Momomato Posted January 30, 2023 Share Posted January 30, 2023 Does somebody know if Ammo by Mig acrylic paint sets are brushable or are they just for airbrushing ? 1 Link to comment Share on other sites More sharing options...
treker_ed Posted January 31, 2023 Share Posted January 31, 2023 Might be better asking this in the paints sub-forum. Not really a WWII aviation question. Link to comment Share on other sites More sharing options...
PhantomBigStu Posted January 31, 2023 Share Posted January 31, 2023 Unless they've changed the formula no, they are thin for airbrush use too thin to brush unless you let it dry on a pallet and time it right Link to comment Share on other sites More sharing options...
SprueMan Posted February 4, 2023 Share Posted February 4, 2023 In one word: no. I have tried to do this myself, as a surface, and as touch up, and they are both too thin, and not pigment-y enough to brush paint. Link to comment Share on other sites More sharing options...
daneel Posted February 4, 2023 Share Posted February 4, 2023 However, AK real color, if you can get your hands on them, are perfectly brushable. Link to comment Share on other sites More sharing options...
Stef N. Posted February 4, 2023 Share Posted February 4, 2023 Yes and no in my opinion. They're good for large areas, with a larger flat brush, but need numerous coats. For detail painting they are too thin, as others have said, and there are better alternatives out there. Link to comment Share on other sites More sharing options...
AndySG Posted February 16, 2023 Share Posted February 16, 2023 Yes they are and I have found them very good. I make 1/72 and 1/48 ww2 aircraft and have had some decent results. I like to use multiple thin coats and I have found that just dipping your brush in thinner before applying them works well. A primer layer helps and for this I use vallejo surface primer and I brush paint that on to. I do have an airbrush but personally I get a lot more satisfaction with normal brush painting :) 2 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted February 25, 2023 Share Posted February 25, 2023 That's good to hear, my local has an entire rack of them I noticed the other day though it took till now to register, shame as I'd have picked up a couple to tryout. Link to comment Share on other sites More sharing options...
PhantomBigStu Posted March 9, 2023 Share Posted March 9, 2023 Picked up a couple, both are thinner than I'm used too but very much brushable , what I am concerned by is one of them was sating black which looks a little browny on the paint mule....... Link to comment Share on other sites More sharing options...
Seahawk Posted March 9, 2023 Share Posted March 9, 2023 Mig Ammo acrylics are perfectly brushable, especially when used over a primer (I find MA’s own brand very thin and effective and use it under all acrylics). I have a different issue with them in that their “authentic” shades can’t trusted to be more than approximations to the real thing. However for colours like Track Colour, satin and matt Black, Rust and Gunmetal they are my acrylic of first choice. 1 Link to comment Share on other sites More sharing options...
alecras234 Posted December 15, 2023 Share Posted December 15, 2023 Hi i want to make painting models easier as i have trouble thinning paint, i use vallejo model colour paints. I was told in a different modelling group that i can use mig ammo acrylics for bush painting without having to thin them which would be great for me. im disabled and use a wheelchair and i have difficulty using my hands. Thanks. Ash Link to comment Share on other sites More sharing options...
Stef N. Posted December 16, 2023 Share Posted December 16, 2023 13 hours ago, alecras234 said: Hi i want to make painting models easier as i have trouble thinning paint, i use vallejo model colour paints. I was told in a different modelling group that i can use mig ammo acrylics for bush painting without having to thin them which would be great for me. im disabled and use a wheelchair and i have difficulty using my hands. Thanks. Ash As @Seahawk says they work fine but over a base/primer coat. They struggle a bit to purchase straight onto plastic. Link to comment Share on other sites More sharing options...
Seahawk Posted December 17, 2023 Share Posted December 17, 2023 On 12/16/2023 at 9:18 AM, Stef N. said: As @Seahawk says they work fine but over a base/primer coat. They struggle a bit to purchase straight onto plastic. The flip-side of quick-drying paints is that they try to skin over very quickly in the pallette so I do keep some water handy in a dropper bottle to thin them as required. i think you'd have the same issue with any modern model acylic paint. 1 Link to comment Share on other sites More sharing options...
Casey Posted December 17, 2023 Share Posted December 17, 2023 (edited) 1 hour ago, Seahawk said: The flip-side of quick-drying paints is that they try to skin over very quickly in the pallette so I do keep some water handy in a dropper bottle to thin them as required. i think you'd have the same issue with any modern model acylic paint. You can use wet palette, it helps a lot especially if you need more time (and place to mix your colors). Commercial ones are airtight to keep paints wet for hours or even between paint sessions, have anti-mold layer and cost around but cost 30$ like this one - https://www.thearmypainter.com/shop/us/tl5051p But you can simply make one on your own - It is basically a wet sponge with a kitchen parchment paper on top of it. One of my favorites is this one - Reynold's Kitchens Parchment Paper, but I guess any will do. One roll of it will last you for years. If you can't get a good thin flat sponge or foam, use wet paper towel, it'll work in a pinch. Paint retarders also help, just don't overdo them or they'll need comparable time to universe lifespan to dry (like some old humbrol enamels...) Edited December 17, 2023 by Casey Link to comment Share on other sites More sharing options...
