453rd BG Museum Build - USAAF Boulton Paul Defiant TT Mk I (from the Airfix 1/48 Mk I)
50 minutes ago, Fritag said:
Now I’ve gotta say that statement is impressive.
Back in the late 80’s when I was doing the Jaguar QWI course, I did a presentation on the EAP, the technology demonstrator for the Typhoon.  Makes me feel old… :rofl2:
Sounds possibly better than it should, but I was part of the aerodynamics team (albeit junior)........    Even more so with EAP.  I was involved with a significant amount of the early flight test monitoring from an aeroelastics and dynamic loading point of view.   Great times - well I thought so  🙂
Although it seems like "yesterday", I was somewhat chastened when I visited Cosford last year.  What was in the 1980's cutting edge stuff is now in the museum - at least now they've stopped the Loughborough students having sole pleasure of and access to EAP!  How did your presentation go...........no, no I shouldn't do "thread drift". :wicked:
cheers
Rob
  • Haha 2
Thread drift?. No such thing in one of my builds Rob.  You should see where some of the notorious types on BM have dragged em.  To be fair, probably when bored with the large down-time between progress with a build :whistle:
Well, all I can really remember is it was bl**min hard getting any information about it out of anyone.  Must have gone all right as I passed the QWI course :D
So.  Test print of the TT rear insert fuselage insert.
Not displeased.
I know the fairing at the front of the insert needs some more work in Fusion.  It’s a complicated transition from a squarish cross section at the front (basically the shape of the pilots cockpit canopy) to the rounded cross section at the rear (the shape of the TT operators canopy) with the added complexity of flaring out to a rounded triangular shape at the lower extremity to meet the fuselage.
y4mWoZBzyfHqaj_Bx8yj_xFHcMfAuWhsFq3WICgS
y4mxSjk_aGY8spUsFqNnCTLIeplVz87HCH4VF_Xy
y4mnOY7aANWkODRvB1lTK2_uuzR1onwq2TPKYp8Y
This is the sketching for the front fuselage fairing as it stands:
y4m4YBgFJBpJWFcGK5EvlGFu0aUzZpzmhUJWZwfD
I’ve caught the basic shape of the fairing at the front, but I need to iron out the creases at the side as the 1:1 is a constantly changing curved surface.  I did think of using the forms environment and sculpting it; but actually it’s getting there using standard lofts from two sketches with a series of guide rails.  I hopefully just need to play with the guide rails or add one or two more planes and sketch a few more guide rails and let the algorithm in the loft smooth it out….
There’s also a rather irritating c. 1 or 2 degree difference in the angle of the rear fuselage top line of the insert from the residual fuselage left on the kit.
y4mPenZkF7zW9xcZrXrPpCmtmPRMT3v2020XPYxB
Can’t decide at the mo’ whether to adjust the angle of the insert (it’ll mean amending several intersecting sketches), remove the remainder of the upper fuselage from the kit and print it all (an option I considered at the outset), or ignore it on the basis that it’s a small discrepancy that will probably disappear during the ‘non-virtual’ fitting and making good stages of the build.
Edited by Fritag
Typo
  • Like 24
6 hours ago, Fritag said:
it’ll mean amending several intersecting sketches... or ignore it on the basis that it’s a small discrepancy
I think I know the answer to this one
  • Haha 11
9 hours ago, PeteH1969 said:
PM Sent to you.
Noted, actioned, thanks Pete.
13 hours ago, giemme said:
Me too... :winkgrin:
Oh yeah.  Ok - amending the several intersecting sketches…..
36 minutes ago, Fritag said:
10 hours ago, PeteH1969 said:
PM Sent to you.
I wonder what Steve will do children?
I wonder what hendie would do too?
Exciting times.
I do know what SIHRSC would do on the basic kit, I remember what Alan Hall had me do with the old Airfix version with balsa wood and dope loaded with talc.
This is lots more fun.
  • Haha 4
Looks very good Steve. I would only increase the section height at the rear end (where 1.5cm line stands) by 0.5mm to fix this issue. But I am sure you will try the challenging way 🙂
Serkan
C'mon Bill, do we ever really expect Steve to be doing stuff with a SIHRSC? Beers all round on me if we ever see that day 🍺
T.
  • Haha 3
That’s what I’ve now done Serkan, but also extended the new resin deck back to near the base of the vertical fin so there’s no possibility of there being a visible change of angle half way along the fuselage.  There are knock on changes to some of the more forward cross section profiles but not particularly challenging :D
2 hours ago, The Spadgent said:
Yes I’d do what @Serkan Sen said. Obvs I don’t lift I just model, so in my case I’d pull the verts up at the rear a little to solve the issue.  It’s a darn good fit you have already. Lovely work chap.
I may still try modelling the front section in front of the operators canopy, rather than doing it with lofts.  It’s a pesky shape.
So Terry, if Bill lends me a SIHRSC and I make a few swipes with it just before Telford next year……
  • Haha 6
Interesting take on the definition of "doing stuff with" a SIHRC. Lack of clarity on my part obvs (I've lost many wagers that way), but would that really be classed as using said tool in earnest, and would cajoling Bill in this way make an admissible case?
I guess I should be careful with all this................... dealing with a lawyer can be fraught with wordy complexities 🙄 I never learn do I.
43 minutes ago, perdu said:
So we won't be seeing it this year then?
Nice try Bill!
Terry
  • Haha 4
Evening peeps.
So, the design was revisited.  The fuselage insert taken rearwards to just in front of the fin and the design (believe it or not) simplified with fewer cross sections and the shape maintained in the loft by the use of a few strategic guide rails.
y4m9xJS3edpMmu7swk7tvmistFzzSqn2ROJkVsQN
Lofts ok.  This is again just a test piece with simple solid lofts followed by use of the shell and extrude (cut) commands.
y4mDtnfcNll0V5qlJvqN8XJOY-LNMPhPdGWILmZR
Printed neatly enough with no thought to the best orientation beyond horizontal = quickest and with only short (2mm) supports and a 1mm raft.
y4mH86I_e3X36LmpoBu1NqKO2C7licofRfYnU4lg
And I'm pleased to report that it fits neatly enough too (nb. the bottom edge of the print is a little rough where I was somewhat hasty/careless trimming the supports away) :
y4mS2tdI76MbP5SwhfNenKpQqhnP8cEq9qVbvfJ9
The little bulges either side of the kit fuselage are where it flares out to meet the Mk I turret.  They'll sand off easily enough later on.
y4mUJg5yLyJx0lmUS-XTPNSbxbLAmuYolePpdesj
And with the pilot's canopy in the slid-back open position, the rather bizarre shape of the TT fuselage is seen.
y4mhJmIny3miLpFZDNohxyyRtEByhMdFcImvJGaE
On reflection I don't know why I originally planned to have the join halfway along the fuselage when to do so always risked any slight change in contour being more visible.
I think I still have a little more work to do on the contours of the fairing at the front of the insert:
y4mKXDbq_0xjwfhDuqu-FcJDkogrRloEoXOo3-8X
But it's close.  Just a bit more rounded, I think.
y4mbqGQTVM7_s9ce4ysk34DroddD4VqqbF8JJjbO
y4mE97Jnblpq1NvUAxcueboqlYczKT3frpwMAtmp
And tbh I could probably fix it with a few passes of a 1000 grit Tamiya sanding sponge.  But that would feel like cheating a bit :rofl2:
So, now need to sort out the contours of the very front of the Merlin XX nose and the rear fuselage fairing and I can move on.
Edited by Fritag
  • Like 24
Lovely work there Steve, and I agree it's looking close to the profile in that picture.
This sort of talk makes me nervous. Are you gently letting me down towards your eventual use of a SIHRC by any chance? 😰
T.
  • Haha 4
Nice lofting there Steve.
 Are you talking about the lateral to longitudinal fillet? Or the fillet between the curved spine and where it goes vertical with that hump thingy?  Variable fillets may be your friend there (either way)
Edited by hendie
Auto correct kept trying to ruin my day
That's looking superb - makes me want to dig out the Defiant kit I donated the turret parts from and cobble together the Defiant two seat trainer. This was first proposed in 1940 to cut the wastage of Hurricanes and Spitfires at the Operational Training Unit level, but it was dropped as being 'too complex' to undertake. They tried again in 1942, with the same outcome.
When the first TT Defiant was converted, they were concerns for the drogue operator as in the prototype it was deemed way too hot for them ( seating was close to the radiator ) and the possibility of the operator falling through the open floor!
Nicely done on the insert Steve. It looks (to me) from the pics that it should be pinched in more right behind the lower edge of the canopy. I don't see any flare out, just a smooth transition from open canopy to rear fuselage. Certainly below the bottom edge where the fuselage lines appear to run smoothly all the way back.
Ian
I think you're onto something there Ian, although the angle of the photograph is somewhat deceiving.  The fuselage has to transition between these two very different cross sections in only a little over 3mm (at 1/48).
y4mlqZkNu-tyxsaYhUYmz4_dzYzi0LaID4ZgAswB
y4mpIClL8yNLAuku-F7Y20uwc3QtIy35lcYe67Li
So there is no widening at all at the bottom corner, but quite a lot of widening required abeam the bottom of the canopy shaped front cross section, and then very little half way up the canopy before widening out again.
Both the MPM 1/72 kit:
y4mHNj27AWboMBVhZeQLrRbC2LwGtZx5Ww2OgdIk
And the CA 1/48 kit
y4mOHmtDYD4GSXofi_8HnmLoGY2f2PYoH2p58g-W
Solve the transition by having the fuselage at the bottom of the canopy shaped front cross flare out at almost at 90 degrees to the fuselage and then curve sharply backwards.  And and I was influenced in my approach by them.
But now I'm not so sure.
Really good photographs of the area are hard to come by.  the best I've found are these (cropped):
y4mScf0OLzpEdoWuM6vwTjRn5bQpScbQR13ibymB
y4my035MFvG06jmGlHR3pCgJQThtjLk9g8ZRFw-S
y4mjA8nk-ICeGEiXgKwQ5ia_MYClwXzmtzbJFQE6
y4meTjFk3laT10q-4dEhtoO8o08z8vC8Es3-rrkU
Which suggest that MPM and CA exaggerate the flare and curve somewhat and I probably have done too.
But it's a tricky transition to model and no mistake....
  • Like 15
Looks extremely tricky to me. FWIW I tend to agree with Ian re the "join". I'd describe the lower part of that transition as a convex curve outwards, rather than concave. I've not explained that well, but I know what I mean!
T.
I know what you mean too, Terry: although I think you mean concave rather than convex.  And I think you may have put your finger on summat.
Redrawn with a concave curve at the level of the bottom of the canopy transitioning through neutral to convex at the top plus a few fillets as suggested by Alan
A few photos in the design and render mopde sandwiching a similar angle photo of the 1:1 for comparison.
y4mNC5xP4uG9K_SZTWm8fDrKMDUDkZp3ktEB1PBO
y4myCq28tPcrs9SHeBLmEFSBIppvyO7PscRz4a2q
y4m4SwLicM0CnNoejUtWs0EWzTLIYV5mH9Kvb7Vs
y4m_zZ59YyaOKorOOn_ZU1d-VrGii62ZUs32xxgx
y4mAhq0slcB5qfWjQt21lHIdZDgi1OqPKmTZvj42
y4mIUF-feF8izFS-bi43S020of5YkoMkGrrWkXUC
I think that's rather more like it meself.
And if so it's a combination of Ian + Terry on the visuals + Alan on the technique...
  • Like 20
  • Fritag changed the title to 453rd BG Museum Build - USAAF Boulton Paul Defiant TT Mk I (from the Airfix 1/48 Mk I)
