Austrian Champions...1/20 Lotus 72C (1970), Jochen Rindt
Reini78
13 hours ago, Reini78 said:
as with other race car model kits, no full cigarette ads included
therefore bought aftermarket decals a while ago
52501642852_c756f32fb0_b.jpgDSC_0003 by grimreaper110, auf Flickr
Nice,  Very interested now - as I couldn't find anything like that.
On 11/17/2022 at 6:33 AM, Redstaff said:
Pretty sure Indycals do the sponsor decals for the gold leaf as well
Think that's where I got mine from
Yes Indecals are my go-to and I'd assumed they'd have something for Rindt's 72C, but thought it's always good to get alternatives to consider.
Edited by Flying Badger
the kit is made out of a special plastic which doens´t like every glue and every paint
Tamyia thin cement works fine
concerning the paints, ended with AK Real Color Signal Red and Tamiya white
the white decals are a bit translucent, so gonna paint white underneath the numbers
masking and painting the nose gonna be fun...
52529537803_fab5d6ca4c_b.jpgDSC_0003 by grimreaper110, auf Flickr
52529537653_f85954276c_b.jpgDSC_0004 by grimreaper110, auf Flickr
52528990261_dc71d88641_b.jpgDSC_0005 by grimreaper110, auf Flickr
52529537328_0c11e4f457_b.jpgDSC_0006 by grimreaper110, auf Flickr
Good progress so far Reini on this challenging kit. I built two of these when they were first released ten years ago (when they were only $40 USD!!!). On the first build,  I totally botched the alignment/ squareness of the rear engine/ suspension/ rear tires assembly to the chassis because I pre-bonded most of the rear suspension/ transmission/ axle/ exhaust and upright support components to the engine before bonding the engine to the rear of the body assembly. The rear tires came out at weird angles relative to the chassis longitudinal axis and one of the rear tires did not touch the ground. I tried to fix my disaster using heat and bending and ended up with an expensive pile of parts/paint/ decals.
On my second 72C kit attempt, I pre-assembled the rear suspension and transmission assembly without bonding it to the engine block. The instructions would have you bond the engine + transmission + rear suspension together before joining it to the body. I didn’t take any photos of my second 72C WIP but here’s a similar view of the Ebbro Lotus 49B rear suspension / transmission assembly I pre-built:
I then cut two long plastic rods and press-fit them into the the rear upright wheel bearing housings to eyeball check alignment/ straightness BEFORE doing the final transmission to engine block bond:
I’ve built all my other Ebbro F1 kits (and a few Tamiya/ Hasegawa/ Fujimi) this same way with pretty good success.
Hopefully you won’t run into these issues but I wanted to pass on my own experience in case you wanted to consider this alternative assembly method. Whichever way you go, take your time and test fit liberally. It’s a great kit of one of F1’s all-time best  looking cars IMO.
Edited by nearsightedjohn
Spelling
after several attempts on masking and painting the nose, my dad now puts a fork in it
wasn´t that easy to get the curve..
52539878765_c50b39d4de_b.jpgDSC_0005 by grimreaper110, auf Flickr
52539394146_80196a7e69_b.jpgDSC_0006 by grimreaper110, auf Flickr
used Gunze H9 Gold
52538934522_a8b4810390_b.jpgDSC_0010 by grimreaper110, auf Flickr
front suspension done
some red plastis still shines through, but my dad will display everything closed, so it doesn´t matter
52539394041_78811a52e9_b.jpgDSC_0007 by grimreaper110, auf Flickr
52539693064_f783d76dd8_b.jpgDSC_0008 by grimreaper110, auf Flickr
some more cockpit progress
52539947813_b3d543b25f_b.jpgDSC_0009 by grimreaper110, auf Flickr
transmission work
52548259986_e84bbf926d_b.jpgDSC_0003 by grimreaper110, auf Flickr
52548806958_f30a579f90_b.jpgDSC_0004 by grimreaper110, auf Flickr
using yellowish painted clear elastic threads for tubing
52547799597_f2173b47b3_b.jpgDSC_0005 by grimreaper110, auf Flickr
the chrome coloured plastic of the rims was too shiny and bright, so sprayed them with a primer and painted them Gunze Mr. Color Chrome
52548806798_b7ee82dea4_b.jpgDSC_0006 by grimreaper110, auf Flickr
and already started with the decals
52548259611_ec317c5444_b.jpgDSC_0007 by grimreaper110, auf Flickr
52548734315_12de44c37e_b.jpgDSC_0008 by grimreaper110, auf Flickr
52548556644_a9f103f834_b.jpgDSC_0009 by grimreaper110, auf Flickr
52548806468_0228bde6f8_b.jpgDSC_0010 by grimreaper110, auf Flickr
transmission-engine block finished
52560710661_a04685885d_b.jpgDSC_0001 by grimreaper110, auf Flickr
52561253998_05cfbe4163_b.jpgDSC_0002 by grimreaper110, auf Flickr
52561253903_cd173a736a_b.jpgDSC_0003 by grimreaper110, auf Flickr
the radiator housings/intakes didn´t fit that good to the main body
sanded down the radiators but still no tight fit, had to fill a gap and repaint some red
52561004979_52624811e1_b.jpgDSC_0006 by grimreaper110, auf Flickr
