FrancisGL Posted January 9, 2023 Posted January 9, 2023 (edited) Hi Pals, Again taking up the hobby, this time I have opted for something a priori simple. It is about the JAGDTIGER Early from TAKOM, from their "Blitz" range, which seems to be somewhat simplified compared to other kits, but I see that it is a very complete kit (without interiors), with many small details and some beautiful moulds. It also includes a jig for the tracks, which I think will make my always tedious work easier... In principle, I hope it is OOB, perhaps add an antenna, and some handle that due to position/fragility is a candidate for breakage in the handling process... Soon I will be adding progress. Thanks for the interest. Cheers and TC Francis,👍 Edited February 13, 2023 by FrancisGL 9
Keeff Posted January 9, 2023 Posted January 9, 2023 Looking forward to following this build Francis ..... Keith 😁 1
Stef N. Posted January 9, 2023 Posted January 9, 2023 I have this kit loitering in the stash and I'll watch with interest. All the best in you build Francis.👍 1
Maddoxx77 Posted January 9, 2023 Posted January 9, 2023 I'll follow along. Got a Jagdtiger in the stash so this will serve as a great buildlog. 1
Hamden Posted January 10, 2023 Posted January 10, 2023 Looking forward to watching you work your magic on this one Stay safe Roger 1
FrancisGL Posted January 10, 2023 Author Posted January 10, 2023 20 hours ago, Keeff said: Looking forward to following this build Francis ..... Keith 😁 Hi Keith, Many thanks for your interest. Cheers and TC Francis.👍
FrancisGL Posted January 10, 2023 Author Posted January 10, 2023 20 hours ago, Stef N. said: I have this kit loitering in the stash and I'll watch with interest. All the best in you build Francis.👍 Hi Stef, Many thanks for your like, kind comments and interest, I hope you find it useful. Cheers and TC Francis.👍 1
FrancisGL Posted January 10, 2023 Author Posted January 10, 2023 18 hours ago, Maddoxx77 said: I'll follow along. Got a Jagdtiger in the stash so this will serve as a great buildlog. Hi Maddox, Many thanks for your, like, follow, and interest, I hope you find it useful, and find what you are looking for. Cheers and TC Francis.👍 1
FrancisGL Posted January 10, 2023 Author Posted January 10, 2023 9 hours ago, Hamden said: Looking forward to watching you work your magic on this one Stay safe Roger Hi Roger, Many thanks for your trust and interest, I hope it is worth the work and useful to you. Cheers and TC Francis.👍 1
FrancisGL Posted January 14, 2023 Author Posted January 14, 2023 UPDATE 01: Hi Pals, The first progress with the kit, and the part that I like the least, the running gear and the tracks. Having a jig to align and make the corresponding saggy has been helpful, along with the fact that the tracks are large, it is easier to manipulate and is appreciated, because when it comes to taking the links, there is no major problem , compared to those of a PzIV, it is already easy to see the difference... Once filed where they have been cut from the sprue, the fit is very good and the work is methodical but productive. It is necessary to be careful with the choice of links, as it is easy to confuse the correct side with the opposite, so it is advisable to pay close attention to the drawing of the link. I have decided to fix the tracks in their place, because I don't like to be constantly putting them on and taking them off, to see if they are adjusted or if something needs to be changed, because in the end, they end up unsticking somewhere... The size is a big help, and I know I can paint them properly, with some patience, skill, and the right brush for the job. As a positive, the parts that will inevitably not be seen (since they are glued), do not have to be cleaned/scraped afterwards to glue them, or mask in some way so that the grip is necessary later, or paint them, since not being seen is work lost.... The trick is to review well from all visible angles, and paint where necessary, if it is not seen from any angle, it is not possible to paint... Thanks for watching and comment. Cheers and TC Francis.👍 15
THEscaleSHOW Posted January 18, 2023 Posted January 18, 2023 On 14/01/2023 at 10:43, FrancisGL said: UPDATE 01: Hi Pals, The first progress with the kit, and the part that I like the least, the running gear and the tracks. Having a jig to align and make the corresponding saggy has been helpful, along with the fact that the tracks are large, it is easier to manipulate and is appreciated, because when it comes to taking the links, there is no major problem , compared to those of a PzIV, it is already easy to see the difference... Once filed where they have been cut from the sprue, the fit is very good and the work is methodical but productive. It is necessary to be careful with the choice of links, as it is easy to confuse the correct side with the opposite, so it is advisable to pay close attention to the drawing of the link. I have decided to fix the tracks in their place, because I don't like to be constantly putting them on and taking them off, to see if they are adjusted or if something needs to be changed, because in the end, they end up unsticking somewhere... The size is a big help, and I know I can paint them properly, with some patience, skill, and the right brush for the job. As a positive, the parts that will inevitably not be seen (since they are glued), do not have to be cleaned/scraped afterwards to glue them, or mask in some way so that the grip is necessary later, or paint them, since not being seen is work lost.... The trick is to review well from all visible angles, and paint where necessary, if it is not seen from any angle, it is not possible to paint... Thanks for watching and comment. Cheers and TC Francis.👍 Hello Francis Good start so far! Will follow the build and have already looked at some videos on YT. There should be fit problems with the front armor ?, so I will test this year the Tamiya kit of the early version. For this I have pre-ordered T-Rex tracks 😁 All the best! MD 1
Muchmirth Posted January 18, 2023 Posted January 18, 2023 Liking this already! Good luck and I will follow along. best regards, Paul 1
FrancisGL Posted January 18, 2023 Author Posted January 18, 2023 On 15/01/2023 at 10:12, Hamden said: . Nice work on those tracks Stay safe Roger Hi Roger, Many thanks for your like and interest, Cheers and TC Francis 👍
FrancisGL Posted January 18, 2023 Author Posted January 18, 2023 4 hours ago, THEscaleSHOW said: Hello Francis Good start so far! Will follow the build and have already looked at some videos on YT. There should be fit problems with the front armor ?, so I will test this year the Tamiya kit of the early version. For this I have pre-ordered T-Rex tracks 😁 All the best! MD Hi MD, Many thanks for your kind words and interest, It is possible that yes, because the fit of the pieces is very "tight"... with little margin of tolerance, even sometimes without glue, it is difficult to separate the pieces... Fortunately, being a tank destroyer, and not a tank, it does not have a turret, and the superstructure is a single large piece, so that by simplifying the work, angle adjustment problems are also reduced, which could not be well resolved. in TAKOM's mold (his M3 Lee, which I did just before this one, and I did have problems aligning all the angles, which are also asymmetrical.) The tracks have not been very difficult for me, I just clean the cut-off points, and put in their place (includes jig), other much smaller ones if they are a headache...also this kit had a super-affordable price when I bought it first hand, I seem to remember that I did it for around €28... Cheers and TC Francis.👍
FrancisGL Posted January 18, 2023 Author Posted January 18, 2023 3 hours ago, Muchmirth said: Liking this already! Good luck and I will follow along. best regards, Paul Hi Paul. Many thanks for your like, kind words and interest. Cheers and TC Francis.👍 2 hours ago, Maddoxx77 said: Great start @FrancisGL Hi Maddoxx, Many thanks for your like and kind comment, Cheers and TC Francis.👍 1
FrancisGL Posted January 21, 2023 Author Posted January 21, 2023 UPDATE 2: Hi Pals, Some progress with the kit. There have been no major problems with the assembly, if it is true that the adjustment of the rear plate when the superstructure is in place, makes it somewhat difficult to adjust, since it has very little margin, so you have to deal with some strength so that everything remains as it should. The good thing is that once in place, it looks great. The barrel has some movement, with an ingenious system, but in practice, it is not very useful, also, it has a strange alignment, so it will be fixed... I have been putting all the pieces that I think will not break during assembly and handling, even so some have already broken... at least I have recovered the broken part to glue it again later... I finished the PEs, which are not difficult (thank goodness), and the front machine gun, I changed it for a metal one, which I had spare parts... I have replaced some handles with wire, because I know that in the end they will end up broken or lost. As you can see in the photos, the kit has very good details, such as the butterfly clamps for the rear equipment, without the need for PEs... and the roughness of the "Pig's Snout", and the support of the exhausts, a "jack" quite detailed, the wooden block with its good wooden detail and the handle, a little rifled at the tip of the barrel (I don't think you can see it), the rear doors are functional, although very delicate, so it is not convenient to touch them often...in short, for a "simplified" kit (BLITZ), it offers a very good level of detail without having to spend on extras if you don't want it, with a very competitive price, for example compared to TAMIYA. I have not yet fixed the superstructure or the gun to the lower part of the hull, that way all subsequent processes will be easier. Until the next update, Thanks for watching and commenting.👍 14
Geo1966 Posted January 21, 2023 Posted January 21, 2023 A nice clean build. Keep up the good work Francis. George 1
FrancisGL Posted January 22, 2023 Author Posted January 22, 2023 On 21/01/2023 at 11:31, Geo1966 said: A nice clean build. Keep up the good work Francis. George Hi George, Many thanks for your like and interest Cheers and TC Francis.👍 On 21/01/2023 at 12:07, echen said: Looking really good. 👍 Hi echen, Many thanks for your like and kind comment, Cheers and TC Francis.👍 On 21/01/2023 at 13:26, bissyboat said: Coming together nicely. ⚓👍 Hi bissyboat, Many thanks for your like and kind comment, Cheers and TC Francis.👍
Hamden Posted January 22, 2023 Posted January 22, 2023 Great progress with attention to details, looking forward to seeing this one in paint now! Stay safe Roger 1
Bullbasket Posted January 23, 2023 Posted January 23, 2023 This is moving along at a steady pace. Nice work so far Francis. John. 1
edjbartos Posted January 23, 2023 Posted January 23, 2023 Very nice clean build Francis, its look s great. I'm looking forward to seeing some paint on this, It'll look fabulous... Ed 1
