GiampieroSilvestri Posted December 6, 2022 Share Posted December 6, 2022 Does the Kinetic 1/48 scale Mirage 2000D Taiwan airforce kit also include the parts for a French aircraft? Thank you very much Saluti Giampiero Link to comment Share on other sites More sharing options...
scotthldr Posted December 6, 2022 Share Posted December 6, 2022 If you’re referring to the Taiwan boxing for a D-5i, then basically yes it can. Only parts you’ll be short of will be the targeting pod and air to ground weapons and of course the decals. I could sort you out with the pod and weapons. Is there a reason that you can’t just use the proper D boxing? Link to comment Share on other sites More sharing options...
exdraken Posted December 7, 2022 Share Posted December 7, 2022 It is the same plastic in all kits as far as I know. ( Apart from the obvious single vs two seat parts.) You need to be careful anyways if you want a correct sircraft! Special care needs to be taken with tanks, weapons fins and nose choices.... The instructions arenot necessarily clear or correct 😞 Link to comment Share on other sites More sharing options...
scotthldr Posted December 7, 2022 Share Posted December 7, 2022 I’ll echo the above. I’ve just finished building the-5F boxing and instructions are very vague, so get yourself some good reference material as some antennas, scoops and vents will need to be added. 1 Link to comment Share on other sites More sharing options...
hopkp Posted December 9, 2022 Share Posted December 9, 2022 The best 'one stop shop' reference on the differences between Mirage 2000 variants that I've ever come across is a two-sided A4 sheet that comes with the Syhart decal sheets for the type. In my view it's worth getting one of the sheets for that alone even if you were never to use the decals. Link to comment Share on other sites More sharing options...
drake122 Posted December 9, 2022 Share Posted December 9, 2022 7 minutes ago, hopkp said: The best 'one stop shop' reference on the differences between Mirage 2000 variants that I've ever come across is a two-sided A4 sheet that comes with the Syhart decal sheets for the type. In my view it's worth getting one of the sheets for that alone even if you were never to use the decals. I have this sheet with the variant differences listed, but for some versions (ex. Peruvian Mirage 2000P) it is inaccurate, missing special aerials, etc. Link to comment Share on other sites More sharing options...
