Bengalensis Posted February 19, 2023 Author Share Posted February 19, 2023 19 hours ago, klubman01 said: All that detail, just to be hidden from view. Fabulous! Trevor 19 hours ago, JeroenS said: What an amazing detail... That looks really good, crikey! 5 hours ago, Neddy said: Agreed with the above, that engine's a work of art in itself. It's almost a shame to hide it away inside the car! Amazing work. Thanks a lot gentlemen, glad you like! At least the engine cover will be removable. 2 hours ago, Vesa Jussila said: And some years later working with Warburg's. 🤣 1 hour ago, Neddy said: I must be careful to read the posts correctly, I thought for one ludicrous moment you said "Wartburgs". Ah yes, but I'm hopefully one of those who will luckily escape to the west in the messy weeks, so it could be BMW or Audi with a little luck 😎 2 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 19, 2023 Author Share Posted February 19, 2023 The compressor housing and the rotors are installed. Then the top cover with bolts and locking clamp, followed by oil lines, some locking wire and also the fuel pump. 10 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 19, 2023 Author Share Posted February 19, 2023 The air filter is assembled. I had to make a simple tool to press the four narrow photo etched mesh parts to the correct curvature. Then the large carburettor with throttle linkage is built up and the air filter fitted. At last the whole assembly could be mounted to the compressor and the fuel line connected. 15 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 20, 2023 Author Share Posted February 20, 2023 The next major parts to fit was to be the water pipes from the cylinder heads, but to make sure the completed installation would line up with the hole in the firewall I really need the engine sitting correctly in the frame. This has become more critical as I modified the pipe assembly from two to three separate parts. So the gearbox had to join the engine first. Then I cleaned up the relevant places of the frame and firewall mouldings. The engine assembly is a screw fit in the frame, so the screw holes were drilled open and tiny adjustments were made to the mounting points in the frame to let the engine drop in place as intended. Really very little adjustments were needed. Here we are with the engine assembly tightened to the frame and the firewall inserted to its locating points. Next I must rehearse the fitting procedure of the water pipes, before committing to glue. 14 Link to comment Share on other sites More sharing options...
Spiny Posted February 20, 2023 Share Posted February 20, 2023 It's almost a shame abut the modelling bench background as those first 3 pictures show just how realistic that engine is looking. 1 Link to comment Share on other sites More sharing options...
Neddy Posted February 21, 2023 Share Posted February 21, 2023 Agreed! It's almost a shame to cover up that clutch mechanism too. This build is amazing to watch. 1 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 22, 2023 Author Share Posted February 22, 2023 On 20/02/2023 at 21:57, Spiny said: It's almost a shame abut the modelling bench background as those first 3 pictures show just how realistic that engine is looking. On 21/02/2023 at 10:37, Neddy said: Agreed! It's almost a shame to cover up that clutch mechanism too. This build is amazing to watch. Thanks a lot gentlemen! The engine could perhaps deserve a display on it's own. 1 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 22, 2023 Author Share Posted February 22, 2023 The water pipes are finally glued. Some interesting use of tape and tooth picks to keep everything aligned and tied down while the epoxy cures. 10 Link to comment Share on other sites More sharing options...
Toftdale Posted February 24, 2023 Share Posted February 24, 2023 Beautiful work as ever. It astounds me, that the engineers who designed this car used such ingenuity and cutting edge ideas for the day with regards the engine and gearbox design and placement, would then use such a basic chassis - Andy 2 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 24, 2023 Author Share Posted February 24, 2023 29 minutes ago, Toftdale said: Beautiful work as ever. It astounds me, that the engineers who designed this car used such ingenuity and cutting edge ideas for the day with regards the engine and gearbox design and placement, would then use such a basic chassis - Andy Thanks a lot Andy! I tend to agree with you, but when I think of it this chassis and suspension might actually be regarded as relatively high development back in those days. The very similar type A appeared in 1934 when many racing cars where still built with live axles and mechanical brakes. 2 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 24, 2023 Author Share Posted February 24, 2023 With the epoxy fully cured the water pipes could be finished off with hose clamps and the air bleeder nipple. Next was the exhaust pipes. I felt it would be a good idea to do some basic dry fitting to ensure that they will line up with the bodywork later on. So the basic parts were cleaned up where needed and the underbody fitted to the frame. The tail section with the rear wall and the main body section seems to be OK with the carburettor and air filter. After some more checking I glued the exhaust sections. I used CA and only carefully applied in the holes for the mounting pegs. The plan is that this will still leave a little flex for some last small bending adjustments when final assembly comes. The body panels were then taped back in place. There will be a lot of fine adjusting of the parts needed later, but there is good hope it will work out. The engine and gearbox assembly is done. It’s time to start seriously on the next steps. 16 Link to comment Share on other sites More sharing options...
klubman01 Posted February 24, 2023 Share Posted February 24, 2023 The engine and gearbox are a complete model in themselves. Fabulous work, well done. Looking forward to seeing this build progress. Trevor 1 Link to comment Share on other sites More sharing options...
Vesa Jussila Posted February 25, 2023 Share Posted February 25, 2023 Impressive. And it's possible all engineering that was done in real car. 1 Link to comment Share on other sites More sharing options...
Mpfiend Posted February 25, 2023 Share Posted February 25, 2023 Jörgen, that is a stunning piece of work so far. I have really enjoyed seeing it come together. Do the MFH parts require a lot of cleaning up before they can be used? Regards Keith 1 Link to comment Share on other sites More sharing options...
Bengalensis Posted February 25, 2023 Author Share Posted February 25, 2023 16 hours ago, klubman01 said: The engine and gearbox are a complete model in themselves. Fabulous work, well done. Looking forward to seeing this build progress. Trevor Thanks a lot Trevor! Indeed they could release the engine as a separate kit really. 2 hours ago, Vesa Jussila said: Impressive. And it's possible all engineering that was done in real car. Thank you very much Vesa! It does give a pretty good feeling for the real thing working on this I think. 1 hour ago, Mpfiend said: Jörgen, that is a stunning piece of work so far. I have really enjoyed seeing it come together. Do the MFH parts require a lot of cleaning up before they can be used? Regards Keith Many thanks Keith! For a white metal & resin kit the parts are pretty clean and nice, definitely in the very top range for this type of kit. That said all parts do need work with removing fine mould lines, minor adjustments, drilling out all holes, test fitting etc. Not very much filling so far though. It does take time and work. So I'd say that compared to other resin/metal/pe kits they are very nice. 1 1 Link to comment Share on other sites More sharing options...
Mpfiend Posted February 26, 2023 Share Posted February 26, 2023 22 hours ago, Bengalensis said: Many thanks Keith! For a white metal & resin kit the parts are pretty clean and nice, definitely in the very top range for this type of kit. That said all parts do need work with removing fine mould lines, minor adjustments, drilling out all holes, test fitting etc. Not very much filling so far though. It does take time and work. So I'd say that compared to other resin/metal/pe kits they are very nice. Thank you for the reply Jörgen, there is a couple of MFH kits I am interested in adding to my collection, your comments will make an easier decision. Best Regards Keith 1 Link to comment Share on other sites More sharing options...
Brandy Posted February 27, 2023 Share Posted February 27, 2023 The engine is a work of art in itself, I hope you're going to leave the covers off! Ian 1 Link to comment Share on other sites More sharing options...
Bengalensis Posted March 26, 2023 Author Share Posted March 26, 2023 There has been frustratingly little progress – read none – over the last few weeks as life and work intervenes, again… There isn’t much to show today either, but I sat down and planned ahead a little. With the engine and gearbox done the next major step is the frame with suspension, fuel tank and cockpit floor with details. First the frame. I have already prepared the fit of the engine, but I didn’t look forward to cleaning up the rest of the part as it’s a rather large piece with a lot of details across the mould separation lines, but here it’s done after an hour or two. Now there are a number of holes to be drilled out and much test fitting and adjustments to be done to make sure all parts to be attached later on will fit well. 11 Link to comment Share on other sites More sharing options...
Spiny Posted March 26, 2023 Share Posted March 26, 2023 Always frustrating when you get to a fiddly bit like that, but I can almost guarantee that when it comes to fitting bits to the frame you won't regret it at all. It's doing the prep work like this which helps your models to end up looking so good. 1 Link to comment Share on other sites More sharing options...
Bengalensis Posted March 28, 2023 Author Share Posted March 28, 2023 On 26/03/2023 at 21:54, Spiny said: Always frustrating when you get to a fiddly bit like that, but I can almost guarantee that when it comes to fitting bits to the frame you won't regret it at all. It's doing the prep work like this which helps your models to end up looking so good. Thanks for the kind words. You are absolutely right, preparation and test fitting is the foundation for later (hopefully) rewards. Most vital with a resin/metal kit, but always very worthwhile. Link to comment Share on other sites More sharing options...
Bengalensis Posted March 28, 2023 Author Share Posted March 28, 2023 Not much to show, but slowly the first white metal parts for this step of the build are prepared. Here we have parts for the torsion bar rear suspension. Floor parts, pedals, master brake cylinders and gear lever parts. The parts glued to the frame will need a little bit of filling and sanding in some spots of the joints. 11 Link to comment Share on other sites More sharing options...
Bengalensis Posted April 2, 2023 Author Share Posted April 2, 2023 To fully enjoy these kits it is necessary to somewhere appreciate the work of cleaning up all the cast parts, drilling holes, test fitting and tweaking. Most of the front suspension and steering parts finished. The friction damper discs where assembled before painting. As each friction disc is already moulded together with a steel disc there would have been some fiddly detail painting anyway. Uprights, brakes and more rear suspension parts after initial preparation. A few bits of photo etch involved as well. The rubber boots for the rear axle tubes are nicely moulded in a tool avoiding all visible mould lines More parts assembled prior to painting, here done to avoid visible joint lines where there should be none. Test fitting brake cylinders and shoes. Each finned brake drum is made up from five white metal discs. It may seem overly complicated, but just like the compressor housing earlier, I think it will prove to b a clever move in the end. No dreaded mould line mismatching across them to deal with. 9 Link to comment Share on other sites More sharing options...
Bengalensis Posted April 2, 2023 Author Share Posted April 2, 2023 Cleaned up, sorted, test fitted and ready for glue. The inside of the drums has pegs that are meant to fit against the brake backing plates. I don’t see much point in that as it won’t take up any real load, just force all drums to be fitted at exactly the same angle when it comes to the detail patterns, for what it’s worth… I decided to remove that feature to create a smooth inner surface, that won’t be seen… It will make the glue joints between the discs weaker, but I take that chance. Four finished brake drums, more to my liking. Test fitting with the wheel hubs, just to be sure. 13 Link to comment Share on other sites More sharing options...
JeroenS Posted April 3, 2023 Share Posted April 3, 2023 It's a serious parts count. Looking very beautiful though. 1 Link to comment Share on other sites More sharing options...
Neddy Posted April 3, 2023 Share Posted April 3, 2023 Wow. Just......wow. That's a unique way of producing finned brake drums avoiding moulding lines and mismatches! Great result though. 1 Link to comment Share on other sites More sharing options...
