Mike Posted January 25 Share Posted January 25 Yak-9D Wheels (Q48405 for Zvezda) 1:48 CMK Quick & Easy Line by Special Hobby Kit wheels are generally moulded in two halves, which means you have the resultant joins to deal with, possible mould-slip issues on single part wheels, and sometimes less than stellar detail due to the moulding limitations of styrene injection technology, especially in the tread department. That's where replacement resin wheels come in, with their lack of seamline and superior detail making a compelling argument. They are also usually available at a reasonable price, and can be an easy introduction to aftermarket and resin handling, as they are usually a drop-in replacement. To be clear, the photo above shows both sides of the set. You get two main wheels and one tail-wheel. As usual with CMK's Quick & Easy resin sets, they arrive in the familiar clear bag, with the resin parts safely inside, and the instructions sandwiched between the header card at the rear. Inside are three resin wheels on a single casting block. Each one is attached to the casting block at the contact patch, which has a small flat-spot and bulge that indicates the weight of the airframe on the tyres. Detail is excellent on the hubs, and the main wheel tyres have radial tread on the contact surface, while the tail-wheel has a circumferential tread with radial lines on the sidewalls. Once they’re cut from the blocks, installation is as simple as sliding them onto the axles of the main wheels, and flexing the kit's tail-wheel yoke to admit the replacement resin part. Highly recommended. Review sample courtesy of Link to comment Share on other sites More sharing options...
