SprueMan Posted January 15, 2023 Posted January 15, 2023 22 hours ago, nickc said: Can someone tell me what folks gain from criticising what are otherwise really great kits? I mean; we're talking commercially available plastic model kits out of boxes. If scale and accuracy are that important, why are you even bothering with plastic, how come you're not building to scaled plans from metal, I mean anything else is just going to be wrong isn't it?. It seems to me that folks are judging these kits to a standard that Meng and others are not holding themselves to, it 's like criticising someone for getting a great grade in GSCE History by suggesting that the mark isn't good enough for A-level economics. It just makes no sense to me It's less than £70 for perhaps one of the best F4 kits on the market, and all folks can do is have a downer on it. it's weird, like some odd competition to be the most Judgey Mcjudgy pants Because people have a right to ask for the the best possible. Models, also should be factually accurate representations. If a model maker makes a model of, say a Phantom with Norwegian markings and WWII weapons, then people are right to point that out. A modeller can of course make up his own mind whether the mistake is big enough to put them off buying a kit, or small enough to be fixable with aftermarket, or even if it is so small as to ignore it, but the discussion is valid. 1
Tokyo Raider Posted January 23, 2023 Posted January 23, 2023 Wow! I just picked up the Meng F-4G. I am finding myself opening it up and looking it over many times. It looks like the most BUILDABLE F4 ever. Fuselage and lower wing are only 3 pieces! Fuselage basically one molded piece and has splendid detail on spine that would have been lost if it was two halves! Great design.. I just ordered the Meng F4E. I already have ZM, Tamiya, Hasegawa, Academy F4s. I would assume Tamiya is good, but they are far too slow to market with other versions. Looking forward to getting thru this cateract surgery so I can build models again. This Meng F4G will be one of my first efforts! Great job Meng! 2
Stephen Posted January 25, 2023 Posted January 25, 2023 I received my F-4E today. it looks just as nice as the G. 1
Stephen Posted January 25, 2023 Posted January 25, 2023 The F-4G is in stock and available at Creative Models.
Nacho_73 Posted January 27, 2023 Posted January 27, 2023 Hi .... this is my first post to. Can I use this Meng F-4E to made a Viet Nam bird? thanks a lot
Steve McArthur Posted January 27, 2023 Posted January 27, 2023 16 minutes ago, Nacho_73 said: Hi .... this is my first post to. Can I use this Meng F-4E to made a Viet Nam bird? thanks a lot Slats started appearing in late 1972. So yes you can if you keep it to very late in the war.
Shaun Posted January 28, 2023 Posted January 28, 2023 Are the Meng Panel lines as deep as they appear in some photo's?.
mr_stomach Posted January 28, 2023 Posted January 28, 2023 8 hours ago, Shaun said: Are the Meng Panel lines as deep as they appear in some photo's?. Not Italeri like 🙂 Same as Meng Superhornets and ZM Phantoms.
Masinissa Posted January 29, 2023 Posted January 29, 2023 On 1/27/2023 at 9:56 AM, Nacho_73 said: Hi .... this is my first post to. Can I use this Meng F-4E to made a Viet Nam bird? thanks a lot They were deployed as part of Rivet Haste, but only saw service for a few weeks before America's involvement in the Vietnam War ended. You can find a photo of the first F-4E (sn. 71-0237) with factory installed slats, the TISEO and the 556 cockpit modifications in Squadron Signal's F-4E Walkaround book. No tail code, just RRRRIBIT painted in yellow on the tail near the root. All F-4E's built from serial number 71-0237 and up had thicker belly skin reinforcement and no belly strap. The belly strap was installed on the F-4Es that were modified from hard wings to slatted wings. "Some 71 model F-4Es with LES and TISEO were sent to the 432nd TFRW (later 432nd TFW) under project Rivet Haste. They were assigned to the 555th TFW which had exchanged their F-4Ds for F-4Es either shortly before or during Linebacker II. The Rivet Haste F-4Es were uncoded and initially had RRRRIBIT in yellow on the tail, which was later painted out and just the fin cap was painted green. From Smoke Trails, Vol. 3 # 4, Tail Codes, 432 TFRW, by Harley Copic. By 1975, when Saigon fell, I'm sure that the F-4Es still flying in Thailand had the LES installed. Most of them were later sent to Clark and Korea." Meng's F-4E will need a TISEO. I'm sure the aftermarket makers will be 3D printing one up shortly. 1 1
Nacho_73 Posted February 6, 2023 Posted February 6, 2023 On 15/1/2023 at 13:29, Mascota said: ¡Hola!. Esta es mi primera publicación en este increíble foro. ¿Puedo usar este modelo para hacer un avión israelí de Yom Kippur de 1973? He visto una hermosa hoja DXM con marcas IDF. ¡Gracias! Is it possible to make a Hellenic version with this model? Any suggestions for decals?
Creepy Pete Posted February 6, 2023 Posted February 6, 2023 @Nacho_73 Looks like pretty much everything you need for a pre-update Hellenic F-4E is in the box. I recently bought these decals, and they are very nice. You can also get them without the booklet. https://the48ers.com/f-4e-classic-hellenic-greek-airforce-decals-deluxe-edition.html
Hook Posted February 7, 2023 Posted February 7, 2023 15 hours ago, Nacho_73 said: Is it possible to make a Hellenic version with this model? Yes, the Greek flew slatted E's. Cheers, Andre
arnobiz Posted February 12, 2023 Posted February 12, 2023 Doed anyone know if the Meng fuselage parts are the same between E and G? I would thing so but cannot find positive confirmation anywhere 🤔 Thank you, Arnaud
Homebee Posted February 26, 2023 Author Posted February 26, 2023 The most wanted add ons are available by BAM ! - McDD F-4E Phantom II - TISEO Two 3D-printed parts and one clear lens, sized for the Meng 1/48 F-4E Phantom II kit. https://bam-models.com/product/1-48-f-4e-tiseo-for-meng/ - McDD F-4E/G/FG Phantom II - Belly strap reinforcement plates Adhesive belly strap sized for the Meng 1/48 F-4E and F-4G Phantom II kits. https://bam-models.com/product/1-48-f-4e-g-fg-belly-strap-reinforcement-plate-for-meng/ V.P. 4 1
Ben Brown Posted February 26, 2023 Posted February 26, 2023 Nice! That lower aft fuselage detail is now the only thing giving me pause about the F-4E kit. Ben
Homebee Posted February 26, 2023 Author Posted February 26, 2023 In box review in your favourite forum - ref. LS-015 - McDonnel Douglas F-4G Phantom II - WildWeasel https://www.britmodeller.com/forums/index.php?/topic/235121876-mcdonnell-douglas-f-4g-phantom-ii-wild-weasel-ls-015-148/ V.P. 1
alt-92 Posted February 26, 2023 Posted February 26, 2023 7 hours ago, Homebee said: The most wanted add ons are available by BAM ! Awesomesauce. Only thing remaining is the one-piece windscreen, but I guess that's a bit too niche
Nocoolname Posted February 26, 2023 Posted February 26, 2023 9 hours ago, Homebee said: The most wanted add ons are available by BAM ! - McDD F-4E Phantom II - TISEO Two 3D-printed parts and one clear lens, sized for the Meng 1/48 F-4E Phantom II kit. https://bam-models.com/product/1-48-f-4e-tiseo-for-meng/ - McDD F-4E/G/FG Phantom II - Belly strap reinforcement plates Adhesive belly strap sized for the Meng 1/48 F-4E and F-4G Phantom II kits. https://bam-models.com/product/1-48-f-4e-g-fg-belly-strap-reinforcement-plate-for-meng/ V.P. Cool! Just ordered one. Now just need my seats, decals and hopefully a 3D cockpit in the near future.
Homebee Posted February 27, 2023 Author Posted February 27, 2023 And a dedicated Hypersonic Models TISEO is also on approach. Source: https://www.facebook.com/hypersonicmodels/posts/pfbid02FuWFC7Q2MMCSUr9ebKAGA3Cube4mNSmBtjbJP5PPgoKiPbMcGLxUyfYg41KHnbbAl V.P. 3
Shaun Posted February 27, 2023 Posted February 27, 2023 Did any of the Hasegawa 1/48th F-4's come with TISEO?. If not i guess these new sets with fit the older Hasegawa kits.
Boman Posted February 27, 2023 Posted February 27, 2023 1 hour ago, Shaun said: Did any of the Hasegawa 1/48th F-4's come with TISEO?. Yes
Shaun Posted February 27, 2023 Posted February 27, 2023 2 hours ago, Boman said: Yes Do you know which kits, i'd guess the E's?
Corey in Colorado Posted February 28, 2023 Posted February 28, 2023 4 hours ago, Shaun said: Do you know which kits, i'd guess the E's? check here:https://modelingmadness.com/splfeat/kr/has48d.htm looks like sprue M and M* has the tiseo on it. Just search the list of kits for these sprues. 1
Ben Brown Posted February 28, 2023 Posted February 28, 2023 11 hours ago, Shaun said: Do you know which kits, i'd guess the E's? The slatted F-4E kits came with the TISEO. The Republic of Korea boxing included a resin LORAN doghouse antenna seen on F-4Es with the ARN-101 mod. Ben
