Hey everyone :)
I have been getting a lot of requests for updates on when we will release a set for the new Airfix Spitfire IX
Well, the test shot PE arrived today so I did a test fit I thought I would share...
The decals are in production, so sadly I don't have those to show yet, but now I know the PE is all good i can place the production order for them. I am being told the PE will be late December / early January but will see if I can get them to run a very small batch before Christmas
it's a sad fact Airfix wouldn't supply anyone with test sprues so we are all scrabbling round trying to design & produce from the kits we received when you did
..anyways on with the preview..
..here is the fret..
first up the seat gets some improved mounting brackets..
..the seat bulkhead has an improved finish and is detailed for those not using Armour Plate..
..and with Armour Plate and the correct seatbelt roller (tube not included..)
..rudder pedal treads..
..corrected and upgraded undercarriage selector..
..compass frame and missing fuel select lever..
..and what it really needs - a new IP and Blind Flying panel..
..how things look in place..
..there are a number of other bits & bobs too..
will update again when I have decals - I need to pull all this apart to install them
It's a fabulous kit and has been a pleasure to put something together to help if folks feel it needs it :)
Pre order available here
TTFN
Peter
Edited by airscale
  • Like 19
Looks good to me. I like all those rivets and the lightening holes are well done too. The Instrument panel looks great. All well up to your normal standards.
Of course an expert will pop up soon to prove me wrong, but hey, what do I know about Spitfires?
Oh that look awwwffy nice. And there I was saying I will stick with my Tamiya 1/32 kit and you go and do that ……….
See what you did @airscale
I won’t sleep well tonight now
Still my wife is wondering what to get me for Christmas and while I promised not to buy more models getting presents doesn’t break that does it, not really
Excellent! Didn't waste any time before pre-ordering these! Thank you.
Hi all,
Quick update on progress...
..the decals have arrived so did a test for the instructions to be developed...
no kit decals are illustrated, but some are still used - happy with how the set is shaping up
..the only problem is the etch folks at PPD are breaking for Xmas and my production order will be mid January for a limited number and end of January for the rest, so I do encourage pre-orders if you have the kit and are waiting on the set.
I will turn off pre-orders if we hit the total in the first batch and none will go to retailers until the full production order has been met
..this is all a frustrating by-product of not getting access to the kit prior to release
anyways, thats it for now
Peter
OK Peter you've sold me - One 1/24 Spit on order and a pre-order just made with you.  It all looks very nice but I keep asking "Do I really need the new Spitfire?"  Well not now thanks to Mrs T and Santa Claus  :D
  • 4 weeks later...
18 hours ago, airscale said:
Thank you all :)
Pleased to say the set is out today and all pre-orders have been shipped :)
TTFN
Peter
I received mine this morning and the set looks absolutely fantastic.
Thanks so much,
Alistair
Thanks so much,
Alistair
Me too - and what Ali says !
Ordered it today, and I will get the Sutton harness when it’s back in stock. The harness is unquestionably the best I’ve ever seen!
Thanks Peter
Jeff
Mine also received, looks superb, and love the presentation as 'pilot's notes', very good 😊👍
Received and very impressed! I'm there must be other areas in the cockpit that could use your attention...do you do the Harness in 1/24?
Edited by Whitewolf
  • 2 years later...
Very impressed by this upgrade and about to start work with it. Any recommendations on how to go about widening the slots in the fuselage as per the instructions?
Where the bulkhead fits the fuselage, is defined by a slight groove on the fuselage forward of the two stringers that are moulded on, and all the stringers in the cockpit tub have a break to fit the bulkhead, as well as a shallow groove. Because the photo etch for the bulkhead goes right to the edge, you need to widen that place where it fits. I just cut the stringers a bit and slightly beveled them and then i ran a spear shaped file inside the shallow groove to widen them a bit. Also, I beveled the backside of the bulkhead as well, seeing as how it's not really visible. It worked for me. I should have explained "stringers", the raised ridges that run fore and aft.
HTH
Jeff
Edited by MrB17
Explanation
