modelling minion Posted February 7, 2023 Share Posted February 7, 2023 Brilliant Alistair, a simple solution to the problem which has worked out extremely well. You have to be happy with that mate. 🇺🇦 1 Link to comment Share on other sites More sharing options...
vppelt68 Posted February 7, 2023 Share Posted February 7, 2023 , I'd go with that - on the other hand, who'd spot the difference? 1 Link to comment Share on other sites More sharing options...
stevesoutar Posted February 8, 2023 Share Posted February 8, 2023 13 hours ago, Mottlemaster said: Thanks Craig It was a toss up between trying to do the spots free hand or with a mask . In the end i decided that the size ,sharpness of the border and spacing would make spraying free hand far ,far above my skill level . I started by applying an overall top coat of RLM 66 and when totally dry i applied the masks . The spot making kit . The two matchstick sizes allowed for the creation of different size spots . I found the square profile of the match stick end gave a much cleaner spot than a round applicator as maybe it was easier for the surface tension of the Copydex to break from the corners of a square . I started at the tail so i could match the spot size and dencity from the diagram supplied by Aims . It took around two days for the copydex to fully dry after which i applied the Rlm 76 . The 76 was left to fully dry so that when the edge of the spots are cleaned off with a trimmed down stiff brush i would get no smudging I hope to get some black on today but am away on holiday next week so thisone will be a non finisher . Neat solution - and it has worked out well. fabulous effect!! 1 Link to comment Share on other sites More sharing options...
