bismarck builder Posted January 29 Share Posted January 29 guys can some of you point me or show me how hairspray is used please gary r Link to comment Share on other sites More sharing options...
RAF4EVER Posted January 29 Share Posted January 29 Normally on the hair on your head,mainly female usage.👍😈 [I'll get my coat] 4 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted January 29 Share Posted January 29 Point nozzle at hair on head. Close eyes. Hold breath. Push button. I'll get my coat too. Regards, Jeff. 5 Link to comment Share on other sites More sharing options...
bismarck builder Posted January 29 Author Share Posted January 29 gentlemen your answers although gigglesome are not helping gary r Link to comment Share on other sites More sharing options...
RAF4EVER Posted January 29 Share Posted January 29 Perhaps you should be more specific.👍 Link to comment Share on other sites More sharing options...
bismarck builder Posted January 29 Author Share Posted January 29 RAF4EVER i would like to know how to use hairspray in ship model painting how to get the effects of a distressed hull and painwork gary r Link to comment Share on other sites More sharing options...
europapete Posted January 29 Share Posted January 29 Hi Gary, if you scoot over to the armour or aircraft sections they use that technique all the time. It's relatively uncommon on the ship models. ( I have no clue why). Ask again over on the "OTHER" side. You will probably get much more detailed answers. I have never used that method. 1 1 Link to comment Share on other sites More sharing options...
Pin Posted January 29 Share Posted January 29 https://letmegooglethat.com/?q=scale+model+hairspray+technique Although I prefer 1 Link to comment Share on other sites More sharing options...
beefy66 Posted January 29 Share Posted January 29 2 hours ago, bismarck builder said: RAF4EVER i would like to know how to use hairspray in ship model painting how to get the effects of a distressed hull and paintwork gary r Gary you might get more info in the amour section not many ship builders use the Hairspray technique but it goes something like this Spray the base colour red oxide for instance leave to fully dry and then spray a varnish coat to seal the paint. When dry spray the hairspray on let that dry for about10 to 15 minutes just use the cheap stuff or the missus will go Mad at you I have experience in this matter. Then spray your top coat on and again leave for 10 minutes Then using a stiff brush dipped in water you can start to scrub at the paint and make it look worn thus allowing the red to show through making it look like the top coat has been chipped off You will still have to then seal the finished surface Hope that helps a bit. Stay Safe beefy 3 Link to comment Share on other sites More sharing options...
europapete Posted January 29 Share Posted January 29 Well done Beefy👍 1 Link to comment Share on other sites More sharing options...
bismarck builder Posted January 29 Author Share Posted January 29 Beefy66 many thanks for the clear description and step by step walk through that's all i wanted to know and it was in English rather than jargon cheers gary r ps its too late for the hood but i think Ark or Bismarck is up next and they will defo benefit from hairspray 2 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted January 30 Share Posted January 30 14 hours ago, bismarck builder said: gentlemen your answers although gigglesome are not helping Gidday Gary, I don't weather my models so I couldn't give useful advice. As for my frivolous suggestions, well this was an opportunity too good to pass up. 🙂 I appreciate that this can become a bit wearisome after a while and I apologize if this was the case. 🙂 It seems that others here wore their sensible hats and were able to give you sound advice. Regards, Jeff. 1 Link to comment Share on other sites More sharing options...
Chewbacca Posted February 18 Share Posted February 18 On 29/01/2023 at 17:06, bismarck builder said: its too late for the hood but i think Ark or Bismarck is up next and they will defo benefit from hairspray I'm no expert on Bismarck, but bear in mind that she had a relatively short life and spent very little time at sea, I wouldn't have thought that she would have been looking too distressed (at least before she started taking damage from the British fleet but that's a whole new area of weathering that I won't go in to!). There are some types of ships that look spot on with the type of heavy weathering that the hairspray technique can produce (Flower class corvettes for example), but I would always counsel that less is more when it comes to weathering ship models. 3 Link to comment Share on other sites More sharing options...
