Casey Posted July 25, 2022 Share Posted July 25, 2022 (edited) I've been asked by one of fellow modellers to do some work on this color. I have FS34092 samples from various times, but I've based my work on excellent Monogram US Navy and Marine corps Aircraft Colors 1940-1949 publication, where they provided a sample of Medium Green 612 color. I've did all the color matching to that parcitular paint chip. Those are practice-verified samples, so here are the results: TAMIYA MIX based on VOLUME Golden Fluid Acrylics based on MASS (I've added some Matt medium to that sample to bring it closer in perception to the matt level of the target. Tamiya XF paints are by definition having matt finish, but if you are a modeller that uses glossy varnish before decals, you may prefer to use paints without any finish additives) FYI - if one of Medium Green above looks like it has blueish undertone to you, then it is the effect of different daylight time I had when making those photos. The source (bottom) are the same colors samples just photgraphed in two different condition. That's why relying on color photographs is not the best idea for judging color differences... Anyway, here are the recipes: TAMIYA (volume based) OUSAC075 - Medium Green 612 - Flat Suggested using total of 4 parts (DE00: 0.84) Expected: #4C594C, Simulated: #4C584C XF-5 - Flat Green: 1 XF-2 - Flat White: 1 XF-11 - J.N. Green: 2 GOLDEN FLUID ACRYLICS (mass based) OUSAC075 - Medium Green 612 - Flat Suggested using total of 49 parts (DE00: 0.21) Expected: #4C594C, Simulated: #4B594C Primary Cyan: 5 Raw Sienna: 37 Ultramarine Blue: 7 And here is spectrophotometer analysis of end results: TAMIYA: GOLDEN: They both seem to be equally good match in practice for me. Hope that helps! Edited July 25, 2022 by Casey Updated title to be more descriptive 5 5 Link to comment Share on other sites More sharing options...
Jackson Duvalier Posted July 25, 2022 Share Posted July 25, 2022 Useful information relevant to my interests. Thank you for sharing your work, Casey. 1 Link to comment Share on other sites More sharing options...
Prop Duster Posted August 21, 2022 Share Posted August 21, 2022 Hummm,I wasn't interested- then I read it all. Wow! Fine work Casey. Thanks for this. [aside to self: wonder what "Sky" really looks like? -I crack myself up-sometimes] 1 Link to comment Share on other sites More sharing options...
Graham Boak Posted August 21, 2022 Share Posted August 21, 2022 Surely Medium Green is something different to Dull Dark Green, - a colour, I thought, restricted to interiors? Link to comment Share on other sites More sharing options...
Seawinder Posted August 22, 2022 Share Posted August 22, 2022 8 hours ago, Graham Boak said: Surely Medium Green is something different to Dull Dark Green, - a colour, I thought, restricted to interiors? Yes, pretty sure that's true. The two colors are similar, but DDG is darker. Link to comment Share on other sites More sharing options...
Casey Posted August 22, 2022 Author Share Posted August 22, 2022 (edited) 10 hours ago, Graham Boak said: Surely Medium Green is something different to Dull Dark Green, - a colour, I thought, restricted to interiors? I based a lot of my assumptions on data from here: https://www.ipmsstockholm.org/magazine/2004/01/stuff_eng_interior_colours_us.htm I have samples of Bronze Green #9 from same book and a multiple real FS 34092 samples + calculations of those if it is of any help. Edited August 22, 2022 by Casey 1 Link to comment Share on other sites More sharing options...
