1/12 Jet Bike & Punk Girl Android Rider
Well its time for a new project!
This is one I've had in mind for a while, I'm an ex biker and love motorbikes so have always wanted to do a sci fi build based around a motorbike model.
The motorbike kit I'm playing about with is a 1/12 Tamiya ducati 888 and I want it to look pretty sleek so I'm going to go with a very glossy race bike finish.
Plan is to keep it looking pretty much how it does, obviously its going to have no front wheel/forks and no swingarm on the back, I dont want to muck about with the fairing much to make it easier to get it all smooth and nice for high gloss finish. So where the swingarm was there will be an engine sticking out and at the back on the parts where the exhausts attach I'll put some small fins on.
For the rider she is going to be mostly sculpted, but I'm going for an android so it will be along the lines of her face will be a panel on her head with a lot of metal at the back. Want to use plenty of tubing and spring tubes so she'll be leaning a bit more towards the robot side of things, and she'll be a punk so bright pink mohawk and an attitude!
The pose I'm going for is to help aid the jet bike bike look by not giving it any support, it will be held up by her leg to give the impression of hovering. I was going to have her sitting on it with one leg down, but thats no fun, so instead she will be in the middle of a hard 180 turn with one foot on the ground as it skids round. To help with the sense of motion there will be a puddle on the floor with a small bow wave coming from her foot to look as though she has slid through it.
Also as she looks back as the bike turns she will also have one arm up firing a gun behind her because I basically want it to seem as though she is being chased but has turned the tables on the people chasing.
Its all a bit hard to explain but it will all become clear as I go (hopefully!)
so without further a do the first think I'm tackling is the jet bike so I pulled out the kit and started cutting out the fairing, frame and engine bits to get them together and tidy
52436395356_de702824c6_c.jpgIMG_20221006_132327390 by Nick Frost, on Flickr
52436395301_d0f9f61352_c.jpgIMG_20221006_132432654 by Nick Frost, on Flickr
52435890992_3ee6048cb0_c.jpgIMG_20221006_135200870 by Nick Frost, on Flickr
Your really not going to see much of the engine at all, especially as the open end where I'll be putting engines of some description, so I got it all together to paint in one piece for speed, oh and only mod to the frame so far is I've cut off the two small exhaust brackets from the end as they're not needed, exhausts are being left off too.
52436395131_01d442f86a_c.jpgIMG_20221007_141617964 by Nick Frost, on Flickr
So got those bits primed
52436912413_68b891aed4_c.jpgIMG_20221007_142327200 by Nick Frost, on Flickr
Sprayed the engine with alclad airframe aluminium as a base coat and used some tamiya acrylic white on the frame bits.
52436912233_077696b938_c.jpgIMG_20221008_161100012 by Nick Frost, on Flickr
52436394906_2dff0b571b_c.jpgIMG_20221008_161112170 by Nick Frost, on Flickr
Whilst that was drying I turned to the fairing to start getting that together and filled.
52436394766_b8f803ec4b_c.jpgIMG_20221008_161918357 by Nick Frost, on Flickr
52435890557_5e7efc194d_c.jpgIMG_20221008_162426157 by Nick Frost, on Flickr
52436846655_63b5fd78ef_c.jpgIMG_20221009_154652644 by Nick Frost, on Flickr
52436846520_2f365165fb_c.jpgIMG_20221011_155035375 by Nick Frost, on Flickr
This was primed and then of course more sanding!
52436669739_60ee1ed2f2_c.jpgIMG_20221014_163209549 by Nick Frost, on Flickr
Switched back to the engine and used some enamels to get some detail on it.
52436669689_f6f4c2faf3_c.jpgIMG_20221017_191129379 by Nick Frost, on Flickr
Got the frame together and realised I missed a bit, the rear suspension is not needed as there's no swingarm but I do want the top part that holds the spring in place, just because its another detail to have in there and it also helps connect/stabilise the two frame halves, which suits me fine because as you can see below I really wasn't happy with how the white looked so it would have needed more painting anyway.
52436394361_804851f8c2_c.jpgIMG_20221017_193444434 by Nick Frost, on Flickr
And speaking of paint just want to take a second to explain how I'm approaching the paint work. Now I'm not a glossy finish guy, I'm a matt paint heavy weathering guy, so this is all a bit new to me; so I looked up how car modellers approach a nice realistic glossy finish on cars.
So what I'll be doing is after priming I'll give it a rub down with a 4000 grit micromesh pad to get it smooth, and I have also switched to Mr Color laquer paints to get a smooth glossy finish (and more vibrant colours)  which will then be given a couple of clear coats and finally will be polished to a high sheen with tamiyas polishing compounds.
Oh and for the colour scheme I'm going for a light blue with yellow striping, so I'll spray the whole thing yellow so I can mask off the stripes then spray it a light blue.
The rear fairing and petrol tank are molded in one piece, and this had some fine mould marks so I rubbed it all over with a 3600 micromesh pad then hit it with primer which as I stated above was rubbed down with a 4000 grit pad.
52436669569_ca2f9edef2_c.jpgIMG_20221017_194151823 by Nick Frost, on Flickr
52436911663_622848a234_c.jpgIMG_20221017_194657370 by Nick Frost, on Flickr
The below has had 2 coats of the yellow gloss Mr Color paint.
52441283019_f495e758ff_c.jpgIMG_20221019_195311014 by Nick Frost, on Flickr
I have to say, I am completely in love with Mr Color paints. They go down like a dream, the colour is so bright and wow over the rubbed down primer it has already achieved a crazy smooth finish.
So I primed and did the same thing for the main fairing part.
52440504522_feaed4d260_c.jpgIMG_20221019_195304642 by Nick Frost, on Flickr
52440504252_407795dbbd_c.jpgIMG_20221019_195854672 by Nick Frost, on Flickr
Then I reprimed the frame, and sprayed it this time with Mr Color white and man it came out so much stronger white in just one spray session.
52440504047_b6a8c1e1a1_c.jpgIMG_20221019_195902546 by Nick Frost, on Flickr
52442541248_11b2e28d0e_c.jpgIMG_20221020_200436636 by Nick Frost, on Flickr
And whilst I was spraying white I decided I want a white detail at the bottom of the fairing so I masked off and sprayed that too,
52441510332_86362bf6d9_c.jpgIMG_20221020_194645033 by Nick Frost, on Flickr
52442290114_feb26e3608_c.jpgIMG_20221020_200445464 by Nick Frost, on Flickr
And now its completely up to date with where I am.
Next Up I'll remove the masking tape when dry and start to plan out how I want my stripe details to look so I can mask it off and spray the blue.
Thanks for looking, more soon :)
  • Like 18
although i not a biker, i enjoy motorbike and F1 model kits too. I like the sponsor logos on racing bike / F1, and enjoy to apply extra large water decals on model kit. hence, never think to build it in scifi way. back to the future? 😗
i built a red scifi bike before. it came from video game: death stranding 😉
btw, i prefer AK's Real Colors (lacquer based paints). 😁
https://ak-interactive.com/product-category/ak-real-colors/?orderby=sku-asc
Edited by Yg Models
Yeah I like that too, I'm going to search through my water decals to find some good ones for the bike. I might even make some custom ones but we'll see.
And that is a cool motorbike! Never played Death Stranding, Hideo Kojimas gone a bit too bizarre and weird with his games these days! Although I'm a big fan of Metal Gear V, that was great fun!
I've pretty much got it locked down in my minds eye. It's a fantastic plan.
My vision has the androids head shaped as a teardrop though, with the Mohawk trailing down to the point.
Those colours do have a great shine. Impressive stuff. I look forward to more. Meantime I'll be at the door, selling tickets to this one!
yes, i feel his try too hard to get away from MGS series, and created a strange FedEx game which has cool story but no replay value as per MGS series...😑
you enjoy MGSV, should buy and build its model kit 😈
for sci-fi bike, you could make reference to the bikes in another video game: Cyberpunk 2077. 🙂
Edited by Yg Models
6 hours ago, Corsairfoxfouruncle said:
Im in count me in the room of people watching along.
Cool glad to have you aboard :)
Wow that sahelanthropus model does look nice! Funny you mention Cyberpunk because I was looking at character models from there to get inspiration for the android rider
Thanks voozet!
I have been working on this, weathers slowed me down a little but I've been sorting out the masking on the main fairing.
Tjis is what the white looks like now I've taken off the tape
52452009863_d02b33e066_c.jpgIMG_20221021_161449284 by Nick Frost, on Flickr
And I decided I wanted this little detail at the bottom to have a retro vibe so I what a swish stripe of white followed by orange and then the yellow.
So I masked and painted the orange
52452009813_14e0550cd9_c.jpgIMG_20221022_201048535 by Nick Frost, on Flickr
52450968882_ff77d1d3e5_c.jpgIMG_20221022_202238763 by Nick Frost, on Flickr
52452009413_906aeff0ed_c.jpgIMG_20221022_202252494 by Nick Frost, on Flickr
I've masked off the section that will remain yellow when I spray the light blue, I'm now in the process of masking off some yellow stripes and sections
52450968917_b6cfc7d180_c.jpgIMG_20221024_165127542 by Nick Frost, on Flickr
So I'm just carrying on with that and then I'll mask out some bits on the tank and rear fairing so I can get it all just sprayed over in the light blue in one paint session
  • Like 9
Time for another update! I finished the masking and sprayed down my light blue
52456915240_4c5d6e0857_c.jpgIMG_20221025_194459866 by Nick Frost, on Flickr
52456996188_8b92a143ce_c.jpgIMG_20221025_201143453 by Nick Frost, on Flickr
52456996158_b06d306a43_c.jpgIMG_20221025_201452641 by Nick Frost, on Flickr
52456465591_d5dcec1b3b_c.jpgIMG_20221026_194900642 by Nick Frost, on Flickr
And before the Mr color paint had even fully dried I just couldn't wait and carefully peeled off the masking tape!
52455942972_f96a5a62d4_c.jpgIMG_20221026_203536933 by Nick Frost, on Flickr
52455942937_29c3609155_c.jpgIMG_20221026_203603415 by Nick Frost, on Flickr
Really pumped about how the colours look together and thankfully all the masking worked out with no overspray or anything, plus it was a swine to copy the details from one side to the other but it looks a close enough match to me.
The only minor issue was a little bit of paint came away on the yellow front stripe
52456735659_1ab0696409_c.jpgIMG_20221026_203614900 by Nick Frost, on Flickr
But thats no big deal I'll just mask the stripe off and spray more yellow.
I also got the engine screwed in to the frame, a lot of the pipework cant go in till its in place so I can get that sorted now. Also I want it together to help me sort out how I'm doing the engine, I'd like to be able to sort out the added engine bits with it all together and have them be removable so I can then paint and then glue it in place.
52456995603_f78f90c540_c.jpgIMG_20221026_201544676 by Nick Frost, on Flickr
And speaking of the engine, I had a couple of parts in mind for the jet bits at the back, so I dug an old 1/60 freedom gundam I made yeeeeears ago out of his spares box coffin.
52456736329_6a5f1b11a9_c.jpgIMG_20221026_201202632 by Nick Frost, on Flickr
The parts I want to use are his shoulder boosters
52456465156_070dc569bb_c.jpgIMG_20221026_201210120 by Nick Frost, on Flickr
After a bit of careful surgery (which was simple as I'd just rattle canned the paint on the sprue and then just push fitted it all with no glue) I have the engines out.
52456914565_ea3a452b8d_c.jpgIMG_20221026_201714267 by Nick Frost, on Flickr
Next up I'll take a look at how I can get them in place and I'll mask out the rear tank and fairing and also sort out the chip on the yellow stripe
  • Like 18
Loving how this project is going Nick and your concept sounds a cool one.
The fairing paintwork is rather smart and has a great 80s retro vibe to the colour-scheme :speak_cool: if anything I'd leave the chipped part on the front as it looks quite natural.
Edited by Col.
Thanks Col.! Yeah I really want that 80's view of the future kind of look, and oh man I'd love to just leave it but its all I see when I look at it now and if I dont I'm pretty sure my brain will explode! :lol:
42 minutes ago, Uncle Monty said:
I love this colour scheme, I'll be watching with interest. The engine is already looking very cool.
Thanks Monty, yeah I'm really liking how it came out too, I wanted to go for different colours to what I usually go for.
  • Haha 2
Disassembling your gundam is a nice source of parts for the future. As a definite non-fan of this style, I think that it is a pretty good use of the model 😉
(I apologize to the fans in advance, I would not like to offend anyone).
Yeah I never throw old or broken kits, especially the big guy, tons of interesting bits on him!
Had some shed time over the weekend, so started by sorting out the paint chip at the front.
Masked it out and then gave it 2 more coats of yellow
52465872663_589c819bc0_c.jpgIMG_20221027_193655613 by Nick Frost, on Flickr
52464823307_7911b0edda_c.jpgIMG_20221029_161138919 by Nick Frost, on Flickr
You can still see it a bit but its way better than it was so I'm fine with it
So I was free to start masking out the rear fairing and tank. I want the stripes to continue across the fairing parts so I started by holding the fairing parts on the frame so I can line up the masking tape properly, then got the rest of it done.
52465319601_83955f2d08_c.jpgIMG_20221030_114215451 by Nick Frost, on Flickr
52465872398_f7bd664697_c.jpgIMG_20221030_123654326 by Nick Frost, on Flickr
52465787110_b65f71cd7c_c.jpgIMG_20221030_123703642 by Nick Frost, on Flickr
Then with that done I can spray down the light blue
52465786865_34da3e2922_c.jpgIMG_20221030_161228594 by Nick Frost, on Flickr
Once it was dry I whipped off the masking tape
52465871868_a62b38ff68_c.jpgIMG_20221030_184952285 by Nick Frost, on Flickr
And then I dry fitted the parts on the frame again to check how it looks
52465871848_33cb039710_c.jpgIMG_20221030_185128708 by Nick Frost, on Flickr
Really happy with how that came out, I wanted the design to spread across the whole bike like you get on race bike fairing.
Next up I'm going to start getting the other frame details sorted, still have some pipes and bits to add and before I carry on with the fairing.
  • Like 19
