Mosquito B.Mk.IV Löök (644188 for Tamiya) 1:48
1:48 Eduard
This set contains a combination of pre-printed resin and PE parts to detail up the cockpit of your Tamiya Mosquito quickly and efficiently.  It’s a classic kit that is still just as crisply moulded as it was when first released, but aftermarket technology has proceeded apace in the years since it arrived on our shores. As usual with Eduard's Photo-Etch (PE), Löök and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between.  The resin parts are protected by a crystal-clear plastic clamshell box with a sticky pad in the bottom to prevent the parts from rattling around within, while the PE is glued to the cardboard backing.
There is one resin part to replace the kit instrument panel in front of the pilot, and two more replacing the transmitter and receiver radio boxes in the rear of the cockpit, all with glossy faced dials, switches and knobs already painted for you on black resin.  Additionally, the PE sheet contains four-point belts for the pilot and navigator, and a pair of grab-handles for the R.1155 Radio Receiver.
Highly recommended.
Review sample courtesy of
