Bullbasket Posted January 15, 2023 Share Posted January 15, 2023 I had no idea which was the correct place to put this, and ended up here. Anyway, my question is, can anyone tell me what percentage I need to reduce a 1/35th scale drawing down to 1/48th scale. TIA. John. Link to comment Share on other sites More sharing options...
BritJet Posted January 15, 2023 Share Posted January 15, 2023 The maths is 35/48x100 as the easiest way to get your head around it is to go back to full size (so x35) then divide by the scale you want (48) and multiply by 100 to get it as a percentage. As this works out to 72.9% I would copy/scan the drawing to 72% and 73% to account for the inaccuracies of the original copy as well as the copier/scanner you're using. You can then work out some measurements from full size to 1/48 to find out which new drawing is closest. Hope this helps. Steve 1 Link to comment Share on other sites More sharing options...
Phil1960 Posted January 15, 2023 Share Posted January 15, 2023 Hi John, look at this https://finescale.com/~/media/import/files/pdf/9/c/0/tips_for_scales.pdf HTH Ciao Filippo 1 Link to comment Share on other sites More sharing options...
Bullbasket Posted January 15, 2023 Author Share Posted January 15, 2023 4 hours ago, BritJet said: The maths is 35/48x100 as the easiest way to get your head around it is to go back to full size (so x35) then divide by the scale you want (48) and multiply by 100 to get it as a percentage. As this works out to 72.9% I would copy/scan the drawing to 72% and 73% to account for the inaccuracies of the original copy as well as the copier/scanner you're using. You can then work out some measurements from full size to 1/48 to find out which new drawing is closest. Hope this helps. Steve Steve, thank you very much for that. That's a great help. John. 1 Link to comment Share on other sites More sharing options...
Bullbasket Posted January 15, 2023 Author Share Posted January 15, 2023 4 hours ago, Phil1960 said: Hi John, look at this https://finescale.com/~/media/import/files/pdf/9/c/0/tips_for_scales.pdf HTH Ciao Filippo Many thanks for that Filippo. I shall print that off and keep it handy. John. Link to comment Share on other sites More sharing options...
