Brandy Posted October 10, 2022 Share Posted October 10, 2022 On 10/2/2022 at 3:31 PM, The Spadgent said: they do get more pronounced during flight but on the ground not so much. But not as dips, the air pressure above the wing in flight is lower so tends to "suck" the fabric up leaving the ribs as the low point! I think the idea that fabric should show ridges is, as Troy says, down to the early kit manufacturers. Ian 4 Link to comment Share on other sites More sharing options...
The Spadgent Posted October 11, 2022 Author Share Posted October 11, 2022 On 09/10/2022 at 13:22, Troy Smith said: Prototypes had all sorts of things, which is why they are prototypes. No pylons are in your reference photo, so I'd fill them, but they likely were set for underwing stores. Aesthetically, I'd say leave them off, as it will show off the aircraft lines better. Note the standard sized roundels I was going on about. Also, the just visible serial is small, probably 4 inch (so just under 2mm high in 1/48th) as seen on the decals above, can you make Z1832... well the is 183 above. I can't see on the photo, but it's likely note, this https://www.hlj.com/1-48-scale-fairey-firefly-mk-i-early-nf-2-azm06395 AZ kit has these decals, though, again, the roundel proportion are wrong.... and the serial lettering look wrong style as well. note, to add to the decals sent by Chris, either paint in the red roundel centre, or use one of these you have Ah, I now note the Trumpeter sheet has "Royal navy Z1832" decals which look OK. You still need the fin flash, but that is a standard marking, available in many kits. 9.3%!!!!! Not surprised. I surprised you can see anything to today though..... HTH T That’s some great advice and super informative. Thanks @Troy Smith again you supply the goods. 😀 I wonder if you can post beer? 🤪 On 09/10/2022 at 15:01, woody37 said: All these little improvements are making a big difference, enjoying seeing it come together Thanks kid. Too kind. On 09/10/2022 at 18:01, bigbadbadge said: Looking good Johnny and coming together well. Great work. Chris Thanks. Looking forward to paint. On 10/10/2022 at 06:54, giemme said: Agreed 100%! The nose vent looks the biz, IMO Ciao Thanks G. On 10/10/2022 at 10:46, SafetyDad said: Johnny, would these be of any use to you? Roy was selling them off at the Nationals some years back and I bought a few packs for Sea Furies etc. Ironically, I don't have any Firefly kits! Yours gratis. Drop me a PM if interested with your address Enjoying your build - great problem-solving and painting skills SD A pound!!!! What a bargain. Thank you so much for the offer but look what I had printed while you were writing that kind offer. Very very kind but I have some now. I’m sure they will find their way to a good home. ❤️ On 10/10/2022 at 14:04, Brandy said: But not as dips, the air pressure above the wing in flight is lower so tends to "suck" the fabric up leaving the ribs as the low point! I think the idea that fabric should show ridges is, as Troy says, down to the early kit manufacturers. Ian Aaah I see. More excellent info. Thanks. 👍 7 Link to comment Share on other sites More sharing options...
The Spadgent Posted October 11, 2022 Author Share Posted October 11, 2022 Good evening. 😀 Thank you all for your kind words and indeed more offers of parts for my little build. 🤩 I’ve said it before and I’ll say it again, you bunch don’t arf warm the cockles. 😇 while I have been away some resin action has been going on. First of I spent a bit of time 3D modelling some bits that I needed: Wheels, cannons, vent covers, wing lamp and some nose vents. After a little while in the resin bath I got the booty. After a bit of sanding of support stubs they turned out ok. A lot better than the kit offerings. 😃 The other bits look ok too. The vent covers even had the wires modelled. They turned out better than I expected. The Hispano cannons. ( Is that right? ) If you zoom you can see the little spring. And the wing lamp. Which is loads better than the kit offering as there wasn’t one. 😫😲 I had to share this. Looks like a couple of resin monsters looming from the gloop.🧟♂️ The nice vents I printed so I get the same arc on each side, Then I sanded and added sprue goo and sanded again. Then blasted with a spot of primer. Not bad. Maybe a tad more sanding but the shape is ok for me. Well that’s that for this update. Thanks for dropping by, have yourselves a splendid week and as always all comments welcome. Johnny. 🐫 26 Link to comment Share on other sites More sharing options...
giemme Posted October 12, 2022 Share Posted October 12, 2022 Amazing 3D prints, Johnny You mentioned using sprue goo for the vents: is that effective on resin too? TIA Ciao 1 1 Link to comment Share on other sites More sharing options...
SafetyDad Posted October 12, 2022 Share Posted October 12, 2022 Your 3D printing is producing some outstanding results there Johnny! Excellent work on those parts. Your wheels look really good - the hub detail and tread pattern is astonishing. I'm pleased to see that you're sorted in that department. SD 1 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted October 12, 2022 Share Posted October 12, 2022 Terrific work play Johnny! Looking fab. Regards, Adrian 1 1 Link to comment Share on other sites More sharing options...
Quiet Mike Posted October 12, 2022 Share Posted October 12, 2022 Well colour me impressed, as always Johnny, fascintating seeing these actual parts being produced from shuffling pixels around in a 3D program! 1 Link to comment Share on other sites More sharing options...
perdu Posted October 12, 2022 Share Posted October 12, 2022 Looking very developed Johnny, quite like magic really. 👍 1 1 Link to comment Share on other sites More sharing options...
LorenSharp Posted October 12, 2022 Share Posted October 12, 2022 Excellent job on the new parts Johnny. Especially the wheels and the grating. Thin rods are always problematic. I learned that keeping anything over a diameter of 200um threshold very rarely failed to print, under that and it was a 50-50 roll of the dice. 1 Link to comment Share on other sites More sharing options...
Brandy Posted October 12, 2022 Share Posted October 12, 2022 1 minute ago, LorenSharp said: a 50-50 roll of the dice. Surely you mean a 50-50 flip of the coin? I think dice have 6 sides.... Being pedantic. Time for a beer! Ian 4 Link to comment Share on other sites More sharing options...
Max Headroom Posted October 12, 2022 Share Posted October 12, 2022 Where the heck have I been? Eight pages late! Another masterclass in solid, honest to goodness modelling. And the sorcery of 3D printing too. Trevor 1 Link to comment Share on other sites More sharing options...
mahavelona Posted October 12, 2022 Share Posted October 12, 2022 Amazing work. @wellsprop there is some exciting 3d printing action you will enjoy here 1 Link to comment Share on other sites More sharing options...
wellsprop Posted October 12, 2022 Share Posted October 12, 2022 The landing lamps are lovely, I'd recommend getting one of these pens to paint the chrome bit (the paint can be decanted from the pen). I'm looking forward to seeing them built https://www.amazon.co.uk/Molotow-Liquid-Chrome-Pump-Marker/dp/B01E7EFSVU/ref=sr_1_1?crid=GYI877N8YXHM&keywords=molotow+1mm&qid=1665603031&qu=eyJxc2MiOiIxLjY1IiwicXNhIjoiMS40NiIsInFzcCI6IjEuMDAifQ%3D%3D&sprefix=molotow+1mm%2Caps%2C93&sr=8-1 1 Link to comment Share on other sites More sharing options...
The Spadgent Posted October 12, 2022 Author Share Posted October 12, 2022 13 hours ago, giemme said: Amazing 3D prints, Johnny You mentioned using sprue goo for the vents: is that effective on resin too? TIA Ciao Yeah. I just use it as filler. Levels really well. And Thankyou my friend. 😃 13 hours ago, SafetyDad said: Your 3D printing is producing some outstanding results there Johnny! Excellent work on those parts. Your wheels look really good - the hub detail and tread pattern is astonishing. I'm pleased to see that you're sorted in that department. SD Thank you. Too kind. Trust me I would have taken you up on your offer had I not decided to spend Sunday in front of the computer. 😉 10 hours ago, AdrianMF said: Terrific work play Johnny! Looking fab. Regards, Adrian Thanks Adrian. 🤩 7 hours ago, Quiet Mike said: Well colour me impressed, as always Johnny, fascintating seeing these actual parts being produced from shuffling pixels around in a 3D program! I know right. It still amazes me. 4 hours ago, perdu said: Looking very developed Johnny, quite like magic really. 👍 Thanks Bill. 3 hours ago, LorenSharp said: Excellent job on the new parts Johnny. Especially the wheels and the grating. Thin rods are always problematic. I learned that keeping anything over a diameter of 200um threshold very rarely failed to print, under that and it was a 50-50 roll of the dice. I was quite surprised myself that they printed so well. 😇 3 hours ago, Brandy said: Surely you mean a 50-50 flip of the coin? I think dice have 6 sides.... Being pedantic. Time for a beer! Ian Mmmm beer. 1 hour ago, Max Headroom said: Where the heck have I been? Eight pages late! Another masterclass in solid, honest to goodness modelling. And the sorcery of 3D printing too. Trevor Thank you sir. Welcome. 57 minutes ago, mahavelona said: Amazing work. @wellsprop there is some exciting 3d printing action you will enjoy here Thanks. 21 minutes ago, wellsprop said: The landing lamps are lovely, I'd recommend getting one of these pens to paint the chrome bit (the paint can be decanted from the pen). I'm looking forward to seeing them built https://www.amazon.co.uk/Molotow-Liquid-Chrome-Pump-Marker/dp/B01E7EFSVU/ref=sr_1_1?crid=GYI877N8YXHM&keywords=molotow+1mm&qid=1665603031&qu=eyJxc2MiOiIxLjY1IiwicXNhIjoiMS40NiIsInFzcCI6IjEuMDAifQ%3D%3D&sprefix=molotow+1mm%2Caps%2C93&sr=8-1 Thanks. I do have one of those pens I may have to decant as is seems to have gone a bit “funny” over the years. 1 Link to comment Share on other sites More sharing options...
corsaircorp Posted October 12, 2022 Share Posted October 12, 2022 Lovely job John !! I stay in awe !! That will be a Spadpeter Firebox !! This 3 D magic of your is really improving the kit !! Congratulations !! Impressed CC 1 Link to comment Share on other sites More sharing options...
Troy Smith Posted October 12, 2022 Share Posted October 12, 2022 On 11/10/2022 at 19:39, The Spadgent said: After a bit of sanding of support stubs they turned out ok. A lot better than the kit offerings. 😃 these look superb.... for a late Mk.I or Mk.IV Note the barracudacast ones are 5 spoke and smooth. this is captioned as Fairey Firefly F.I Z1908 , 5 spoke and smooth.... In the case of Spitfires, the 4 spoke were stronger, and could take a greater load, 5 being replace by 4 spoke is also seen on the Hawker Tempest. I assume the same for the Firefly. Block tread become more used with the wider use of concrete runways. HTH On 11/10/2022 at 19:39, The Spadgent said: The Hispano cannons. ( Is that right? ) yes. Hispano Mk.II, the Mk.I had flat coils. what was fitted to what is one of my Hurricane questions, as both are, but seems the Mk.II became the common type as the war went on. They were hulking great guns as originally designed as 'motor cannon' they got rework and the Mk.V as used on the Tempest was more compact. this looks basically correct https://en.wikipedia.org/wiki/Hispano-Suiza_HS.404 Lovely 3-D printing work.... cheers T 4 1 Link to comment Share on other sites More sharing options...
SafetyDad Posted October 13, 2022 Share Posted October 13, 2022 The wheels are here for you if you decide to 'go smooth'. No worries. SD 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted October 13, 2022 Share Posted October 13, 2022 Great printing Johnny,those bits look fantastic, the lights and grillslook phenomenal. Chris 1 Link to comment Share on other sites More sharing options...
opus999 Posted October 14, 2022 Share Posted October 14, 2022 Wow, those 3D wheels are incredible! I mean, the rest of the parts are incredible too, but for some reason the wheels stand out to me. Nice job on that little nose intake too -- beautiful! 1 Link to comment Share on other sites More sharing options...
The Spadgent Posted October 16, 2022 Author Share Posted October 16, 2022 On 12/10/2022 at 21:09, corsaircorp said: Lovely job John !! I stay in awe !! That will be a Spadpeter Firebox !! This 3 D magic of your is really improving the kit !! Congratulations !! Impressed CC Thanks Alain. Thank you for the kind words. 🥰 On 12/10/2022 at 23:26, Troy Smith said: these look superb.... for a late Mk.I or Mk.IV Note the barracudacast ones are 5 spoke and smooth. this is captioned as Fairey Firefly F.I Z1908 , 5 spoke and smooth.... In the case of Spitfires, the 4 spoke were stronger, and could take a greater load, 5 being replace by 4 spoke is also seen on the Hawker Tempest. I assume the same for the Firefly. Block tread become more used with the wider use of concrete runways. HTH yes. Hispano Mk.II, the Mk.I had flat coils. what was fitted to what is one of my Hurricane questions, as both are, but seems the Mk.II became the common type as the war went on. They were hulking great guns as originally designed as 'motor cannon' they got rework and the Mk.V as used on the Tempest was more compact. this looks basically correct https://en.wikipedia.org/wiki/Hispano-Suiza_HS.404 Lovely 3-D printing work.... cheers T Thanks Troy. All your info is slowly sinking in. You’re an absolute star. 🤩 On 13/10/2022 at 17:38, SafetyDad said: The wheels are here for you if you decide to 'go smooth'. No worries. SD Thank you. So kind. 😀 On 13/10/2022 at 18:59, bigbadbadge said: Great printing Johnny,those bits look fantastic, the lights and grillslook phenomenal. Chris Thanks Chris. On 14/10/2022 at 17:47, opus999 said: Wow, those 3D wheels are incredible! I mean, the rest of the parts are incredible too, but for some reason the wheels stand out to me. Nice job on that little nose intake too -- beautiful! Thanks. Wheels are quite easy to reproduce s they’re round. The tread is more problematic but I find it’s getting them to print that is my only set back. Figuring out supports and what orientation is not my strong point. 4 Link to comment Share on other sites More sharing options...
The Spadgent Posted October 16, 2022 Author Share Posted October 16, 2022 Rise and shine. Beautiful Autumn morning out there. A lovely and strangely relaxing weekend. It was my daughters sixteenth birthday. (Yesterday) birthdays get easier as they get older. 🙃 Also my father in-laws seventy sixth. We went to see a pink Floyd tribute act in Kidderminister on Friday. Cor the town hall in Kiddy is awesome, small but beautifully formed. The band were really good too. The female vocalist on the dark side tracks was especially fantastic! Any hoo. I guess you’re here for the fly and not my life story. 😉 As the house got cleaned on Friday I had most of Saturday to myself so….. Here is a shot of the kit wheel and the new one side by side. I kept with the four spoked option but am more happy now I know why that’s to @Troy Smith’s excellent info Bank. 👌 I couldn’t put off the masking any longer so. Not too bad really. I added some extra little details before closing up. Wires in the rear. And the gun sight got its glass/Perspex added along with some light weathering to my printed part. I decanted some silver from my molotow pen and painted the new lamps. (Always good to have a spare. ❤️ And then popped in place. Then covered for all time with the clear bit. Jeez I must have lost this part about six or seven times while gluing on. I aware at one point I felt like a magician doing sleight of hand. I just did some kind of little shuffle while losing grip focus and POP! Gone! 😭😩 Twenty minutes later to no avail I gave up and luckily decided to check the turn up on my jeans. Yup, there it was. 🤣 So here it now stays. Phew. Things are getting dangerously close to paint. canopies on with Gators grip and sprayed the internal colour. And tail stuck in place. I’ll fit the positioned flaps after the fact. Holes filled with goop and wells and vents masked. (Yes I have masked the vent) 😉 The little tail wheel got glued and a bit of goo added to fill a slight sink hole. I clipped off the bits and bobs and added them to the styrene of anticipation. All this stuff will get primed soon and I can get on with the paint. still have the spinner and the UC to build but that’s it. Came together all of a sudden. 🤩🤩 Thanks for dropping by. I hope you’re having a nice relaxing weekend too. Happy modelling chums. Johnny. 20 Link to comment Share on other sites More sharing options...
Rémi Posted October 16, 2022 Share Posted October 16, 2022 Your 3D job is very impressive How many time you have spent to build these pieces ? 1 Link to comment Share on other sites More sharing options...
giemme Posted October 16, 2022 Share Posted October 16, 2022 57 minutes ago, The Spadgent said: Things are getting dangerously close to paint. Indeed! Ciao 2 Link to comment Share on other sites More sharing options...
The Spadgent Posted October 16, 2022 Author Share Posted October 16, 2022 54 minutes ago, Rémi said: Your 3D job is very impressive How many time you have spent to build these pieces ? Thank you. A few hours I think. I did all the bits in one sitting. The print in the Elegoo too about one and a half hours but I made lots of spares. 😀 6 minutes ago, giemme said: Indeed! Ciao I know right. 🤩 1 Link to comment Share on other sites More sharing options...
81-er Posted October 16, 2022 Share Posted October 16, 2022 Very nice, Johnny! The light looks superb, as do your replacement wheels. The kit ones are definitely somewhat James 1 Link to comment Share on other sites More sharing options...
