Andrew D Jolly Rogers guy Posted September 16, 2022 Share Posted September 16, 2022 Are there any aftermarket gun barrels that would work for a 1/72 Mirage F.1? Found the Quickboost ones for the Mirage III but they're 1/48. Have also found the Staghound metal ones but not sure they're correct for my build. Maybe I could cheat with A-4 guns? Link to comment Share on other sites More sharing options...
drake122 Posted September 16, 2022 Share Posted September 16, 2022 I just used hypodermic needles.🤷♂️ 1 Link to comment Share on other sites More sharing options...
Selwyn Posted September 16, 2022 Share Posted September 16, 2022 4 hours ago, Andrew D Jolly Rogers guy said: Are there any aftermarket gun barrels that would work for a 1/72 Mirage F.1? Found the Quickboost ones for the Mirage III but they're 1/48. Have also found the Staghound metal ones but not sure they're correct for my build. Maybe I could cheat with A-4 guns? You are looking at something tiny, 30mm calibre works out to 0.41mm in 1/72 so you are looking at less than 1mm external diameter of the barrel in 1/72. I would go for a hypodermic needle as well but even that is probably oversize! Selwyn Link to comment Share on other sites More sharing options...
Andrew D Jolly Rogers guy Posted September 16, 2022 Author Share Posted September 16, 2022 Ok, I should point out they're not just tubular-looking, they have a lot more to them. See: 1 Link to comment Share on other sites More sharing options...
drake122 Posted September 16, 2022 Share Posted September 16, 2022 Honestly, translated to 1/72nd scale, those additional details seem quite pointless. 1 Link to comment Share on other sites More sharing options...
Julien Posted September 16, 2022 Share Posted September 16, 2022 6 hours ago, Andrew D Jolly Rogers guy said: Ok, I should point out they're not just tubular-looking, they have a lot more to them. See: they do, 1 Link to comment Share on other sites More sharing options...
Andrew D Jolly Rogers guy Posted September 16, 2022 Author Share Posted September 16, 2022 8 hours ago, drake122 said: Honestly, translated to 1/72nd scale, those additional details seem quite pointless. With respect, I'd think that it's up to the individual builder to determine how much detail they wish to attempt. What's "pointless" for one person may be someone else's total enjoyment. If you think my level of detail is pointless, then I'm sorry. 2 Link to comment Share on other sites More sharing options...
Julien Posted September 17, 2022 Share Posted September 17, 2022 10 hours ago, Andrew D Jolly Rogers guy said: With respect, I'd think that it's up to the individual builder to determine how much detail they wish to attempt. What's "pointless" for one person may be someone else's total enjoyment. If you think my level of detail is pointless, then I'm sorry. 100% its your build and it upto you. If doing an F.1 these might help; Link to comment Share on other sites More sharing options...
Selwyn Posted September 17, 2022 Share Posted September 17, 2022 16 hours ago, Julien said: they do, For info, That is just the blast suppressor fitted on the end of the barrel. Selwyn Link to comment Share on other sites More sharing options...
junglierating Posted September 17, 2022 Share Posted September 17, 2022 22 minutes ago, Selwyn said: For info, That is just the blast suppressor fitted on the end of the barrel. Selwyn Spoken like a true bombhead geek 👍 1 Link to comment Share on other sites More sharing options...
Selwyn Posted September 17, 2022 Share Posted September 17, 2022 1 minute ago, junglierating said: Spoken like a true bombhead geek 👍 I resemble that remark! Selwyn 1 1 Link to comment Share on other sites More sharing options...
exdraken Posted September 18, 2022 Share Posted September 18, 2022 On 9/16/2022 at 5:32 AM, Andrew D Jolly Rogers guy said: Are there any aftermarket gun barrels that would work for a 1/72 Mirage F.1? Found the Quickboost ones for the Mirage III but they're 1/48. Have also found the Staghound metal ones but not sure they're correct for my build. Maybe I could cheat with A-4 guns? Be carefully the ones for the Mirage III are basically just tubes! For the F1 and M2000 it is what you show above. In 48 you get them from relight in their F1 upgrade set. In 72 I really have no idea if at all.. Maybe scratch the with a base tube and a larger diameter sleeve and some CA glue? Or cut some Master pitot tubes? That is was Special Hobby did on their kit https://www.modellversium.de/kit/bilder/3/4/9/13349-217030.jpg 1 Link to comment Share on other sites More sharing options...
