speedy Posted September 20, 2022 Share Posted September 20, 2022 Hi folks, I’m looking at doing a motorcycle and it’s completely left field for me. Dangerously searching 1/6 or 1/12 scale it’s coming up with the 2 manufacturers. Thoughts on both makes please for those in the know. Link to comment Share on other sites More sharing options...
Marco F. Posted September 20, 2022 Share Posted September 20, 2022 Hi Speedy Tamiya kits are normally good kits, easy to build and good details and Tamiya is offering 1/6 and 1/12 scaled models. I got an Aoshima Kawasaki z750 in my stash, but did not started it yet. But this kit include fine looking parts, several option parts but no chrome parts. Here on the board you should find some threaths about the Aoshima Suzuki GT380, and if I remember right also about a Kawasaki 2-stroker and a Honda CB400 Marco F 1 Link to comment Share on other sites More sharing options...
Redstaff Posted September 20, 2022 Share Posted September 20, 2022 Not sure about bikes as that's not my field, but car wise, Tamiya has the upper hand everytime 😃 Aircraft were the same as well when I used to build those, I've never built a bad Tamiya kit to be honest Ian 1 Link to comment Share on other sites More sharing options...
Spiny Posted September 20, 2022 Share Posted September 20, 2022 Again I can't comment on bikes, but the best advice I can give if your chosen subject is made by both Aoshima and Tamiya is to do some research and see which appears to have the best reception. While I would say Tamiya are usually of pretty consistently high standard, the best kit I've built to date is from Aoshima (their Countach in case you're wondering). So I don't think there is a cut and dried answer to "Which is better, Tamiya or Aoshima?". 3 Link to comment Share on other sites More sharing options...
gamblor916 Posted September 21, 2022 Share Posted September 21, 2022 It all depends on the subject. When it comes to motorcycles it unusual to have choice of manufacturer for any make or model. That said Tamiya has the best bike kits. 1 Link to comment Share on other sites More sharing options...
Alan R Posted September 21, 2022 Share Posted September 21, 2022 I would agree that Tamiya are usually the better kits. However, Aoshima do models of more 'mundane' bikes. for example the Honda CB400 four on mk 1 & mk 2 versions. The only major difference that I can see is the rear foot-pegs are attached to the swing-arm on the mk 1, and to the frame on the mk 2. I had a bright yellow CB400 mk 2, and I remember the reviews of the time pointing this out. Makes the ride for the passenger a bit more comfortable. I have a partially built Aoshima Suzuki GS400 twin which has, so far, gone together well. It's a pity that neither do much, if any in the classic brit/US range of bikes. I wish there was a 1/12 scale early 70's Triumph Bonneville, for example. Also, there are a few Fujimi 1/12 scale bike kits, but I have heard that they are a bit more simplistic than the Aoshima and Tamiya kits. Cheers, Alan. Link to comment Share on other sites More sharing options...
