oldmodeler Posted August 12, 2022 Share Posted August 12, 2022 Hello All!, To test making diorama bases for 1/48 WW2 aircraft, I got a 4ft square foam board (,the art board with paper covering) , rolled matt black emulsion over it, it(dried in seconds in our heatwave) 2 coats, then some matt grey rolled on emulsion, then used a felt tip to make the tar fill in between ash-felt / and or concrete blocks , pressing the large Pentel round in to make a slight depression, then rubbing a lot of pastels all over, in very small steps, vacuumed off the access, looks OK. I did the block outlines, large rectangles, all different shapes, plus tar crack repairs the same way, as hardstandings tend to crack. I did the whole thing slightly tapered off the the distance for forced projection. then added a few railway model bushed at the edge. Behind is another 4ft white foam board, out of focus for the sky. Added a few Tamiya 1/48 vehicles, toolboxes etc. plus ICM 1/48 RAF air-persons and: Photographed using a old NIKON D70 and NIKON 35-105 MACRO MANUAL or Tamron 18-200, AUTO + tripod, at minimum aperture and about 1/20 testing, + some, minus some secs to make it look as would be in the era: blurred, under exposed, b/w etc. Added a few Tamiya 1/48 vehicles, toolboxes etc. plus ICM 1/48 RAF air-persons, the 1/56 truck behind that, then 1/72 Wellington III just behind that. I think I got away with it beginners luck. Also did a 1/48 Mozzie and Contrail/Sangar 1/48 Halixax 2 series 1 : Mozzie: Dark, as at night time. Picture taken at what would have been eye-level on the ground from an ERK with a camera. Halifax: this was the biggie, at least 100 hours work: And again, same technique and the Sangar 1/48 Halifax completed as V9977 This one shows all my modeling faults making a vac-u-form: needs blurring I think n: 2 Link to comment Share on other sites More sharing options...
Icabod Posted August 13, 2022 Share Posted August 13, 2022 I think that Halifax looks superb. Something you should be very proud of. Link to comment Share on other sites More sharing options...
oldmodeler Posted August 13, 2022 Author Share Posted August 13, 2022 Hi Icabod, the Halifax is average to poor I think, so many compromises compare to say: HK Lancaster. Some parts were way off shape, but had to be as there was no alternative.Some bits: cockpit canopy etc, are messy and poor. It was big, and I did it for a museum who have a glass cabinet to keep the dust off. All models there are / will be under Glass. The NT RAF Defford museum, near Croome , Worcestershire , is now filling up with equipment relevant to the work there and at RSRE Malvern : H2S , Gee, Oboe, Rebecca etc. Though only very small place, the exhibits apply to us modellers. Croome, near High Green, Worcester, Worcestershire, WR8 9DW https://deffordairfieldheritagegroup.wordpress.com/ https://www.nationaltrust.org.uk/croome/features/raf-defford M Link to comment Share on other sites More sharing options...
