Cklasse Posted September 28, 2022 Share Posted September 28, 2022 (edited) I am working on my Lynx helicopter and it’s about time I build a structure at this stage. I know nothing on diorama making but would certainly want to do it for all my models, at least a decent base. Can someone kindly suggest how can I make this cement structure? I am thinking of building a shell of this structure with foam but not sure what material can I use to coat the outer surface to achieve that “Stone” effect. Edited September 28, 2022 by Cklasse Link to comment Share on other sites More sharing options...
Crayons Posted September 28, 2022 Share Posted September 28, 2022 3 hours ago, Cklasse said: I am working on my Lynx helicopter and it’s about time I build a structure at this stage. I know nothing on diorama making but would certainly want to do it for all my models, at least a decent base. Can someone kindly suggest how can I make this cement structure? I am thinking of building a shell of this structure with foam but not sure what material can I use to coat the outer surface to achieve that “Stone” effect. You could try a mix of mod podge, plaster/grout, water and a squirt of the basic colour of choice. Mix it into a paste and trowel it on. Link to comment Share on other sites More sharing options...
Black Knight Posted September 28, 2022 Share Posted September 28, 2022 Pollyfilla, or the equivalent in your area. Home DIY repair ready-mixed plaster Link to comment Share on other sites More sharing options...
speedy Posted September 28, 2022 Share Posted September 28, 2022 As above with plaster, but for the scale effect use a cube of sponge and dab it. You’ll use all 4 sides as it will clag up, so make sure you have some more available. The painting will make it though Link to comment Share on other sites More sharing options...
voozet Posted October 1, 2022 Share Posted October 1, 2022 (edited) The shape is quite simples. Use foam as a mold. Fill it with plaster of paris. Once out of the mold, texture with a metal bristle brush. Horizontal "steps" can be easy made in plaster, for example, with a file or knive (this seems easier than cutting them in foam/mold). Recently I was making plaster diorama elements for my model, a little more detailed description: https://www.britmodeller.com/forums/index.php?/topic/235099759-135-ian-mcques-remora-flying-boat-scratch-build/page/9/#comment-4500602 However, if you prefer to cover the foam with a layer of texture, you can use this. This is, say, instant concrete, ready to use. Edited October 1, 2022 by voozet Supplement the content of the post Link to comment Share on other sites More sharing options...
Cklasse Posted January 17 Author Share Posted January 17 Just an update to what I have build for this cement stone structure. I had used gritty plaster, mod podge on plastic sheets. 3 Link to comment Share on other sites More sharing options...
