB0040 | No 40 | Pale Grey - Gloss | GU 65.2 DB0041 | No 41 | Ivory - Gloss | GU 58.2 DB0042 | No 42 | Pastel Violet - Matt | GU 4.8 DB0044 | No 44 | Pastel Blue - Matt | GU 7.0 DB0048 | No 48 | Mediterranean Blue - Gloss | GU 71.1 DB0053 | No 53 | Gunmetal - Metallic | GU 6.1 | Metallic DB0054 | No 54 | Brass - Metallic | GU 8.0 | Metallic DB0055 | No 55 | Bronze - Metallic | GU 6.7 | Metallic DB0056 | No 56 | Aluminium - Metallic | GU 14.6 | Metallic DB0057 | No 57 | Pink - Matt | GU 5.2 DB0058 | No 58 | Magenta - Matt | GU 6.4 DB0060 | No 60 | Scarlett - Matt | GU 3.5 DB0061 | No 61 | Flesh - Matt | GU 5.9 DB0062 | No 62 | Leather - Matt | GU 3.5 DB0063 | No 63 | Sand - Matt | GU 7.1 DB0064 | No 64 | Light Grey - Matt | GU 5.9 DB0067 | No 67 | Matt Tank Grey - Matt | GU 5.2 DB0068 | No 68 | Purple - Gloss | GU 79.1 DB0069 | No 69 | Yellow - Gloss | GU 93.5 DB0071 | No 71 | Oak - Satin | GU 19.7 DB0072 | No 72 | Khaki Drill - Matt | GU 6.8 DB0080 | No 80 | Grass Green - Matt | GU 3.6 DB0081 | No 81 | Pale Yellow - Matt | GU 1.9 DB0085 | No 85 | Black - Satin | GU 19.5 DB0085 | No 86 | Light Olive - Matt | GU 9.2 DB0089 | No 89 | Middle Blue - Matt | GU 5.4 DB0093 | No 93 | Desert Yellow - Matt | GU 4.5 DB0096 | No 96 | RAF Blue - Matt | GU 6.6 DB0098 | No 98 | Chocolate - Matt | GU 3.0 DB0099 | No 99 | Lemon - Matt | GU 8.5 DB0102 | No 102 | Army Green - Matt | GU 4.6 DB0103 | No 103 | Cream - Matt | GU 6.1 DB0106 | No 106 | Ocean Grey - Matt | GU 4.4 DB0109 | No 109 | WWI Blue - Matt | GU 4.7 DB0110 | No 110 | Natural Wood - Matt | GU 6.4 DB0113 | No 113 | Rust - Matt | GU 4.9 DB0117 | No 117 | US Light Green - Matt | GU 3.5 DB0118 | No 118 | US Tan - Matt | GU 5.6 DB0123 | No 123 | Extra Dark Sea Grey - Satin | GU 18.4 DB0127 | No 127 | US Ghost Grey - Satin | GU 19.7 DB0130 | No 130 | White - Satin | GU 27.3 DB0153 | No 153 | Insignia Red - Matt | GU 4.1 DB0154 | No 154 | Insignia Yellow - Matt | GU 9.6 DB0155 | No 155 | Olive Drab - Matt | GU 6.2 DB0156 | No 156 | Dark Camouflage Grey - Satin | GU 7.3 DB0160 | No 160 | German Camouflage Red - Matt | GU 4.9 DB0163 | No 163 | Dark Green - Satin | GU 21.8 DB0171 | No 171 | Antique Bronze - Metallic | GU 7.1 | Metallic DB0174 | No 174 | Signal Red - Satin | GU 25.2 DB0186 | No 186 | Brown - Matt | GU 4.5 DB0189 | No 189 | Chrome Silver - Metallic | GU 89.6 | Metallic DB0208 | No 208 | Fluorescent Signal Green - Gloss | GU 11.3 | Fluorescent DB0209 | No 209 | Fire Orange - Gloss | GU 20.2 | Fluorescent DB0242 | No 242 | RLM 71 Dunkelgrun - Matt | GU 1.5 MET27001 | No 27001 | Aluminium - Metalcote | GU 5.2 | Metallic MET27002 | No 27002 | Polished Aluminium - Metalcote | GU 10.8 | Metallic MET27003 | No 27003 | Polished Steel - Metalcote | GU 47.4 | Metallic MET27004 | No 27004 | Gunmetal - Metalcote | GU 5.2 | Metallic Sample set: Revell (86 samples) 36104 | White | RAL 9010 | GU 72.8 36105 | White | RAL 9001 | GU 5.7 36106 | Tar black | RAL 9021 | GU 2.3 36107 | Black | RAL 9005 | GU 79.8 36108 | Black | RAL 9011 | GU 1.4 36109 | Anthracite | RAL 7021 | GU 4.7 36112 | Yellow | RAL 1018 | GU 79.5 36115 | Yellow | RAL 1017 | GU 6.5 36116 | Sandy yellow | RAL 1024 | GU 2.6 36117 | Africa brown | GU 3.1 36125 | Luminous orange | GU 3.5 | Fluorescent 36130 | Orange | RAL 2004 | GU 87.7 36131 | Fiery red | RAL 3000 | GU 90.5 36134 | Italian Red | GU 88.5 36135 | Flesh | GU 5.9 36136 | Carmine red | RAL 3002 | GU 3.0 36137 | Reddish brown | RAL 3009 | GU 1.8 36139 | Dark green | GU 2.2 36140 | Black green | GU 2.1 36142 | Yellowish olive | GU 1.8 36143 | Medium grey USAF | GU 2.9 36145 | Light olive | RAL 7003 | GU 2.2 36146 | Nato olive | RAL 7013 | GU 1.6 36147 | Mouse grey | RAL 7005 | GU 2.4 36148 | Sea green | RAL 6028 | GU 2.1 36149 | Light blue | GU 3.1 36150 | Light blue | RAL 5012 | GU 72.9 36151 | Ultramarine | RAL 5002 | GU 85.4 36152 | Blue | RAL 5005 | GU 82.7 36154 | Night blue | RAL 5022 | GU 85.3 36155 | Light green | RAL 6027 | GU 3.3 36156 | Blue | RAL 5000 | GU 2.2 36157 | Grey | RAL 7000 | GU 3.5 36159 | Sky RAF | GU 3.4 36161 | Emerald green | RAL 6029 | GU 82.3 36162 | Sea green | RAL 6005 | GU 88.5 36165 | Bronze green | RAL 6031 | GU 2.9 36166 | Olive grey | RAL 7010 | GU 2.2 36167 | Greenish grey | RAL 7009 | GU 2.3 36168 | Dark green RAF | GU 2.1 36169 | Granite grey | RAL 7026 | GU 1.6 36174 | Gunship grey | GU 3.1 36175 | Stone grey | RAL 7030 | GU 3.5 36176 | Light grey USAF | GU 4.1 36177 | Dust grey | RAL 7012 | GU 3.8 36178 | Tank grey | RAL 7024 | GU 2.9 36179 | Greyish blue | RAL 7031 | GU 1.9 36180 | Mud brown | RAL 8003 | GU 82.2 36182 | Dark earth RAF | GU 2.1 36183 | Rust | GU 1.9 36184 | Leather brown | RAL 8027 | GU 1.9 36185 | Brown | RAL 8023 | GU 2.5 36186 | Olive brown | RAL 7008 | GU 2.2 36187 | Earth brown | RAL 7006 | GU 4.8 36188 | Ochre brown | RAL 1011 | GU 2.4 36189 | Beige | RAL 1019 | GU 2.9 36190 | Silver | GU 76.6 | Metallic 36191 | Steel | GU 4.9 | Metallic 36192 | Brass | GU 54.8 | Metallic 36193 | Copper | GU 60.8 | Metallic 36194 | Gold | GU 53.0 | Metallic 36195 | Bronze | GU 61.5 | Metallic 36199 | Aluminium | GU 9.6 | Metallic 36301 | White | RAL 9010 | GU 20.9 36302 | Black | RAL 9005 | GU 11.1 36310 | Lufthansa Yellow | RAL 1028 | GU 25.6 36312 | Luminous yellow | RAL 1026 | GU 4.9 | Fluorescent 36314 | Beige | RAL 1001 | GU 18.8 36330 | Fiery red | RAL 3000 | GU 16.2 36331 | Purple red | RAL 3004 | GU 17.8 36332 | Luminous red | RAL 3026 | GU 3.7 | Fluorescent 36350 | Lufthansa blue | RAL 5013 | GU 19.6 36360 | Fern green | RAL 6025 | GU 22.2 36361 | Olive green | RAL 6003 | GU 24.5 36362 | Greyish green | RAL 6013 | GU 12.4 36363 | Dark green | RAL 6020 | GU 21.6 36364 | Leaf green | RAL 6001 | GU 20.4 36365 | Patina green | RAL 6000 | GU 38.1 36371 | Light grey | RAL 7035 | GU 17.8 36374 | Grey | RAL 7001 | GU 20.7 36378 | Dark grey | RAL 7012 | GU 28.0 36381 | Brown | RAL 8025 | GU 42.5 36382 | Wood brown | RAL 8001 | GU 24.0 36730 | Orange | GU 87.2 | Opacity 34.45% | Transparent 36731 | Red | GU 93.0 | Opacity 42.21% | Transparent 36752 | Blue | GU 88.5 | Opacity 48.3 | Transparent Sample set: Vallejo (260 samples) 71.001 | White | Blanco | FS37925 | RAL9016 | RLM21 | GU 3.5 71.002 | Medium Yellow | Amarillo Medio | GU 3.0 | Opacity 59.78% 71.003 | Red RLM 23 | RLM23 Rot | RLM23 | GU 1.6 | Opacity 92.19% 71.004 | Blue | Azul | GU 1.4 71.005 | Grey Blue | Azul Gris | RAL5008 | GU 1.5 71.006 | Light Green Chromate | Verde Claro Chromo | GU 1.3 71.007 | Olive Green | Verde Oliva | GU 1.2 71.008 | Pale Blue | Azul Claro | FS35414 | GU 2.0 71.009 | Eau De Nil "D.E. Green" | Verde Huevo Pato | BS216 | GU 1.8 71.010 | Interior Green | Verde Interior | FS34098 | GU 3.5 71.011 | Dark Green RLM83 | RLM83 Dunkelgrün | RLM83 | GU 1.2 71.012 | Dark Green | Verde Oscuro | GU 2.6 71.013 | Yellow Olive | Oliva Amarillo | FS34062 | RAL6016 | GU 3.7 71.014 | Gunship Green | Verde Acorazado | GU 2.7 71.015 | Dark Green RLM71 | RLM71 Dunkelgrün | RLM71 | GU 2.0 71.015 | Dark Green RLM71 | RLM71 Dunkelgrün | RLM71 | GU 2.6 71.016 | USAF Olive Drab | USAF Verde Oliva | FS34088 | ANA613 | GU 2.6 71.017 | Russian Green 4BO | Verde Ruso 4BO | FS34082 | GU 2.6 71.018 | Black Green | Verde Negro | GU 3.2 71.019 | Cam. Dark Green | RAL6007 Grün | FS34083 | RAL6007 | GU 3.5 71.020 | Green Brown | Verde Pardo | GU 2.0 71.021 | Black Green RLM70 | RLM70 Schwarzgrün | RLM70 | GU 0.6 71.021 | Black Green RLM70 | RLM70 Schwarzgrün | RLM70 | GU 3.3 71.022 | Light Green RLM82 | RLM82 Hellgrün | RLM82 | GU 0.8 71.022 | Light Green RLM82 | RLM82 Hellgrün | RLM82 | GU 1.3 71.023 | Hemp | Tan Green | FS34201 | GU 2.8 71.024 | Khaki Brown | Marron Caqui | GU 2.4 71.025 | Dark Yellow | RAL7028 Dunkelgelb | RAL7028 | GU 3.0 71.026 | US Flat Brown | Marron US | FS30215 | GU 2.5 71.027 | Light Brown | Marron Claro | GU 5.2 71.028 | Sand Yellow | Amarillo Arena | GU 4.2 71.029 | Dark Earth | Tierra Oscura | GU 1.0 71.030 | Brown Green | Marron Verdoso | GU 1.7 71.031 | Middlestone | Piedra Medio | GU 1.5 71.032 | Golden Brown | Marron Dorado | GU 1.2 71.033 | Yellow Ochre | RAL1006 Gelb | RAL1006 | GU 1.7 71.034 | Sand Brown | Marron Arena | GU 1.6 71.035 | Cam. Pale Brown | Cam. Pardo Claro | FS30140 | RAL8025 | GU 2.1 71.036 | Mahogany | Caoba | GU 1.9 71.037 | Mud Brown | Marron Lodo | GU 2.0 71.038 | Cam. Medium Brown | Cam Pardo Medio | FS30097 | GU 1.3 71.039 | Hull Red | Marron Rojizo | GU 2.6 71.040 | Burnt Umber | Sombra Tostada | RAL8014 | GU 1.6 71.041 | Armour Brown | RAL8017 Rotbraun | RAL8017 | GU 1.1 71.042 | Dark Brown RLM61 | RLM61 Dunkelbraun | RLM61 | GU 1.3 71.042 | Dark Brown RLM61 | RLM61 Dunkelbraun | RLM61 | GU 1.6 71.043 | US Olive Drab | US Verde Oliva | FS34087 | GU 3.0 71.044 | Grey RLM02 | RLM02 Grau | RLM02 | GU 1.8 71.044 | Grey RLM02 | RLM02 Grau | RLM02 | GU 1.9 71.045 | Cement Grey | Gris Cemento | RAL7033 | GU 2.8 71.046 | Pale Blue Grey | Azul Gris Claro | GU 3.6 71.047 | Grey | Gris | GU 2.0 71.048 | Engine Grey | Gris Motor | FS36076 | GU 2.2 71.049 | Sea Grey | Gris Mar | GU 3.2 71.050 | Light Gray | Gris Claro | FS36300 | RAL7046 | GU 3.1 71.051 | Neutral Gray | Gris Neutral | FS36173 | GU 3.4 71.052 | Anthracite Grey | Gris Antracita | GU 2.2 71.053 | Dark Sea Grey | Gris Mar Osc. | FS36099 | RAL7011 | GU 2.9 71.054 | Dark Grey Blue | Gris Azul Oscuro | RAL7024 | GU 2.2 71.055 | Black Grey RLM66 | RLM66 Schwarzgrau | RLM66 | GU 1.7 71.055 | Black Grey RLM66 | RLM66 Schwarzgrau | RLM66 | GU 3.3 71.056 | Panzer Dk. Grey | RAL7021 Dunkelgrau | RAL7021 | GU 1.6 71.057 | Black | Negro | FS37038 | RAL9004 | RLM22 | ANA604 | BS642 | GU 1.3 71.062 | Aluminium | Aluminio | GU 45.5 | Metallic 71.063 | Silver RLM01 | RLM01 Silber | RLM01 | GU 38.8 | Metallic 71.064 | Chrome | Cromo | FS17178 | GU 41.7 | Metallic 71.065 | Steel | Acero | GU 29.0 | Metallic 71.066 | Gold | Oro | FS17043 | GU 19.8 | Metallic 71.067 | Bright Brass | Laton | GU 32.1 | Metallic 71.068 | Copper | Cobre | GU 11.1 | Metallic 71.069 | Rust | Oxido | GU 7.1 | Metallic 71.070 | Signal Red | Rojo Señal | GU 6.2 | Metallic | Opacity 82.48% 71.071 | Arctic Blue | Azul Artico | GU 6.3 | Metallic 71.072 | Gunmetal | Fusil | FS37200 | GU 17.3 | Metallic 71.073 | Black | Negro | GU 14.6 | Metallic 71.074 | Beige | Beige | FS33695 | GU 2.7 71.075 | Ivory | RAL1001 Elfenbein | RAL1001 | GU 3.9 71.076 | Skin Tone | Color Piel | GU 5.1 71.077 | Wood | Madera | GU 1.7 71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.5 71.078 | Yellow RLM04 | RLM04 Gelb | FS33538 | RLM04 | ANA614 | BS356 | GU 2.7 71.079 | Tan Earth | Tierra | GU 2.4 71.080 | Rust | Oxido | FS30111 | BS435 | GU 2.7 71.081 | Ochre | Ocre | GU 2.1 71.082 | Fluorescent Red | Rojo Fluorescente | FS38903 | RAL2005 | GU 2.5 | Fluorescent | Opacity 32.63% 71.083 | Orange | Naranja | GU 2.5 | Opacity 64.68% 71.084 | Fire Red | Rojo Fuego | GU 3.1 71.085 | Ferrari Red | Rojo Ferrari | GU 2.9 | Opacity 95.6% 71.086 | Light Red | Rojo Claro | GU 3.2 | Opacity 68.56% 71.087 | Steel Blue | Azul Acero | RAL5013 | GU 2.3 71.088 | French Blue | Azul Francés | GU 3.0 71.089 | Light Sea Blue | Azul Mar Claro | GU 3.5 71.090 | Deep Sky | Azul Oscuro | FS35056 | GU 1.9 71.091 | Signal Blue | Azul Señal | FS35044 | RAL5004 | ANA605 | BS106 | GU 1.7 71.092 | Medium Olive | RAL6003 Olivgrün | RAL6003 | GU 1.9 71.093 | Nato Green | Verde Otan | FS34094 | GU 2.0 71.094 | Green Zinc Chromate | Verde Zinc | GU 2.0 71.095 | Pale Green | Verde Pálido | RAL6011 | GU 2.4 71.096 | Olive Grey | Verde Oliva Grisáceo | GU 4.6 71.097 | Medium Gunship Gray | Gris Medio USAF | FS36118 | ANA603 | GU 3.1 71.101 | Light Blue RLM78 | RLM78 Hellblau | RLM78 | GU 5.3 71.102 | Red | Rojo | GU 3.6 | Opacity 91.71% 71.103 | Grey Blue RLM84 | RLM84 Graublau | FS36559 | RLM84 | GU 1.7 71.104 | Green RLM62 | RLM62 Grün | RLM62 | GU 3.4 71.105 | Brown RLM26 | RLM26 Braun | RLM26 | GU 2.6 71.106 | Ivory RLM05 | RLM05 Elfenbein | GU 6.3 71.107 | US Interior Green | US Amarillo Inter. | GU 3.0 71.108 | Uk Azure Blue | Uk Azul Azure | FS35231 | ANA609 | GU 3.1 71.109 | Faded P.R.U. Blue | M485 Blue Gray | FS35189 | BS636 | GU 1.6 71.110 | Dark Grey | Gris Oscuro | BS640 | GU 3.7 71.111 | USAF Light Blue | USAF Azul Claro | FS35109 | GU 2.1 71.112 | Sand | Arena | GU 3.5 71.113 | IDF Blue | Azul IDF | FS35177 | GU 2.4 71.114 | Medium Gray | Gris Medio | FS35237 | GU 4.2 71.115 | Blue Grey | RAL7016 Blaugrau | RAL7016 | GU 2.0 71.116 | Camouflage Grey Green | RAL7008 Graugrün | RAL7008 | GU 2.3 71.117 | Camouflage Brown | RAL8020 Braun | RAL8020 | GU 3.0 71.118 | Camouflage Grey | RAL7027 Grau | RAL7027 | GU 2.7 71.119 | White Grey | RAL9002 Grauweiss | RAL9002 | GU 5.2 71.120 | Dark Ghost Gray | Gris Oscuro USAF | FS36320 | GU 5.9 71.121 | Light Gull Gray | Gris Gaviota USN | FS36440 | ANA620 | GU 2.6 71.122 | US Desert Armour 686 | US Camuflaje Moderno 686 | FS33446 | ANA620 | GU 8.0 71.123 | Dark Grey RLM42 | RLM42 Dunkelgrau | RLM42 | GU 3.2 71.124 | USAF Green | Verde USAF | FS34092-ANA612 | GU 2.7 71.125 | USAF Brown | Marrón USAF | FS30219 | ANA628 | GU 2.6 71.126 | IDF/IAF Green | Verde IDF/IAF | FS34227 | BS283 | GU 4.1 71.128 | Gris Violeta | Gray Violet | FS36134 | GU 4.0 71.129 | Light Rust | Óxido Claro | GU 3.2 71.130 | Orange Rust | Óxido Aanaranjado | RAL2010 | GU 4.5 71.131 | Concrete | Cemento | GU 3.4 71.132 | Aged White | Blanco Envejecido | FS37769 | RAL1015 | GU 4.9 71.133 | Suciedad | Dirt | GU 6.0 71.134 | IJA Midouri Green | IJA Verde Midouri | GU 5.3 71.135 | IJA Chrome Yellow | IJA Amarillo Cromado | FS33655 | RAL1003 | GU 3.4 | Opacity 67.5% 71.136 | IJA Earth Brown | IJA Marrón Tierra | GU 1.9 71.137 | US Light Green | US Verde Claro | FS34151 | ANA611 | GU 3.1 71.138 | US Sand | US Arena | FS30277 | GU 3.2 71.139 | US Field Drab | US Marrón Verdoso | FS30118 | ANA617 | GU 3.9 71.140 | US Desert Sand | US Arena Desierto | FS30279 | ANA616 | GU 3.1 71.141 | IDF Sand Grey 73 | IDF Gris Arena 73 | GU 4.0 71.142 | IDF Sinai Grey 82 | IDF Gris Sinai 82 | GU 3.6 71.143 | UK Light Stone | UK Piedra Clara | BS361 | GU 3.9 71.244 | Sand Beige | Sandbeige | RAL1039 | GU 1.8 71.245 | Loam Beige | Lehmbeige | RAL1040 | GU 3.9 71.246 | Yellow Brown | Sandbraun | RAL8031 | GU 4.3 71.247 | Light Olive | Helloliv | RAL6040 | GU 4.2 71.248 | Brown Grey | Gris Marrón | RAL7050 | GU 5.6 71.249 | Nato Brown | Lederbraun | FS30051 | RAL8027 | GU 1.9 71.250 | Bronze Green | Bronzegrün | RAL6031 | GU 2.3 71.251 | Nato Black | Teerschwarz | FS37030 | RAL9021 | GU 0.4 71.255 | Light Blue RLM65 | RLM65 Hellblau | RLM65 | GU 1.7 71.256 | Green RLM73 | RLM73 Grün | RLM73 | GU 3.2 71.257 | Light Blue RLM76 | RLM76 Lichtblau | RLM76 | GU 1.7 71.258 | Grey Green RLM74 | RLM74 Graugrün | RLM74 | GU 1.4 71.259 | Grey Violet RLM75 | RLM75 Grauviolett | RLM75 | GU 1.5 71.260 | Light Grey RLM63 | RLM63 Hellgrau | RLM63 | GU 1.5 71.263 | Green RLM72 | RLM72 Grün | RLM72 | GU 2.6 71.264 | Brown Violet RLM81 | RLM81 Braunviolett | RLM81 | GU 1.2 71.265 | Olive Green RLM80 | RLM80 Olivgrün | RLM80 | GU 2.9 71.266 | Dark Blue RLM24 | RLM24 Dunkelblau | RLM24 | GU 4.9 71.267 | Light Green RLM25 | RLM25 Hellgrün | RLM25 | GU 4.7 71.268 | German Grey | RAL6006 Feldgrau | RAL6006 | GU 2.2 71.269 | Red | RAL3000 Rot | RAL3000 | GU 5.3 71.270 | Off-White | RAL9001 Weiss | RAL9001 | GU 4.9 71.271 | German Red Brown | RAL8012 Rotbraun | RAL8012 | GU 3.2 71.272 | German Yellow Brown | RAL8000 Gelbbraun | RAL8000 | GU 2.3 71.273 | Ocean Gray | Gris Oceano | FS36176 | BS629 | GU 3.9 71.274 | Aggressor Gray | Gris Aggressor | FS36251 | GU 4.7 71.275 | USAF Medium Gray | USAF Gris Medio | FS36270 | GU 5.5 71.276 | USAF Light Gray | Gris Claro | FS36495 | GU 6.2 71.277 | Dark Gull Gray | Gris Gaviota Oscuro | FS36231 | ANA621 | GU 1.7 71.278 | Sand Yellow RLM79 | RLM79 Sandgelb | RLM79 | GU 3.7 71.279 | Insignia White | Blanco Insignia | FS37875 | ANA601 | GU 5.2 71.280 | Camouflage Gray | Gris Camuflaje | FS36170 | GU 5.0 71.281 | 3B Russian Green | 3B Verde Ruso | GU 6.7 71.282 | 6K Russian Brown | 6K Marrón Ruso | GU 5.5 71.283 | 7K Russian Tan | 7K Tierra Rusa | GU 8.6 71.284 | Uk Light Mud | Uk Marrón Claro | GU 9.3 71.285 | IJA Dark Green | IJA Verde Oscuro | GU 10.3 71.286 | IJA Olive Green | IJA Verde Oliva | GU 6.9 71.287 | IJA Khaki Brown | IJA Marrón Caqui | GU 4.7 71.288 | UK BSC 64 Portland Stone | UK BSC 64 Piedra Portland | GU 9.9 71.289 | US Dark Green | US Verde Oscuro | FS34102 | GU 4.4 71.290 | US Earth Brown | US Tierra Marrón | FS30099 | GU 5.1 71.291 | US Earth Yellow | US Tierra Amarilla | FS30257 | GU 4.6 71.292 | US Loam | US Marrón Barro | FS34086 | GU 7.6 71.293 | US Earth Red | US Tierra Roja | FS30117 | GU 6.8 71.294 | US Forest Green | US Verde Bosque | FS34079 | ANA631 | GU 3.1 71.295 | USN Sea Blue | USN Azul Marino | FS35042 | ANA607 | GU 2.2 71.296 | USAAF Light Gray | Curtiss Grey | FS36622 | GU 5.1 71.297 | JGSD Brown 3606 | JGSD Marrón 3606 | GU 6.4 71.298 | M495 Light Gray | M495 Gris Claro | FS36357 | GU 1.8 71.299 | Intermediate Blue | Azul Intermedio | FS35164 | ANA608 | GU 2.5 71.300 | Glossy Sea Blue | Azul Mar Brillante | FS15042 | ANA623 | GU 24.6 71.301 | Amt-4 Camouflage Green | Amt-4 Camuflaje Verde | GU 5.8 71.302 | Sky Type S | Verde Cielo | BS210 | GU 2.5 71.303 | A-24M Camouflage Green | A-24M Verde Camuflaje | GU 7.1 71.304 | Amt-11 Blue Grey | Amt-11 Azul Grisáceo | GU 6.7 71.305 | Interior Grey Green | Interior Gris Verde | FS34373 | GU 3.7 71.306 | Sky Blue | Azul Cielo | FS35550 | GU 3.5 71.307 | BS Medium Sea Grey | BS Gris Mar Medio | BS637 | GU 5.3 71.308 | Amt-12 Dark Grey | Amt-12 Gris Oscuro | GU 6.0 71.309 | Dark Slate Grey | Gris Pizarra Oscuro | FS34096 | BS634 | GU 1.9 71.310 | IJN Deep Dark Green | IJN Verde Oscuro Intenso | GU 2.0 71.311 | IJN Ash Grey | IJN Gris Ceniza | GU 2.4 71.312 | IJN Medium Grey | IJN Gris Medio | GU 2.2 71.313 | Dark Mediterranean Blue | Azul Mediterraneo Oscuro | GU 1.3 71.314 | Seaplane Gray | Gris Hidroavión | FS36081 | ANA625 | GU 3.8 71.315 | Tire Black | Negro Caucho | GU 1.2 71.316 | N. 41 Dark Olive Drab | N. 41 Verde Oliva Oscuro | GU 2.9 71.317 | AII SV. Gol Light Blue | AII SV. Gol Azul Claro | GU 3.2 71.318 | Amt-7 Greyish Blue | Amt-7 Azul Grisáceo | GU 1.7 71.319 | A-28M Greyish Blue | A-28M Azul Grisáceo | GU 2.8 71.321 | Sky Green | IJA Light Grey Green | FS34424 | ANA610 | GU 2.4 71.322 | IJN Black Green | IJN Verde Negro | GU 1.3 71.323 | BS Dark Earth | BS Tierra Oscura | BS450 | GU 1.6 71.324 | BS Dark Green | BS Verde Oscuro | BS241 | GU 1.7 71.325 | IJN Dark Black Green | IJN Verde Negro Oscuro | GU 2.4 71.326 | IJA Grey Green | IJA Gris Verdoso | GU 7.2 71.327 | IAF Sand | Arena IAF | FS33531 | GU 1.7 71.328 | Light Blue | Azul Claro | FS35622 | GU 2.6 71.329 | Green | Verde | FS34159 | GU 5.0 71.330 | Khaki Green Num. 3 | Verde Caqui Nº3 | GU 2.1 71.331 | Cockpit Eme. Green “Faded” | Verde Interior Cabina | GU 1.6 71.332 | Underside Blue “Faded” | Azul Desgastado | FS35450 | GU 2.3 71.333 | Russian AF Blue | Azul AF Ruso | GU 2.0 71.334 | Flanker Light Blue | Azul Claro Flanker | GU 2.9 71.335 | Flanker Light Gray | Gris Claro Flanker | GU 3.8 71.336 | A-14 Steel Grey | A-14 Gris Acero | GU 1.7 71.337 | Flanker Blue | Azul Flanker | GU 3.0 71.338 | Russian AF Grey Blue | Gris Azul AF Ruso | GU 2.7 71.339 | Russian AF Grey N.3 | Gris N.3 AF Ruso | FS36373 | GU 2.3 71.340 | Grey Green | Gris Verdoso | GU 1.8 71.341 | Green Grey | Verde Grisáceo | GU 1.8 71.342 | Russian AF Light Blue | Azul Claro AF Ruso | GU 2.6 71.343 | Russian AF Grey N.7 | Gris N.7 AF Ruso | GU 1.9 71.344 | Russian AF Grey Prot. Coat | Gris AF Ruso | GU 2.8 71.345 | Russian AF Grey N.8 | Gris N.8 AF Ruso | GU 2.3 71.346 | Russian AF Grey N.4 | Gris N.4 AF Ruso | GU 2.5 71.347 | Russian AF Dark Green | Verde Oscuro AF Ruso | GU 1.4 71.348 | USAF Tan | USAF Marrón Arena | FS20400 | GU 2.0 71.401 | Uk Bsc 28 Sil. Grey | Uk Bsc28 Gris Plata | GU 1.8 71.402 | Uk Bsc 49 L. Purple Br. | Uj Bsc49 Mr. Purpura | GU 2.5 71.403 | Light Green | Verde Claro | GU 2.0 71.404 | No. 1 "Duck Egg Blue" | Azul Huevo De Pato | GU 1.8 71.405 | BS Dark Sea Grey | BS Gris Mar Osc. | GU 1.3 71.406 | Light Slate Grey | Gris Pizarra Claro | GU 1.5 71.407 | Sky Grey | Gris Cielo | FS36463 | GU 3.8 71.408 | PRU Pink | PRU Rosa | GU 3.7 71.409 | Zaschchitnyi Khaki | Verde Zaschcitnyi | GU 1.3 71.410 | AII Zashchitnyi Cam. Green | AII Verde Zaschitnyi | GU 1.2 71.411 | A-19F Grass Green | A-19F Verde Hierba | GU 1.5 71.412 | VVS Grey Blue | VVS Gris Azulado | GU 7.4 71.413 | A-18F Light Blue | A-18F Azul Claro | GU 8.8 71.414 | AEH-9 Light Grey | AEH-9 Gris Claro | GU 2.7 71.415 | A-21 Light Greyish Br. | A-21 Mr. Gris. Claro | GU 1.7 71.416 | IJA Dark Beige | IJA Beige Oscuro | GU 1.3 71.417 | "Aotake" Trans. Green | "Aotake" Verde Trans | GU 31.2 | Opacity 56.37% 71.418 | IJN Medium Brown | IJN Maroon Medio | GU 1.3 71.419 | "Aotake" Trans. Blue | "Aotake" Azul Trans. | GU 17.3 | Opacity 87.81% Sample set: Hataka (10 samples) HTK-A009 | Dark Earth | GU 9.1 HTK-A015 | Black-Green (RLM70) | GU 7.9 HTK-A016 | Dark Green | GU 9.6 HTK-A017 | Dark Green (RLM71) | GU 10.5 HTK-A023 | Grey (RLM02) | GU 14.1 HTK-A025 | Interior Grey-Green | GU 17.4 HTK-A026 | Sky "Type S" | GU 13.1 HTK-A029 | Light Blue (RLM65/78) | GU 13.2 HTK-A032 | Ocean Grey | GU 13.3 HTK-A034 | Medium Sea Grey | GU 14.2 Sample set: Tamiya (40 samples) XF-1 | Flat Black | GU 3.5 XF-10 | Flat Brown | GU 4.1 XF-11 | J.N. Green | GU 3.9 XF-12 | J.N. Gray | GU 1.9 XF-13 | J.A. Green | GU 8.2 XF-14 | J.A. Grey | GU 8.8 XF-15 | Flat Flesh | GU 15.2 XF-16 | Flat Aluminum | GU 6.7 | Metallic XF-17 | Sea Blue | GU 4.6 XF-18 | Medium Blue | GU 6.5 XF-19 | Sky Grey | GU 7.1 XF-2 | Flat White | GU 7.3 XF-20 | Medium Grey | GU 3.8 XF-21 | Sky | GU 6.7 XF-22 | RLM Grey | GU 4.3 XF-23 | Light Blue | GU 4.5 XF-24 | Dark Grey | GU 5.8 XF-25 | Light Sea Grey | GU 4.5 XF-26 | Deep Green | GU 5.3 XF-27 | Black Green | GU 2.1 XF-28 | Dark Copper | GU 5.3 | Metallic XF-3 | Flat Yellow | GU 3.8 XF-4 | Yellow Green | GU 5.1 XF-49 | Khaki | GU 5.5 XF-5 | Flat Green | GU 2.8 XF-50 | Field Blue | 7.1 XF-51 | Khaki Drab | GU 4.9 XF-52 | Flat Earth | GU 5.3 XF-53 | Neutral Grey | GU 6.6 XF-54 | Dark Sea Grey | GU 6.5 XF-55 | Deck Tan | GU 19.1 XF-56 | Metallic Grey | GU 6.3 | Metallic XF-57 | Buff | GU 18.2 XF-58 | Olive Green | GU 6.1 XF-59 | Desert Yellow | GU GU 20.7 XF-6 | Copper | GU 4.5 | Metallic XF-60 | Dark Yellow | GU 13.0 XF-7 | Flat Red | GU 0.9 XF-8 | Flat Blue | GU 3.4 XF-9 | Hull Red | GU 4.2 Sample set: Lifecolor (12 samples) UA 501 | RLM 70 - Schwarzgrün | GU 9.2 UA 502 | RLM 71 - Dunkelgrün | GU 11.3 UA 503 | RLM 65 - Hellblau | GU 9.1 UA 504 | RLM 02 Grau | GU 6.5 UA 505 | RLM 79 - Sandgelb II | GU 8.7 UA 506 | RLM 80 Olivgrün | GU 8.1 UA 546 | Dark Green | *FS 34079 | GU 7.0 UA 547 | Dark Earth | *FS 30118 | GU 6.3 UA 548 | Light Green | FS 34102 | GU 6.4 UA 549 | Light Earth | FS 30257 | GU 6.8 UA 550 | Sky | FS 34424 | GU 6.4 UA 551 | Grey Green | FS 34226 | GU 9.0 Sample set: Army Painter Warpaints (104 samples) WP1101 | Matt Black | GU 0.7 WP1102 | Matt White | GU 3.6 WP1104 | Pure Red | GU 2.5 WP1105 | Dragon Red | GU 2.7 WP1106 | Lava Orange | GU 2 WP1107 | Daemonic Yellow | GU 3.6 WP1108 | Necrotic Flesh | GU 2.1 WP1109 | Goblin Green | GU 0.9 WP1110 | Army Green | GU 2.1 WP1111 | Greenskin | GU 1.2 WP1112 | Angel Green | GU 1.6 WP1113 | Electric Blue | GU 2.2 WP1114 | Crystal Blue | GU 1.7 WP1115 | Ultramarine Blue | GU 2.4 WP1116 | Deep Blue | GU 4.3 WP1117 | Ash Grey | GU 1.4 WP1118 | Uniform Grey | GU 1.6 WP1119 | Wolf Grey | GU 2 WP1120 | Monster Brown | GU 1.7 WP1121 | Desert Yellow | GU 2.1 WP1122 | Fur Brown | GU 3.1 WP1123 | Leather Brown | GU 3.3 WP1124 | Oak Brown | GU 1.9 WP1125 | Skeleton Bone | GU 2.5 WP1126 | Barbarian Flesh | GU 1.5 WP1127 | Tanned Flesh | GU 1.3 WP1128 | Alien Purple | GU 1.7 WP1129 | Shining Silver | GU 28.6 | Metallic WP1130 | Plate Mail Metal | GU 33.8 | Metallic WP1131 | Gun Metal | GU 28.2 | Metallic WP1132 | Greedy Gold | GU 32.6 | Metallic WP1133 | Weapon Bronze | GU 39.2 | Metallic WP1141 | Hydra Turquoise | GU 2 WP1142 | Chaotic Red | GU 1.3 WP1144 | Bright Gold | GU 24.7 | Metallic WP1401 | Abomination Gore | GU 2.8 WP1402 | Arid Earth | GU 2.4 WP1403 | Babe Blonde | GU 4.8 WP1404 | Banshee Brown | GU 1.5 WP1405 | Basilisk Brown | GU 2.7 WP1406 | Brainmatter Beige | GU 3.9 WP1407 | Castle Grey | GU 1.6 WP1408 | Centaur Skin | GU 2.2 WP1409 | Combat Fatigues | GU 3.2 WP1410 | Commando Green | GU 3.1 WP1411 | Corpse Pale | GU 3.3 WP1412 | Crusted Sore | GU 1.3 WP1413 | Crypt Wraith | GU 1.9 WP1414 | Cultist Robe | GU 1.3 WP1415 | Dark Sky | GU 8.4 WP1416 | Dirt Spatter | GU 1.7 WP1417 | Drake Tooth | GU 2 WP1418 | Dungeon Grey | GU 1.1 WP1419 | Elemental Bolt | GU 2.5 WP1420 | Elf Green | GU 2.7 WP1421 | Elven Flesh | GU 2.6 WP1422 | Orc Blood | GU 2.3 WP1424 | Filthy Cape | GU 2.4 WP1425 | Dark Stone | GU 2.6 WP1426 | Fire Lizard | GU 4.2 WP1427 | Fog Grey | GU 1.4 WP1428 | Gorgon Hide | GU 2.3 WP1429 | Griffon Blue | GU 1.9 WP1430 | Hardened Carpace | GU 1.8 WP1431 | Hemp Rope | GU 3 WP1432 | Ice Storm | GU 1.7 WP1433 | Jungle Green | GU 2.9 WP1434 | Kobold Skin | GU 2.4 WP1435 | Kraken Skin | GU 4.2 WP1436 | Mars Red | GU 3.1 WP1437 | Toxic Mist | GU 1.8 WP1438 | Moon Dust | GU 3.8 WP1439 | Mouldy Clothes | GU 1.4 WP1440 | Mummy Robes | GU 4.1 WP1441 | Mutant Hue | GU 1.9 WP1442 | Mythical Orange | GU 4.4 WP1443 | Necromancer Cloak | GU 1.3 WP1444 | Grimoire Purple | GU 1.7 WP1445 | Oozing Purple | GU 1.6 WP1446 | Phoenix Flames | GU 3.5 WP1447 | Pixie Pink | GU 1.3 WP1448 | Poisonous Cloud | GU 4.4 WP1449 | Royal Cloak | GU 3.5 WP1450 | Scaly Hide | GU 3.2 WP1451 | Warlock Purple | GU 2.4 WP1452 | Voidshield Blue | GU 1.9 WP1453 | Snake Scales | GU 2.5 WP1454 | Spaceship Exterior | GU 2.4 WP1455 | Stone Golem | GU 2 WP1456 | Sulfide Ochre | GU 2.6 WP1457 | Toxic Boils | GU 1.8 WP1458 | Troglodyte Blue | GU 1.5 WP1459 | Troll Claws | GU 3.7 WP1460 | Vampire Red | GU 2.7 WP1461 | Venom Wyrm | GU 3.5 WP1462 | Viking Blue | GU 3 WP1463 | Wasteland Soil | GU 2 WP1464 | Werewolf Fur | GU 2.6 WP1465 | Witch Brew | GU 3.6 WP1466 | Wizards Orb | GU 0.9 WP1467 | True Copper | GU 28.3 | Metallic WP1468 | Rough Iron | GU 16.3 | Metallic WP1480 | Scar Tissue | GU 1.9 WP1481 | Field Grey | GU 2.3 Sample set: Golden Fluid Acrylics (53 samples) 2005 | Anthraquinone Blue 2008 | Benzimidazolone Yellow Medium 2009 | Benzimidazolone Yellow Light 2010 | Bone Black 2020 | Burnt Sienna 2035 | Burnt Umber Light 2040 | Carbon Black 2050 | Cerulean Blue, Chromium 2051 | Cerulean Blue Deep 2060 | Chromium Oxide Green 2140 | Cobalt Blue 2147 | Diarylide Yellow 2150 | Dioxazine Purple 2191 | Hansa Yellow Opaque 2210 | Naphthol Red Light 2220 | Naphthol Red Medium 2240 | Payne's Gray 2250B | Permanent Green Light 2255 | Phthalo Blue (Green Shade) 2270 | Phthalo Green (Blue Shade) 2275 | Phthalo Green (Yellow Shade) 2276 | Pyrrole Orange 2277 | Pyrrole Red 2279 | Pyrrole Red Light 2290 | Quinacridone Crimson 2301 | Quinacridone/Nickel Azo Gold 2305 | Quinacridone Magenta 2310 | Quinacridone Red 2330 | Quinacridone Violet 2340 | Raw Sienna 2350 | Raw Umber 2360 | Red Oxide 2369 | Teal 2370 | Titan Buff 2371 | Titan Green Pale 2380 | Titanium White 2385 | Transparent Red Iron Oxide 2386 | Transparent Yellow Iron Oxide 2400 | Ultramarine Blue 2401 | Ultramarine Violet 2403 | Vat Orange 2407 | Yellow Ochre 2410 | Yellow Oxide 2420 | Primary Cyan 2421 | Primary Magenta 2422B | Primary Yellow 2425 | Cadmium Red Medium Hue 2428B | Cadmium Yellow Medium Hue 2436B | Indian Yellow Hue 2439 | Prussian Blue Hue 2440 | Sap Green Hue 2442 | Van Dyke Brown Hue 5002390 | Turquoise (Phthalo) Edited April 19, 2023 by Casey Added yet another 48 Vallejo measurements 5 1 Link to comment Share on other sites More sharing options...
Casey Posted February 19, 2023 Share Posted February 19, 2023 After checking 6 more Lifecolor paints (from RLM range) I've found one very interesting match. I'll update the previous post with those. Target: RAF04 - Dark Green | GU 2.6, RGB: #55584C (L*=36.49, a=-2.32, b=6.25) Found a match in: Lifecolor (compared with 12 paints) DE00: 1.64 - #52584C - Lifecolor - UA 506 | RLM 80 Olivgrün | GU 8.1 (L*=36.47, a=-3.65, b=6.46) @Mike Any ideas how can I regularly publish similar tables in a form that wont turn this (or any other similar comparison I might make) into dozens posts long "Casey babbles to herself" thread? 4 Link to comment Share on other sites More sharing options...
Casey Posted February 22, 2023 Share Posted February 22, 2023 (edited) I've made 17 more paints measurements from Vallejo Air range and found one potential match for Light Earth Target: RAF01 - Light Earth | GU 4.0, RGB: #A98C68 (L*=59.33, a=8.24, b=22.00) Found a match in: Vallejo (compared with 51 paints) DE00: 1.90 - #B0916E - Vallejo - 71.027 | Light Brown | Marron Claro | GU 5.2 (L*=61.29, a=8.96, b=21.51) Edited February 22, 2023 by Casey 5 Link to comment Share on other sites More sharing options...
Casey Posted February 23, 2023 Share Posted February 23, 2023 (edited) After measuring 40 more Vallejo Air paints (including those with promising names, like Dark Earth). Those are the new matches that I've found this time. Target: RAF07 - Medium Sea Grey | GU 3.0, RGB: #889098 (L*=59.60, a=-1.97, b=-5.01) Found a match in: Vallejo (compared with 91 paints) DE00: 1.59 - #868C95 - Vallejo - 71.050 | Light Gray | Gris Claro | FS36300 | RAL7046 | GU 3.1 (L*=58.26, a=-1.18, b=-5.02) Target: RAF09 - Extra Dark Sea Grey | GU 4.4, RGB: #5C626A (L*=41.40, a=-0.76, b=-5.06) Found a match in: Vallejo (compared with 91 paints) DE00: 2.93 - #61686C - Vallejo - 71.049 | Sea Grey | Gris Mar | GU 3.2 (L*=43.60, a=-1.91, b=-3.41) Target: RAF22 - Night | GU 2.2, RGB: #3A3C3D (L*=25.10, a=-0.20, b=-1.08) Found a match in: Vallejo (compared with 91 paints) DE00: 1.90 - #343637 - Vallejo - 71.057 | Black | Negro | FS37038 | RAL9004 | RLM22 | ANA604 | BS642 | GU 1.3 (L*=22.50, a=-0.43, b=-1.01) Target: RAF26 - Aluminium | GU 58.9 | Metallic, RGB: #CECED0 (L*=82.90, a=-0.01, b=-0.91) Found a match in: Vallejo (compared with 91 paints) DE00: 1.08 - #CED0D4 - Vallejo - 71.063 | Silver RLM01 | RLM01 Silber | RLM01 | GU 38.8 | Metallic (L*=83.55, a=-0.16, b=-1.94) Target: RAF29 - Semi Matt Black | GU 5.0, RGB: #3B3C3D (L*=25.22, a=-0.20, b=-0.77) Found a match in: Vallejo (compared with 91 paints) DE00: 2.00 - #343637 - Vallejo - 71.057 | Black | Negro | FS37038 | RAL9004 | RLM22 | ANA604 | BS642 | GU 1.3 (L*=22.50, a=-0.43, b=-1.01) Edited February 24, 2023 by Casey 3 2 Link to comment Share on other sites More sharing options...
Mr_Sworld Posted February 23, 2023 Share Posted February 23, 2023 Thanks, Casey. This is exactly the level of Geekery I love! 1 Link to comment Share on other sites More sharing options...
Casey Posted February 24, 2023 Share Posted February 24, 2023 (edited) Just added 31 more paint measurements. I found some updated/potential matches: Target: RAF01 - Light Earth | GU 4.0, RGB: #A98C68 (L*=59.33, a=8.24, b=22.00) Found a match in: Vallejo (compared with 122 paints) DE00: 1.20 - #AC8D6E - Vallejo - 71.117 | Camouflage Brown | RAL8020 Braun | RAL8020 | GU 3.0 (L*=60.16, a=8.37, b=20.41) Target: RAF04 - Dark Green | GU 2.6, RGB: #55584C (L*=36.49, a=-2.32, b=6.25) Found a match in: Vallejo (compared with 122 paints) DE00: 1.66 - #585A4B - Vallejo - 71.294 | US Forest Green | US Verde Bosque | FS34079 | ANA631 | GU 3.1 (L*=37.30, a=-2.06, b=8.10) Target: RAF09 - Extra Dark Sea Grey | GU 4.4, RGB: #5C626A (L*=41.40, a=-0.76, b=-5.06) Found a match in: Vallejo (compared with 122 paints) DE00: 0.90 - #5D636B - Vallejo - 71.097 | Medium Gunship Gray | Gris Medio USAF | FS36118 | ANA603 | GU 3.1 (L*=41.99, a=-1.27, b=-4.85) Edited February 25, 2023 by Casey 4 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted February 25, 2023 Author Share Posted February 25, 2023 Absolutely intrepid work Casay, really opened a can of worms here, defiterly decided I hate paoint now, just been going round in circles of USN Sea blues (Surprise xtracrylix is wrong for that as well, and Vallejo 898 looks spot on for postwar Gloss Sea Blue though to bad its matt...) Link to comment Share on other sites More sharing options...
Casey Posted February 25, 2023 Share Posted February 25, 2023 11 minutes ago, PhantomBigStu said: been going round in circles of USN Sea blues Want me to find matches for those too? 2 1 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted February 25, 2023 Author Share Posted February 25, 2023 1 hour ago, Casey said: Want me to find matches for those too? Not on my account, as I said I've found a match for post war sea blue I was interested in as thats the one I've got any plans to build in the short term, might order AK Interactives take on sea blues to see how they compare to period photos just in case I decided to do a wartime aircraft in the future Link to comment Share on other sites More sharing options...
Casey Posted February 25, 2023 Share Posted February 25, 2023 4 minutes ago, PhantomBigStu said: Not on my account, as I said I've found a match for post war sea blue I was interested in as thats the one I've got any plans to build in the short term, might order AK Interactives take on sea blues to see how they compare to period photos just in case I decided to do a wartime aircraft in the future Well, I ran my database over ANA targets and results are really disappointing. There are no good matches (<3.0) for ANA607 and ANA 608 in any paints I have in the database so far. ANA606 is closest to 71.053 but 71.053 is dead flat while 606 is high satin. I think I need whole range of Vallejo paints - matching colors with them is like throwing things at the wall and seeing what sticks... 1 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted February 25, 2023 Author Share Posted February 25, 2023 5 minutes ago, Casey said: Well, I ran my database over ANA targets and results are really disappointing. There are no good matches (<3.0) for ANA607 and ANA 608 in any paints I have in the database so far. ANA606 is closest to 71.053 but 71.053 is dead flat while 606 is high satin. I think I need whole range of Vallejo paints - matching colors with them is like throwing things at the wall and seeing what sticks... You got ANA623 in database? As said Vallejo 70.898 looks good to my eye for FS35042 which is what ANA623 was reformulated into, and indeed looks good as well from period photos of that Link to comment Share on other sites More sharing options...
Casey Posted February 25, 2023 Share Posted February 25, 2023 (edited) 10 minutes ago, PhantomBigStu said: ANA623 Target: ANA623 | Glossy Sea Blue 623 | GU 19.6, RGB: #464E56 (L*=32.82, a=-1.31, b=-5.64) Found a match in: Vallejo (compared with 122 paints) DE00: 1.50 - #4B5259 - Vallejo - 71.053 | Dark Sea Grey | Gris Mar Osc. | FS36099 | RAL7011 | GU 2.9 (L*=34.53, a=-1.48, b=-5.02) Found a match in: Tamiya (compared with 34 paints) DE00: 2.49 - #495155 - Tamiya - XF-50 | Field Blue | 7.1 (L*=33.92, a=-2.34, b=-3.47) Found a match in: Humbrol (compared with 182 paints) DE00: 2.77 - #44C5A - Humbrol - AB0104 | No 104 | Oxford Blue - Matt | GU 1.4 (L*=32.75, a=-0.22, b=-8.68) Vallejo 71.053, Tamiya XF-50 and Humbrol 104, in this order. No matter what Vallejo labels might have and even if they have dedicated ANA623. Those matches are all matt and target is semi gloss - so you cant compare them visually without getting them to the same finish first. Integrating sphere spectrophotometer in SCI mode removes the gloss from color measurements for you. RGB don't really show the differences well (and only confirms that color photos do not show real colors ) Edited February 25, 2023 by Casey 1 Link to comment Share on other sites More sharing options...
Casey Posted February 25, 2023 Share Posted February 25, 2023 (edited) 20 minutes ago, PhantomBigStu said: FS35042 Targets set: Federal Standard 595 Mar 1 1956 Target: 35042, RGB: #303B41 (L*=24.39, a=-4.20, b=-4.49) No matches with DE00<=3.00 Closest match that I have for this color is: DE00: 4.01 - #3C4146 - Vallejo - 71.300 | Glossy Sea Blue | Azul Mar Brillante | FS15042 | ANA623 | GU 24.6 (L*=27.46, a=-1.56, b=-3.49) Sadly DE 4.01 is not even close. Edited February 25, 2023 by Casey 1 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted February 25, 2023 Author Share Posted February 25, 2023 (edited) Thanks Casey, interesting Vallejo’s fs36099 is the closest match, I’ve got the model colour version so will try it out, skeptical it’s blue enough for 623 edit: yep no where near blue enough, not that it’s a big deal Vallejo 898 is probably close enough for me, also think I’ve got something that might be close enough for the bluer of ANA606/607 for me. Edited February 25, 2023 by PhantomBigStu Link to comment Share on other sites More sharing options...
Troy Smith Posted February 26, 2023 Share Posted February 26, 2023 15 hours ago, PhantomBigStu said: for FS35042 which is what ANA623 was reformulated into there is a discussion on USN Sea Blues here https://www.britmodeller.com/forums/index.php?/topic/235049797-us-navy-sea-blues/ I have used some quotes from the link. OK, there are TWO ANA 623's. the original 1944 version, which was found prone to fading, and the 1947 reformulation, which became incorporated into the FS 595 as FS 15042. this from @Dana Bell "There are a couple of other reasons the model paint manufacturers have had problems matching the Sea Blues. Most are working from the FS595 chips, which never accurately matched all three versions of the wartime colors. The other problem is that the formula for ANA 623 Glossy Sea Blue changed in 1947/48. The original color faded to quickly and was replaced with more resilient pigments. When the US Navy gave modelers the old stocks of ANA paint chips in the 1960s/70s, some of us got the 1944 card-stock chip of ANA 623, while others got the 1948 metal replacement chips. I can well remember the arguments back then, arguments that arose because we were working from different standards!" This confusion runs deep through the subject. Plenty of American modellers will tell you ANA606/607/623 = FS595 35042/25042/15042. they don't. 13 hours ago, PhantomBigStu said: interesting Vallejo’s fs36099 is the closest match, I’ve got the model colour version so will try it out, skeptical it’s blue enough for 623 edit: yep no where near blue enough the 1944 version of ANA 623 is not very blue. It was described by @Jamie @ Sovereign Hobbies of Colourcoats as a "deep smoky blue" or if you like, a purple blue dark grey. Note the wartime sea blues are NOT very blue. They are dark blue greys. 13 hours ago, PhantomBigStu said: , not that it’s a big deal Vallejo 898 is probably close enough for me, also think I’ve got something that might be close enough for the bluer of ANA606/607 for me. re ANA 606 and ANA 607 . "ANA 606 Semi-gloss Sea Blue (atop the wings and horizontal tail), and ANS 607 Non-Specular Sea Blue (atop the fuselage and on leading edges of the wings and stabs). The two colors differ in more than the gloss factor - non-spec is distinctly grayer and lighter than the semi-gloss. " I was lucky enough to obtain a copy of The Official Monogram US Navy & Marine Corps Aircraft Color Guide Vol 2 1940-1949 by John M Elliot Maj. USMC (Ret). which has actual chips of ANA 606, 607 and 1944 version of ANA 623. a common problem is that FS595 issue, that FS15042 is quoted for Gloss Sea Blue (which is correct for the post 1947 color) which is a dark grey with a deep blue green hue. FS 25042 (satin) and FS 35042 (matt) are then quoted as being matches for ANA 606 and ANA 607 respectively. while ANA 606,ANA 607 and ANA 623(1944) are similar colors, ANA 623(1947) is noticeably different to ANA 623 (1944) I have good colour vision, and you need to take the chips out into sunlight to really 'see' them clearly. And they are hard to match. re 14 hours ago, PhantomBigStu said: interesting Vallejo’s fs36099 is the closest match, I’ve got the model colour version so will try it out, skeptical it’s blue enough for 623 edit: yep no where near blue enough I don't trust Vallejo stated matches, and I That said, the FS 36099 chip is greyer to the eye (it just looks grey) compared to ANA 607 chip which is a blue grey. This is the problem with spectrometer readings, and the DE reading. I can see why the FS36099 is close to ANA607, but to the eye lacks the blueness that the Elliot chip has. The problem is unless you have the chips, it's really hard to know what these colors really looked like.. 1 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted February 26, 2023 Author Share Posted February 26, 2023 Ah missed that thread, though Ive ended up with your helldiver image saved as my reference images for ANA606 and 607, will post in there now Link to comment Share on other sites More sharing options...
Casey Posted February 26, 2023 Share Posted February 26, 2023 (edited) I have ANA samples (multiple copies) and FS decks (also multiple copies from different years). I can only confirm what @Troy Smith quoted here. Those blues are different colors, and they are more grey than blue. RGB will not show them well, they are way too dark. Luckily, a spectrophotometer can measure them and I can make matches that way. I'll post matches for ANA chips in another thread, this is supposed to be the UK colors thread Update: I started a new thread with this data: Edited February 26, 2023 by Casey 3 1 Link to comment Share on other sites More sharing options...
Casey Posted February 28, 2023 Share Posted February 28, 2023 I've measured 6 more Tamiya paints and found the following match: Target: RAF01 - Light Earth | GU 4.0, RGB: #A98C68 (L*=59.33, a=8.24, b=22.00) Found a match in: Tamiya (compared with 40 paints) DE00: 0.54 - #A88B67 - Tamiya - XF-59 | Desert Yellow | GU GU 20.7 (L*=58.75, a=8.26, b=21.77) It's a pretty good one! 2 1 Link to comment Share on other sites More sharing options...
Mr_Sworld Posted March 6, 2023 Share Posted March 6, 2023 @CaseyDo you have RLM matches on the database? Link to comment Share on other sites More sharing options...
Casey Posted March 6, 2023 Share Posted March 6, 2023 (edited) 1 hour ago, Mr_Sworld said: Do you have RLM matches on the database? Sure. I've placed Feb19 data here and a more comprehensive targeted answer with some specific Tamiya mixes I will update the FW190 reference thread with recent data, just in case there are more matches. Edited March 6, 2023 by Casey 1 Link to comment Share on other sites More sharing options...
