Chaotic Mike Posted October 5, 2022 Share Posted October 5, 2022 Hello all, I have just started using an organic solvent based primer through my airbrush, and whilst it leaves the shed smelling absolutely divine, I would put money on it not being great for my lungs and brain. What to you all use/wear to keep fume inhalation to a minimum? Mike, high as a kite somewhere in Hampshire 1 Link to comment Share on other sites More sharing options...
MODeller Posted October 6, 2022 Share Posted October 6, 2022 3M 4251 has particle and carbon filters. Not cheap around £20 but if kept in an airtight container mine past around 13 months. I bought a Tupperware box around £8. As I have COPD and lost a lung to cancer I am very particular about my health and these masks tick all the boxes. 1 Link to comment Share on other sites More sharing options...
Ray_W Posted October 6, 2022 Share Posted October 6, 2022 Here is what I use. It is not a recommendation but may steer you to do your own research and speak to suppliers. I spray lacquer solvents predominantly. Honeywell 6100V Series Mask With ABEK1 + HF + Formaldehyde Filters. Also I always spray in a very well ventilated area. I try to run the lowest pressure you can get away with to limit bounce-back and overspray. And I also wear glasses. I keep spare filters and replace as needed as they also capture a lot of particulate matter which tends to effect filter life more than anything. One reason why, irrespective of what you are spraying. masks are a must. Ray Link to comment Share on other sites More sharing options...
Rick Brown Posted October 6, 2022 Share Posted October 6, 2022 I went with the 3M7502 with 6051 filters. Works a treat, no smell at all from any paint I use (Lacquer through to enamel's etc). Nice and lightweight too. Not cheap (£60 two years ago) but should last for years and the filters are readily available. Rick. Link to comment Share on other sites More sharing options...
Chaotic Mike Posted October 6, 2022 Author Share Posted October 6, 2022 Thank you everyone... food for thought. Mike 1 Link to comment Share on other sites More sharing options...
IanC Posted October 11, 2022 Share Posted October 11, 2022 Hello Mike, Another one worth considering is the 3M 6502QL mask - with 3M 6051 filters. It comes out well in reviews and I've found it very comfortable and effective. I paid about 25 quid for the mask on Amazon. Ian Link to comment Share on other sites More sharing options...
Chaotic Mike Posted October 11, 2022 Author Share Posted October 11, 2022 I went for the 7502 mask, and 6051 A1 filters, £35 from evilBay. It took me a little while to work out how to fit and adjust the head and neck straps, And how to orient the filters. The instructions could do with a re-write from the WNW team! 1 Link to comment Share on other sites More sharing options...
