sinnerboy Posted July 28, 2022 Share Posted July 28, 2022 Just about to order a new cheapish airbrush for laying down primers & top coats but need to add a few bits to the order to make up to the post free amount, being the tight bottom that I am. I thought what about a tube of the (for the amount expensive ) Iwata lube. So my Q to you chaps is 1) do you use it? 2) Does it make a diff to smoothness of action & tip dry? 3) Would a little Glycerine added to Acrylic thinners do the same job ( quid a bottle a Tescos) TIA Rick 1 Link to comment Share on other sites More sharing options...
John Laidlaw Posted July 28, 2022 Share Posted July 28, 2022 Avoiding all of the potential double entendres, no. As I put both water-based acrylics, and solvent-based paints through the same airbrushes, I just deep clean them more often, and use beeswax on threads and moving parts. Beeswax doesn't seem to react to anything, and prevents the parts binding up. 1 1 Link to comment Share on other sites More sharing options...
sinnerboy Posted July 28, 2022 Author Share Posted July 28, 2022 beeswax, thats interesting, thanks John 👍 1 Link to comment Share on other sites More sharing options...
Black Knight Posted July 28, 2022 Share Posted July 28, 2022 + 1 for beeswax I also give the needle a rub over with the wax, just the length of the needle which comes and goes through the rear of the paint cup and the part by the pull back lever 1 1 Link to comment Share on other sites More sharing options...
Mark Harmsworth Posted July 28, 2022 Share Posted July 28, 2022 I've had a small bottle for about ten years - it may even have come with my H&S airbrush. I seem to remember it came with some advice about using it if the airbrush was going to be unused for a long time. Not sure that the length of time was defined - but I've never used it. I clean the airbrush thoroughly after each use and that seems to be enough. I use acrylics. That probably doesn't help much does it. 1 1 Link to comment Share on other sites More sharing options...
Ray_W Posted July 28, 2022 Share Posted July 28, 2022 I also use beeswax. A very light smear on needle and moving parts. A little on a finger and wipe through. I also clean the airbrush thoroughly after every use. Iwata's and years of trouble free service. 2 1 Link to comment Share on other sites More sharing options...
malpaso Posted July 28, 2022 Share Posted July 28, 2022 Vaseline does the job for me. Ooerr missus! 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted July 28, 2022 Share Posted July 28, 2022 (edited) Ive been airbrushing since 1988 and have owned six airbrush’s without any real differences in operation since then. I use Iwata air brush oil on my needle(s) after every deep clean. I use beeswax on all of my threads and haven't had anything happen since I started doing that. Edited July 30, 2022 by Corsairfoxfouruncle 1 1 Link to comment Share on other sites More sharing options...
Darknark Posted July 29, 2022 Share Posted July 29, 2022 I just use chapstick, a little on the needle after cleaning. I believe you can use straight glycerine as well, but I have never tried it. Chapshick is cheap and convenient for me. 1 Link to comment Share on other sites More sharing options...
Ray_W Posted July 29, 2022 Share Posted July 29, 2022 22 minutes ago, Darknark said: I just use chapstick, Also what I use - beeswax chapstick 1 1 Link to comment Share on other sites More sharing options...
Werdna Posted August 7, 2022 Share Posted August 7, 2022 Shaver oil is what I use, but only because I found some in the bathroom cupboard. I tend not to lube the mechanisms much, but I do occasionally run the needle through my fingers coated with a drop of shaver oil, which tends to help the action. I would guess any other light oil (sewing machine oil and the like) would be equally fine.. 1 1 Link to comment Share on other sites More sharing options...
sinnerboy Posted August 11, 2022 Author Share Posted August 11, 2022 thanks all Link to comment Share on other sites More sharing options...
Panzersgt Posted December 28, 2022 Share Posted December 28, 2022 Water base personal lubricant. if your feeling brave over the counter at Anne Summers or like me off amazon £5 for 500ml not £5 for 5ml with Iwata written on the side Link to comment Share on other sites More sharing options...
daneel Posted December 28, 2022 Share Posted December 28, 2022 I've always found that polishing the needle works much better than lubing it. Of course, if planning not to use the brush for a longer time, then it is a good idea to lube the moving parts. In that case, I would still clean the brush before first use after a long pause, and shoot a cup of thinner first, before letting any paint through. Link to comment Share on other sites More sharing options...
