aust202 Posted September 2, 2022 Share Posted September 2, 2022 Just wondered how people display their “flying” models. All the ones I have done so far have been static with the wheels down but I’m about to start a Tornado I’d like to display as flying. I’ve seen some revell plastic stands but the reviews on Amazon are not very good and airfix do some that are slightly better reviewed. Are there some stands that anyone would recommend? thanks Link to comment Share on other sites More sharing options...
dnl42 Posted September 2, 2022 Share Posted September 2, 2022 You can make a stand with wood, paint, an optional photograph, and acrylic rod. Plastic or brass tubing in the model helps keep it steady on the stand. 1/144 F-16A This has a painted base with an image from the interwebs professionally printed on photo paper. You may also be able to print on photo paper at home. 1/48 X-37B For this base, I created the base image on my computer (background image + logo + caption) and then had it professionally printed. 1/144 F-4F As above, a generated image from graphic elements (squadron badge and spook) found on the interwebs and some work in Gimp. In all cases, the base was cut, sanded, and painted. The image was glued on using rubber cement. The acrylic rod was readily bent using a heat gun (a very powerful hair dryer). HTH -- dnl 3 Link to comment Share on other sites More sharing options...
Alex Gordon Posted September 3, 2022 Share Posted September 3, 2022 You can do a lot with a lump of rock and a wire coathanger. 1 1 Link to comment Share on other sites More sharing options...
Black Knight Posted September 3, 2022 Share Posted September 3, 2022 15 hours ago, aust202 said: . . . I’ve seen some revell plastic stands but the reviews on Amazon are not very good and airfix do some that are slightly better reviewed. Are there some stands that anyone would recommend? . . . Just do not pay the absolutely silly money people are asking for them on ebay Work up to having at least 100 honest postings on here and you can then put a 'Wanted' in the 'Wants' section of the marketplace 2 Link to comment Share on other sites More sharing options...
Rob de Bie Posted September 7, 2022 Share Posted September 7, 2022 To my eye, a 'vertical pole' does not fit the picture of a fast-moving object. And for a reason I cannot put my finger on, I don't like a wire going up the exhaust. Here's my next-best solution. Rob 2 Link to comment Share on other sites More sharing options...
