Roland Pulfrew Posted August 7, 2022 Share Posted August 7, 2022 Doing some painting today and was struggling to get the paint to go where I wanted. When I cleaned the brush after use, I noticed this: Any suggestions on the issue? Bent needle? Bent nozzle? Replacement of both required? Any suggestions gratefully appreciated. Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted August 7, 2022 Share Posted August 7, 2022 First give it a really good clean. You can get that effect from a tiny bit of muck on the side (inside) the nozzle. And if you can’t see that the needle and nozzle aren’t bent, they probably aren’t. 1 Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted August 7, 2022 Share Posted August 7, 2022 check the air channels too. clean everything! Link to comment Share on other sites More sharing options...
Casey Posted August 7, 2022 Share Posted August 7, 2022 (edited) And look at needle through some magnifying glass. It may be bent so slight it cant be seen otherwise. Edited August 7, 2022 by Casey 1 Link to comment Share on other sites More sharing options...
Panzersgt Posted December 28, 2022 Share Posted December 28, 2022 Bent needle. Put the needle in a drill so that about 3 inchs are poking out , thats if the chuck is deep enough. stick some 1000 grit wet and dry to a good solid flat surface, a tile or glass is best. then gently run the needle on it at a shallow angle, 1 or 2 degrees until the bur on the end is nice and smooth. Failling that buy a new one. 1 Link to comment Share on other sites More sharing options...
theplasticsurgeon Posted December 29, 2022 Share Posted December 29, 2022 My airbrush had a similar, though less extreme pattern, which I lived with until the nozzle cracked. I replaced the nozzle, needle and aircap (crown) - which sorted it out. I was able to try both needles, which made no difference - so that was straight. Trying both Aircaps revealed the difference. Has the airbrush ever been dropped? 1 Link to comment Share on other sites More sharing options...
