Ran Posted February 3 Share Posted February 3 With the P-51D done and on the shelf, and the He-280 back on the table I scanned the stash and decided a chopper is due. Picked out this one and will try to go for the White JDF Bird. This should be an easy build with a challenging paint job. Stay tuned. Ran 5 Link to comment Share on other sites More sharing options...
Jackman Posted February 3 Share Posted February 3 Will watch this with interest. JMSDF subjects are rare in modeling forums. 👍 Link to comment Share on other sites More sharing options...
heloman1 Posted February 3 Share Posted February 3 Oooh, I like. An interesting choice of subject and markings. I have the kit in the stash plus the 1/48th kit, which I have purchased a lot of AM parts for. Maybe later this year or early next. I'll follow your build with interest. Colin Link to comment Share on other sites More sharing options...
RupertTheBear Posted February 3 Share Posted February 3 That kicks off some memories. Did this kit (Italeri box) when I was 12 or so but I went for the Marines grey paintjob. Looking forward to yours and also respect for choosing a mostly white camo Link to comment Share on other sites More sharing options...
Ran Posted February 18 Author Share Posted February 18 This past two weeks I managed a lot of bench time - but could not bring myself to sit down and write. I'm now masking with MicroMask and have to take breaks between layers so I might as well update this build log. The fuselage is closed and I'm gluing the outer stuff. Two major takeaways from this build: 1. This chopper is BIG - in 1/72 its almost as long as the 1/48 H-280. 2. Old mold 1/72 kits just suck with poor engineering. This kit has parts that resemble short-runs Want a few examples? Checkout the sponsons - nothing by way of guiding or fixing: Or this strange engineering: The bottom part of the chopper and the floor of the cargo hold are also a strange piece of engineering. The cockpit is simple enough - and I fought the AMS urge quite well. Well, almost, just added a couple of boxes to the rear part. I failed to win against AMS when I noticed the magnitude of grills and exhaust ports. This is the first time for me - I took the DSPIAE electric grinder, armed with a drill, and went to town. The same took in high speed generates enough heat to make it a hot scalpel: The tail was more challenging: The rotor base was glued, but the glue drooled all te stopper piece - I had to cut it and work something else: Fixing inside the fuselage was almost notional, same with engine#3 exhaust, almost no location features: I had to glue the fuselage from the Front to the Back in several steps and then do the same for the bottom part: You can't see the time spent on filing, leveling, filing {repeat} - rrrghrr Cutting those miniature masking parts for the canopy lookednot funnot-fun' so I decided to mask with Micro Mask. Most of the features on the canopy were boldly marked. I hope it will go smoothly. I did put some transparent green on the top windows. That's it for now. Comments are welcomed. Best Ran 5 Link to comment Share on other sites More sharing options...
I Dole Posted February 20 Share Posted February 20 I'm doing the Italeri version at the moment. USN colours. Using the Eduard set, mostly for the grills, and the Reskit exhausts. Lots of opportunities to get the putty out. Link to comment Share on other sites More sharing options...
