FortyEighter Posted July 28, 2022 Share Posted July 28, 2022 This build started life in the Bomber/Strike/Ground Attack GB build thread here (brief as it is). I had some issues with the intakes, so built up another fuselage but then the cockpit section wasn't a great fit to the main fuselage so it went on the shelf of shame! Anyway the troublesome joint has now been smoothed and shouldn't be very noticeable after priming; so this is where the model has got to: In the absence of a 25% rule I'm assuming this will be an acceptable entry and it will certainly comply with rule 9 Mike 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted July 28, 2022 Share Posted July 28, 2022 3 hours ago, FortyEighter said: This build started life in the Bomber/Strike/Ground Attack GB build thread here (brief as it is). I had some issues with the intakes, so built up another fuselage but then the cockpit section wasn't a great fit to the main fuselage so it went on the shelf of shame! Anyway the troublesome joint has now been smoothed and shouldn't be very noticeable after priming; so this is where the model has got to: In the absence of a 25% rule I'm assuming this will be an acceptable entry and it will certainly comply with rule 9 Mike Welcome with your Eagle, usually there is an unwritten rule some hosts allow for a build to continue even over 25%. That is if its a continuation from a previous build. In all honesty I forgot to add the 25% rule into the list. 2 Link to comment Share on other sites More sharing options...
FortyEighter Posted August 3, 2022 Author Share Posted August 3, 2022 Having been given the OK to continue this build by @Corsairfoxfouruncle (thanks Dennis) it's time to get a bit more done: This Limited Edition kit comes with some nice resin exhausts, though gluing on 15 actuator links can test one's patience! One down, one to go. Mike 4 Link to comment Share on other sites More sharing options...
FortyEighter Posted August 13, 2022 Author Share Posted August 13, 2022 Just to show that I haven't been idle - Canopy has now had seam removed; even with a 12000 micromesh pad the finish wasn't perfect but a coat of Deluxe Materials Looks Like Glass has worked wonders: Whilst giving the canopy a few days before masking it, I've been assembling a few weapons. I know "Lady Liberty" can't carry them all but I have a Revell Eagle painted and waiting for decals and loadout and another Academy Eagle that will probably appear in this GB before too long. Mike 3 Link to comment Share on other sites More sharing options...
arfa1983 Posted August 13, 2022 Share Posted August 13, 2022 That's a shed load of ordinance! Link to comment Share on other sites More sharing options...
FortyEighter Posted October 6, 2022 Author Share Posted October 6, 2022 Almost ready for decals - just a final coat of gloss needed One issue on both aircraft is that the canopy won't sit in the closed position which requires some tape inside the cockpit sides to avoid paint bleed (I'm going to have them open) - the brace across the centre of the canopy frame fouls the shroud for the RIO instrument panel. Looking closely at my earlier "Nowhere 2 Hide" this has the same problem but I don't remember it. I've also noticed that the decal sheet doesn't have enough of the "honeycomb" NO STEP signs but too many of the NO PUSH ones - design / layout error? Mike 4 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted October 6, 2022 Share Posted October 6, 2022 Paint is looking good. Link to comment Share on other sites More sharing options...
FortyEighter Posted October 11, 2022 Author Share Posted October 11, 2022 The weekend has seen the fuselage sides and upper surface decals in place: No more modelling until next weekend but hopefully the underside will get finished then, leaving two weeks for weapons and weathering. Mike 4 Link to comment Share on other sites More sharing options...
Wings unlevel Posted October 12, 2022 Share Posted October 12, 2022 Looking great, how are the Two Bobs decals going down? Link to comment Share on other sites More sharing options...
FortyEighter Posted October 12, 2022 Author Share Posted October 12, 2022 12 hours ago, Wings unlevel said: Looking great, how are the Two Bobs decals going down? Thanks, the decals are great to use. 1 Link to comment Share on other sites More sharing options...
FortyEighter Posted October 31, 2022 Author Share Posted October 31, 2022 Well, I wouldn't have met yesterday's original deadline: In rushing to try to get this over the line (and not noticing the two week extension) I was a bit heavy handed with the matt varnish which has left a rough finish (it's not really noticeable in the photo). Just the exhausts and a few antennae to put in place. The masking had been on the canopy a long time and the tape / masks have left some residue, so out with the T-Cut this week. Mike 2 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted October 31, 2022 Share Posted October 31, 2022 2 hours ago, FortyEighter said: Well, I wouldn't have met yesterday's original deadline: In rushing to try to get this over the line (and not noticing the two week extension) I was a bit heavy handed with the matt varnish which has left a rough finish (it's not really noticeable in the photo). Just the exhausts and a few antennae to put in place. The masking had been on the canopy a long time and the tape / masks have left some residue, so out with the T-Cut this week. Mike Im sorry that hsppened as this looks great. 1 Link to comment Share on other sites More sharing options...
