Panther Ausf.G Late (84552) 1:35
Mike
1:35 Hobby Boss via Creative Models Ltd
The Panther was Germany's answer to the surprise appearance of the Russian T-34 after they finally reacted to the invasion that was Operation Barbarossa.  Although the project had been in gestation some time before, they took some design cues from the T-34 in the shape of the sloped armour, resulting in the Panther that was intended to fill the gap between the Panzer.IV and the (then) new Panzer VI Tiger.  It was eventually supposed to replace both the Pz.IV and the earlier Pz.III that was really showing its age, but in reality it often fought alongside the Panzer IV.  It was planned as a lighter, more manoeuvrable tank than the Tiger, and was fitted with a high velocity gun from the outset, which gave it enormous penetrating power that was only equalled later by the 17-pounder the British fitted to the American Sherman to make it into the more lethal Firefly.  The sloped frontal armour gave it an increased effective armour thickness, but this was not so true of the side armour, which was comparatively weak, and this area became the preferred target of engaging allied tanks, especially in urban combat where this was a telling issue.
Like most German WWII tanks it was filled with advanced engineering and therefore complex to produce, so suffered in terms of volume output, and this led to it being rushed into service with a long tick-list of issues still to resolve.  Later production solved most of these initial gremlins, but loses in the interim were high with many being abandoned after breakdown during combat. Confusingly, the Ausf.D was the first to enter production, with the Ausf.A following later in 1943, replacing attrition of the less reliable Ausf.Ds until they themselves were superseded by the Ausf.G, which became the final major variant with increased ammo storage, simplified design to ease production, and further improvements to reliability, although this was never fully cured with a high rate of attrition persisting due to mechanical issues, some of which resulted in catastrophic fires.
The Kit
This is a reboxing with different parts of a range of Panther kits from Hobby Boss that began unexpectedly with a Flakpanther Ausf.D and grew from there, increasing the range of parts available as the series expanded.  This boxing arrives in a standard Hobby Boss top-opening box, and inside are twenty sprues plus four separate hull and turret parts in sand-coloured styrene, five sprues of brown track links, a clear sprue, two sheets of Photo-Etch (PE), a length of braided copper cable, the decal sheet, instruction booklet and A3 colour painting and decaling sheet folded inside it.  Detail is good, as we’ve come to expect from HB Panther kits, and the individual links give you the opportunity for some well-detailed tracks with realistic sag if you put them together sensibly.  The addition of a partial interior is also good to see at this price-point.
Construction begins with the lower hull, which is detailed with suspension parts and a pair of final drive bell-housings at the front, plus the small roller that prevents track throwing.  A long zig-zagging plate is inserted flat against the floor inside, then the internal ladder structure is built-up from two full-length ribs and a set of six cross-braces, plus a few detail parts.  The torsion bar suspension units are slipped through the holes in the ribs from both sides, and capped off with twin sockets before the whole assembly is clipped into the lower hull on several slots in the floor.  A couple of detail parts and panels are laid into the floor, and the whole area is painted in red-brown primer, as this kit has a well-detailed partial interior.  With the hull inverted, the many swing-arms and axles are fitted into the holes in the side of the hull, and once dry they are dressed with interleaved road wheels, some in pairs, others in singles, taking care to put them on the axles in order so that they sit properly.  The idler wheels and drive sprockets finish off the running gear, then it’s time for the tracks.
Each track link is held on the sprue by five sprue gates, and has a pair of guide horns glued to the inner face on a pair of shallow slots, then are joined together with liquid glue in runs of 88 links.  The track runs can be created in one-sitting each and wrapped around the wheels while the glue is still soft, taping and wedging them into position to give the correct sag when the glue finishes curing.  Detail on each link is excellent, and although there are a total of seven sprue gates to deal with per link, there are no ejector-pins or sink marks to be seen, so if you use a good pair of single-edge nippers and sand them carefully while settled in front of your favourite TV show, the time should fly by.
The rear bulkhead of the Panther is detailed with armoured exhaust protectors, plus a pair of tubular exhaust stacks with rearward pointing exits at the top, made from two halves each.  These are inserted into the armour, then the two different stowage boxes plus a well-detailed jack are added, along with the small Notek convoy light on a bracket under one of the exhausts.  A couple of towing eyes are inserted into the raised circular access hatch in the centre of the bulkhead with a pin slotted between them, then the bulkhead is glued into the rear of the hull, adding a pair of towing shackles to the torch-cut sidewall ends.
This kit doesn’t include the full interior, and it is blank aft of where the engine firewall would be, but you do get a handsomely appointed transmission, clutch and drive-shafts, which are assembled and dropped into the front of the hull, connected by a pair of hoses that disappear into the underpinnings.  A control linkage is assembled with levers and end-caps, and attached to the top of the transmission, then a power take-off shaft and turret rotation mechanism are inserted behind the transmission, locating on a rectangular plate in the centre of the hull.
The upper hull is next, laminating an inner panel to the sloped glacis plate, adding a clear periscope for the driver, and making a few holes in the deck for later use.  The bow-mounted machine gun is a complex assembly that is built-up over several steps, with scrap diagrams showing how it should look before and after it is inserted into the ball-mount and the top cap is added above the sight that allows the gunner’s head to assist with moving the weapon.  The ball is inserted into the kugelblende from behind, and is locked in place with an insert.  On the exterior the forward crew hatch insert is prepared with the hatches on the outside and hinges on the inside, then it is dropped into the hole in the front deck, adding armoured protectors over the periscopes, the domed exterior armour to the kugelblende, headlight on its mount on the port fender, and a combination of PE and styrene brackets on the sloped hull sides.  At the rear is the raised heater with PE “pizza slices” to adjust the amount of heat that escapes and this has a PE grille over the top, fitting on the port side of the engine deck, with a cast circular vent on the opposite side, and the engine access hatch between them.  The various grilles and louvres are covered over by a set of PE grilles to keep grenades and dirt out, with a choice of open or closed louvres placed over them.  Pioneer tools, spare track links and schürzen rails are fixed on the hull sides, the latter held in place by folded PE brackets.  A travel-lock is made up and applied to the deck between the two front hatches, a few lifting eyes are added to the engine deck, plus handles on the hatches, brackets and other small parts on the sides to hold some of the pioneer tools in situ.  The upper and lower hulls are then mated so that the pair of towing cable with styrene eyes and 115mm of braided cable between them can be laid over the deck, mounting on brackets at the rear and looped through the towing shackles at the front.  The PE schürzen panels each have rectangular washers applied to stiffen the mounting holes before they are hung from the paired brackets on the sides of the hull, bending the ends of the brackets toward the rear to hold the sheets in position.  These plates did get beaten up and knocked off despite this however, so there’s plenty of opportunity to customise the installation, starting with them hung at an 8° angle from vertical.
The turret is similarly well appointed, with a full depiction of the basket, starting with the two-part floor and the boxed support at the rear, which has a seat hanging off the right and the rotation mechanism at the front, another seat with foot controls, the front supports and a lip around the pedals to prevent jamming caused by objects becoming lodged under them.  A can is glued to the floor on the right, then the turret floor is mated with the basket and the rotation controls are fixed around the edge of the ring.  A shallow lip is added around the sides, then the mantlet is made up, including the sighting gear, coaxial machine gun and the internal mantlet structure, with the hole for the barrel shroud.  The assembly is locked between the inner panel and curved outer mantlet, then has the breech and protective framework fitted behind.  The turret rear has a circular hatch in it, with a choice of posing it open or closed, scrap diagrams showing how it should fit in each position.  The commander’s cupola has seven clear periscopes inserted from below, with styrene surrounds keeping them in place, then closing the assembly with the lower half and adding adjustment wheel and armoured covers on the top, which have the machine gun ring welded to the top.  At the front is a PE blade sight that is folded up from a diamond-shaped part.
The turret roof and sides are moulded as one part, to which the rear is glued, and a clear periscope and vent are applied to the inside.  The mantlet with breech assembly are fixed to the front, and the floor with basket close the area, finishing off by adding the commander’s cupola and the external mantlet, taking care that the coax machine gun muzzle goes through the hole in the mantlet.  The main gun is moulded as a single part, and thanks to sliding moulds, the detail on the muzzle brake is good, locking into the mantlet on a keyed base.  A pair of pegs insert in holes on the sides of the mantlet, a mushroom vent is applied to the roof, and the shell ejection port is installed near the back of the roof.  A PE cover is folded up and inserted between the mantlet and turret roof, with scrap diagrams showing the correct profile of the part once properly folded from above and the side.  The roof periscope gets an armoured cover, and a grab-handle is glued over the rear hatch, with three lifting eyes added front and rear.  As this is a late edition, it is fitted with infrared vision gear, mounted on a complex platform in front of the cupola, then installing an infrared searchlight and sight side-by-side on it, then adding an MG34 to the platform, gluing a yoke to support the end of the barrel at the front.  Finally, the commander’s lift-up-and-rotate hatch is made up and inserted into the hole in the side of the cupola, and the model is completed by dropping the turret into the ring on the hull.
Markings
There are an unusually generous six decal options on the sheet, but only the first option has views of the camouflage from all sides.  The rest have front and left profiles, so you may need to do some research to complete them accurately.  As usual though, there is no detail on when, with whom or where the subjects served, but from the box you can build one of the following:
The decal sheet is filled with vehicle numbers and the occasional cross, plus a few dials for the interior, and is printed with good register, sharpness, and colour density.
Conclusion
This is a well-detailed late Panther, and includes plenty of extras, including a partial interior.  Although it lacks niceties such as seats for the drivers and machine gunners or an engine compartment, it does have a full turret, so some hatches can be left open without fear of blank styrene being visible.  The inclusion of late-war night sights is a welcome addition, and will appeal to many, as will the price.
Highly recommended.
Review sample courtesy of
