Dealing with stiff non sticky decals?
BikingLampy
I'm part way into an Airfix 1/72 Phantom FG.1 and I'm struggling with the decals (of which, being a 'toom, there are bazillions...)
Currently trying to do the weaponry, but the decals, despite LOTS of Microsol/set are just sitting there like planks and refusing to soften and conform. Quite a problem doing the stripes on a Sidewinder that's about 1.5mm dia. and the decals need to wrap around.
Normally you apply the 'sol and after a minute or so the decal wrinkles up a bit and you can smooth it down with a cotton bud. These are just ignoring it. Even when I can get them to conform a bit they're not adhering to the surface, poke one bit to try and make it nestle down and the rest just slithers off again.
Ideas? Is there a more superduper decal softener out there?
Thanks!
BL
Several! DACO Red is difficult to obtain outside of your hemisphere, so I've never used it, but it has a reputation for Ark of the Covenenant-like melting powers on decals: https://www.dacoproducts.com/Ksetting.php
Here in the USA, I use Solvaset, which can do to frail, thin decals what Regency-era rakes did to naïve maidens, but which is pretty much certain to melt a decal right to a model.
8 minutes ago, BikingLampy said:
Ideas?
Are you using cold water?   Have you tried hot water?  I mean quite hot.  It has been discussed on here regarding Japanese decals which are thick, due to the heat activated glue.    I have used a saucer of hot water kept hot on coffee machine hotplate.
Alternately press with a hot flannel/cotton bud.
Bed in Kleer , which aids adhesion. Can be combined with hot water.
https://www.britmodeller.com/forums/index.php?/topic/235038987-bedding-decals-in-klear-future-or-equivalent/
As with anything new, try on a scrap decal first.
HTH
Thanks guys.
Anyone got an (in stock) source for Daco Strong? Either my google-fu is utter rubbish, or its currently not available in the UK.
How does "Ultimate Decal Setting Solution (Extra strong)" compare?
I've got a bottle of Pledge/Klear, so I might give that a whirl, although TBH, I've never found it much use for anything.
Depends what you want/expect.  It's great for these non floor applications
1.Great gloss coat when applied soft wide flat brush. It's meant for floor so very tough.
2. canopy dipping, as a self levelling liquid, it will fill an small imperfections and makes a canopy seem clearer and shinier as a result.
3. as a decal bedding agent, ideally over a Klear gloss coat, it acts as an adhesive and surface leveller,  thus dealing with silvering.
They work for me, but as my sig says..... it's what works for you.
I had quite good results with Humbrol DecalFix. They recommend actually *soaking* the decal in it.
There is good tutorial here:
Be careful it may react with gloss layer if you have any.
But as always - test with some spare decal there if you have any left.
Edited by Casey
