Academy 1/350 Warspite
My current project. The "Grand old lady", as called by by Admiral Sir Andrew Cunningham . Academy's offering leaves a lot to be desired, so I've purchased Pontos set for her.
Hull was bland and detail less, so I've scribed some "panels". Yes I know they are weald seams and should be raised, but, its better then nothing. End I've never have been in "rivet counting category", so as far as I'm concerned... If it looks right  ( when looking from  meter away... ;) )
Anyway, with each ship, I'm trying something new...
First, base coat.
Then some toning,
Some preshading
Result..
Next step, upper hull
Wood deck
Salt corrosion,
First layer of light rust
More to follow..
  • Like 18
1 hour ago, bismarck builder said:
Zoran Srb
that looks impressive  weathering if those panel lines are just paint how have you managed the salt and rust marks
gary r
Panel lines are scribed. Salt is HU147 on light gray, and HU64 on dk gray and waterline, lightly dabbed.  HU83 on underwater sprayed. And light rust are AK acrylic pencils. Now in process is dk rust AK mahogany with 003 brush, when I finish, I'll post photo. Cheers.
Thought on the first take that you were painting  bricks on the keel, but I soon understood the madness to your method. Love the bold weathering. She´s a grand old rust bucket. Very nice. ⚓🙌
Before you RN fans jump in uproar, I'm guessing that she might be bit more rusted than in reality, but that's a way I liked my warships... Weathered, aged, hard working... And just maybe all those busy months in Mediterranean might have left its mark.... Next step all "green stuff" on the hull, then light wash.
Interesting, I actually like my warships perfectly pristine, with not a spot of rust or dirt and only mild shading, but that´s your model after all; your execution is certainly spectacular. Rusty and messed up, the Old Lady.
Edited by Micha_Pol
Great build,   here  is  the  Grand  ol  lady  in her  last days  -  stuck  on rocks  while  she  was  being  towed to the  scrappers  -  she  did not want to  go  obviously.
  • Sad 2
Great work, enjoying seeing it come together👍🏻
These images came up in another thread recently, I think they're rather sad...
After almost three months, hull is finally done. Now real fun begins….
P.S. What you see is work stand. I use it until time comes to install main deck railings (which is second to last step).
1. It gives me better grip, since it isn’t wide as hull
2.It keeps me from leaving greasy fingertips all over…
       Gidday Zoran, once the hull is done on my models I screw them to a block of wood, the screws coming up from underneath into the hull so they can be removed later. I make mine longer and wider than the hull so it protects it somewhat, plus I can place the wood into a vice to hold it at different angles if I wish, for gluing screws and masts etc. And for smaller rounded hulls such as destroyers it keeps them from rolling over. But I agree, it prevents me leaving fingerprints all over it. My model ships are much smaller than yours though, being 1/600 scale.
       Great work on those boats, particularly the open boats (cutters?).
Regards, Jeff.
As we are (mostly) all detail and accuracy fanatics, your perfectly pristine builds are accurate for only a limited time period like right at launch, fitting out or right at refit
when all new paint and fittings (whatever needed attention) were attended to but doing a Warspite at June 6, 1944 for example, with pristine paint and no weathering just
isn't historically accurate. 😉
Several things of note-- A weathered hull like what our OP has done can certainly be seen as accurate because in the middle of wartime or sailing 6 months in the stormy North Atlantic
without respite will trash the hull. As naval vessels are underway, any sailor not pushing a broom is put to work chipping away rust and repainting as necessary but they rarely paid attention
to the hull because it was too dangerous having men over the sides dangling from ropes and painting the hull. Everything on the superstructure though was given priority and I expect
HMS Warspite to be as tidy as possible at deck level and above. Pride of Her Majesty's Fleet and all, dignity has to be maintained, but there are limits to even that in wartime.
🤭🧐🙄 My nit to pick is a modeler's weather beaten, paint peeling rusty hull and superstructure but fresh, pristine, yellow teak on all horizontal surfaces (either a real wooden deck or painted)
and bright brassy brass/gold painted props. Propellers are bronze and quickly turn brown, greenish gray or black after oxidation and exposure to salt water. They are never as bright and
yellowish as pure brass however, but close to it when pristine. I've seen untouched red hulls below the waterline too when everything above the waterline is trashed. Funny stuff.
I like weathering though and the OP's hull looks good to me. Thanks for letting me vent. 😀
Small update... Thanks to increased workload, tempo of model making has subdued...
Anyway, funnel is done, and AA is readied for painting.... I cant recommend 3D printed stuff enough (these are from Black cat)! Imagine octuple pom-pom, ready for painting in 10 minutes!! These are made from TWO parts each....
  • Like 13
  • 4 weeks later...
Some progress report.. Most of set is installed, but there is one thing... IF any of you that  own Pontos set know, where parts (two of them) No 66 go, I'd appreciate info....
Anyway.... gun turrets...
Superstructure......
20230409-135312.jpg.
Masts.......
Cranes.......
Various bits and pieces....
Soon painting starts.......
Edited by Zoran Srb
