McG Posted January 5, 2023 Share Posted January 5, 2023 Any tips for how to separate the front and rear portions of a canopy that I glued together using Ammo Mig Ultra Glue (pva) for clear parts? Link to comment Share on other sites More sharing options...
Mark Harmsworth Posted January 5, 2023 Share Posted January 5, 2023 I don't know that glue but if it really is a pva then a sharp knife should do it. You could then scrape off the remaining pva with the back of the blade. Good luck Mark 1 Link to comment Share on other sites More sharing options...
Mike Posted January 5, 2023 Share Posted January 5, 2023 Put it in a freezer for a few hours if you can't separate it with a sharp blade. That technique uses on other glues, so it might work on a strong PVA. Otherwise, look up PVA solvent and see what you find 1 Link to comment Share on other sites More sharing options...
McG Posted January 5, 2023 Author Share Posted January 5, 2023 Thanks Gents, Found elsewhere a suggestion that Windex would work. Not having any to hand, I tried wiping some UMP Retail airbrush cleaner on a piece of kitchen roll along the join lines. This worked and debonded the glued surfaces. Regards, Mark Link to comment Share on other sites More sharing options...
