F4F Undercarriage BRONZE (648779 for Eduard) 1:48
1:48 Eduard Brassin
We’ve just reviewed the super new tool Wildcat from Eduard, and this is one of the many aftermarket sets that they have released at the same time for those that want to increase the level of detail over and above what’s achievable using injection moulded styrene.  As is now usual with Eduard's smaller resin sets, they arrive in a shallow Brassin cardboard box, with the resin parts safely cocooned in bags, and the instructions folded around acting as padding.
This set enhances the styrene landing gear with metal main struts and 3D printed resin supports on one side, utilising some of the kit parts for the other side.  In the box are a pair of cast bronze main struts, which need very little in the way of preparation, just removing the sprue clipping point from the upper tubular section, which is best done with a motor tool and abrasive disc, taking your time so the part doesn’t overheat and you don't go past the moulded-in limit (you can just see this in the pic above).  With that done, the resin parts are removed from their printing bases and glued in place in the same manner as the original kit parts.  The other side of the support is taken from the kit, using parts L1 and L2, as well as the lower supports from the kit, which are parts L6 and L7.  The main benefit of the bronze is strength, but the included 3D printed centreline gear bay doors are a big improvement on the kit parts and are printed as single parts with no fiddly gluing of small bits together.
Very highly recommended.
Review sample courtesy of
