Dinky Posted February 24 Share Posted February 24 (edited) 46 minutes ago, Schummie said: The manual is updated again, and now in 4 parts. https://support.pocher.com/hc/en-gb/articles/7410676612636-HK114-Lotus-72D-1972-British-GP-Emerson-Fittipaldi Thanks Schummie Edited February 24 by Dinky 2 2 Link to comment Share on other sites More sharing options...
Griph Posted February 24 Share Posted February 24 7 minutes ago, Dinky said: https://support.pocher.com/hc/en-gb/articles/7410676612636-HK114-Lotus-72D-1972-British-GP-Emerson-Fittipaldi Thanks Schummie That is excellent because now we can zoom in and see the details rather than a load of pixels! Hi resolution PDF’s 1 Link to comment Share on other sites More sharing options...
Griph Posted February 24 Share Posted February 24 I should also say thanks for the links! Link to comment Share on other sites More sharing options...
Griph Posted February 24 Share Posted February 24 2 hours ago, Schummie said: The manual is updated again, and now in 4 parts. Thank you! Link to comment Share on other sites More sharing options...
Dinky Posted February 25 Share Posted February 25 I thought the tires would be very difficult because they are so hard. But after 2-3 minutes in boiled water, they slide right over the rim. I only did my rear tires now, both had a nice and a less nice edge where they meet the rim. I put the nice side on the outside, it's worth checking before putting them on the rim because when the tires cool down you cannot get them off anymore. Direct links to the new instructions they are so much better as the previous ones. https://support.pocher.com/hc/en-gb/article_attachments/7843419269660/HK114_-_Lotus_72_Instruction_manual_-_Revised_-_P1.pdf https://support.pocher.com/hc/en-gb/article_attachments/7843435882012/HK114_-_Lotus_72_Instruction_manual_-_Revised_-_P2.pdf https://support.pocher.com/hc/en-gb/article_attachments/7843436213404/HK114_-_Lotus_72_Instruction_manual_-_Revised_-_P3.pdf https://support.pocher.com/hc/en-gb/article_attachments/7843419916700/HK114_-_Lotus_72_Instruction_manual_-_Revised_-_P4.pdf 1 1 Link to comment Share on other sites More sharing options...
Griph Posted February 25 Share Posted February 25 19 minutes ago, Dinky said: I thought the tires would be very difficult because they are so hard. But after 2-3 minutes in boiled water, they slide right over the rim. I only did my rear tires now, both had a nice and a less nice edge where they meet the rim. I put the nice side on the outside, it's worth checking before putting them on the rim because when the tires cool down you cannot get them off anymore. Yes - have done all four using very hot water immersion. Very easy to fit this way! The tyres seemed to be good appearance from either side, so didn’t think. The wear indicators on the tyres I put in a single direction to match when fitted. No idea if this was right or not. I have started sanding the wear surfaces of the tyres to a Matt finish. Looks good (I did this with the Porsche 917KH build also - although they were treaded and not slicks). Made the tyres look less plasticky! I was wondering about the Firestone brand on the tyres being black, as the 917 has white? Anyone got a view on this? 1 Link to comment Share on other sites More sharing options...
Malc2 Posted February 25 Share Posted February 25 2 hours ago, Griph said: I was wondering about the Firestone brand on the tyres being black, as the 917 has white? Anyone got a view on this? From race pics it looks as if at Brands Hatch the cars raced with the raised 'Firestone' lettering unpainted. You are right, at pretty much every other race in 1972 the raised letters were filled in with white paint. Apart from the French GP where Emmo started on Goodyears! 1 Link to comment Share on other sites More sharing options...
brady Posted February 25 Share Posted February 25 1 hour ago, Malc2 said: From race pics it looks as if at Brands Hatch the cars raced with the raised 'Firestone' lettering unpainted. There's an article somewhere that mentioned this, maybe the one in Motorsport magazine. 1 Link to comment Share on other sites More sharing options...
Schummie Posted February 25 Share Posted February 25 Some pictures from my effords to use as much as possible unpainted metal. It's not every ones's taste, but it makes also clear the fantastic details in this kit and the superb casting. Some hidden under the paint. Just to show that this is aso a possibility. 6 1 Link to comment Share on other sites More sharing options...
JohnPlayerSpecial Posted February 25 Share Posted February 25 I have not started mine yet, it's still in the box, I have too many other projects on the workbench at the moment. When I do get start on it, I am planning to replace visible kit screws for allen key bolts, can anyone tell me what size allen key bolts I would need to get? Thanks. Link to comment Share on other sites More sharing options...
cmatthewbacon Posted February 25 Author Share Posted February 25 3 minutes ago, JohnPlayerSpecial said: I have not started mine yet, it's still in the box, I have too many other projects on the workbench at the moment. When I do get start on it, I am planning to replace visible kit screws for allen key bolts, can anyone tell me what size allen key bolts I would need to get? Thanks. Check out the manual or the first link in the PDF. There are 12 different types of screws, the majority of which are 1.5mm in different lengths, thread types and head types. 1.5mm fine thread (for metal) in 3mm, 4mm, 5mm and 7mm lengths will cover off a pretty high proportion of the total number of screws. But many are hidden, most look like black dots until you look closely, and allen key heads are not necessary any more accurate… you need micro hex bolts for that, and an equally tiny socket set… best, M. 1 Link to comment Share on other sites More sharing options...
JohnPlayerSpecial Posted February 25 Share Posted February 25 15 minutes ago, cmatthewbacon said: Check out the manual or the first link in the PDF. There are 12 different types of screws, the majority of which are 1.5mm in different lengths, thread types and head types. 1.5mm fine thread (for metal) in 3mm, 4mm, 5mm and 7mm lengths will cover off a pretty high proportion of the total number of screws. But many are hidden, most look like black dots until you look closely, and allen key heads are not necessary any more accurate… you need micro hex bolts for that, and an equally tiny socket set… best, M. Thanks for your help. I can't seem to find any 1.5mm allen bolts, can only find 1.4 and 1.6mm. Link to comment Share on other sites More sharing options...
cmatthewbacon Posted February 26 Author Share Posted February 26 9 hours ago, JohnPlayerSpecial said: Thanks for your help. I can't seem to find any 1.5mm allen bolts, can only find 1.4 and 1.6mm. That was my problem when I was looking for taps as well. Either 1.5mm is an unusual size, or Pocher is measuring differently from everyone else. I gave up on the tap idea and just used the screws themselves, with a touch of silicone grease as lubricant. I screw every one fully into the receiving hole before assembly with a forward and back off motion, then take it out completely and fit the other part. Others with better miniature engineering knowledge than me may be along to tell us what we’re missing… best, M. 1 Link to comment Share on other sites More sharing options...
Dinky Posted February 26 Share Posted February 26 (edited) 19 hours ago, Griph said: The wear indicators on the tyres I put in a single direction to match when fitted. No idea if this was right or not. I have started sanding the wear surfaces of the tyres to a Matt finish. Not even sure if you can choose the way the wear indicators point to. I also sanded my tires, to have the matt look but also to remove the molding seam in the middle. I found a picture of a built Lotus with the letters on the tires in white in case anyone is interested. Nice work Schummie, love the way your brake discs look. Edited February 26 by Dinky Link to comment Share on other sites More sharing options...
Griph Posted February 26 Share Posted February 26 1 hour ago, Dinky said: Not even sure if you can choose the way the wear indicators point to. I also sanded my tires, to have the matt look but also to remove the molding seam in the middle. I found a picture of a built Lotus with the letters on the tires in white in case anyone is interested. Nice work Schummie, love the way your brake discs look. Yes meant to say about the seams! Please do include the photo of the whitened Firestone branding! I was wondering what is the best way of doing that? Progressive build up of dry brushing? Link to comment Share on other sites More sharing options...
Griph Posted February 26 Share Posted February 26 16 hours ago, Schummie said: Some pictures from my effords to use as much as possible unpainted metal. It's not every ones's taste, but it makes also clear the fantastic details in this kit and the superb casting. Some hidden under the paint. Just to show that this is aso a possibility. Don’t think I’d have the courage to do what you have one! But the results look amazing. What do do do after removal of the paint? Link to comment Share on other sites More sharing options...
Dinky Posted February 26 Share Posted February 26 The below link contains pictures of the Lotus with white letters on the tires. Not sure if it's allowed to post links to shops, if not please let me know and I remove will remove it. https://shop.classicteamlotus.co.uk/pocher-hk114-lotus-72d---1972-british-gp-winner---emerson-fittipaldi-2191-p.asp Link to comment Share on other sites More sharing options...
Griph Posted February 26 Share Posted February 26 15 minutes ago, Dinky said: The below link contains pictures of the Lotus with white letters on the tires. Not sure if it's allowed to post links to shops, if not please let me know and I remove will remove it. https://shop.classicteamlotus.co.uk/pocher-hk114-lotus-72d---1972-british-gp-winner---emerson-fittipaldi-2191-p.asp Thanks for sharing that! Very interesting - they also have the nose code, fairing and anvil removed. I’d definitely want to be able to remove the nose to show the underlying detail on occasion! Link to comment Share on other sites More sharing options...
cmatthewbacon Posted February 26 Author Share Posted February 26 Pretty clear that if you want to model it AT the 1972 British GP, the tyre lettering should not be white. Obviously, the “8” numbering is also for the British GP, and the chassis in its current state carries a different number. I agree the white lettering adds interest to the completed model, though… best, M. Link to comment Share on other sites More sharing options...
Schummie Posted February 26 Share Posted February 26 2 hours ago, Griph said: Don’t think I’d have the courage to do what you have one! But the results look amazing. What do do do after removal of the paint? The darker sections with gun metal acid. Longer periods, or more times to get darker colours. The blank metal parts by polishing with more ore less fine sanding paper. 4000 for aluminium, 8000 for silver and 12000 for chrome. This way you get the real metal look and structure. But it is indeed a lot of work. Maybe Hornby could think about offering a non painted version of the kit. With only the body parts painted. Link to comment Share on other sites More sharing options...
JohnPlayerSpecial Posted February 26 Share Posted February 26 8 hours ago, cmatthewbacon said: That was my problem when I was looking for taps as well. Either 1.5mm is an unusual size, or Pocher is measuring differently from everyone else. I gave up on the tap idea and just used the screws themselves, with a touch of silicone grease as lubricant. I screw every one fully into the receiving hole before assembly with a forward and back off motion, then take it out completely and fit the other part. Others with better miniature engineering knowledge than me may be along to tell us what we’re missing… best, M. O! Well may have to just use kit screws, but thanks for your help. 1 Link to comment Share on other sites More sharing options...
silver911 Posted February 27 Share Posted February 27 This might help.....https://www.amazon.co.uk/Metric-Model-Making-Watchmaker-mm-2-5/dp/B01M4P13FE Used this set for all my builds 😎 Ron Link to comment Share on other sites More sharing options...
cmatthewbacon Posted February 27 Author Share Posted February 27 25 minutes ago, silver911 said: This might help.....https://www.amazon.co.uk/Metric-Model-Making-Watchmaker-mm-2-5/dp/B01M4P13FE Used this set for all my builds 😎 Ron @silver911 Did you use the 1.4mm or 1.6mm tap for the Pocher screws? best, M. Link to comment Share on other sites More sharing options...
silver911 Posted February 27 Share Posted February 27 In the main I used the 1.4mm...however...I rarely used the kit screws for any of my builds (unless they were totally hidden)...preferring to replace them with correct scale and type bolts/nuts etc. Hope this helps. Ron Link to comment Share on other sites More sharing options...
brady Posted February 27 Share Posted February 27 There's also this set (US $11!) with ten single taps, https://www.amazon.com/dp/B08Z3TVFSZ?psc=1&ref=ppx_yo2ov_dt_b_product_details but not sure about UK availability. Link to comment Share on other sites More sharing options...
