Kingsman Posted December 7, 2022 Share Posted December 7, 2022 This image came up on Facebook. You don't often see the tops of lorries. Someone has taken the instruction to make the stars as large as possible very literally! I wonder how common this actually was? Supposedly ships setting out for D Day here. 4 1 Link to comment Share on other sites More sharing options...
colin Posted December 7, 2022 Share Posted December 7, 2022 I'd want them as large as possible, you don't want to be shot up by your own side considering they had air superiority during the invasion and onwards 🙂 1 Link to comment Share on other sites More sharing options...
Hoppy Posted December 7, 2022 Share Posted December 7, 2022 I don't believe it's that common. From what I've read there were quite strict instructions on painting the canvas of soft skins, as the paint could degrade the fabric and effect it's waterproof properties. Photo's of column's of lorries in the Normandy campaign taken from the air, do not show similar markings and until the big breakout from the Normandy area camouflage from the air was taken very seriously. I would hesitate a guess that someone has misinterpreted the instructions to paint the markings in the usual position on the cab roof's. Wouldn't be the first time 😁. I'm sure more knowledgeable members will be along soon. Bob Link to comment Share on other sites More sharing options...
Kingsman Posted December 7, 2022 Author Share Posted December 7, 2022 The nearest one on the left has a cab roof star as usual. Unfortunately you can't see if the others have cab roof stars as well as those on the tilt. Perhaps the large tilt stars were intended to be temporary. It rapidly became clear that the Luftwaffe was not a threat. It is said that German soldiers coined the saying that "if you see a dark plane it is British, if you see a shiny plane it is American, if you see no plane it is the Luftwaffe". 4 Link to comment Share on other sites More sharing options...
Pete Robin Posted December 7, 2022 Share Posted December 7, 2022 My Dad served in Normandy, Sexton SPGs, and they had all the stars etc in the usual positions. At some point after the battle for Caen, they were puled out of the line for R&R. They were then given the clear instruction to repaint all the stars as big as possible, especially on horizontal surfaces. They did this as well as they could and were promptly bombed by a formation of 6 B26s (I believe) before the paint had dried. After much swearing and screaming down radio channels, the new large stars were painted out and they returned to the smaller ones with instructions to henceforth fire upon any aircraft in the vicinity. Regards Pete Link to comment Share on other sites More sharing options...
StuartH Posted December 7, 2022 Share Posted December 7, 2022 The stars on these roof tarps are pointed with a point facing the front of the vehicle. Normally the stars on cab roofs and bonnets are pointed with a point facing the rear of the vehicle? Link to comment Share on other sites More sharing options...
Graham Boak Posted December 7, 2022 Share Posted December 7, 2022 No. The rules called for the point to face forward. Only the Canadians obeyed this to the extent of the ones on the cab sides - everyone else pointed them upward. 1 Link to comment Share on other sites More sharing options...
Mike Starmer Posted December 24, 2022 Share Posted December 24, 2022 The order specified that the star on upturned surfaces should be as large as possible on a permanent surface, i.e. cab, bonnet or roof. However on vehicles with COE and canvas tilt then it by default had to be on the canvas tilt. On carriers or similar vehicles then it should on a dark coloured disc and displayed so that it is visible from above. This was mandatory and retained when later in the campaign it became less common or not marked on side surfaces, mostly on AFVs. The usual depiction had the point forward on top and point upward on vertical surfaces, the same as set out in US instructions. But the Canadian order and diagram I have shows the side surface star point forward. 2 Link to comment Share on other sites More sharing options...
