Mancunian airman Posted December 27, 2022 Share Posted December 27, 2022 Goxhill is quite close to me and I am considering getting a P38 Lightning aircraft but I'm not 100% that the model I want is a J type. Lockheeds chief test pilot in April 1944 was Tony Le Vier and he visited the station to demonstrate the handing characteristic of the P38 (morale was real low with the pilots under training). Its his aircraft I want to model. ' Snafuperman' Was it a J type ? Serial unknown, colour scheme not known . . . quite a bit of research required but this is just the start . . . I have seen two kits, Monogram and Academy both in 1/48th scale so they are available Any pointers would be appreciated guys Ian Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted December 27, 2022 Share Posted December 27, 2022 (edited) 11 minutes ago, Mancunian airman said: Goxhill is quite close to me and I am considering getting a P38 Lightning aircraft but I'm not 100% that the model I want is a J type. Lockheeds chief test pilot in April 1944 was Tony Le Vier and he visited the station to demonstrate the handing characteristic of the P38 (morale was real low with the pilots under training). Its his aircraft I want to model. ' Snafuperman' Was it a J type ? Serial unknown, colour scheme not known . . . quite a bit of research required but this is just the start . . . I have seen two kits, Monogram and Academy both in 1/48th scale so they are available Any pointers would be appreciated guys Ian P-38 J-10 look at the data plate behind Tony in the photo. https://i.imgur.com/z6OZzFi.jpg I prefer Monogram and Hasegawa in 1/48 I cant afford the Tamiya though if you can I recommend it. I just finished an academy P-38J in 1/48 and in the end wasn't happy with the kit. https://www.britmodeller.com/forums/index.php?/topic/235114684-philip-goldstein-and-the-story-of-his-p-38j/ Edited December 27, 2022 by Corsairfoxfouruncle 1 Link to comment Share on other sites More sharing options...
gingerbob Posted December 28, 2022 Share Posted December 28, 2022 Monogram's is a MUCH older kit, and while I have a soft spot for it, it is not up to "modern expectations". Tamiya is the gold standard (mine is on its way) for sophistication of kit design. Hasegawa's is good, but challenging to get everything lined up correctly. Academy's strikes me as a bit less "polished" than Hasegawa's, but possibly slightly easier to build. There is also the Hobby Boss "easy", which I haven't seen with my own eyes, but it seems surprisingly good for what it is. Link to comment Share on other sites More sharing options...
