Richard502 Posted November 16, 2022 Share Posted November 16, 2022 Compared to the kit barrels, the Master barrels are 3mm longer if fitted to the kit's barrels with sleeves (part K4), and more than 5mm short if fittet to the kit barrels w/o sleeve (part K8), presuming I am to cut off the barrel at the forward end of the sleeve or at the trunnion respectively. The Master instructions are not helpful to this modeler of moderate intelligence. Link to comment Share on other sites More sharing options...
Faraway Posted November 16, 2022 Share Posted November 16, 2022 27 minutes ago, Richard502 said: Compared to the kit barrels, the Master barrels are 3mm longer if fitted to the kit's barrels with sleeves (part K4), and more than 5mm short if fittet to the kit barrels w/o sleeve (part K8), presuming I am to cut off the barrel at the forward end of the sleeve or at the trunnion respectively. The Master instructions are not helpful to this modeler of moderate intelligence. I had something similar, but I can’t remember which ship it was. I cut the plastic barrel in the wrong place, making the metal barrel too long. Link to comment Share on other sites More sharing options...
Rich75 Posted November 16, 2022 Share Posted November 16, 2022 Could you post a picture of the parts together? Also maybe compare to picture of a 3d printed one for ref, I have seen these with/without blast bags? Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted November 18, 2022 Share Posted November 18, 2022 On 11/16/2022 at 8:29 AM, Richard502 said: Compared to the kit barrels, the Master barrels are 3mm longer if fitted to the kit's barrels with sleeves (part K4), and more than 5mm short if fittet to the kit barrels w/o sleeve (part K8), presuming I am to cut off the barrel at the forward end of the sleeve or at the trunnion respectively. The Master instructions are not helpful to this modeler of moderate intelligence. Hi Richard, I'm not a moderator here but I notice this isn't the first question you've posted here in WIP. The place to post questions is Maritime Discussion by Era, selecting your particular time period of course. Work in Progress is just for full build logs of models. You'll get lots more advice if you post in the right place, mate. 1 Link to comment Share on other sites More sharing options...
