Masking fluid
bazzacourt
The only time I've used a masking fluid, it was this stuff:
I put some over the Gunze-Sangyo Dark Earth, on the nose of a Hurricane. When I removed it, it lifted up some of the Dark Earth.
Next time, I'll try something else.
Chris
Good question but definitely in the wrong place.
Better off asking it here :
https://www.britmodeller.com/forums/index.php?/forum/68-tools-amp-tips/
The mods are probably having a Sunday snooze but this will get moved soon.
In the meantime I also use Copydex as a cheap masking fluid
4 hours ago, dnl42 said:
I've had good luck with Microscale Industries Micro Mask. I usually fill in around tape borders.
I'll have a look for it thanks.
Chris
I'll stear clear thanks
The paint lifting comment reminds me to note this important point. The masking fluid needs to be compatible with the paint. If the paint and making fluid use similar solvents, you'll have a bad experience.
To that point, I primarily use Mr.Color.
I tried different brands of masking fluid "for modellers" over the years and quite often experienced problems, from difficulty to remove the dried masking to (dis)coloured and even sometimes literally melted paint. That even if the product was said "not aggressive". I found out (thanks BMers) that the problem is that most masking fluids contain more or less ammonia which is really not friendly with the water or alcohol based acrylic paints I use.
I decided to take a look elsewhere, at artist's masking fluid that is. As it's used with watercolours it should be harmless for our paints, shouldn't it? Well, beware, these may also contain ammonia (bought, opened, smelled, binned).
Finally I found (at a local artist shop) one from Schmincke, available in a transparent or blue version. That one states "neutral - ammonia free". Very happy with it: easy to apply and remove, zero adverse effect on paint until now.
One caveat: (very) pricey.
Micro Mask has a "warning" on the label advising use of petroleum-based paints on top.
Paints containing water are not recommended
I've had it lift acrylics
Currently I'm using Mr Masking Sol Neo or Copydex
Some already suggested "watercolor masking fluid" for acrylics - and I want to give +1 there for those, either W&N or any good quality craft one. Yes, the masking fluid for modellers is a case of "re-bottling, relabel and sell for 2x more money".
Edited by Casey
I use Frisk Artist’s Blue Masking Fluid from Hobbycraft - surprisingly cheap (especially for Hobbycraft) which I found was better than any other I’d tried as it seemed slightly thinner, but worked just as well. Don’t know if they still sell it though as I’ve had my current bottle for quite a while now.
  • 1 month later...
Hey guys,
Have you ever experienced a change of finish on areas which were in touch with liquid mask and how to remedy it?
I've applied Ammo liquid mask on Gunze H (Mr Hobby Aqueous) and the parts which were in contact with the liquid mask have now a strange sheen, as if they have been gloss coated. The issue being that the areas which were under the white-tack do not have that sheen and I have a very weird contrast going on.
Any ideas?
  • 4 weeks later...
On 11/27/2022 at 7:29 AM, Planebuilder62 said:
BTW, for what masking application do you want to use making fluid for? In 99 times out of 100 I have found either masking tape or blu tac as the most appropriate masking solution.
regards Toby
Sorry for the belated answer, the notification didn’t come in for some reason.
I used masking liquid to fill in the gap between white tack rolls while masking a camouflage. The paint underneath is Gunze Aqueous.
On 11/24/2022 at 3:51 PM, cpoud117 said:
Hey guys,
Any ideas?
This masking fluid is one of those I discarded just after smelling the content. I just can repeat what I said above.
Whatever the producers say, if a masking medium even faintly smells of ammonia, avoid contact with painted areas. Maybe it won't hurt one or another type/brand of paint but - as a general rule - water and alcohol based paints don't like ammonia.
There should be enough masking methods and ammonia free media mentioned here (correcting fluid, masking tape, blu-tak, ammonia free masking "pens" .....) for you to choose from.
I hope it helps you for your next builds.
Regards.
Pat
I can recommend Ammo liquid mask. Over the years, I've used many different masking fluids, from maskol to graphigum, but was never completely satisfied. Of all I tried, Ammo stuff is definitely the best. Never had a problem with it so far, and it's easy to use. However, every time I do use it, I make sure the paint below had a couple of days to cure, and I never leave it on for a long time. A week to a month is my maximum, I never leave it on for more than that. Use these simple percautions and you won't have a problem
