Mike Posted September 18, 2022 Share Posted September 18, 2022 F4F-3 Cockpit w/Telescopic Gunsight (648765 for Eduard) 1:48 Eduard Brassin But wait… there’s more! More aftermarket for the new tool Wildcat from Eduard, and this is the second wave of aftermarket sets that they have released for those that want to increase the level of detail over and above what’s achievable using injection moulded styrene. As is now usual with Eduard's larger resin sets, they arrive in a deep Brassin cardboard box, with the resin parts safely cocooned in bags, and the instructions folded around acting as padding. This set will please those that want to model an earlier Wildcat with the simple telescopic sight that was fitted to the first aircraft off the production line. There are three Ziploc bags within the box, two containing directly 3D printed parts, the other containing a fret of nickel-plated pre-painted Photo-Etch (PE), and a small decal sheet, both protected by a small sheet of white card. On emptying the parts out of the bag, the first thing you notice is the sheer level of detail present, but also the relatively small parts count thanks to the capabilities of 3D printers, where supports are all that is required to protect overhangs, and there is no degrading of mould fidelity over time because there are no moulds to wear out. The short parts list is also evident immediately on viewing the instructions, which begin with an ostensibly complete aft cockpit assembly, to which you add the seat with painted PE lap belts only for the initial batch of airframes. The control column slips into a deep recess in the gaiter, some half-moon levers are added at the sides of the pilot, then the forward bulkhead with integral tank, plus a separate head cushion are mated to the cockpit. The side consoles are slotted between the two bulkheads with detailed painting guide and decal placement instructions to complete those, then a little wire from your own stocks is threaded through sections of the cockpit, and the kit bulkhead is brought in from behind. The beautifully detailed rudder pedals are a single part that is truly amazing to behold, and it too has its own painting instructions and two decals for the centre of the piece. The kit insert to the tank is slotted into the 3D printed part to complete it, and then you have a choice of how to complete the instrument panel, using a blank panel with two-layer PE dial sections plus some tiny levers, or a detailed printed panel to which you add a decal, or if you’re very brave, paint fully yourself. The small angled coaming with separate tubular gunsight is glued to the top of the coaming to finish off. The cockpit can then be inserted into the fuselage as per the kit instructions, but with a small resin part fixed to the starboard interior, and a pair of tiny pegs are removed from the styrene part. If you are a little anxious about removing the 3D printed parts from their printing bases, and having to deal with all those tendril-like fingers that hold them in place and support them during printing and curing, fret not. As it was the first time I had dealt with a completely 3D printed cockpit from Eduard, I took the precaution of removing the parts from their bases of the previously reviewed later cockpit and preparing them for assembly as part of my build. It didn’t take me long, as I used the new CMK Razor Saw set we reviewed a wee while ago here. I used the square blade chucked all the way over on the fine-toothed blade side, and once I’d cut the attachment points, I snapped off the fingers so I could work on the next side easily. Some parts you can just saw at the base of the supports, but it gets messy and you can’t quite see what you’re cutting. Here’s a quick pic of the mess I was making during the removal process, remembering it isn’t this set, but one very similar: After a little sanding of the forest of tiny ‘pimples’ that were left under parts and the more delicate parts being trimmed by a new #11 blade, the results were very pleasing. There are detailed painting and decaling instructions given throughout the leaflet, in Eduard’s usual Gunze Aqueous and lacquer ranges, using H and C codes respectively. Very highly recommended. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
