AS90 spg
Hamden
1 hour ago, Bullbasket said:
Somebody has nicked my modelling mojo
Hope you find it soon John.
IDF M109A2. Your build is making me lean in that direction.
Go on you know you want to..................................................................
Thanks for your kind comments John more soon hopefully
            Stay safe           Roger
great work... do like seeing someone take a shell and fill it out - and enjoy doing it myself... looking forward to more
More excellent progress Roger. I agree with the others, the mesh grills do look very impressive. :thumbsup:
Kind regards,
Stix
  • 3 weeks later...
Its been awhile since I posted anything on this one but family problems and lack of mojo has slowed this down a bit although I have had the odd five minutes here and there. I have added some basic detail to the buffer/recuperater cover and also fitted the main gun travel lock after opening out the area where the mechanism is situated and scratched something that looks like the original but is not 100% accurate. Inside the turret I have drawn in the cable runs, added the charge bag holders on the LH side wall and added two cylinders to the roof the purpose of these I can not remember. Next up will most likely be the addition of the cables as they are quite a prominent feature then the various fittings to the side walls and the internal magazine rack etc.
Here are a few pictures to show some very slow progress.
Many thanks to everyone who has commented on and liked what what I have done so far it is very much appreciated
Thanks for stopping by
         Stay safe              Roger
Hi Roger,
Common problems that affect all modelers to a greater or lesser extent... Despite that, it is a small job that had to be done and it is becoming more and more attractive.
Cheers and TC
Francis.👍
Been there, done that and I'm still wearing the T shirt. Hope it all sorts itself out soon.
Meanwhile, you're still making great progress. Nice work Roger.
John.
Thanks to @ivan-o @FrancisGL & @Bullbasket for your comments they are very much appreciated.
Some more work on the AS90 turret with the fresh air pipes added to the commander/gunners side  and a dry fit of some of the many electrical boxes for the various systems found on board.
Some more tiny PE parts have also been added to the hull top. The padding around the turret has also been painted.
Thanks for taking the time to stop by and I hope your own projects are progressing as you would like
              Stay safe                     Roger
Nice to see you doing a bit Roger, it looks good!
Any time at the bench is productive and all helps towards that final product. 👍
Keith 😁
Hi Roger. Glad to see there's been some progress again. Hope everything is okay.
Kind regards,
Stix
Thanks for the comments and encouragement @Keeff @FrancisGL @viper-30 @Bullbasket and @PlaStix it really does make a difference.
Small update in that the electrical boxes on the commander/gunners side have been fitted and painted and the first run of cables has been added. Also now fitted is the RH side/indicator lamp unit in PE, not looking forward to the LH one!
Not much but time is short and it's fiddley bits and pieces that I'm doing at the moment.
            Stay safe            Roger
Know what you mean Roger. I'm in the same boat, so to speak, at the moment. But the good thing is that it's moving forward and will look good when the paint is on.
John.
Hi Roger.
All the kits have this problem, there comes a point where due to difficulty, life, or lack of mojo, it makes the progress very small or boring, but, in the end, it ends up ending.
Francis,👍
As the others have said above, Roger, despite some of the difficulties, it's good that you are getting a bit more done. The payoff will be when you see how well it is all coming together towards the end.
Kind regards,
Stix
            Stay safe            Roger
I share your pain mate😂good to see your still ploughing on👌
First many thanks to @Bullbasket @FrancisGL @PlaStix and @ivan-o for the comments and to all who hit the like button it's very much appreciated and helps to keep me motivated with this project!
This is just a pictorial update to show how things are shaping up, there is still along way to go. The turret is not glued on just rested in place for effect and also to give some idea of what will be visible when completed. Enough waffle here's the pictures
        Stay safe            Roger
  • Like 13
