Silenoz Posted September 21, 2022 Share Posted September 21, 2022 been working on this one now and then till I got to the point that I was actually achieving something... The Henschel P.75 was a proposal for a heavy fighter to replace the Bf-110 (2 engined heavy fighter). Initially it was to be propelled by a DB-610 engine (2 coupled DB605 engines, but this unit was prone to overheating, and it was to be changed into a DB613 (2 coupled DB603 engines) DB-610 DB613 This engine was to propell 2 contrarotating propellors with a 3.2m diameter. The form of the engine gave it a flat, wide section. Further it was to have a nose gear, canards and a rudder at the bottom that also could serve as a bumper to not to damage the propeller during take-off and landing. This configuration gave home to 4 30mm cannons in the nose (4x 30mm MK-108 kanonnen) for concentrated fire. Windtunneltests were promising, but in the end the project was halted. Later on some planes appeared in a similar layout like the J7W1 Shinden, XP-55 Ascender, but these all had a troubled short life, also due to heating problems, jet engines coming available, etc... The kit: What is is supposed to look in the end: First job was to remove all parts from the pouring blocks. To prevent aligning problems when glueing with CA, I drilled holes for positioning pins. and dryfit: The cockpit was very sparse, but started connecting the main parts for sanding: and a new cockpit was made from styrene and paper: Om deze beter te kunnen detailleren heb ik de romp nog in 2 delen gelaten: The hull is mostly massive resin, so it is heavy. The landing gear is also resin, but I think it will deform over time. So I got a bit creative with Albion Alloy tubing: To be continued... 10 Link to comment Share on other sites More sharing options...
Silenoz Posted September 22, 2022 Author Share Posted September 22, 2022 Yesterday I had some work done on the cockpit. I wanted to try some Quinta Studio decals to see how they work (Sidewalls are in paper, so i can adjust these to the hull when glueing everything) And cutting these up to fit the cockpit: and finally glued them as you would with regular decals, but they advise to use some PVA-glue, and it is a necessity and to be honest, these Quinta Studia decals are a charm to work with. 9 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted September 22, 2022 Share Posted September 22, 2022 It's a new one to me. The brass gear is a good idea. An ejection seat would also have been a good idea. It also looks like there wouldn't have been much room for fuel, so drop tanks would probably be a must. 1 1 Link to comment Share on other sites More sharing options...
Silenoz Posted September 22, 2022 Author Share Posted September 22, 2022 thanks for the input. Been thinking about that ejection seat... could be with the idea of explosive bolts for the screws at the rear to avoid things getting mixed up. Those external fuel tanks are a great idea... Haven't thought about that to be honest 1 1 Link to comment Share on other sites More sharing options...
Silenoz Posted September 23, 2022 Author Share Posted September 23, 2022 So I ordered 2 fuel tanks and just in case also two MG casings for under the wings, just in case 😉 Link to comment Share on other sites More sharing options...
81-er Posted September 23, 2022 Share Posted September 23, 2022 A beautifully wierd Luft '46 design that I hadn't seen before, I love it! You're doing a good job of it as well. I'll pull up a set for the rest of this one James 1 Link to comment Share on other sites More sharing options...
Silenoz Posted September 25, 2022 Author Share Posted September 25, 2022 Thx James. Started on the wings this weekend. Postponed it because of the weird section they have Their section is almost symmetrical, against all logic concerning generating lift, and the autistic engineer in me says aaaarrrggggghh This is what should be removed from the resin wings, looks a lot of sanding... An easier problem was this dent in the trailing edge: Some heat with a mini-heatgun and a bit of pushing later: Also the holes for the alignment/reinforcement pins are drilled And dryfit: So... To sand or not to sand... that is the question. Opinions are appreciated 5 Link to comment Share on other sites More sharing options...
Silenoz Posted September 27, 2022 Author Share Posted September 27, 2022 So... I bit the bullet and sanded the wing profile. The things that bothered me most were: - the overall thickness - the rear of the wings were very thick with a very steep bend to make for a thin trailing edge - upper and lower side weren't defined... left and right could be interchanged - it didn't look like a wingprofile there aren't any drawings to rely on, so here it goes... 80 grit, 120grit and 360grit before halfway to: Symmetry looks ok so far Some more will be needed till they fit the hull: soon more... 4 Link to comment Share on other sites More sharing options...
81-er Posted September 27, 2022 Share Posted September 27, 2022 They definitely look far more wing shaped now James 1 Link to comment Share on other sites More sharing options...
Silenoz Posted September 28, 2022 Author Share Posted September 28, 2022 Thank you James,. Another night of sanding... first filling the gaps with CA and the dust from the previous sanding proces. And some filler for some finer sanding. Also a lot of airbubbles in the wing, hence the extra filler there and then a general view so far with the nose attached: So guess what I will do the next modelling session... 1 Link to comment Share on other sites More sharing options...
Silenoz Posted September 29, 2022 Author Share Posted September 29, 2022 Next round: And another one because it didn't feel smooth enough yet. So far: Ready for primer... 3 Link to comment Share on other sites More sharing options...
Sturmovik Posted September 29, 2022 Share Posted September 29, 2022 Your model reminds me of the Ocean Sunfish. What paint scheme will you choose? 1 Link to comment Share on other sites More sharing options...
Winded Penguin Posted September 29, 2022 Share Posted September 29, 2022 This model is way outside my comfort zone. It's still nice to watch someone else do a cracking job on it though 👍 1 Link to comment Share on other sites More sharing options...
Silenoz Posted September 30, 2022 Author Share Posted September 30, 2022 @Sturmovik: I haven't decided yet, been checking some late war camo's. Also the one from the first post looks very nice.. @Winded Penguin Thank you 1 Link to comment Share on other sites More sharing options...
81-er Posted September 30, 2022 Share Posted September 30, 2022 I'm really enjoying watching this take shape. Looking forward to seeing what you do with the paint too James p.s. Is your username anything to do with Dimmu Borgir? Link to comment Share on other sites More sharing options...
Silenoz Posted September 30, 2022 Author Share Posted September 30, 2022 (edited) Thx James, yes, when I was a student a long time ago, I was a big fan (now I don't really follow it anymore) hence the nickname (together with Cradle of Filth, Children of Bodom etc..) Primer applied.. some small holes from bubbles in the wing, but overall rather good: To be continued... Edited September 30, 2022 by Silenoz 4 Link to comment Share on other sites More sharing options...
81-er Posted September 30, 2022 Share Posted September 30, 2022 That looks like a nice smooth coat of primer Big fan of all of those bands as well, plus a good friend played for Cradle for a bit. Coincidentally, he now lives in Belgium too James 1 Link to comment Share on other sites More sharing options...
Courageous Posted September 30, 2022 Share Posted September 30, 2022 3 hours ago, 81-er said: That looks like a nice smooth coat of primer Stuart 1 Link to comment Share on other sites More sharing options...
Silenoz Posted October 5, 2022 Author Share Posted October 5, 2022 Thx guys. started the scribing : first on the topside marked everything in pencil as a guide: In between there's some small filling to do with tiny amounts of CA (airbubbles, wrong engraving, etc...), but most areas need some sanding anyway. Next up is the actual engraving with the use of a JLC microsaw and the MRP scribers, a steel ruler and some patience. The holes are gone.. a nice smooth wing, except for the double line... The nose will require more work, because I am adapting it till the platework corresponds more with the canards and acces for the MG's and ammo... Most difficult part is the difference in hardness, not only in the different areas of the resin, but also where the CA is applied. That's where the microsaw comes in very handy. to be continued 4 Link to comment Share on other sites More sharing options...
81-er Posted October 5, 2022 Share Posted October 5, 2022 Nice progress there. I really don't envy you having to rescribe the whole of a resin model James 1 1 Link to comment Share on other sites More sharing options...
Silenoz Posted October 7, 2022 Author Share Posted October 7, 2022 Cooling has always been a serious problems aircraft with the engine tucked away halfway into the hull. At the bottom there were some cooling vents cut out, there will also be cooling scoops on top and bottom, but I still wanted to open up the louvres at the topside. Found out that it was better to make the vertical cuts first and then scrape away the material Also made a start at the bottomside 4 Link to comment Share on other sites More sharing options...
Mattlow Posted October 7, 2022 Share Posted October 7, 2022 Very nice... Has the look of a craft from the Star Wars universe... just needs some ion engines above and below the wing roots... Matt 1 Link to comment Share on other sites More sharing options...
Silenoz Posted October 7, 2022 Author Share Posted October 7, 2022 I must admit... I have been thinking about this one a lot lately... Link to comment Share on other sites More sharing options...
Mattlow Posted October 7, 2022 Share Posted October 7, 2022 Yep, there's familial resemblance there... Matt Link to comment Share on other sites More sharing options...
Silenoz Posted October 8, 2022 Author Share Posted October 8, 2022 Yesterday I did some work for the layout for the positioning of airscoops, exhausts, etc... Bottomside with additional droptank, resin Typhoon exhausts (here the size looks good), extra guns under the wings to compensate for the lack of 2 mg's in the nose (only 2 there instead of four... ) on the top side it's a bit of a different story. The creme parts are the original ones: the original exhausts don't look streamlined for the design, but the typhoon exhausts look way too large. I also have some other exhausts that I would have to cut up that are smaller and maybe fit better at the top: The only part I would use are these: Opinions, remarks, etc... more then welcome 2 Link to comment Share on other sites More sharing options...
