”Hold the Rope Willi!” (DS3516) 1:35
Mike
1:35 ICM via H G Hannants Ltd
The Panther was Germany's answer to the surprise appearance of the Russian T-34 after they finally reacted to the invasion that was Operation Barbarosa.  Although the project had been in gestation for some time before, they took some design cues from the T-34 in the shape of the sloped armour, resulting in the Panther that was intended to fill the gap between the Panzer.IV and the (then) new Panzer VI Tiger.  It was eventually supposed to replace both the Pz.IV and the earlier Pz.III that was really showing its age, but in reality it often fought alongside the Panzer IV due to lack of production numbers.  It was planned as a lighter, more manoeuvrable tank than the Tiger, and was fitted with a high velocity gun from the outset, which gave it enormous penetrating power that was only equalled by the British 17-pounder fitted to the Sherman that turned it into the Firefly.  The sloped frontal armour gave it an increased effective armour thickness, but this was not so true of the side armour, which was weaker and more steeply sloped, becoming the preferred target area of allied tanks, especially in urban combat where this was a telling issue.
Like most German tanks of WWII, it was complex to produce, so suffered in terms of volume, which led to it being rushed into service with quite a list of problems still to resolve.  Later production solved most of these initial gremlins, but loses in the interim were high with many being abandoned after breaking down during combat. Curiously, the Ausf.D was the first to enter production, with the Ausf.A following later in 1943, replacing attrition of the less reliable Ausf.Ds until they themselves were superseded by the Ausf.G, which became the final major variant with increased ammo storage, simplified design to ease production, and further improvements to reliability, although this was never fully cured with a high rate of attrition due to mechanical issues, some of which resulted in catastrophic fires.
The Kit
This box set contains quite a bundle of kits, including two Panther kits, one Ausf.D, the other an early Bergepanther, a catchily titled le.gl.Einheitz-Pkw Kfz.4 with a Zwilling Anti-Aircraft (AA) mount, and three sets of figures, one of drivers, one of tankers and another of tank riders.  It arrives in a compact top-opening box with their usual captive inner flap on the lower tray, and inside are several bags that contain a total of seventeen sprues in grey styrene, either in black, one clear sprue and three small sheets of decals.  The instructions are contained in a glossy white folder, and there are seven of them in total, as the figure sets and the AA mount is also available as a separate kit.
The two panthers are ostensibly the same except for their turret sprues, or lack of in the case of the Bergepanther, which has its turret removed and replaced by a wooden top cover, a winch and some additional parts that aren’t included in the other kit.  We’ll cover the Panther with the turret first, then differentiate between the two kits, then the little AA truck, and finally the figure sets at the end.
Px.Kpfw.V Panther Ausf.D
This kit is the subject of the Bergepanther’s ministrations, and is a standard Ausf.D that’s combat-focused, and has the following sprues:
Construction begins with the lower hull, which is completed by adding the T-shaped rear bulkhead and the armoured surrounds around the final drive housings at the front of the hull.  The many stub axles are inserted into the hull with a peg holding them at the correct angle, and these are accompanied by a number of additional suspension parts, bumpers, the housings themselves and of course the interleaved main wheels, plus the four-part idler wheels and two-part drive sprockets.  The rear bulkhead is detailed with twin exhausts that hold the detailed jack, and on each side a pair of angular stowage boxes with separate lids are included.  The upper hull has the inside of the glacis plate detailed with driver’s hatch and vision blocks, plus two hatches on pegs that insert into the lift-out front section of the forward deck.  The rear deck also has a large inspection hatch in the centre that is decked out with mushroom vents and grab-handles, then has the various rectangular and circular vents from the engine compartment added either side, plus a couple more circular vents and lifting lugs.  The stowage for the sides of the hull are made up on frames, a couple for each side, plus a tube for the barrel-cleaning rods and two racks of spare track links at the rear.  The front mudguards have width indicators added that I’ve not seen before, then it’s time to make up the tracks.
The track links are made up from individual parts that are joined together to create the complete run, although you aren’t given a guide figure of how many to use, but from memory I suspect around 90 would be appropriate.  They clip together, but need some glue to retain their integrity, so wrapping them around the road wheels while the glue is still flexible, then hold them in place with tape, foam wads and other tools to obtain the correct sag on the return run.  The good news is that there are only two sprue gates to deal with per link, but they are on a concave surface, so if you have a circular sanding stick, file or burr for your motor tool, they won’t hold you back for long.  There are however two small circular ejector-pin marks in the outriggers of each link’s outer face.  Sanding those could be done with a small, flat-tipped burr, or you could make your own and glue some wet’n’dry to it, as I have done in the past.  The alternative is to slap some weathering and mud on the tracks to hide any issues you didn’t fix.
The turret is moulded as one part with an open back to which the rear bulkhead with its circular hinged hatch is fitted, and at the front the basic breech is mounted on a pair of trunnions that project through the front of the turret and receive the two-layer mantlet.  The barrel is made from two halves with the muzzle brake moulded-in, and once the seams are dealt with, it is inserted into the mantlet, locating its notch on a pin within the aperture.  The rest of the turret details involve the hinged shell-ejection port, the multi-layer commander’s cupola with pivoting hatch, lifting eyes and grab-handles, the corner-mounted smoke grenade dischargers, and finally the bottom plate, which has the bayonet lugs that secure it in the turret ring with a twist.  The model is completed by adding the spaced schurzen side skirts under the sponsons, the twin tow ropes, one on each side, and the gun’s travel lock, which glues on the front between the two hatches, and is made from four parts that should allow it to hinge if you are sparing with the glue.
Markings
There are two schemes you can depict from the sheet, both based on a dark yellow (dunkelgelb) base and wearing different types of green camouflage.  From the sheet you can build one of the following:
  • 52nd Battalion, 39th Armoured Regiment, The Kursk Salient, July 1943
  • Armoured Regiment of Division “GrossDeutschland”, August 1943
All the decals are by ICM’s usual partner, and are in good registration, sharpness and colour density, with a thin gloss carrier film cut close to the printed areas.
Bergepanther Early (35342)
This kit builds up the same as the one above until the turret, which is missing for obvious reasons, as is the sprue.  Instead, there is a different sprue that includes the wooden two-part hatch that fits over the turret ring, a self-defence machine gun on a short mount on the front right corner and an optional upstand on the other side to move it to if the need arises.  Additionally, there is a crane with two supports that fix on brackets at the rear, and hangs over to the side with a twin-sheave block and a pair of hooks to attach the loads on.  At the rear is a large two-plate towing bracket with drop-in pin for heavy-duty towing duty.
Markings
There are two options on the sheet, one in plain dunkelgelb, the other with lengths of diagonal green camouflage sprayed over the yellow, both wearing just a trio of crosses.  From the sheet you can build one of the following:
  • S.Pz. Jäger Abt. 653, Kursk, Summer 1943
  • Panzer Regiment Herman Göring, East Prussia, Autumn 1944
This bag contains seven sprues in grey styrene plus a single clear sprue and decal sheet, with two sets of instructions with integral painting guide at the rear of the larger one.  This is a re-box and amalgamation of the staff car with their Zwillingssockel 36 that is available separately, plus a few extra parts on new sprues that helps merge the two together into the completed vehicle.
The chassis is first to be built up with dual springs supporting independent suspension and a driveshaft linking the two transfer boxes, plus the steering linkage front and rear.  Fuel tank and stowage are placed to either side of the chassis rails and an exhaust pipe is threaded through to the engine compartment, which is filled with a full rendering of its 4-cylinder 2 litre Stoewer power plant over the front axle.  The floor of the cab is built up and added to the chassis, then the three-part styrene wheels with moulded-in tread are fitted to each corner along with the radiator at the front.  The firewall and a rear passenger bulkhead are installed next with the former having instruments and transmission tunnel moulded in and pedals attached to the floor.  The cab sides, boot/trunk cover, engine cowling and gear shifter are all put in place before the seats are built up from base, cushion and curved back in the front, with a large tread-plated area for the gunners that has just enough room down the sides for spare ammo cans in racks lining the lip.  Two rifle stowage points are attached to the front bulkhead, bumpers/fenders and doors are all added with steering wheel, and windscreen also made up between the front and rear compartments with tripods racked on the rear deck of the vehicle.  The rear light cluster is fitted to the rear quarters with a spare wheel in between them, and the folded canvas roof above the divide between compartments.  Front lights and pioneer tools are attached to the fenders, and windscreen wipers are fitted into the depressions on the frame, with wiper-motor boxes moulded into the frame for completeness.  The lights and windscreen all have clear parts so the passengers don't get bugs in their teeth.  The guns are built on a separate instruction sheet, and the completed assembly is shown in the main instructions being dropped into place in the rear fighting compartment.
To make up the gun, the ammo cans are made up first, joined to the twin frame, which then has the gun mounts fitted on top.  The guns are still fitted with their bipods, which along with the breech cover are moulded separately to the rest of the guns.  If you’re a detailer, you may want to drill out the muzzles very carefully with a tiny bit in a pin vice.  With the guns on their frame, the outer frame is fitted around it in two halves, slotting into the pivot points moulded into the frame, and supported by a cross-brace lower in the frame.  Another bracing strut fits across the front and has a canvas brass catcher curtain suspended beneath it that is attached to the tube by a series of rings moulded into the part.  The conical base is built from two parts and inserts into a socket in the underside of the outer frame, then it’s a case of making up the seat that fits at the very rear of the outer frame, and choosing the correct sighting part for your chosen pose, pivoting the guns to an appropriate elevation during the process.  A pair of scrap diagrams shows the two finished poses, and overleaf is a painting guide in greyscale that could be a tad confusing as it has no paint call-outs on the two greyscale profiles.
Markings
There are three theatre specific options included in the box with early war Panzer Grey the colour of choice.  From the box you can build one of the following:
  • Luftwaffe Ground Units, Greece, 1940
  • 1st Panzer Division, Greece, 1941
  • 11th Panzer Division, Eastern Front
The decal sheet is small and printed on a bright blue paper, with good register, sharpness and colour density.
German Drivers 1939-45
This small set from ICM gives you four figures to fill those empty seats. It is single sprue with four figures and  It's safe to say that all of them are posed in the seated position, while two are dressed in standard Wehrmacht uniforms with a forage and patrol cap on their heads.  One other figure has a smock coat over his uniform with a lace-up neck, and the final one is an officer with a rather relaxed hand draped over the top of his steering wheel.  Two of the drivers forage cap and smock guy are looking to their left, while patrol cap guy seems to be looking at his steering wheel, perhaps at a map?  Each figure comes broken down as torso, individual legs and arms, head and hat, with a couple of ammo pouches for the belt around the smock bedecked gentleman.
The instructions are on a single sheet of glossy paper, with part numbers and colour call outs that reference a chart on the rear that shows Revell and Tamiya colour codes, plus the name of the colour in English and Ukrainian (that's a guess).  Sculpting and moulding is excellent as we have come to expect from ICM, and the figures will doubtless fit a lot of applications without any adjustment.
German Tank Riders (1942-45)
Riding is better than walking, and tanks are generally a better way to hitch a ride to or from the battlefield, and also make for a great hiding place if the front isn’t where it was supposed to be.  This set arrives on a single sprue in grey styrene that contains parts for four figures, three of which are seated, the standing with a forage cap and MP40 in a semi-ready stance.  Two of the seated characters are wearing camouflaged smocks and stahlhelms, one nursing an MG42, the other crouching with a rifle in one hand.  The uniformed seated figure has an MP40 over his shoulder and helmet on his head.  Parts breakdown is as you’d expect with separate heads, torso, arms and legs, plus helmets that fit over their bald heads with moulded-in chin-straps, except for the cap-wearer, who has his hat moulded onto his head.  The additional parts on the sprues include gas mask cylinders, water bottles, pouches, bags, grenades and an ammo box for the MG42.
German Tank Crew (1943-45)
Another four figure sprue in grey styrene, which includes a standing commander in flat peaked cap checking his watch, an officer in a peaked cap bending over to look at the work being done with a choice of two optional left arms, a spanner twirler on his knees in shirt and trousers, wiping the sweat from his brow with the back of his spanner equipped hand, and another crewman in overalls leaning on one hand on his hands and knees.  Parts breakdown is standard ICM with separate heads, torsos, arms and legs, with the spanner twirler sporting a nice centre-part while his compatriot has a moulded-on cap.  The Officers have flat tops to their heads and separate caps.  They also have pistol holsters to fix to their sides.
Conclusion
How they managed to pack two Panthers minus one turret, a 4x4 Anti-Aircraft truck and three figure sets into this relatively compact box and keep the price so attractive is amazing.  The Panthers aren’t the latest toolings, but they should suffice for everyone but the most detail hungry, with tons of detail in the Einheitz, and excellent sculpting on the figures.
Very highly recommended.
Available in the UK from importers H G Hannants Ltd.
Review sample courtesy of
