infofrog Posted September 5, 2022 Share Posted September 5, 2022 Meng F/A_18F 1/48 scale build Not sure on the theme yet Always start with Dawn soap bath Rick 10 Link to comment Share on other sites More sharing options...
coneheadff Posted September 5, 2022 Share Posted September 5, 2022 Started that one a while ago, but then Covid hit me full force and at the end "normal life" killed my MOJO. Hope I can finish it one day...sooner than later My F/A-18F build 1 1 Link to comment Share on other sites More sharing options...
Thom216 Posted September 5, 2022 Share Posted September 5, 2022 Shiny, clean, ready. 1 Link to comment Share on other sites More sharing options...
Bell209 Posted September 6, 2022 Share Posted September 6, 2022 I have one of these on order to do as a 6SQN RAAF bird at some point. I'll be watching this thread closely to see the hurdles! 2 Link to comment Share on other sites More sharing options...
infofrog Posted September 6, 2022 Author Share Posted September 6, 2022 Could someone tell what part # A37 A36 or A39 A38 is ? what part I need to use here . Not sure what parts to use here Rick 1 Link to comment Share on other sites More sharing options...
Peter W Posted September 6, 2022 Share Posted September 6, 2022 Hi Infofrog, The parts that you are referring to are the bard stacks or environmental control system exhaust vents to be accurate. Parts 38 & 39 were for Hornets pre block 26 ( pre Bu No 166420). Parts 36 & 37 are for Hornets built after this. Depending on the aircraft that you are building then you will fit the appropriate ones but some of the test squadron (China Lake / Patuxent River) early aircraft were retrofitted with the later stacks. The Modern Super Hornet Guide, Jake Melampy, Reid Air Publications) is a great source of information if you can find it. Pete 1 4 Link to comment Share on other sites More sharing options...
infofrog Posted September 6, 2022 Author Share Posted September 6, 2022 1 hour ago, Peter W said: Hi Infofrog, The parts that you are referring to are the bard stacks or environmental control system exhaust vents to be accurate. Parts 38 & 39 were for Hornets pre block 26 ( pre Bu No 166420). Parts 36 & 37 are for Hornets built after this. Depending on the aircraft that you are building then you will fit the appropriate ones but some of the test squadron (China Lake / Patuxent River) early aircraft were retrofitted with the later stacks. The Modern Super Hornet Guide, Jake Melampy, Reid Air Publications) is a great source of information if you can find it. Pete Thank you go info rick Link to comment Share on other sites More sharing options...
infofrog Posted September 7, 2022 Author Share Posted September 7, 2022 14 hours ago, Peter W said: Hi Infofrog, The parts that you are referring to are the bard stacks or environmental control system exhaust vents to be accurate. Parts 38 & 39 were for Hornets pre block 26 ( pre Bu No 166420). Parts 36 & 37 are for Hornets built after this. Depending on the aircraft that you are building then you will fit the appropriate ones but some of the test squadron (China Lake / Patuxent River) early aircraft were retrofitted with the later stacks. The Modern Super Hornet Guide, Jake Melampy, Reid Air Publications) is a great source of information if you can find it. Pete What would this build need for jolly build thanks Link to comment Share on other sites More sharing options...
Peter W Posted September 7, 2022 Share Posted September 7, 2022 Hi Rick, If I read the Bu No correctly (166620) then this is a later than block 26 Hornet and you would need parts 36 & 37. Pete 2 Link to comment Share on other sites More sharing options...
infofrog Posted September 7, 2022 Author Share Posted September 7, 2022 43 minutes ago, Peter W said: Hi Rick, If I read the Bu No correctly (166620) then this is a later than block 26 Hornet and you would need parts 36 & 37. Pete Thank you Link to comment Share on other sites More sharing options...
infofrog Posted September 7, 2022 Author Share Posted September 7, 2022 little glue up Rick 3 Link to comment Share on other sites More sharing options...
infofrog Posted September 7, 2022 Author Share Posted September 7, 2022 3 Link to comment Share on other sites More sharing options...
infofrog Posted September 8, 2022 Author Share Posted September 8, 2022 badger white primer Rick Alclad Steel 3 Link to comment Share on other sites More sharing options...
infofrog Posted September 9, 2022 Author Share Posted September 9, 2022 little update . The fit is really good so far .Love the detail Rick 8 Link to comment Share on other sites More sharing options...
exdraken Posted September 9, 2022 Share Posted September 9, 2022 nice work! 1 Link to comment Share on other sites More sharing options...
phildagreek Posted September 10, 2022 Share Posted September 10, 2022 Looks good. This is very slowly working it’s way up my build pile so I’m going to pay close attention. What’s the quality been like so far? 1 Link to comment Share on other sites More sharing options...
Biggles87 Posted September 10, 2022 Share Posted September 10, 2022 Looks like a nice kit so far, not too keen on the illuminated MFD screens though, do you get a switched off variety? John. 1 Link to comment Share on other sites More sharing options...
infofrog Posted September 10, 2022 Author Share Posted September 10, 2022 2 hours ago, Biggles87 said: Looks like a nice kit so far, not too keen on the illuminated MFD screens though, do you get a switched off variety? John. I used what the kit called for . The screen is simple . I guess I'm not sure what u mean by switch off . Sorry Link to comment Share on other sites More sharing options...
infofrog Posted September 10, 2022 Author Share Posted September 10, 2022 The intake fit not good . I had to sand and file to get this to fit Rick 1 Link to comment Share on other sites More sharing options...
infofrog Posted September 10, 2022 Author Share Posted September 10, 2022 2 Link to comment Share on other sites More sharing options...
infofrog Posted September 10, 2022 Author Share Posted September 10, 2022 The fit on the other side still not good 2 Link to comment Share on other sites More sharing options...
infofrog Posted September 11, 2022 Author Share Posted September 11, 2022 i had to use little plastic card to fill small gaps . Now little sanding I should be good Rick 1 Link to comment Share on other sites More sharing options...
infofrog Posted September 11, 2022 Author Share Posted September 11, 2022 Applied black primer to see how this looks. Also re scribed couple lines . I'm happy Rick 1 Link to comment Share on other sites More sharing options...
infofrog Posted September 12, 2022 Author Share Posted September 12, 2022 I am working on bring the 2 fuselage together . As you can see this area needs a little sanding to make fit .No biggie Rick 1 Link to comment Share on other sites More sharing options...
infofrog Posted September 12, 2022 Author Share Posted September 12, 2022 Now I'm slowing gluing these 2 parts together 2 Link to comment Share on other sites More sharing options...
