F/A-18F & EA-18G Blocks 25+ (QD48243 for Meng)
1:48 Quinta Studios
When Quinta’s innovative products first came to our attention, they caused quite a stir, as well they should.  The replacement Instrument Panels and internal details are mind-boggling to look at, because we’re used to seeing simplified styrene instrument panels, or Photo-Etch Brass panels with either two layers of etch, or laminated parts that can be tricky to glue together, even though they are pre-painted for your ease.  But decals?  These aren’t your run-of-the-mill decals though, they’re 3D printed in many layers and colours on a flat carrier film, having as much in the way of elevation as is needed to complete a realistic panel printed in the correct colours, complete with shiny dial faces and metallic-effect hardware, and often including cushions and seat belts in the set.
Each set arrives in a Ziploc bag with a folded instruction booklet protecting the decals, which are also separately bagged, so they should reach you in good condition.  The pictorial instructions are printed on glossy paper, and are shown in full colour as befits the awesomeness of the sets, showing exactly where each part should go on the actual model, so there’s no confusion due to the “pictures speak a thousand words” maxim.  Additional hints and instructions are also included, marking out parts needing bases, kit parts that are used or replaced and other useful tips.  The technical instructions in the text-based, giving additional tips to the new user about maximising adhesion and preventing lift at the edges by wicking in super glue.
Although you are advised to use Super Glue (CA) to attach the decals to the surface permanently, preparation is much the same as your standard decal, but you will need to remove any raised detail that would be underneath the location depicted in the instructions, and some new parts will need small backing panels or bases on which to apply the decal.  A slim piece of sheet styrene would perform that task, and painting the edges a matching colour should minimise its appearance or turn it completely invisible.
This set is patterned for the Meng kits of the type later than block 26, which you’ll need to look into yourself, as I’m clueless on that matter.  The set comprises four sheets of decals, containing two beautifully detailed instrument panels with glossy MFD screens, side consoles with plenty of relief, sidewall inserts with cushioned black panels and document bags that have organic-looking creases printed-in, plus two full sets of seatbelts and an actuator loop between the pilot’s knees to get him out of there in an emergency.
Conclusion
The detail on the parts is incredible, even down to the infinitesimal switches, relief of the consoles, deep gloss in the MFDs and overall impressive crispness of the set.  Any cockpit with a Quinta set installed really needs a crystal-clear or opened canopy to show off the details, which the Meng kits are able to provide straight from the box.
Very highly recommended.
Review sample courtesy of
