Gisbod Posted September 13, 2022 Share Posted September 13, 2022 Hello all, I have a dremel drill - the chuck goes up to 3.2mm - most of my accessories are just bigger than that, I can’t seem to find a larger chuck anywhere? Any ideas? thanks Guy Link to comment Share on other sites More sharing options...
Mike Posted September 13, 2022 Share Posted September 13, 2022 Yup. There's an aftermarket chuck that's just like an old skool drill chuck, available allez over the platz. https://amzn.eu/d/8tQv4g2 I'd rather buy from someone else, but that should give you a hint Link to comment Share on other sites More sharing options...
Gisbod Posted September 13, 2022 Author Share Posted September 13, 2022 6 minutes ago, Mike said: Yup. There's an aftermarket chuck that's just like an old skool drill chuck, available allez over the platz. https://amzn.eu/d/8tQv4g2 I'd rather buy from someone else, but that should give you a hint that’s great Mike, but it’s a bit confusing.. says it accepts shanks up to 3.2mm then later on says clamping range 0.8mm-6.5mm? Guy Link to comment Share on other sites More sharing options...
Mike Posted September 13, 2022 Share Posted September 13, 2022 I tried to measure mine, but the batteries on my calipers chose today to die. I'll have to look some new ones up, but by shoving drill-bits in there, I'd say you can put Almost 3.5mm in there. It's more use for smaller diameter tools, and speed of changing them TBH, if you're trying to drill anything bigger than 3.5mm, you probably need the torque of a proper drill. Remember that the Dremel is a motor tool Link to comment Share on other sites More sharing options...
Gisbod Posted September 13, 2022 Author Share Posted September 13, 2022 7 minutes ago, Mike said: I tried to measure mine, but the batteries on my calipers chose today to die. I'll have to look some new ones up, but by shoving drill-bits in there, I'd say you can put Almost 3.5mm in there. It's more use for smaller diameter tools, and speed of changing them TBH, if you're trying to drill anything bigger than 3.5mm, you probably need the torque of a proper drill. Remember that the Dremel is a motor tool It’s just the standard drill bit accessories that you get in modelling shops.. they’re only fractionally larger than the 3.2mm.. Link to comment Share on other sites More sharing options...
Gisbod Posted September 14, 2022 Author Share Posted September 14, 2022 Just for closure, I’m giving up on this as I can’t find one! I think the easiest option is to buy a Dremel accessory set… If you can’t beat ‘em, join ‘em 😆 Guy Link to comment Share on other sites More sharing options...
bmwh548 Posted September 15, 2022 Share Posted September 15, 2022 The original Dremel chuck can fit shanks that are only marginally bigger than 3.2mm in diameter. Just tried to fit a 3.5mm drill bit and it aaaalmost fits. So my guess would be 3.3-3.4mm maximum shank diameter. There's aftermarket chucks that can go up to 6.5mm, but I have no idea if they'll actually fit your Dremel tool (the thread and diameter on the tool's shank isn't universal). 1 Link to comment Share on other sites More sharing options...
