F-15J special scheme (1/72 Hasegawa)
  • 1 month later...
Well, I am not sure whether I am going to get this one built by the end of next month...but that'll never happen if I don't start.
So I did a little work on it last night. In addition to the meagre progress you see in the photo I also assembled and painted a pilot from the Hasegawa ground crew set. My other (stalled) F-15J has a pilot in it so I wanted them to match.
IMG_20220914_221604785.jpg?w=1352&ssl=1
Started with a new kit, although I'd built the cockpit tub by the time I photographed it.
IMG_20220914_221307968_HDR.jpg?w=1352&ss
Detail is pretty good when you consider how old this kit is.
What a decal sheet!
IMG_20220914_221513232.jpg?w=1352&ssl=1
It's going to be interesting to see how that looks on the Tamiya spray can paint job I have in mind. A bit of an experiment for me, this kit is.
7 hours ago, Wings unlevel said:
I was sorely tempted by this kit/those markings, glad to see it here. How do you say ‘Greased Lightning’ in Japanese? :giggle:
油を塗った雷
Abura o nutta kaminari
Well at least according to Google translate ?
Edited by Corsairfoxfouruncle
  • Haha 2
Not much greased lightning yet I'm afraid...
But I have moved things along a bit.
for this one you have to cut out the instrument panel coaming and replace it with a newer part appropriate to this era of F-15J.
IMG_20220920_223234659_HDR.jpg?w=1352&ss
You can see the older part in two pieces there after I cut it out of the two fuselage halves.
The newer bit is way better - (a) because it's a single part with one less join line to manage and (b) because it has a bit of detail on it.
Here it is next to the same area on the Strike Eagle I'm doing at the same time.
IMG_20220922_115432356_HDR.jpg?w=1352&ss
I now have an airframe:
Started here with the intakes and the pre-painted intake ramps:
IMG_20220928_151202145.jpg?w=1352&ssl=1
Once i got those intake ramps inside the air intakes I moved along to here:
IMG_20220928_152723194.jpg?w=1352&ssl=1
And then to the worst part of the Hasegawa F-15 - getting a decent fit of the nose part to the main part of the fuselage.
IMG_20220928_155948962_HDR.jpg?w=1352&ss
Looks like you’ve made a decent job of it, and a great looking shape has emerged before you.
